NRF5340 BIS gateway audio and central mode BLE
We currently have a project based off of the NRF5340_audio example.  This project was started off the 2.1.2 SDK.  Would like to use this build in Gateway BIS mode, but also enable Central BLE mode and have it connect to our buds for command/control.  I have managed to enable BLE Central in our source code, but when the Central gets connected the BIS audio never works, and if the BIS audio is connected, I always get a 0x3E from the BLE connection attempt.
I have read where maybe some improvements have been made in the most recent SDK, so I am considering upgrading to the 2.5.2, but what to confirm is it possible to use Central role BLE and gateway BIS in the same build in either SDK 2.1.2 or 2.5.2, and if so how.
I see this code in the latest 2.5.2 which tells me maybe not ?
    if (type == BT_MGMT_SCAN_TYPE_CONN && IS_ENABLED(CONFIG_BT_CENTRAL)) {
        ret = bt_mgmt_scan_for_conn_start(scan_param, srch_name);
    } else if (type == BT_MGMT_SCAN_TYPE_BROADCAST &&
           IS_ENABLED(CONFIG_BT_BAP_BROADCAST_SINK)) {
        ret = bt_mgmt_scan_for_broadcast_start(scan_param, srch_name);
  • Karl,
    Here is my latest.  I have tried to scan an connect to multiple peripheral device and get the same issue as above (0x3E).  This seems to be a timeout on our QUALCOMM buds.
    This is what I have added to our prj.conf
    CONFIG_BT_PER_ADV=y
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_MAX_CONN=2
    #CONFIG_BT_SCAN_WITH_IDENTITY=y
    And this is what I have changed in the streamctrl_broadcast_source.c
    int streamctrl_start(void)
    	int ret;
    	static bool started;
    	if (started) {
    		LOG_WRN("Streamctrl already started");
    		return -EALREADY;
    	size_t ext_adv_size = 0;
    	size_t per_adv_size = 0;
    	const struct bt_data *ext_adv = NULL;
    	const struct bt_data *per_adv = NULL;
    	ret = audio_system_init();
    	ERR_CHK_MSG(ret, "Failed to initialize the audio system");
    	ret = zbus_subscribers_create();
    	ERR_CHK_MSG(ret, "Failed to create zbus subscriber threads");
    	ret = zbus_link_producers_observers();
    	ERR_CHK_MSG(ret, "Failed to link zbus producers and observers");
    	ret = broadcast_source_enable();
    	ERR_CHK_MSG(ret, "Failed to enable broadcaster");
    	broadcast_source_adv_get(&ext_adv, &ext_adv_size, &per_adv, &per_adv_size);
    	ret = bt_mgmt_adv_start(ext_adv, ext_adv_size, per_adv, per_adv_size, false);
    	ERR_CHK_MSG(ret, "Failed to start advertiser");
    #if 1
    	// now start the scanner as well
    	if (IS_ENABLED(CONFIG_BT_CENTRAL)) {
    		ret = bt_mgmt_scan_start(0, 0, BT_MGMT_SCAN_TYPE_CONN, NULL);
    		if (ret) {
    			LOG_ERR("Failed to restart scanning: %d", ret);
    	started = true;
    	return 0;
    In the above code, if I comment out the bt_mgmt_adv_start() call then the central connection is made and stays connected.
    Is there just a configuration that we are missing ?
    Chris
  • After playing with the connection parameters, I am able to get central to usually connect, sometimes it still fails the first time.
    #define CONNECTION_PARAMETERS        \
    	BT_LE_CONN_PARAM(CONFIG_BLE_ACL_CONN_INTERVAL, CONFIG_BLE_ACL_CONN_INTERVAL,               \
    			 CONFIG_BLE_ACL_SLAVE_LATENCY, CONFIG_BLE_ACL_SUP_TIMEOUT)
    #define NEW_CONNECTION_PARAMETERS        \
    	BT_LE_CONN_PARAM(100, 100,               \
    			 2, 250)
    However, now I get these errors and audio breaks up which was not occurring prior to this ?
    GW [00:00:47.267,120] <wrn> broadcast_source: HCI ISO TX overrun on ch 0 - Single print
    GW [00:00:47.267,150] <wrn> streamctrl_brcast_src: Problem with sending LE audio data, ret: -12
    0x3e is failed to establish connection, which usually means that the peripheral did not reply to the CONN_IND packet sent by the central device. Does the earbuds you are testing against have any particular set of connection parameters that they must use?
