NRF5340 BIS gateway audio and central mode BLE
We currently have a project based off of the NRF5340_audio example.  This project was started off the 2.1.2 SDK.  Would like to use this build in Gateway BIS mode, but also enable Central BLE mode and have it connect to our buds for command/control.  I have managed to enable BLE Central in our source code, but when the Central gets connected the BIS audio never works, and if the BIS audio is connected, I always get a 0x3E from the BLE connection attempt.
I have read where maybe some improvements have been made in the most recent SDK, so I am considering upgrading to the 2.5.2, but what to confirm is it possible to use Central role BLE and gateway BIS in the same build in either SDK 2.1.2 or 2.5.2, and if so how.
I see this code in the latest 2.5.2 which tells me maybe not ?
    if (type == BT_MGMT_SCAN_TYPE_CONN && IS_ENABLED(CONFIG_BT_CENTRAL)) {
        ret = bt_mgmt_scan_for_conn_start(scan_param, srch_name);
    } else if (type == BT_MGMT_SCAN_TYPE_BROADCAST &&
           IS_ENABLED(CONFIG_BT_BAP_BROADCAST_SINK)) {
        ret = bt_mgmt_scan_for_broadcast_start(scan_param, srch_name);
  • CONFIG_NRF5340_AUDIO=y
    CONFIG_AUDIO_DEV=2
    CONFIG_TRANSPORT_BIS=y
    # CONFIG_TRANSPORT_CIS is not set
    CONFIG_ZBUS_RUNTIME_OBSERVERS_POOL_SIZE=6
    CONFIG_REBOOT=y
    CONFIG_MAIN_THREAD_PRIORITY=10
    CONFIG_MAIN_STACK_SIZE=1600
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    CONFIG_THREAD_NAME=y
    # CONFIG_NCS_INCLUDE_RPMSG_CHILD_IMAGE is not set
    # CONFIG_RESET_ON_FATAL_ERROR is not set
    CONFIG_HW_CODEC_CIRRUS_LOGIC=y
    CONFIG_BT=y
    CONFIG_BOARD_ENABLE_DCDC_APP=y
    CONFIG_BOARD_ENABLE_DCDC_NET=y
    CONFIG_BOARD_ENABLE_CPUNET=y
    CONFIG_NFCT_PINS_AS_GPIOS=y
    CONFIG_ZBUS=y
    CONFIG_ZBUS_RUNTIME_OBSERVERS=y
    CONFIG_SENSOR=y
    CONFIG_REGULATOR=y
    CONFIG_CONTIN_ARRAY=y
    CONFIG_NRFX_I2S0=y
    CONFIG_PCM_MIX=y
    CONFIG_TONE=y
    CONFIG_PSCM=y
    CONFIG_DATA_FIFO=y
    CONFIG_NRFX_CLOCK=y
    CONFIG_I2C=y
    CONFIG_FPU=y
    CONFIG_FPU_SHARING=y
    CONFIG_DISK_DRIVERS=y
    CONFIG_DISK_DRIVER_SDMMC=y
    CONFIG_SPI=y
    CONFIG_ADC=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=8
    CONFIG_FILE_SYSTEM=y
    CONFIG_FAT_FILESYSTEM_ELM=y
    CONFIG_FS_FATFS_LFN=y
    CONFIG_FS_FATFS_EXFAT=y
    CONFIG_FS_FATFS_MAX_LFN=255
    CONFIG_BT_LL_ACS_NRF53=y
    CONFIG_WATCHDOG=y
    CONFIG_TASK_WDT=y
    CONFIG_NRFX_TIMER1=y
    CONFIG_NRFX_DPPI=y
    CONFIG_CMSIS_DSP=y
    CONFIG_CMSIS_DSP_FASTMATH=y
    CONFIG_LC3_BITRATE=96000
    CONFIG_LC3_ENC_CHAN_MAX=2
    CONFIG_LC3_DEC_CHAN_MAX=1
    CONFIG_AUDIO_TEST_TONE=y
    CONFIG_AUDIO_MUTE=y
    # Audio
    # CONFIG_AUDIO_FRAME_DURATION_7_5_MS is not set
    CONFIG_AUDIO_FRAME_DURATION_10_MS=y
    CONFIG_AUDIO_FRAME_DURATION_US=10000
    CONFIG_AUDIO_MIN_PRES_DLY_US=4000
    CONFIG_AUDIO_MAX_PRES_DLY_US=60000
    # CONFIG_AUDIO_SAMPLE_RATE_16000_HZ is not set
    # CONFIG_AUDIO_SAMPLE_RATE_24000_HZ is not set
    CONFIG_AUDIO_SAMPLE_RATE_48000_HZ=y
    CONFIG_AUDIO_SAMPLE_RATE_HZ=48000
    CONFIG_AUDIO_BIT_DEPTH_16=y
    # CONFIG_AUDIO_BIT_DEPTH_32 is not set
    CONFIG_AUDIO_BIT_DEPTH_BITS=16
    CONFIG_AUDIO_BIT_DEPTH_OCTETS=2
    # CONFIG_AUDIO_SOURCE_USB is not set
    CONFIG_AUDIO_SOURCE_I2S=y
    CONFIG_AUDIO_HEADSET_CHANNEL_RUNTIME=y
    # CONFIG_AUDIO_HEADSET_CHANNEL_COMPILE_TIME is not set
    # SW Codec
    CONFIG_SW_CODEC_LC3=y
    # CONFIG_SW_CODEC_PLC_DISABLED is not set
    # LC3
    CONFIG_LC3_BITRATE_MAX=124000
    CONFIG_LC3_BITRATE_MIN=32000
    CONFIG_SW_CODEC_LC3_T2_SOFTWARE=y
    # CONFIG_LC3_PLC_DISABLED is not set
    # Encoder sample rates
    CONFIG_LC3_ENC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_ENC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Encoder sample rates
    # Decoder sample rates
    CONFIG_LC3_DEC_SAMPLE_RATE_8KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_16KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_24KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_32KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_441KHZ_SUPPORT=y
    CONFIG_LC3_DEC_SAMPLE_RATE_48KHZ_SUPPORT=y
    # end of Decoder sample rates
    # end of LC3
    # end of SW Codec
    # Stream
    CONFIG_BUF_BLE_RX_PACKET_NUM=5
    # CONFIG_WALKIE_TALKIE_DEMO is not set
    # CONFIG_MONO_TO_ALL_RECEIVERS is not set
    # end of Stream
    # Log levels
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_SYSTEM_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_SYSTEM_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_SYSTEM_LOG_LEVEL=3
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_OFF is not set
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_ERR is not set
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_WRN is not set
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_INF is not set
    # CONFIG_SW_CODEC_SELECT_LOG_LEVEL_DBG is not set
    CONFIG_SW_CODEC_SELECT_LOG_LEVEL_DEFAULT=y
    CONFIG_SW_CODEC_SELECT_LOG_LEVEL=3
    # CONFIG_STREAMCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_STREAMCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_STREAMCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_STREAMCTRL_LOG_LEVEL_INF is not set
    # CONFIG_STREAMCTRL_LOG_LEVEL_DBG is not set
    CONFIG_STREAMCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_STREAMCTRL_LOG_LEVEL=3
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_DATAPATH_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_DATAPATH_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_DATAPATH_LOG_LEVEL=3
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_OFF is not set
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_ERR is not set
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_WRN is not set
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_INF is not set
    # CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_DBG is not set
    CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL_DEFAULT=y
    CONFIG_AUDIO_SYNC_TIMER_LOG_LEVEL=3
    # CONFIG_LE_AUDIO_RX_LOG_LEVEL_OFF is not set
    # CONFIG_LE_AUDIO_RX_LOG_LEVEL_ERR is not set
    # CONFIG_LE_AUDIO_RX_LOG_LEVEL_WRN is not set
    # CONFIG_LE_AUDIO_RX_LOG_LEVEL_INF is not set
    # CONFIG_LE_AUDIO_RX_LOG_LEVEL_DBG is not set
    CONFIG_LE_AUDIO_RX_LOG_LEVEL_DEFAULT=y
    CONFIG_LE_AUDIO_RX_LOG_LEVEL=3
    # end of Log levels
    # Thread priorities
    CONFIG_ENCODER_THREAD_PRIO=3
    CONFIG_AUDIO_DATAPATH_THREAD_PRIO=4
    CONFIG_BUTTON_MSG_SUB_THREAD_PRIO=5
    CONFIG_LE_AUDIO_MSG_SUB_THREAD_PRIO=5
    CONFIG_CONTENT_CONTROL_MSG_SUB_THREAD_PRIO=5
    # end of Thread priorities
    # Stack sizes
    CONFIG_ENCODER_STACK_SIZE=7500
    CONFIG_AUDIO_DATAPATH_STACK_SIZE=4096
    CONFIG_BUTTON_MSG_SUB_STACK_SIZE=2048
    CONFIG_LE_AUDIO_MSG_SUB_STACK_SIZE=1024
    CONFIG_CONTENT_CONTROL_MSG_SUB_STACK_SIZE=1024
    # end of Stack sizes
    # Zbus
    CONFIG_BUTTON_MSG_SUB_QUEUE_SIZE=4
    CONFIG_LE_AUDIO_MSG_SUB_QUEUE_SIZE=4
    CONFIG_CONTENT_CONTROL_MSG_SUB_QUEUE_SIZE=4
    # end of Zbus
    # end of Audio
    CONFIG_BT_AUDIO=y
    CONFIG_BT_DEVICE_NAME="NRF5340_AUDIO"
    CONFIG_BT_ECC=y
    CONFIG_BT_EXT_ADV=y
    CONFIG_BT_ATT_PREPARE_COUNT=1
    # Bluetooth
    # BT management
    # CONFIG_BT_ATT_ENFORCE_FLOW is not set
    # CONFIG_BT_HCI_VS_EXT is not set
    # CONFIG_BT_HCI_ACL_FLOW_CONTROL is not set
    # Controller config
    # nRF21540
    # CONFIG_NRF_21540_MAIN_TX_POWER_0DBM is not set
    CONFIG_NRF_21540_MAIN_TX_POWER_10DBM=y
    # CONFIG_NRF_21540_MAIN_TX_POWER_20DBM is not set
    CONFIG_NRF_21540_MAIN_DBM=10
    # CONFIG_NRF_21540_PRI_ADV_TX_POWER_0DBM is not set
    CONFIG_NRF_21540_PRI_ADV_TX_POWER_10DBM=y
    # CONFIG_NRF_21540_PRI_ADV_TX_POWER_20DBM is not set
    CONFIG_NRF_21540_PRI_ADV_DBM=10
    # end of nRF21540
    # Log level
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_CTLR_CFG_LOG_LEVEL=3
    # end of Log level
    # end of Controller config
    # Power control
    # CONFIG_BLE_LE_POWER_CONTROL_ENABLED is not set
    # CONFIG_WDT_CTLR is not set
    CONFIG_BLE_CONN_TX_POWER_0DBM=y
    # CONFIG_BLE_CONN_TX_POWER_NEG_1DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_2DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_3DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_4DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_5DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_6DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_7DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_8DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_12DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_16DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_20DBM is not set