    Does it then still fail with the 0x3e error, failed to establish connection?
    If not, could you possibly capture a sniffer trace of the communication when this happens?
    It would be very helpful to see what is being exchanged before it fails.
    errno 12 is ENOMEM, which means that there is not sufficient memory resources for the operation, which in this case seems to be returned from the bt_le_audio_tx_send call, which returns this if the number of streams exceeds the configured amount.
    Could you share your full kconfig configuration for your project? You can find it under build/zephyr/ named .conf.
    It would also still be great to see the full application log's output from when this happens, if possible.
    Karl
  • Prj.conf
    # Copyright (c) 2022 Nordic Semiconductor ASA
    # nRF5340 Audio
    CONFIG_NRF5340_AUDIO=y
    # General
    CONFIG_DEBUG=y
    CONFIG_DEBUG_INFO=y
    CONFIG_ASSERT=n
    CONFIG_STACK_USAGE=y
    CONFIG_THREAD_RUNTIME_STATS=y
    CONFIG_STACK_SENTINEL=y
    CONFIG_INIT_STACKS=y
    # Uart driver
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_TAG_MAX_LEN=2
    CONFIG_LOG_TAG_DEFAULT="--"
    CONFIG_LOG_BACKEND_UART=y
    # Console related defines
    CONFIG_CONSOLE=y
    CONFIG_RTT_CONSOLE=n
    CONFIG_UART_CONSOLE=y
    # Shell related defines
    CONFIG_SHELL=y
    CONFIG_KERNEL_SHELL=y
    CONFIG_USE_SEGGER_RTT=n
    ## Disable logs on RTT
    CONFIG_SHELL_RTT_INIT_LOG_LEVEL_NONE=y
    CONFIG_SHELL_BACKEND_RTT=y
    CONFIG_SHELL_BACKEND_SERIAL=n
    CONFIG_SHELL_VT100_COLORS=y
    CONFIG_SHELL_STACK_SIZE=1024
    CONFIG_SHELL_CMD_BUFF_SIZE=128
    ## Reduce shell memory usage
    CONFIG_SHELL_WILDCARD=n
    CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT=n
    CONFIG_SHELL_STATS=n
    CONFIG_SHELL_CMDS=n
    CONFIG_SHELL_HISTORY=y
    # Turn off default shell commands
    CONFIG_I2C_SHELL=n
    CONFIG_CLOCK_CONTROL_NRF_SHELL=n
    CONFIG_FLASH_SHELL=n
    CONFIG_DEVICE_SHELL=n
    CONFIG_NRFX_UARTE2=y
    CONFIG_NRFX_PRS_BOX_2=y
    # I2C
    CONFIG_I2C=y
    CONFIG_NRFX_TWIM1=y
    # Suppress LOG_ERR messages from sd_check_card_type. Because SPI_SDHC has no card presence method,
    # assume card is in slot. Thus error message is always shown if card is not inserted
    CONFIG_SD_LOG_LEVEL_OFF=y
    # Suppress LOG_INF messages from hci_core
    CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN=y
    CONFIG_AUDIO_DEV=2
    CONFIG_AUDIO_SOURCE_I2S=y
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_COMMON_LIBC_MALLOC=n
    CONFIG_DEBUG_THREAD_INFO=y
    #CONFIG_NRFX_SPIM4=y
    #CONFIG_SPI_SDHC=y
    CONFIG_SPI=y
    CONFIG_SPI_ASYNC=y
    CONFIG_NRFX_SPIM1=y
    CONFIG_I2C_TARGET=y
    CONFIG_PWM=y
    #CONFIG_SDMMC_SUBSYS=y
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    CONFIG_BT_AUDIO_USE_BROADCAST_ID_RANDOM=n
    #CONFIG_BT_AUDIO_BROADCAST_ID_FIXED=0x004A7526
    # for now disable BT controller watchdog
    CONFIG_WDT_CTLR=n
    #Enable MCUBOOT bootloader build in the application
    #CONFIG_BOOTLOADER_MCUBOOT=y
    #Include MCUMGR and the dependencies in the build
    #CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
    #CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
    #CONFIG_AUDIO_DFU=1
    #CONFIG_MAIN_LOG_LEVEL_ERR=y
    #CONFIG_AUDIO_HEADSET_CHANNEL_COMPILE_TIME=y
    CONFIG_BT_PER_ADV=y
    CONFIG_BT_CENTRAL=y
    CONFIG_TRANSPORT_BIS=y
    Log file
    -- [00:00:00.254,455] <err> i2c_nrfx_twim: Error 0x0BAE0001 occurred for message 0
    GW [00:00:00.254,455] <err> INA230: Failed to write configuration register!
    GW [00:00:00.254,638] <err> i2c_nrfx_twim: Error 0x0BAE0001 occurred for message 0
    GW [00:00:00.254,638] <err> INA230: Failed to write configuration register!
    GW [00:00:00.255,767] <err> i2c_nrfx_twim: Error 0x0BAE0001 occurred for message 0
    GW [00:00:00.255,767] <err> INA230: Failed to write configuration register!
    *** Booting nRF Connect SDK v2.5.2 ***
    GW [00:00:00.256,317] <inf> fw_info:
    	 nRF5340 Audio nRF5340 Audio DK cpuapp
    	 NCS base version: 2.5.2
    	 Cmake run : Thu Feb 29 09:37:19 2024
    GW [00:00:00.256,317] <inf> fw_info: ------- DEBUG BUILD -------
    GW [00:00:00.256,317] <inf> fw_info: Compiled for GATEWAY device
    GW [00:00:00.257,812] <err> max17303: Register 0x1C0 = 00
    GW [00:00:00.258,392] <err> max17303: Register 0x1C1 = 00
    GW [00:00:00.258,972] <err> max17303: Register 0x1C2 = 00
    GW [00:00:00.259,552] <err> max17303: Register 0x1C3 = e000
    GW [00:00:00.260,131] <err> max17303: Device Name Read 407c
    GW [00:00:00.260,711] <err> max17303: Device Name Read 407c
    GW [00:00:00.261,260] <err> max17303: Device Name Read 407c
    GW [00:00:00.347,961] <err> max17303: Register 0x1FD = 303 03
    GW [00:00:00.348,114] <inf> mxc4005: Device Found
    GW [00:00:00.485,565] <inf> esp32: send Command (cmd: 208) (l: 1)
    GW [00:00:00.502,105] <inf> esp32: send Command (cmd: 208) (l: 1)
    GW [00:00:01.348,205] <inf> esp32: send Command (cmd: 129) (l: 4)
    GW [00:00:01.448,242] <inf> iqs7222a: IQS7222A Initialization:
    GW [00:00:01.548,553] <inf> iqs7222a: Product number is: 840 v 0.0
    GW [00:00:01.548,553] <inf> iqs7222a: IQS7222A Release UI Confirmed!
    GW [00:00:01.710,540] <inf> esp32: send Command (cmd: 130) (l: 0)
    GW [00:00:02.210,601] <inf> main: Read ESP Mac 1
    GW [00:00:02.210,601] <inf> esp32: send Command (cmd: 130) (l: 0)
    GW [00:00:02.710,662] <inf> main: Read ESP Mac 2
    GW [00:00:02.710,662] <inf> esp32: send Command (cmd: 130) (l: 0)
    GW [00:00:03.210,693] <inf> main: Read ESP Mac 3
    GW [00:00:03.210,723] <inf> esp32: send Command (cmd: 130) (l: 0)
    GW [00:00:03.471,496] <inf> esp32: send Command (cmd: 129) (l: 4)
    GW [00:00:03.472,656] <inf> esp32: Mac ID [2] cc:db:a7:4a:75:26
    GW [00:00:03.524,169] <inf> esp32: CC Speed  1 false
    GW [00:00:03.524,902] <inf> esp32: Update Mode 1
    GW [00:00:03.710,784] <inf> main: Read ESP Mac 4
    GW [00:00:03.722,412] <inf> bt_mgmt_ctlr_cfg: Controller: LL_ACS_NRF53. Version: 3424
    GW [00:00:03.723,052] <inf> bt_mgmt: Local identity addr: ED:3E:DF:45:16:B7 (random)
    GW [00:00:03.724,578] <inf> broadcast_source: Enabling broadcast_source NRF5340_BROADCASTER
    GW [00:00:03.725,463] <inf> broadcast_source: Broadcast ID 004a7526
    GW [00:00:03.727,081] <inf> bt_mgmt_scan: Start Scan
    GW [00:00:03.727,996] <inf> bt_mgmt_adv: Local addr: 3C:8D:63:69:5B:85 (random)
    GW [00:00:03.729,248] <inf> bt_mgmt_scan: Local addr: ED:3E:DF:45:16:B7 (random). May time out. Updates not printed
    GW [00:00:03.729,278] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:00:03.730,133] <inf> streamctrl_brcast_src: Ext adv ready
    GW [00:00:03.730,590] <inf> bt_mgmt_adv: Advertising successfully started
    GW [00:00:03.858,123] <inf> broadcast_source: Broadcast source 0x2000c098 started