    # CONFIG_BLE_CONN_TX_POWER_NEG_40DBM is not set
    CONFIG_BLE_CONN_TX_POWER_DBM=0
    CONFIG_BLE_ADV_TX_POWER_0DBM=y
    # CONFIG_BLE_ADV_TX_POWER_NEG_1DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_2DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_3DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_4DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_5DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_6DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_7DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_8DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_12DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_16DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_20DBM is not set
    # CONFIG_BLE_ADV_TX_POWER_NEG_40DBM is not set
    CONFIG_BLE_ADV_TX_POWER_DBM=0
    # end of Power control
    # DFU
    # Log level
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_DFU_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_DFU_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_DFU_LOG_LEVEL=3
    # end of Log level
    # end of DFU
    # Advertising
    CONFIG_BLE_ACL_PER_ADV_INT_MIN=0x0078
    CONFIG_BLE_ACL_PER_ADV_INT_MAX=0x00A0
    CONFIG_BLE_ACL_EXT_ADV_INT_MIN=0x30
    CONFIG_BLE_ACL_EXT_ADV_INT_MAX=0x40
    CONFIG_EXT_ADV_BUF_MAX=10
    CONFIG_EXT_ADV_UUID_BUF_MAX=10
    # Log level
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_ADV_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_ADV_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_ADV_LOG_LEVEL=3
    # end of Log level
    # end of Advertising
    CONFIG_BT_BACKGROUND_SCAN_INTERVAL=32
    CONFIG_BT_BACKGROUND_SCAN_WINDOW=32
    CONFIG_BT_SCAN_WITH_IDENTITY=y
    # Scanning
    CONFIG_SCAN_MODE_PASSIVE=y
    # CONFIG_SCAN_MODE_ACTIVE is not set
    # Connection
    CONFIG_BLE_ACL_CONN_INTERVAL=32
    CONFIG_BLE_ACL_SLAVE_LATENCY=0
    CONFIG_BLE_ACL_SUP_TIMEOUT=100
    # end of Connection
    # Log level
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_SCAN_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_SCAN_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_SCAN_LOG_LEVEL=3
    # end of Log level
    # end of Scanning
    # Log level
    # CONFIG_BT_MGMT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MGMT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MGMT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MGMT_LOG_LEVEL_INF is not set
    # CONFIG_BT_MGMT_LOG_LEVEL_DBG is not set
    CONFIG_BT_MGMT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_MGMT_LOG_LEVEL=3
    # end of Log level
    # end of BT management
    # Bluetooth audio
    CONFIG_BT_BUF_ACL_RX_SIZE=27
    CONFIG_BT_OBSERVER=y
    # CONFIG_BT_PERIPHERAL is not set
    CONFIG_BT_DEVICE_APPEARANCE=2181
    # CONFIG_BT_ISO_SYNC_RECEIVER is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR is not set
    CONFIG_BT_ISO_MAX_CHAN=2
    CONFIG_BT_ISO_MAX_BIG=1
    # CONFIG_BT_SMP is not set
    # CONFIG_BT_PAC_SNK is not set
    CONFIG_BT_CAP_INITIATOR=y
    CONFIG_BT_AUDIO_BROADCAST_NAME="NRF5340_BROADCASTER"
    CONFIG_BT_ISO_BROADCASTER=y
    CONFIG_BT_BAP_BROADCAST_SOURCE=y
    CONFIG_BT_ISO_TX_BUF_COUNT=2
    CONFIG_BT_BAP_BROADCAST_SRC_STREAM_COUNT=2
    CONFIG_BT_AUDIO_TX=y
    # Broadcast
    CONFIG_BT_AUDIO_BROADCAST_CONFIGURABLE=y
    # CONFIG_BT_BAP_BROADCAST_16_2_1 is not set
    # CONFIG_BT_BAP_BROADCAST_24_2_1 is not set
    # CONFIG_BT_BAP_BROADCAST_16_2_2 is not set
    # CONFIG_BT_BAP_BROADCAST_24_2_2 is not set
    CONFIG_BT_AUDIO_BROADCAST_NAME_ALT="NRF5340_BROADCASTER_ALT"
    # CONFIG_BT_AUDIO_USE_BROADCAST_NAME_ALT is not set
    # CONFIG_BT_AUDIO_BROADCAST_ENCRYPTED is not set
    CONFIG_BT_AUDIO_BROADCAST_ENCRYPTION_KEY="NRF5340_BIS_DEMO"
    # CONFIG_BT_AUDIO_USE_BROADCAST_ID_RANDOM is not set
    CONFIG_BT_AUDIO_BROADCAST_ID_FIXED=0x123456
    # CONFIG_BT_AUDIO_BROADCAST_IMMEDIATE_FLAG is not set
    CONFIG_AURACAST=y
    CONFIG_BT_AUDIO_BITRATE_BROADCAST_SRC=96000
    # Log levels
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_OFF is not set
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_ERR is not set
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_WRN is not set
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_INF is not set
    # CONFIG_BROADCAST_SOURCE_LOG_LEVEL_DBG is not set
    CONFIG_BROADCAST_SOURCE_LOG_LEVEL_DEFAULT=y
    CONFIG_BROADCAST_SOURCE_LOG_LEVEL=3
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_OFF is not set
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_ERR is not set
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_WRN is not set
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_INF is not set
    # CONFIG_BROADCAST_SINK_LOG_LEVEL_DBG is not set
    CONFIG_BROADCAST_SINK_LOG_LEVEL_DEFAULT=y
    CONFIG_BROADCAST_SINK_LOG_LEVEL=3
    # end of Log levels
    # end of Broadcast
    # CONFIG_BT_GATT_CLIENT is not set
    CONFIG_BT_AUTO_PHY_UPDATE=y
    CONFIG_BT_AUTO_DATA_LEN_UPDATE=y
    CONFIG_BT_L2CAP_TX_BUF_COUNT=3
    # CONFIG_SETTINGS is not set
    # CONFIG_FLASH is not set
    # CONFIG_NVS is not set
    # CONFIG_BT_BAP_UNICAST_SERVER is not set
    CONFIG_BT_MAX_CONN=3
    # CONFIG_BT_VCP_VOL_REND is not set
    # CONFIG_BT_MCC is not set
    # CONFIG_BT_CSIP_SET_MEMBER is not set
    CONFIG_BT_AUDIO_CODEC_CFG_MAX_METADATA_SIZE=4
    # CONFIG_BT_BAP_UNICAST_CLIENT is not set
    CONFIG_BT_MAX_PAIRED=0
    # CONFIG_BT_VCP_VOL_CTLR is not set
    # CONFIG_BT_GATT_DYNAMIC_DB is not set
    # CONFIG_UTF8 is not set
    # CONFIG_BT_MPL is not set
    # CONFIG_MCTL is not set
    # CONFIG_BT_AUDIO_PACKING_INTERLEAVED is not set
    # QoS
    CONFIG_BT_AUDIO_PRESENTATION_DELAY_US=10000
    CONFIG_BT_AUDIO_MAX_TRANSPORT_LATENCY_MS=20
    CONFIG_BT_AUDIO_RETRANSMITS=2
    # end of QoS
    # end of Bluetooth audio
    # BT renderer
    # Volume
    CONFIG_BT_AUDIO_VOL_DEFAULT=195
    CONFIG_BT_AUDIO_VOL_STEP_SIZE=16
    # Log level
    # CONFIG_BT_REND_VOL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_REND_VOL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_REND_VOL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_REND_VOL_LOG_LEVEL_INF is not set
    # CONFIG_BT_REND_VOL_LOG_LEVEL_DBG is not set
    CONFIG_BT_REND_VOL_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_REND_VOL_LOG_LEVEL=3
    # end of Log level
    # end of Volume
    # Log level
    # CONFIG_BT_REND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_REND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_REND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_REND_LOG_LEVEL_INF is not set
    # CONFIG_BT_REND_LOG_LEVEL_DBG is not set
    CONFIG_BT_REND_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_REND_LOG_LEVEL=3
    # end of Log level
    # end of BT renderer
    # Content control
    # Media
    # Log level
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_DBG is not set
    CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_CONTENT_CTRL_MEDIA_LOG_LEVEL=3
    # end of Log level
    # end of Media
    # Log level
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_DBG is not set
    CONFIG_BT_CONTENT_CTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_CONTENT_CTRL_LOG_LEVEL=3
    # end of Log level
    # end of Content control
    # Log levels
    # CONFIG_BLE_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_LOG_LEVEL_INF is not set
    # CONFIG_BLE_LOG_LEVEL_DBG is not set
    CONFIG_BLE_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_LOG_LEVEL=3
    # end of Log levels
    # end of Bluetooth
    # Drivers
    # Thread priorities
    CONFIG_CS47L63_THREAD_PRIO=5
    # Stack sizes
    CONFIG_CS47L63_STACK_SIZE=700
    # Log levels
    # CONFIG_CS47L63_LOG_LEVEL_OFF is not set
    # CONFIG_CS47L63_LOG_LEVEL_ERR is not set
    # CONFIG_CS47L63_LOG_LEVEL_WRN is not set
    # CONFIG_CS47L63_LOG_LEVEL_INF is not set
    # CONFIG_CS47L63_LOG_LEVEL_DBG is not set
    CONFIG_CS47L63_LOG_LEVEL_DEFAULT=y
    CONFIG_CS47L63_LOG_LEVEL=3
    # end of Log levels
    # end of Drivers
    # CONFIG_USB_DEVICE_STACK is not set
    CONFIG_NET_BUF=y
    # Modules
    CONFIG_BUTTON_DEBOUNCE_MS=50
    # Power measurement
    CONFIG_POWER_MEAS_INTERVAL_MS=8500
    # CONFIG_POWER_MEAS_START_ON_BOOT is not set
    # end of Power measurement
    # I2S
    CONFIG_I2S_LRCK_FREQ_HZ=48000
    CONFIG_I2S_CH_NUM=2
    # end of I2S
    # Log levels
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_AUDIO_USB_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_AUDIO_USB_LOG_LEVEL=3
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_BUTTON_HANDLER_LOG_LEVEL=3
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_HW_CODEC_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_HW_CODEC_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_HW_CODEC_LOG_LEVEL=3
    # CONFIG_MODULE_LED_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_LED_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_LED_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_LED_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_LED_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_LED_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_LED_LOG_LEVEL=3
    # CONFIG_MODULE_POWER_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_POWER_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_POWER_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_POWER_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_POWER_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_POWER_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_POWER_LOG_LEVEL=3
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_OFF is not set
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_ERR is not set
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_WRN is not set
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_INF is not set
    # CONFIG_MODULE_SD_CARD_LOG_LEVEL_DBG is not set
    CONFIG_MODULE_SD_CARD_LOG_LEVEL_DEFAULT=y
    CONFIG_MODULE_SD_CARD_LOG_LEVEL=3
    # end of Log levels
    # Thread priorities
    CONFIG_POWER_MEAS_THREAD_PRIO=6
    CONFIG_BUTTON_PUBLISH_THREAD_PRIO=5
    CONFIG_VOLUME_MSG_SUB_THREAD_PRIO=5
    # Stack sizes
    CONFIG_POWER_MEAS_STACK_SIZE=1152
    CONFIG_BUTTON_PUBLISH_STACK_SIZE=300
    CONFIG_VOLUME_MSG_SUB_STACK_SIZE=768
    # Zbus
    CONFIG_VOLUME_MSG_SUB_QUEUE_SIZE=4
    # end of Zbus
    # end of Modules
    CONFIG_NRFX_NVMC=y
    # Utils
    # FIFO
    CONFIG_FIFO_FRAME_SPLIT_NUM=10
    CONFIG_FIFO_TX_FRAME_COUNT=3
    CONFIG_FIFO_RX_FRAME_COUNT=1
    # end of FIFO
    # Log levels
    # CONFIG_BOARD_VERSION_LOG_LEVEL_OFF is not set
    # CONFIG_BOARD_VERSION_LOG_LEVEL_ERR is not set
    # CONFIG_BOARD_VERSION_LOG_LEVEL_WRN is not set
    # CONFIG_BOARD_VERSION_LOG_LEVEL_INF is not set
    # CONFIG_BOARD_VERSION_LOG_LEVEL_DBG is not set
    CONFIG_BOARD_VERSION_LOG_LEVEL_DEFAULT=y
    CONFIG_BOARD_VERSION_LOG_LEVEL=3
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_OFF is not set
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_ERR is not set
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_WRN is not set
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_INF is not set
    # CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_DBG is not set
    CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL_DEFAULT=y
    CONFIG_CHAN_ASSIGNMENT_LOG_LEVEL=3
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_OFF is not set
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_ERR is not set
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_WRN is not set
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_INF is not set
    # CONFIG_ERROR_HANDLER_LOG_LEVEL_DBG is not set
    CONFIG_ERROR_HANDLER_LOG_LEVEL_DEFAULT=y
    CONFIG_ERROR_HANDLER_LOG_LEVEL=3
    # CONFIG_FW_INFO_LOG_LEVEL_OFF is not set
    # CONFIG_FW_INFO_LOG_LEVEL_ERR is not set
    # CONFIG_FW_INFO_LOG_LEVEL_WRN is not set
    # CONFIG_FW_INFO_LOG_LEVEL_INF is not set
    # CONFIG_FW_INFO_LOG_LEVEL_DBG is not set
    CONFIG_FW_INFO_LOG_LEVEL_DEFAULT=y
    CONFIG_FW_INFO_LOG_LEVEL=3
    # end of Log levels
    # end of Utils
    CONFIG_AUDIO_DFU=0
    # CONFIG_B0N_MINIMAL is not set
    # CONFIG_BOOTLOADER_MCUBOOT is not set
    # CONFIG_ZCBOR is not set
    # CONFIG_STREAM_FLASH is not set
    CONFIG_BT_L2CAP_TX_MTU=23
    CONFIG_BT_BUF_ACL_TX_SIZE=27
    CONFIG_THREAD_MONITOR=y
    # CONFIG_STATS is not set
    # CONFIG_BT_DEVICE_NAME_DYNAMIC is not set
    # CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
    # Logging
    # CONFIG_MAIN_LOG_LEVEL_OFF is not set
    # CONFIG_MAIN_LOG_LEVEL_ERR is not set
    # CONFIG_MAIN_LOG_LEVEL_WRN is not set
    # CONFIG_MAIN_LOG_LEVEL_INF is not set
    # CONFIG_MAIN_LOG_LEVEL_DBG is not set
    CONFIG_MAIN_LOG_LEVEL_DEFAULT=y
    CONFIG_MAIN_LOG_LEVEL=3
    # end of Logging
    # CONFIG_INPUT is not set
    # CONFIG_WIFI is not set
    # CONFIG_LV_COLOR_16_SWAP is not set
    CONFIG_LV_DPI_DEF=130
    CONFIG_ADC_INIT_PRIORITY=50
    # CONFIG_MIPI_DSI is not set
    # CONFIG_MODEM is not set
    # CONFIG_UART_INTERRUPT_DRIVEN is not set
    CONFIG_BOARD="nrf5340_audio_dk_nrf5340_cpuapp"
    CONFIG_FLASH_LOAD_SIZE=0
    CONFIG_SRAM_SIZE=448
    CONFIG_FLASH_LOAD_OFFSET=0
    CONFIG_MBOX_NRFX_IPC=y
    CONFIG_HEAP_MEM_POOL_SIZE=4096
    # CONFIG_BT_CTLR is not set
    CONFIG_NUM_IRQS=69
    CONFIG_SOC_SERIES="nrf53"
    CONFIG_SYS_CLOCK_HW_CYCLES_PER_SEC=32768
    CONFIG_SOC="nRF5340_CPUAPP_QKAA"
    CONFIG_CLOCK_CONTROL_INIT_PRIORITY=30
    CONFIG_FLASH_SIZE=1024
    CONFIG_FLASH_BASE_ADDRESS=0x0
    CONFIG_ICACHE_LINE_SIZE=32
    CONFIG_DCACHE_LINE_SIZE=32
    CONFIG_ROM_START_OFFSET=0
    CONFIG_PINCTRL=y
    CONFIG_CLOCK_CONTROL=y
    # CONFIG_RESET is not set
    CONFIG_GPIO=y
    CONFIG_SOC_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_CUSTOM_BUSY_WAIT=y
    # CONFIG_PM_DEVICE is not set
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_SHMEM_RESET=y
    CONFIG_LOG_DOMAIN_NAME=""
    CONFIG_NRF_RTC_TIMER=y
    CONFIG_SYS_CLOCK_TICKS_PER_SEC=32768
    CONFIG_BUILD_OUTPUT_HEX=y
    CONFIG_SERIAL_INIT_PRIORITY=55
    # CONFIG_MBEDTLS is not set
    # CONFIG_MEMC is not set
    # CONFIG_CODE_DATA_RELOCATION is not set
    # CONFIG_CPU_HAS_CUSTOM_FIXED_SOC_MPU_REGIONS is not set
    CONFIG_TINYCRYPT=y
    CONFIG_SERIAL=y
    # CONFIG_SRAM_VECTOR_TABLE is not set
    # CONFIG_USE_DT_CODE_PARTITION is not set
    CONFIG_PLATFORM_SPECIFIC_INIT=y
    CONFIG_IDLE_STACK_SIZE=320
    CONFIG_TASK_WDT_HW_FALLBACK_DELAY=20
    # CONFIG_BT_USER_PHY_UPDATE is not set
    CONFIG_BUILD_OUTPUT_BIN=y
    CONFIG_MP_MAX_NUM_CPUS=1
    CONFIG_HAS_DTS=y
    # Devicetree Info
    CONFIG_DT_HAS_ARM_ARMV8M_ITM_ENABLED=y
    CONFIG_DT_HAS_ARM_ARMV8M_MPU_ENABLED=y
    CONFIG_DT_HAS_ARM_CORTEX_M33F_ENABLED=y
    CONFIG_DT_HAS_ARM_CRYPTOCELL_312_ENABLED=y
    CONFIG_DT_HAS_ARM_V8M_NVIC_ENABLED=y
    CONFIG_DT_HAS_FIXED_PARTITIONS_ENABLED=y
    CONFIG_DT_HAS_GPIO_KEYS_ENABLED=y
    CONFIG_DT_HAS_GPIO_LEDS_ENABLED=y
    CONFIG_DT_HAS_MMIO_SRAM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_MBOX_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CC312_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CLOCK_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_CTRLAPPERI_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DCNF_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_DPPIC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_EGU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_FICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIO_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPIOTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_GPREGRET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_I2S_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_IPC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_KMU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_MUTEX_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_NFCT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_OSCILLATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PINCTRL_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_POWER_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_PWM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_REGULATORS_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_RESET_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SAADC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_SPU_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_TWIM_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UARTE_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_UICR_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBD_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_USBREG_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_VMC_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF_WDT_ENABLED=y