    GW [00:00:03.858,337] <inf> broadcast_source: Broadcast source 0x2000c0bc started
    GW [00:00:03.882,415] <inf> audio_datapath: Drft comp state: CALIB
    GW [00:00:03.915,802] <inf> bt_mgmt_scan: Device found: B8:4C:87:C0:27:3E (public) (RSSI -22)
    GW [00:00:03.916,473] <inf> bt_mgmt_scan: Creating connection to device: B8:4C:87:C0:27:3E (public)
    GW [00:00:03.982,391] <inf> audio_datapath: Drft comp state: INIT
    GW [00:00:03.983,398] <inf> audio_datapath: Drft comp state: CALIB
    GW [00:00:04.083,404] <inf> audio_datapath: Drft comp state: OFFSET
    GW [00:00:04.175,415] <inf> bt_mgmt: check Connected 0
    GW [00:00:04.175,415] <inf> bt_mgmt: check Connected new connection 1
    GW [00:00:04.175,445] <inf> bt_mgmt: Connected: B8:4C:87:C0:27:3E (public)
    GW [00:00:04.175,445] <inf> bt_mgmt_scan: Start Scan
    GW [00:00:04.176,025] <inf> bt_mgmt_scan: Local addr: ED:3E:DF:45:16:B7 (random). May time out. Updates not printed
    GW [00:00:04.176,025] <inf> bt_mgmt_scan: Scanning successfully started
    GW [00:00:04.176,269] <inf> streamctrl_brcast_src: Connected
    GW [00:00:05.483,337] <inf> iqs7222a: Status 00, Events 02 00, touch 00 00. prox 00 00
    GW [00:00:05.483,367] <inf> iqs7222a: Lid Open
    GW [00:00:05.483,367] <inf> esp32: send Command (cmd: 208) (l: 1)
    GW [00:00:06.901,580] <wrn> broadcast_source: HCI ISO TX overrun on ch 0 - Single print
    GW [00:00:06.901,580] <wrn> streamctrl_brcast_src: Problem with sending LE audio data, ret: -12
    GW [00:00:07.031,738] <wrn> broadcast_source: HCI ISO TX overrun on ch 0 - Single print
    GW [00:00:07.031,768] <wrn> streamctrl_brcast_src: Problem with sending LE audio data, ret: -12
    GW [00:00:07.183,197] <inf> audio_datapath: Drft comp state: LOCKED
    GW [00:00:07.281,646] <wrn> broadcast_source: HCI ISO TX overrun on ch 0 - Single print
    GW [00:00:07.281,677] <wrn> streamctrl_brcast_src: Problem with sending LE audio data, ret: -12
    GW [00:00:07.531,707] <wrn> broadcast_source: HCI ISO TX overrun on ch 0 - Single print
    GW [00:00:07.531,707] <wrn> streamctrl_brcast_src: Problem with sending LE audio data, ret: -12
    GW [00:00:07.831,665] <wrn> broadcast_source: HCI ISO TX overrun on ch 0 - Single print
    GW [00:00:07.831,695] <wrn> streamctrl_brcast_src: Problem with sending LE audio data, ret: -12
    GW [00:00:13.782,775] <inf> audio_datapath: Drft comp state: INIT
    GW [00:00:13.783,782] <inf> audio_datapath: Drft comp state: CALIB
    GW [00:00:13.883,758] <inf> audio_datapath: Drft comp state: OFFSET
    ChrisBon said:
    Prj.conf
    It would be better if you could send the .conf file from the build, located in build/zephyr/ since this contains all the kconfig's used in your project.
    ChrisBon said:
    Log file
    Thank you for sharing the log as well. Do I understand it correctly that you are here trying to establish a ACL connection to two peripheral devices, while also broadcasting, and that it now successfully connects to both peripherals (and these connections functions as expected), but once you start to receive data from the peripherals the broadcasted audio turns choppy with the errors displayd in the log?
    Could you elaborate on how your 'esp32 send Command: cmd 208) is implemented? Is this command sent over one of the peripheral ACL links?
    Karl