    CONFIG_DT_HAS_NORDIC_NRF53_FLASH_CONTROLLER_ENABLED=y
    CONFIG_DT_HAS_PWM_LEDS_ENABLED=y
    CONFIG_DT_HAS_SOC_NV_FLASH_ENABLED=y
    CONFIG_DT_HAS_TI_INA230_ENABLED=y
    CONFIG_DT_HAS_USB_AUDIO_HS_ENABLED=y
    CONFIG_DT_HAS_VOLTAGE_DIVIDER_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_BT_HCI_ENTROPY_ENABLED=y
    CONFIG_DT_HAS_ZEPHYR_IPC_OPENAMP_STATIC_VRINGS_ENABLED=y
    # end of Devicetree Info
    # Modules
    # Available modules.
    # nrf (C:/ncs/v2.5.2/nrf)
    CONFIG_NEWLIB_LIBC_NANO=y
    CONFIG_NUM_METAIRQ_PRIORITIES=0
    CONFIG_LOG_BUFFER_SIZE=1024
    CONFIG_INIT_STACKS=y
    # Nordic nRF Connect
    CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
    CONFIG_WARN_EXPERIMENTAL=y
    CONFIG_PRIVILEGED_STACK_SIZE=1024
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    # CONFIG_ENTROPY_GENERATOR is not set
    CONFIG_INIT_ARCH_HW_AT_BOOT=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_GETOPT=y
    # CONFIG_NCS_SAMPLES_DEFAULTS is not set
    # CONFIG_NRF700X_RADIO_TEST_COMBO is not set
    # CONFIG_NCS_SAMPLE_PROVISIONING_NET_CORE_CHILD_IMAGE is not set
    # Image build variants
    # CONFIG_NCS_MCUBOOT_IN_BUILD is not set
    # end of Image build variants
    # Bootloader
    # CONFIG_BUILD_S1_VARIANT is not set
    # CONFIG_SECURE_BOOT is not set
    CONFIG_PM_PARTITION_SIZE_PROVISION=0x280
    # CONFIG_B0_MIN_PARTITION_SIZE is not set
    CONFIG_PM_PARTITION_SIZE_B0_IMAGE=0x8000
    # CONFIG_SECURE_BOOT_CRYPTO is not set
    # Secure Boot firmware validation
    CONFIG_SB_VALIDATION_INFO_MAGIC=0x86518483
    CONFIG_SB_VALIDATION_POINTER_MAGIC=0x6919b47e
    CONFIG_SB_VALIDATION_INFO_CRYPTO_ID=1
    CONFIG_SB_VALIDATION_INFO_VERSION=2
    CONFIG_SB_VALIDATION_METADATA_OFFSET=0
    CONFIG_SB_VALIDATE_FW_SIGNATURE=y
    # end of Secure Boot firmware validation
    # end of Bootloader
    # Bluetooth Low Energy
    CONFIG_BT_LL_SOFTDEVICE_HEADERS_INCLUDE=y
    CONFIG_BT_HCI_TX_STACK_SIZE=1024
    CONFIG_BT_RX_STACK_SIZE=2048
    # BLE Libraries
    # CONFIG_BT_GATT_POOL is not set
    # CONFIG_BT_GATT_DM is not set
    # CONFIG_BT_ADV_PROV is not set
    # CONFIG_BT_SCAN is not set
    # CONFIG_BT_CONN_CTX is not set
    CONFIG_BT_EXT_ADV_MAX_ADV_SET=1
    # Bluetooth Services
    # CONFIG_BT_AMS_CLIENT is not set
    # CONFIG_BT_ANCS_CLIENT is not set
    # CONFIG_BT_BAS_CLIENT is not set
    # CONFIG_BT_BMS is not set
    # CONFIG_BT_CTS_CLIENT is not set
    # CONFIG_BT_DFU_SMP is not set
    # CONFIG_BT_GATTP is not set
    # CONFIG_BT_HIDS is not set
    # CONFIG_BT_HOGP is not set
    # CONFIG_BT_LBS is not set
    # CONFIG_BT_NSMS is not set
    # CONFIG_BT_NUS is not set
    # CONFIG_BT_NUS_CLIENT is not set
    # CONFIG_BT_RSCS is not set
    # CONFIG_BT_THROUGHPUT is not set
    # CONFIG_BT_LATENCY is not set
    # CONFIG_BT_LATENCY_CLIENT is not set
    # CONFIG_BT_HRS_CLIENT is not set
    # CONFIG_BT_DDFS is not set
    # CONFIG_BT_MDS is not set
    # CONFIG_BT_CGMS is not set
    # CONFIG_BT_FAST_PAIR is not set
    # CONFIG_BT_DIS is not set
    # end of Bluetooth Services
    # BLE over nRF RPC
    CONFIG_BT_DRIVERS=y
    # CONFIG_BT_RPC_STACK is not set
    CONFIG_BT_CENTRAL=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_CONN=y
    # CONFIG_BT_REMOTE_VERSION is not set
    CONFIG_BT_PHY_UPDATE=y
    CONFIG_BT_DATA_LEN_UPDATE=y
    # CONFIG_BT_EXT_ADV_LEGACY_SUPPORT is not set
    CONFIG_BT_PER_ADV=y
    # CONFIG_BT_PER_ADV_RSP is not set
    # CONFIG_BT_PER_ADV_SYNC is not set
    # CONFIG_BT_PER_ADV_SYNC_RSP is not set
    # CONFIG_BT_BAS is not set
    # CONFIG_BT_HRS is not set
    # CONFIG_BT_TPS is not set
    # CONFIG_BT_IAS is not set
    # CONFIG_BT_IAS_CLIENT is not set
    # CONFIG_BT_OTS is not set
    # CONFIG_BT_OTS_CLIENT is not set
    CONFIG_BT_BUF_ACL_TX_COUNT=3
    CONFIG_BT_BUF_ACL_RX_COUNT=6
    CONFIG_BT_BUF_EVT_RX_SIZE=255
    CONFIG_BT_BUF_EVT_RX_COUNT=10
    CONFIG_BT_BUF_EVT_DISCARDABLE_SIZE=58
    CONFIG_BT_BUF_EVT_DISCARDABLE_COUNT=3
    CONFIG_BT_BUF_CMD_TX_SIZE=255
    CONFIG_BT_HAS_HCI_VS=y
    CONFIG_BT_HCI_VS=y
    # CONFIG_BT_HCI_MESH_EXT is not set
    # CONFIG_BT_WAIT_NOP is not set
    CONFIG_BT_ASSERT=y
    CONFIG_BT_ASSERT_VERBOSE=y
    # CONFIG_BT_ASSERT_PANIC is not set
    CONFIG_BT_DEBUG_NONE=y
    # CONFIG_BT_DEBUG_LOG is not set
    # CONFIG_BT_DEBUG_MONITOR_UART is not set
    CONFIG_BT_LONG_WQ=y
    CONFIG_BT_LONG_WQ_STACK_SIZE=1300
    CONFIG_BT_LONG_WQ_PRIO=10
    CONFIG_BT_LONG_WQ_INIT_PRIO=50
    CONFIG_BT_HCI_HOST=y
    # CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT is not set
    CONFIG_BT_HCI_TX_PRIO=7
    CONFIG_BT_HCI_RESERVE=1
    # CONFIG_BT_RECV_BLOCKING is not set
    # CONFIG_BT_RECV_WORKQ_SYS is not set
    CONFIG_BT_RECV_WORKQ_BT=y
    CONFIG_BT_RX_PRIO=8
    CONFIG_BT_DRIVER_RX_HIGH_PRIO=6
    # CONFIG_BT_MESH is not set
    CONFIG_BT_AUDIO_NOTIFY_RETRY_DELAY=20
    CONFIG_BT_AUDIO_CODEC_CFG_MAX_DATA_SIZE=19
    CONFIG_BT_AUDIO_CODEC_CAP_MAX_DATA_SIZE=19
    CONFIG_BT_AUDIO_CODEC_CAP_MAX_METADATA_SIZE=4
    CONFIG_BT_BAP_BROADCAST_SRC_SUBGROUP_COUNT=1
    CONFIG_BT_BAP_BROADCAST_SRC_COUNT=1
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT is not set
    CONFIG_BT_BAP_STREAM=y
    # CONFIG_BT_PAC_SRC is not set
    # CONFIG_BT_ASCS is not set
    CONFIG_BT_VOCS_MAX_INSTANCE_COUNT=0
    CONFIG_BT_VOCS_CLIENT_MAX_INSTANCE_COUNT=0
    CONFIG_BT_AICS_MAX_INSTANCE_COUNT=0
    CONFIG_BT_AICS_CLIENT_MAX_INSTANCE_COUNT=0
    # CONFIG_BT_MICP_MIC_DEV is not set
    # CONFIG_BT_MICP_MIC_CTLR is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR is not set
    # CONFIG_BT_TBS is not set
    # CONFIG_BT_TBS_CLIENT_GTBS is not set
    # CONFIG_BT_TBS_CLIENT_TBS is not set
    # CONFIG_BT_HAS_CLIENT is not set
    CONFIG_BT_CAP=y
    # CONFIG_BT_TMAP is not set
    CONFIG_BT_TMAP_LOG_LEVEL=3
    CONFIG_BT_TMAP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_TMAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TMAP_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_INF is not set
    # CONFIG_BT_AUDIO_LOG_LEVEL_DBG is not set
    CONFIG_BT_AUDIO_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_AUDIO_LOG_LEVEL=3
    CONFIG_BT_HOST_CRYPTO=y
    CONFIG_BT_HOST_CRYPTO_PRNG=y
    # CONFIG_BT_FILTER_ACCEPT_LIST is not set
    CONFIG_BT_LIM_ADV_TIMEOUT=30
    CONFIG_BT_CONN_TX_USER_DATA_SIZE=8
    CONFIG_BT_CONN_TX_MAX=3
    # CONFIG_BT_CONN_PARAM_ANY is not set
    # CONFIG_BT_USER_DATA_LEN_UPDATE is not set
    # CONFIG_BT_REMOTE_INFO is not set
    CONFIG_BT_L2CAP_TX_FRAG_COUNT=2
    CONFIG_BT_L2CAP_RESCHED_MS=1000
    # CONFIG_BT_L2CAP_SEG_RECV is not set
    CONFIG_BT_GATT_SERVICE_CHANGED=y
    CONFIG_BT_GATT_CACHING=y
    # CONFIG_BT_GATT_NOTIFY_MULTIPLE is not set
    # CONFIG_BT_GATT_ENFORCE_CHANGE_UNAWARE is not set
    CONFIG_BT_GATT_ENFORCE_SUBSCRIPTION=y
    CONFIG_BT_GATT_READ_MULTIPLE=y
    CONFIG_BT_GATT_READ_MULT_VAR_LEN=y
    CONFIG_BT_CREATE_CONN_TIMEOUT=3
    CONFIG_BT_CONN_PARAM_UPDATE_TIMEOUT=5000
    CONFIG_BT_CONN_PARAM_RETRY_COUNT=3
    CONFIG_BT_CONN_PARAM_RETRY_TIMEOUT=5000
    CONFIG_BT_EXT_SCAN_BUF_SIZE=229
    # CONFIG_BT_DEVICE_APPEARANCE_DYNAMIC is not set
    CONFIG_BT_ID_MAX=1
    # CONFIG_BT_DF is not set
    # CONFIG_BT_TINYCRYPT_ECC is not set
    # CONFIG_BT_HOST_CCM is not set
    # CONFIG_BT_LOG_SNIFFER_INFO is not set
    # CONFIG_BT_TESTING is not set
    # CONFIG_BT_BREDR is not set
    # CONFIG_BT_HCI_VS_EVT_USER is not set
    # end of BLE over nRF RPC
    # end of Bluetooth Low Energy
    # DFU
    # CONFIG_DFU_MULTI_IMAGE is not set
    # CONFIG_DFU_TARGET is not set
    # end of DFU
    # CONFIG_ESB is not set
    # CONFIG_ESB_LOG_LEVEL_OFF is not set
    # CONFIG_ESB_LOG_LEVEL_ERR is not set
    # CONFIG_ESB_LOG_LEVEL_WRN is not set
    # CONFIG_ESB_LOG_LEVEL_INF is not set
    # CONFIG_ESB_LOG_LEVEL_DBG is not set
    CONFIG_ESB_LOG_LEVEL_DEFAULT=y
    CONFIG_ESB_LOG_LEVEL=3
    # Peripheral CPU DFU (PCD)
    # CONFIG_PCD is not set
    # CONFIG_PCD_APP is not set
    CONFIG_PCD_VERSION_PAGE_BUF_SIZE=2046
    # CONFIG_PCD_NET is not set
    # end of Peripheral CPU DFU (PCD)
    # Networking
    # Application protocols
    # nRF Cloud
    # Client ID (nRF Cloud Device ID)
    CONFIG_NRF_CLOUD_CLIENT_ID_SRC_COMPILE_TIME=y
    CONFIG_NRF_CLOUD_CLIENT_ID="my-client-id"
    # end of Client ID (nRF Cloud Device ID)
    # CONFIG_NRF_CLOUD_MQTT is not set
    # CONFIG_NRF_CLOUD_FOTA is not set
    # CONFIG_NRF_CLOUD_FOTA_FULL_MODEM_UPDATE is not set
    # CONFIG_NRF_CLOUD_REST is not set
    # CONFIG_NRF_CLOUD_ALERT is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_ALERT_LOG_LEVEL=3
    CONFIG_NRF_CLOUD_LOG_OUTPUT_LEVEL=1
    CONFIG_NRF_CLOUD_LOG_BUF_SIZE=256
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LOG_LEVEL=3
    # CONFIG_NRF_CLOUD_COAP is not set
    # CONFIG_NRF_CLOUD_GATEWAY is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_OFF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_ERR is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_WRN is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_INF is not set
    # CONFIG_NRF_CLOUD_LOG_LEVEL_DBG is not set
    CONFIG_NRF_CLOUD_LOG_LEVEL_DEFAULT=y
    CONFIG_NRF_CLOUD_LOG_LEVEL=3
    # end of nRF Cloud
    # CONFIG_REST_CLIENT is not set
    # CONFIG_DOWNLOAD_CLIENT is not set
    # CONFIG_AWS_IOT is not set
    # CONFIG_AWS_JOBS is not set
    # CONFIG_AZURE_IOT_HUB is not set
    # Self-Registration (Zi ZHu Ce)
    # end of Self-Registration (Zi ZHu Ce)
    # CONFIG_ICAL_PARSER is not set
    # CONFIG_FTP_CLIENT is not set
    # CONFIG_LWM2M_CLIENT_UTILS is not set
    # CONFIG_WIFI_CREDENTIALS is not set
    # CONFIG_WIFI_CREDENTIALS_STATIC is not set
    # CONFIG_MQTT_HELPER is not set
    # CONFIG_NRF_MCUMGR_SMP_CLIENT is not set
    # end of Application protocols
    # end of Networking
    # NFC
    # CONFIG_NFC_NDEF is not set
    # CONFIG_NFC_NDEF_PARSER is not set
    # CONFIG_NFC_NDEF_PAYLOAD_TYPE_COMMON is not set
    # CONFIG_NFC_T2T_PARSER is not set
    # CONFIG_NFC_T4T_NDEF_FILE is not set
    # CONFIG_NFC_T4T_ISODEP is not set
    # CONFIG_NFC_T4T_APDU is not set
    # CONFIG_NFC_T4T_CC_FILE is not set
    # CONFIG_NFC_T4T_HL_PROCEDURE is not set
    # CONFIG_NFC_PLATFORM is not set
    # CONFIG_NFC_TNEP_TAG is not set
    # CONFIG_NFC_TNEP_POLLER is not set
    # CONFIG_NFC_TNEP_CH is not set
    # end of NFC
    # CONFIG_APP_EVENT_MANAGER is not set
    # CONFIG_NRF_PROFILER is not set
    # CONFIG_FW_INFO is not set
    # CONFIG_FW_INFO_API is not set
    # Debug
    # CONFIG_CPU_LOAD is not set
    # CONFIG_PPI_TRACE is not set
    # end of Debug
    # CONFIG_SHELL_BT_NUS is not set
    # CONFIG_SHELL_IPC is not set
    # CONFIG_MPSL_FEM_ONLY is not set
    # CONFIG_MPSL_FEM_DEVICE_CONFIG_254 is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_FEM_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_FEM_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_FEM_LOG_LEVEL=3
    CONFIG_MPSL_THREAD_COOP_PRIO=8
    CONFIG_MPSL_WORK_STACK_SIZE=1024
    CONFIG_MPSL_TIMESLOT_SESSION_COUNT=0
    # CONFIG_MPSL_ASSERT_HANDLER is not set
    # CONFIG_MPSL_LOG_LEVEL_OFF is not set
    # CONFIG_MPSL_LOG_LEVEL_ERR is not set
    # CONFIG_MPSL_LOG_LEVEL_WRN is not set
    # CONFIG_MPSL_LOG_LEVEL_INF is not set
    # CONFIG_MPSL_LOG_LEVEL_DBG is not set
    CONFIG_MPSL_LOG_LEVEL_DEFAULT=y
    CONFIG_MPSL_LOG_LEVEL=3
    # Partition Manager
    # CONFIG_PARTITION_MANAGER_ENABLED is not set
    CONFIG_SRAM_BASE_ADDRESS=0x20000000
    # Zephyr subsystem configurations
    # end of Zephyr subsystem configurations
    # NCS subsystem configurations
    # CONFIG_PM_SINGLE_IMAGE is not set
    CONFIG_PM_EXTERNAL_FLASH_BASE=0
    CONFIG_PM_EXTERNAL_FLASH_PATH=""
    CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=0
    CONFIG_PM_SRAM_BASE=0x20000000
    CONFIG_PM_SRAM_SIZE=0x80000
    # end of Partition Manager
    # nRF RPC (Remote Procedure Call) library
    # end of nRF RPC (Remote Procedure Call) library
    # CONFIG_ZIGBEE is not set
    # Full Modem Firmware Update Management(FMFU)
    # CONFIG_MGMT_FMFU_LOG_LEVEL_OFF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_ERR is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_WRN is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_INF is not set
    # CONFIG_MGMT_FMFU_LOG_LEVEL_DBG is not set
    CONFIG_MGMT_FMFU_LOG_LEVEL_DEFAULT=y
    CONFIG_MGMT_FMFU_LOG_LEVEL=3
    # end of Full Modem Firmware Update Management(FMFU)
    # CONFIG_CAF is not set
    # Nordic IEEE 802.15.4
    # end of Nordic IEEE 802.15.4
    # CONFIG_DM_MODULE is not set
    # nRF Security
    # CONFIG_NORDIC_SECURITY_BACKEND is not set
    # CONFIG_NRF_SECURITY is not set
    # CONFIG_PSA_WANT_GENERATE_RANDOM is not set
    # CONFIG_PSA_WANT_ALG_CTR_DRBG is not set
    # CONFIG_PSA_WANT_ALG_HMAC_DRBG is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DERIVE is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RAW_DATA is not set
    # CONFIG_PSA_WANT_KEY_TYPE_HMAC is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PASSWORD_HASH is not set
    # CONFIG_PSA_WANT_KEY_TYPE_PEPPER is not set
    # CONFIG_PSA_WANT_KEY_TYPE_AES is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_ECC_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_RSA_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_KEY_PAIR is not set
    # CONFIG_PSA_WANT_KEY_TYPE_DH_PUBLIC_KEY is not set
    # CONFIG_PSA_WANT_ALG_CCM is not set
    # CONFIG_PSA_WANT_ALG_CCM_STAR_NO_TAG is not set
    # CONFIG_PSA_WANT_ALG_GCM is not set
    # CONFIG_PSA_WANT_ALG_CHACHA20_POLY1305 is not set
    # CONFIG_PSA_WANT_ALG_CMAC is not set
    # CONFIG_PSA_WANT_ALG_HMAC is not set
    # CONFIG_PSA_WANT_ALG_SHA_1 is not set
    # CONFIG_PSA_WANT_ALG_SHA_224 is not set
    # CONFIG_PSA_WANT_ALG_SHA_256 is not set
    # CONFIG_PSA_WANT_ALG_SHA_384 is not set
    # CONFIG_PSA_WANT_ALG_SHA_512 is not set
    # CONFIG_PSA_WANT_ALG_RIPEMD160 is not set
    # CONFIG_PSA_WANT_ALG_MD5 is not set
    # CONFIG_PSA_WANT_ALG_ECB_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_NO_PADDING is not set
    # CONFIG_PSA_WANT_ALG_CBC_PKCS7 is not set
    # CONFIG_PSA_WANT_ALG_CFB is not set
    # CONFIG_PSA_WANT_ALG_CTR is not set
    # CONFIG_PSA_WANT_ALG_OFB is not set
    # CONFIG_PSA_WANT_ALG_XTS is not set
    # CONFIG_PSA_WANT_ALG_STREAM_CIPHER is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXTRACT is not set
    # CONFIG_PSA_WANT_ALG_HKDF_EXPAND is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PRF is not set
    # CONFIG_PSA_WANT_ALG_TLS12_PSK_TO_MS is not set
    # CONFIG_PSA_WANT_ALG_TLS12_ECJPAKE_TO_PMS is not set
    # CONFIG_PSA_WANT_ALG_ECDH is not set
    # CONFIG_PSA_WANT_ALG_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_DETERMINISTIC_ECDSA is not set
    # CONFIG_PSA_WANT_ALG_RSA_OAEP is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_CRYPT is not set
    # CONFIG_PSA_WANT_ALG_RSA_PKCS1V15_SIGN is not set
    # CONFIG_PSA_WANT_ALG_RSA_PSS is not set
    # CONFIG_PSA_WANT_ALG_JPAKE is not set
    # CONFIG_PSA_WANT_ALG_SPAKE2P is not set
    # CONFIG_PSA_WANT_ALG_SRP_6 is not set
    # CONFIG_PSA_WANT_ALG_PURE_EDDSA is not set
    # CONFIG_PSA_WANT_ALG_ED25519PH is not set
    # CONFIG_PSA_WANT_ALG_ED448PH is not set
    # end of nRF Security
    # CONFIG_NET_CORE_MONITOR is not set
    # TF-M SPM component configs
    CONFIG_TFM_CONN_HANDLE_MAX_NUM=8
    # end of TF-M SPM component configs
    # CONFIG_WPA_SUPP is not set
    CONFIG_POSIX_MAX_FDS=4
    # Libraries
    # Binary libraries
    # Log levels
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_OFF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_ERR is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_WRN is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_INF is not set
    # CONFIG_BLE_HCI_VSC_LOG_LEVEL_DBG is not set
    CONFIG_BLE_HCI_VSC_LOG_LEVEL_DEFAULT=y
    CONFIG_BLE_HCI_VSC_LOG_LEVEL=3
    # end of Log levels
    # end of Binary libraries
    # CONFIG_ADP536X is not set
    # CONFIG_AT_MONITOR is not set
    # CONFIG_LTE_LINK_CONTROL is not set
    CONFIG_NRF_SPU_FLASH_REGION_SIZE=0x4000
    CONFIG_FPROTECT_BLOCK_SIZE=0x4000
    # CONFIG_FPROTECT is not set
    # CONFIG_AT_CMD_CUSTOM is not set
    # CONFIG_DK_LIBRARY is not set
    # CONFIG_AT_CMD_PARSER is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_OFF is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_ERR is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_WRN is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_INF is not set
    # CONFIG_MODEM_BATTERY_LOG_LEVEL_DBG is not set
    CONFIG_MODEM_BATTERY_LOG_LEVEL_DEFAULT=y
    CONFIG_MODEM_BATTERY_LOG_LEVEL=3
    # CONFIG_MODEM_INFO is not set
    # CONFIG_SMS is not set
    # CONFIG_SUPL_CLIENT_LIB is not set
    # CONFIG_DATE_TIME is not set
    # CONFIG_HW_ID_LIBRARY is not set
    # CONFIG_RAM_POWER_DOWN_LIBRARY is not set
    # CONFIG_WAVE_GEN_LIB is not set
    CONFIG_HW_UNIQUE_KEY_PARTITION_SIZE=0
    # CONFIG_MODEM_JWT is not set
    # CONFIG_MODEM_SLM is not set
    # CONFIG_LOCATION is not set
    # CONFIG_QOS is not set
    # CONFIG_SFLOAT is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_OFF is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_ERR is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_WRN is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_INF is not set
    # CONFIG_CONTIN_ARRAY_LOG_LEVEL_DBG is not set
    CONFIG_CONTIN_ARRAY_LOG_LEVEL_DEFAULT=y
    CONFIG_CONTIN_ARRAY_LOG_LEVEL=3
    # CONFIG_PCM_MIX_LOG_LEVEL_OFF is not set
    # CONFIG_PCM_MIX_LOG_LEVEL_ERR is not set
    # CONFIG_PCM_MIX_LOG_LEVEL_WRN is not set
    # CONFIG_PCM_MIX_LOG_LEVEL_INF is not set
    # CONFIG_PCM_MIX_LOG_LEVEL_DBG is not set
    CONFIG_PCM_MIX_LOG_LEVEL_DEFAULT=y
    CONFIG_PCM_MIX_LOG_LEVEL=3
    # CONFIG_TONE_LOG_LEVEL_OFF is not set
    # CONFIG_TONE_LOG_LEVEL_ERR is not set
    # CONFIG_TONE_LOG_LEVEL_WRN is not set
    # CONFIG_TONE_LOG_LEVEL_INF is not set
    # CONFIG_TONE_LOG_LEVEL_DBG is not set
    CONFIG_TONE_LOG_LEVEL_DEFAULT=y
    CONFIG_TONE_LOG_LEVEL=3
    # CONFIG_PSCM_LOG_LEVEL_OFF is not set
    # CONFIG_PSCM_LOG_LEVEL_ERR is not set
    # CONFIG_PSCM_LOG_LEVEL_WRN is not set
    # CONFIG_PSCM_LOG_LEVEL_INF is not set
    # CONFIG_PSCM_LOG_LEVEL_DBG is not set
    CONFIG_PSCM_LOG_LEVEL_DEFAULT=y
    CONFIG_PSCM_LOG_LEVEL=3
    # CONFIG_DATA_FIFO_LOG_LEVEL_OFF is not set
    # CONFIG_DATA_FIFO_LOG_LEVEL_ERR is not set
    # CONFIG_DATA_FIFO_LOG_LEVEL_WRN is not set
    # CONFIG_DATA_FIFO_LOG_LEVEL_INF is not set
    # CONFIG_DATA_FIFO_LOG_LEVEL_DBG is not set
    CONFIG_DATA_FIFO_LOG_LEVEL_DEFAULT=y
    CONFIG_DATA_FIFO_LOG_LEVEL=3
    # CONFIG_FEM_AL_LIB is not set
    # end of Libraries
    # Device Drivers
    # CONFIG_BT_DRIVER_QUIRK_NO_AUTO_DLE is not set
    CONFIG_HW_CC3XX=y
    # CONFIG_ETH_RTT is not set
    # CONFIG_BH1749 is not set
    # CONFIG_SENSOR_SIM is not set
    # CONFIG_SENSOR_STUB is not set
    # CONFIG_PMW3360 is not set
    # CONFIG_PAW3212 is not set
    # CONFIG_NRF_SW_LPUART is not set
    CONFIG_NRFX_GPIOTE_NUM_OF_EVT_HANDLERS=1
    # CONFIG_IPC_UART is not set
    # end of Device Drivers
    # External libraries
    # end of External libraries
    # Test
    CONFIG_ZTEST_MULTICORE_DEFAULT_SETTINGS=y
    # CONFIG_UNITY is not set
    # Mocks
    # CONFIG_MOCK_NRF_MODEM_AT is not set
    # end of Mocks
    # end of Test
    # end of Nordic nRF Connect
    CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (C:/ncs/v2.5.2/nrf)
    # wfa-qt-control-app (C:/ncs/v2.5.2/modules/lib/wfa-qt-control-app)
    # CONFIG_WFA_QT_LOG_LEVEL_OFF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_ERR is not set
    # CONFIG_WFA_QT_LOG_LEVEL_WRN is not set
    # CONFIG_WFA_QT_LOG_LEVEL_INF is not set
    # CONFIG_WFA_QT_LOG_LEVEL_DBG is not set
    CONFIG_WFA_QT_LOG_LEVEL_DEFAULT=y
    CONFIG_WFA_QT_LOG_LEVEL=3
    # CONFIG_WFA_QT_CONTROL_APP is not set
    CONFIG_WFA_QT_THREAD_STACK_SIZE=4096
    CONFIG_ZEPHYR_WFA_QT_CONTROL_APP_MODULE=y
    # end of wfa-qt-control-app (C:/ncs/v2.5.2/modules/lib/wfa-qt-control-app)
    # mcuboot (C:/ncs/v2.5.2/bootloader/mcuboot)
    # MCUboot
    CONFIG_BOOT_SIGNATURE_KEY_FILE=""
    CONFIG_DT_FLASH_WRITE_BLOCK_SIZE=4
    CONFIG_MCUBOOT_USB_SUPPORT=y
    # CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM is not set
    # end of MCUboot
    CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    # end of mcuboot (C:/ncs/v2.5.2/bootloader/mcuboot)
    # mbedtls (C:/ncs/v2.5.2/modules/crypto/mbedtls)
    CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    CONFIG_MBEDTLS_BUILTIN=y
    # CONFIG_MBEDTLS_LIBRARY is not set
    # PSA RNG support
    # end of PSA RNG support
    # PSA key type support
    # end of PSA key type support
    # PSA AEAD support
    # end of PSA AEAD support
    # PSA MAC support
    # end of PSA MAC support
    # PSA Hash support
    # end of PSA Hash support
    # PSA Cipher support
    # end of PSA Cipher support
    # PSA Key derivation support
    # end of PSA Key derivation support
    # PSA Asymmetric support
    # end of PSA Asymmetric support
    # end of mbedtls (C:/ncs/v2.5.2/modules/crypto/mbedtls)
    # trusted-firmware-m (C:/ncs/v2.5.2/modules/tee/tf-m/trusted-firmware-m)
    CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    # end of trusted-firmware-m (C:/ncs/v2.5.2/modules/tee/tf-m/trusted-firmware-m)
    # cjson (C:/ncs/v2.5.2/modules/lib/cjson)
    # CONFIG_CJSON_LIB is not set
    CONFIG_ZEPHYR_CJSON_MODULE=y
    # end of cjson (C:/ncs/v2.5.2/modules/lib/cjson)
    # azure-sdk-for-c (C:/ncs/v2.5.2/modules/lib/azure-sdk-for-c)
    # CONFIG_AZURE_SDK is not set
    CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    # end of azure-sdk-for-c (C:/ncs/v2.5.2/modules/lib/azure-sdk-for-c)
    # cirrus-logic (C:/ncs/v2.5.2/modules/hal/cirrus-logic)
    CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    # end of cirrus-logic (C:/ncs/v2.5.2/modules/hal/cirrus-logic)
    # openthread (C:/ncs/v2.5.2/modules/lib/openthread)
    # CONFIG_OPENTHREAD is not set
    CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    # end of openthread (C:/ncs/v2.5.2/modules/lib/openthread)
    # memfault-firmware-sdk (C:/ncs/v2.5.2/modules/lib/memfault-firmware-sdk)
    # CONFIG_MEMFAULT is not set
    CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    # end of memfault-firmware-sdk (C:/ncs/v2.5.2/modules/lib/memfault-firmware-sdk)
    # canopennode (C:/ncs/v2.5.2/modules/lib/canopennode)
    CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    # end of canopennode (C:/ncs/v2.5.2/modules/lib/canopennode)
    # chre (C:/ncs/v2.5.2/modules/lib/chre)
    CONFIG_ZEPHYR_CHRE_MODULE=y
    # CONFIG_CHRE is not set
    # end of chre (C:/ncs/v2.5.2/modules/lib/chre)
    # cmsis (C:/ncs/v2.5.2/modules/hal/cmsis)
    CONFIG_HAS_CMSIS_CORE=y
    CONFIG_HAS_CMSIS_CORE_M=y
    # Components
    CONFIG_CMSIS_DSP_BASICMATH=y
    # CONFIG_CMSIS_DSP_COMPLEXMATH is not set
    # CONFIG_CMSIS_DSP_CONTROLLER is not set
    # CONFIG_CMSIS_DSP_FILTERING is not set
    # CONFIG_CMSIS_DSP_INTERPOLATION is not set
    # CONFIG_CMSIS_DSP_MATRIX is not set
    # CONFIG_CMSIS_DSP_QUATERNIONMATH is not set
    # CONFIG_CMSIS_DSP_STATISTICS is not set
    # CONFIG_CMSIS_DSP_SUPPORT is not set
    # CONFIG_CMSIS_DSP_TRANSFORM is not set
    # CONFIG_CMSIS_DSP_SVM is not set
    # CONFIG_CMSIS_DSP_BAYES is not set
    # CONFIG_CMSIS_DSP_DISTANCE is not set
    CONFIG_CMSIS_DSP_TABLES=y
    CONFIG_CMSIS_DSP_TABLES_ALL_FAST=y
    # CONFIG_CMSIS_DSP_TABLES_ALL_FFT is not set
    # Interpolation Tables
    CONFIG_CMSIS_DSP_TABLES_ARM_COS_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_COS_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_COS_Q15=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_Q15=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_COS_F32=y
    CONFIG_CMSIS_DSP_TABLES_ARM_SIN_COS_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_LMS_NORM_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_LMS_NORM_Q15=y
    CONFIG_CMSIS_DSP_TABLES_ARM_CMPLX_MAG_Q31=y
    CONFIG_CMSIS_DSP_TABLES_ARM_CMPLX_MAG_Q15=y
    # Transformation Tables
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F64_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F32_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_F16_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q31_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_16 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_Q15_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_RADIX4_Q31 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_RADIX4_Q15 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_RADIX2_Q31 is not set
    # CONFIG_CMSIS_DSP_TABLES_CFFT_RADIX2_Q15 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F64_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F32_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_FAST_F16_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F32_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F32_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F32_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F32_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F16_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F16_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F16_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_F16_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q31_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_32 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_64 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_256 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_1024 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_4096 is not set
    # CONFIG_CMSIS_DSP_TABLES_RFFT_Q15_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_F32_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_F32_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_F32_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_F32_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q31_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q31_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q31_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q31_8192 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q15_128 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q15_512 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q15_2048 is not set
    # CONFIG_CMSIS_DSP_TABLES_DCT4_Q15_8192 is not set
    # Instruction Set
    # Features
    # CONFIG_CMSIS_DSP_LOOPUNROLL is not set
    # CONFIG_CMSIS_DSP_ROUNDING is not set
    # CONFIG_CMSIS_DSP_MATRIXCHECK is not set
    # CONFIG_CMSIS_DSP_AUTOVECTORIZE is not set
    CONFIG_CMSIS_DSP_FLOAT16=y
    # CONFIG_CMSIS_NN is not set
    CONFIG_ZEPHYR_CMSIS_MODULE=y
    # end of cmsis (C:/ncs/v2.5.2/modules/hal/cmsis)
    # fatfs (C:/ncs/v2.5.2/modules/fs/fatfs)
    CONFIG_ZEPHYR_FATFS_MODULE=y
    # end of fatfs (C:/ncs/v2.5.2/modules/fs/fatfs)
    # hal_nordic (C:/ncs/v2.5.2/modules/hal/nordic)
    CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    CONFIG_HAS_NORDIC_DRIVERS=y
    # Nordic drivers
    # CONFIG_NRF_802154_SOURCE_HAL_NORDIC is not set
    # CONFIG_NRF_802154_SER_HOST is not set
    # end of Nordic drivers
    CONFIG_HAS_NRFX=y
    # nrfx drivers
    # nrfx drivers logging
    # CONFIG_NRFX_CLOCK_LOG is not set
    # CONFIG_NRFX_DPPI_LOG is not set
    # CONFIG_NRFX_GPIOTE_LOG is not set
    # CONFIG_NRFX_I2S_LOG is not set
    # CONFIG_NRFX_IPC_LOG is not set
    # CONFIG_NRFX_NVMC_LOG is not set
    # CONFIG_NRFX_PRS_LOG is not set
    # CONFIG_NRFX_PWM_LOG is not set
    # CONFIG_NRFX_SPIM_LOG is not set
    # CONFIG_NRFX_TIMER_LOG is not set
    # CONFIG_NRFX_TWIM_LOG is not set
    # CONFIG_NRFX_UARTE_LOG is not set
    # CONFIG_NRFX_WDT_LOG is not set
    # end of nrfx drivers logging
    CONFIG_NRFX_CLOCK_LFXO_TWO_STAGE_ENABLED=y
    # CONFIG_NRFX_COMP is not set
    # CONFIG_NRFX_EGU0 is not set
    # CONFIG_NRFX_EGU1 is not set
    # CONFIG_NRFX_EGU2 is not set
    # CONFIG_NRFX_EGU3 is not set
    # CONFIG_NRFX_EGU4 is not set
    # CONFIG_NRFX_EGU5 is not set
    CONFIG_NRFX_GPIOTE=y
    CONFIG_NRFX_I2S=y
    CONFIG_NRFX_IPC=y
    # CONFIG_NRFX_NFCT is not set
    # CONFIG_NRFX_PDM is not set
    # CONFIG_NRFX_POWER is not set
    CONFIG_NRFX_PWM=y
    CONFIG_NRFX_PWM0=y
    CONFIG_NRFX_PWM1=y
    CONFIG_NRFX_PWM2=y
    # CONFIG_NRFX_PWM3 is not set
    # CONFIG_NRFX_QDEC0 is not set
    # CONFIG_NRFX_QDEC1 is not set
    # CONFIG_NRFX_QSPI is not set
    # CONFIG_NRFX_RTC0 is not set
    # CONFIG_NRFX_RTC1 is not set
    # CONFIG_NRFX_SAADC is not set
    CONFIG_NRFX_SPIM=y
    # CONFIG_NRFX_SPIM0 is not set
    CONFIG_NRFX_SPIM1=y
    # CONFIG_NRFX_SPIM2 is not set
    # CONFIG_NRFX_SPIM3 is not set
    CONFIG_NRFX_SPIM4=y
    # CONFIG_NRFX_SYSTICK is not set
    CONFIG_NRFX_TIMER=y
    # CONFIG_NRFX_TIMER0 is not set
    # CONFIG_NRFX_TIMER2 is not set
    CONFIG_NRFX_TWIM=y
    # CONFIG_NRFX_TWIM0 is not set
    CONFIG_NRFX_TWIM1=y
    # CONFIG_NRFX_TWIM2 is not set
    # CONFIG_NRFX_TWIM3 is not set
    CONFIG_NRFX_UARTE=y
    # CONFIG_NRFX_UARTE0 is not set
    # CONFIG_NRFX_UARTE1 is not set
    CONFIG_NRFX_UARTE2=y
    # CONFIG_NRFX_UARTE3 is not set
    # CONFIG_NRFX_USBD is not set
    # CONFIG_NRFX_USBREG is not set
    CONFIG_NRFX_WDT=y
    CONFIG_NRFX_WDT0=y
    # CONFIG_NRFX_WDT1 is not set
    # Peripheral Resource Sharing module
    CONFIG_NRFX_PRS=y
    # CONFIG_NRFX_PRS_BOX_0 is not set
    # CONFIG_NRFX_PRS_BOX_1 is not set
    CONFIG_NRFX_PRS_BOX_2=y
    # CONFIG_NRFX_PRS_BOX_3 is not set
    # CONFIG_NRFX_PRS_BOX_4 is not set
    # end of Peripheral Resource Sharing module
    # end of hal_nordic (C:/ncs/v2.5.2/modules/hal/nordic)
    # liblc3 (C:/ncs/v2.5.2/modules/lib/liblc3)
    CONFIG_ZEPHYR_LIBLC3_MODULE=y
    # CONFIG_LIBLC3 is not set
    # end of liblc3 (C:/ncs/v2.5.2/modules/lib/liblc3)
    # littlefs (C:/ncs/v2.5.2/modules/fs/littlefs)
    CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    # end of littlefs (C:/ncs/v2.5.2/modules/fs/littlefs)
    # loramac-node (C:/ncs/v2.5.2/modules/lib/loramac-node)
    CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    # CONFIG_HAS_SEMTECH_RADIO_DRIVERS is not set
    # end of loramac-node (C:/ncs/v2.5.2/modules/lib/loramac-node)
    # lvgl (C:/ncs/v2.5.2/modules/lib/gui/lvgl)
    # LVGL configuration
    # CONFIG_LV_CONF_SKIP is not set
    # CONFIG_LV_CONF_MINIMAL is not set
    # Color settings
    # CONFIG_LV_COLOR_DEPTH_32 is not set
    CONFIG_LV_COLOR_DEPTH_16=y
    # CONFIG_LV_COLOR_DEPTH_8 is not set
    # CONFIG_LV_COLOR_DEPTH_1 is not set
    CONFIG_LV_COLOR_DEPTH=16
    # CONFIG_LV_COLOR_SCREEN_TRANSP is not set
    CONFIG_LV_COLOR_MIX_ROUND_OFS=128
    CONFIG_LV_COLOR_CHROMA_KEY_HEX=0x00FF00
    # end of Color settings
    # Memory settings
    # CONFIG_LV_MEM_CUSTOM is not set
    CONFIG_LV_MEM_SIZE_KILOBYTES=32
    CONFIG_LV_MEM_ADDR=0x0
    CONFIG_LV_MEM_BUF_MAX_NUM=16
    # CONFIG_LV_MEMCPY_MEMSET_STD is not set
    # end of Memory settings
    # HAL Settings
    CONFIG_LV_DISP_DEF_REFR_PERIOD=30
    CONFIG_LV_INDEV_DEF_READ_PERIOD=30
    # CONFIG_LV_TICK_CUSTOM is not set
    # end of HAL Settings
    # Feature configuration
    # Drawing
    CONFIG_LV_DRAW_COMPLEX=y
    CONFIG_LV_SHADOW_CACHE_SIZE=0
    CONFIG_LV_CIRCLE_CACHE_SIZE=4
    CONFIG_LV_LAYER_SIMPLE_BUF_SIZE=24576
    CONFIG_LV_IMG_CACHE_DEF_SIZE=0
    CONFIG_LV_GRADIENT_MAX_STOPS=2
    CONFIG_LV_GRAD_CACHE_DEF_SIZE=0
    # CONFIG_LV_DITHER_GRADIENT is not set
    CONFIG_LV_DISP_ROT_MAX_BUF=10240
    # end of Drawing
    # GPU
    # CONFIG_LV_USE_GPU_ARM2D is not set
    # CONFIG_LV_USE_GPU_STM32_DMA2D is not set
    # CONFIG_LV_USE_GPU_SWM341_DMA2D is not set
    # CONFIG_LV_USE_GPU_NXP_PXP is not set
    # CONFIG_LV_USE_GPU_NXP_VG_LITE is not set
    # CONFIG_LV_USE_GPU_SDL is not set
    # end of GPU
    # Logging
    # CONFIG_LV_USE_LOG is not set
    # end of Logging
    # Asserts
    CONFIG_LV_USE_ASSERT_NULL=y
    CONFIG_LV_USE_ASSERT_MALLOC=y
    # CONFIG_LV_USE_ASSERT_STYLE is not set
    # CONFIG_LV_USE_ASSERT_MEM_INTEGRITY is not set
    # CONFIG_LV_USE_ASSERT_OBJ is not set
    CONFIG_LV_ASSERT_HANDLER_INCLUDE="assert.h"
    # end of Asserts
    # Others
    # CONFIG_LV_USE_PERF_MONITOR is not set
    # CONFIG_LV_USE_MEM_MONITOR is not set
    # CONFIG_LV_USE_REFR_DEBUG is not set
    # CONFIG_LV_SPRINTF_CUSTOM is not set
    # CONFIG_LV_SPRINTF_USE_FLOAT is not set
    CONFIG_LV_USE_USER_DATA=y
    # CONFIG_LV_ENABLE_GC is not set
    # end of Others
    # Compiler settings
    # CONFIG_LV_BIG_ENDIAN_SYSTEM is not set
    CONFIG_LV_ATTRIBUTE_MEM_ALIGN_SIZE=1
    # CONFIG_LV_ATTRIBUTE_FAST_MEM_USE_IRAM is not set
    # CONFIG_LV_USE_LARGE_COORD is not set
    # end of Compiler settings
    # end of Feature configuration
    # Font usage
    # Enable built-in fonts
    # CONFIG_LV_FONT_MONTSERRAT_8 is not set
    # CONFIG_LV_FONT_MONTSERRAT_10 is not set
    # CONFIG_LV_FONT_MONTSERRAT_12 is not set
    CONFIG_LV_FONT_MONTSERRAT_14=y
    # CONFIG_LV_FONT_MONTSERRAT_16 is not set
    # CONFIG_LV_FONT_MONTSERRAT_18 is not set
    # CONFIG_LV_FONT_MONTSERRAT_20 is not set
    # CONFIG_LV_FONT_MONTSERRAT_22 is not set
    # CONFIG_LV_FONT_MONTSERRAT_24 is not set
    # CONFIG_LV_FONT_MONTSERRAT_26 is not set
    # CONFIG_LV_FONT_MONTSERRAT_28 is not set
    # CONFIG_LV_FONT_MONTSERRAT_30 is not set
    # CONFIG_LV_FONT_MONTSERRAT_32 is not set
    # CONFIG_LV_FONT_MONTSERRAT_34 is not set
    # CONFIG_LV_FONT_MONTSERRAT_36 is not set
    # CONFIG_LV_FONT_MONTSERRAT_38 is not set
    # CONFIG_LV_FONT_MONTSERRAT_40 is not set
    # CONFIG_LV_FONT_MONTSERRAT_42 is not set
    # CONFIG_LV_FONT_MONTSERRAT_44 is not set
    # CONFIG_LV_FONT_MONTSERRAT_46 is not set
    # CONFIG_LV_FONT_MONTSERRAT_48 is not set
    # CONFIG_LV_FONT_MONTSERRAT_12_SUBPX is not set
    # CONFIG_LV_FONT_MONTSERRAT_28_COMPRESSED is not set
    # CONFIG_LV_FONT_DEJAVU_16_PERSIAN_HEBREW is not set
    # CONFIG_LV_FONT_SIMSUN_16_CJK is not set
    # CONFIG_LV_FONT_UNSCII_8 is not set
    # CONFIG_LV_FONT_UNSCII_16 is not set
    # CONFIG_LV_FONT_CUSTOM is not set
    # end of Enable built-in fonts
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_8 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_12 is not set
    CONFIG_LV_FONT_DEFAULT_MONTSERRAT_14=y
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_16 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_18 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_20 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_22 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_24 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_26 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_28 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_30 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_32 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_34 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_36 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_38 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_40 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_42 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_44 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_46 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_48 is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_12_SUBPX is not set
    # CONFIG_LV_FONT_DEFAULT_MONTSERRAT_28_COMPRESSED is not set
    # CONFIG_LV_FONT_DEFAULT_DEJAVU_16_PERSIAN_HEBREW is not set
    # CONFIG_LV_FONT_DEFAULT_SIMSUN_16_CJK is not set
    # CONFIG_LV_FONT_DEFAULT_UNSCII_8 is not set
    # CONFIG_LV_FONT_DEFAULT_UNSCII_16 is not set
    # CONFIG_LV_FONT_FMT_TXT_LARGE is not set
    # CONFIG_LV_USE_FONT_COMPRESSED is not set
    # CONFIG_LV_USE_FONT_SUBPX is not set
    CONFIG_LV_USE_FONT_PLACEHOLDER=y
    # end of Font usage
    # Text Settings
    CONFIG_LV_TXT_ENC_UTF8=y
    # CONFIG_LV_TXT_ENC_ASCII is not set
    CONFIG_LV_TXT_BREAK_CHARS=" ,.;:-_"
    CONFIG_LV_TXT_LINE_BREAK_LONG_LEN=0
    CONFIG_LV_TXT_COLOR_CMD="#"
    # CONFIG_LV_USE_BIDI is not set
    # CONFIG_LV_USE_ARABIC_PERSIAN_CHARS is not set
    # end of Text Settings
    # Widget usage
    CONFIG_LV_USE_ARC=y
    CONFIG_LV_USE_BAR=y
    CONFIG_LV_USE_BTN=y
    CONFIG_LV_USE_BTNMATRIX=y
    CONFIG_LV_USE_CANVAS=y
    CONFIG_LV_USE_CHECKBOX=y
    CONFIG_LV_USE_DROPDOWN=y
    CONFIG_LV_USE_IMG=y
    CONFIG_LV_USE_LABEL=y
    CONFIG_LV_LABEL_TEXT_SELECTION=y
    CONFIG_LV_LABEL_LONG_TXT_HINT=y
    CONFIG_LV_USE_LINE=y
    CONFIG_LV_USE_ROLLER=y
    CONFIG_LV_ROLLER_INF_PAGES=7
    CONFIG_LV_USE_SLIDER=y
    CONFIG_LV_USE_SWITCH=y
    CONFIG_LV_USE_TEXTAREA=y
    CONFIG_LV_TEXTAREA_DEF_PWD_SHOW_TIME=1500
    CONFIG_LV_USE_TABLE=y
    # end of Widget usage
    # Extra Widgets
    CONFIG_LV_USE_ANIMIMG=y
    CONFIG_LV_USE_CALENDAR=y
    # CONFIG_LV_CALENDAR_WEEK_STARTS_MONDAY is not set
    CONFIG_LV_USE_CALENDAR_HEADER_ARROW=y
    CONFIG_LV_USE_CALENDAR_HEADER_DROPDOWN=y
    CONFIG_LV_USE_CHART=y
    CONFIG_LV_USE_COLORWHEEL=y
    CONFIG_LV_USE_IMGBTN=y
    CONFIG_LV_USE_KEYBOARD=y
    CONFIG_LV_USE_LED=y
    CONFIG_LV_USE_LIST=y
    CONFIG_LV_USE_MENU=y
    CONFIG_LV_USE_METER=y
    CONFIG_LV_USE_MSGBOX=y
    CONFIG_LV_USE_SPAN=y
    CONFIG_LV_SPAN_SNIPPET_STACK_SIZE=64
    CONFIG_LV_USE_SPINBOX=y
    CONFIG_LV_USE_SPINNER=y
    CONFIG_LV_USE_TABVIEW=y
    CONFIG_LV_USE_TILEVIEW=y
    CONFIG_LV_USE_WIN=y
    # end of Extra Widgets
    # Themes
    CONFIG_LV_USE_THEME_DEFAULT=y
    # CONFIG_LV_THEME_DEFAULT_DARK is not set
    CONFIG_LV_THEME_DEFAULT_GROW=y
    CONFIG_LV_THEME_DEFAULT_TRANSITION_TIME=80
    CONFIG_LV_USE_THEME_BASIC=y
    # CONFIG_LV_USE_THEME_MONO is not set
    # end of Themes
    # Layouts
    CONFIG_LV_USE_FLEX=y
    CONFIG_LV_USE_GRID=y
    # end of Layouts
    # 3rd Party Libraries
    # CONFIG_LV_USE_FS_STDIO is not set
    # CONFIG_LV_USE_FS_POSIX is not set
    # CONFIG_LV_USE_FS_WIN32 is not set
    # CONFIG_LV_USE_FS_FATFS is not set
    # CONFIG_LV_USE_PNG is not set
    # CONFIG_LV_USE_BMP is not set
    # CONFIG_LV_USE_SJPG is not set
    # CONFIG_LV_USE_GIF is not set
    # CONFIG_LV_USE_QRCODE is not set
    # CONFIG_LV_USE_FREETYPE is not set
    # CONFIG_LV_USE_RLOTTIE is not set
    # CONFIG_LV_USE_FFMPEG is not set
    # end of 3rd Party Libraries
    # Others
    CONFIG_LV_USE_SNAPSHOT=y
    # CONFIG_LV_USE_MONKEY is not set
    # CONFIG_LV_USE_GRIDNAV is not set
    # CONFIG_LV_USE_FRAGMENT is not set
    # CONFIG_LV_USE_IMGFONT is not set
    # CONFIG_LV_USE_MSG is not set
    # CONFIG_LV_USE_IME_PINYIN is not set
    # end of Others
    # Examples
    CONFIG_LV_BUILD_EXAMPLES=y
    # end of Examples
    # Demos
    # CONFIG_LV_USE_DEMO_WIDGETS is not set
    # CONFIG_LV_USE_DEMO_KEYPAD_AND_ENCODER is not set
    # CONFIG_LV_USE_DEMO_BENCHMARK is not set
    # CONFIG_LV_USE_DEMO_STRESS is not set
    # CONFIG_LV_USE_DEMO_MUSIC is not set
    # end of Demos
    # end of LVGL configuration
    CONFIG_ZEPHYR_LVGL_MODULE=y
    # end of lvgl (C:/ncs/v2.5.2/modules/lib/gui/lvgl)
    # lz4 (C:/ncs/v2.5.2/modules/lib/lz4)
    CONFIG_ZEPHYR_LZ4_MODULE=y
    # CONFIG_LZ4 is not set
    # end of lz4 (C:/ncs/v2.5.2/modules/lib/lz4)
    # nanopb (C:/ncs/v2.5.2/modules/lib/nanopb)
    CONFIG_ZEPHYR_NANOPB_MODULE=y
    # CONFIG_NANOPB is not set
    # end of nanopb (C:/ncs/v2.5.2/modules/lib/nanopb)
    # picolibc (C:/ncs/v2.5.2/modules/lib/picolibc)
    # CONFIG_PICOLIBC_MODULE is not set
    CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    # end of picolibc (C:/ncs/v2.5.2/modules/lib/picolibc)
    # segger (C:/ncs/v2.5.2/modules/debug/segger)
    CONFIG_ZEPHYR_SEGGER_MODULE=y
    CONFIG_HAS_SEGGER_RTT=y
    # CONFIG_USE_SEGGER_RTT is not set
    # end of segger (C:/ncs/v2.5.2/modules/debug/segger)
    # TraceRecorder (C:/ncs/v2.5.2/modules/debug/TraceRecorder)
    CONFIG_ZEPHYR_TRACERECORDER_MODULE=y
    # end of TraceRecorder (C:/ncs/v2.5.2/modules/debug/TraceRecorder)
    # uoscore-uedhoc (C:/ncs/v2.5.2/modules/lib/uoscore-uedhoc)
    CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    # end of uoscore-uedhoc (C:/ncs/v2.5.2/modules/lib/uoscore-uedhoc)
    # zcbor (C:/ncs/v2.5.2/modules/lib/zcbor)
    CONFIG_ZEPHYR_ZCBOR_MODULE=y
    # end of zcbor (C:/ncs/v2.5.2/modules/lib/zcbor)
    # zscilib (C:/ncs/v2.5.2/modules/lib/zscilib)
    # CONFIG_ZSL is not set
    CONFIG_ZEPHYR_ZSCILIB_MODULE=y
    # end of zscilib (C:/ncs/v2.5.2/modules/lib/zscilib)
    # nrfxlib (C:/ncs/v2.5.2/nrfxlib)
    # Nordic nrfxlib
    CONFIG_NRF_MODEM_SHMEM_CTRL_SIZE=0x4e8
    # CONFIG_NFC_T2T_NRFXLIB is not set
    # CONFIG_NFC_T4T_NRFXLIB is not set
    # Crypto libraries for nRF5x SOCs.
    CONFIG_NRFXLIB_CRYPTO=y
    CONFIG_CRYPTOCELL_CC312_USABLE=y
    CONFIG_CRYPTOCELL_USABLE=y
    # CONFIG_NRF_OBERON is not set
    CONFIG_NRF_CC3XX_PLATFORM=y
    CONFIG_CC3XX_MUTEX_LOCK=y
    # CONFIG_CC3XX_ATOMIC_LOCK is not set
    # CONFIG_CC3XX_HW_MUTEX_LOCK is not set
    # end of Crypto libraries for nRF5x SOCs.
    # CONFIG_NRF_RPC is not set
    CONFIG_NRF_802154_SOURCE_NRFXLIB=y
    # CONFIG_GZLL is not set
    # CONFIG_NRF_DM is not set
    # Encoder sample rates
    # end of Encoder sample rates
    # Decoder sample rates
    # end of Decoder sample rates
    # CONFIG_NRF_FUEL_GAUGE is not set
    # end of Nordic nrfxlib
    CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    # end of nrfxlib (C:/ncs/v2.5.2/nrfxlib)
    # connectedhomeip (C:/ncs/v2.5.2/modules/lib/matter)
    # CONFIG_CHIP is not set
    CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # end of connectedhomeip (C:/ncs/v2.5.2/modules/lib/matter)
    # Optional modules. Make sure they're installed, via the project manifest.
    # Components
    # Instruction Set
    # Features
    CONFIG_LIBMETAL=y
    CONFIG_LIBMETAL_SRC_PATH="libmetal"
    # CONFIG_LVGL is not set
    # CONFIG_HAS_MEC_HAL is not set
    # CONFIG_HAS_MPFS_HAL is not set
    CONFIG_OPENAMP=y
    CONFIG_OPENAMP_SRC_PATH="open-amp"
    CONFIG_OPENAMP_MASTER=y
    CONFIG_OPENAMP_SLAVE=y
    # CONFIG_SOF is not set
    # CONFIG_MIPI_SYST_LIB is not set
    # CONFIG_HAS_TELINK_DRIVERS is not set
    # CONFIG_TINYCRYPT_CTR_PRNG is not set
    CONFIG_TINYCRYPT_SHA256=y
    CONFIG_TINYCRYPT_SHA256_HMAC=y
    CONFIG_TINYCRYPT_SHA256_HMAC_PRNG=y
    # CONFIG_TINYCRYPT_ECC_DH is not set
    # CONFIG_TINYCRYPT_ECC_DSA is not set
    CONFIG_TINYCRYPT_AES=y
    # CONFIG_TINYCRYPT_AES_CBC is not set
    # CONFIG_TINYCRYPT_AES_CTR is not set
    # CONFIG_TINYCRYPT_AES_CCM is not set
    CONFIG_TINYCRYPT_AES_CMAC=y
    # CONFIG_MCUBOOT_BOOTUTIL_LIB is not set
    # Unavailable modules, please install those via the project manifest.
    # hal_gigadevice module not available.
    # Trusted-firmware-a module not available.
    # THRIFT module not available.
    # CONFIG_ACPI is not set
    # end of Modules
    CONFIG_BOARD_REVISION="$BOARD_REVISION"
    # CONFIG_NET_DRIVERS is not set
    CONFIG_BOARD_NRF5340_AUDIO_DK_NRF5340_CPUAPP=y
    # CONFIG_BOARD_NRF5340_AUDIO_DK_NRF5340_CPUAPP_NS is not set
    # Board Options
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    CONFIG_DOMAIN_CPUNET_BOARD="nrf5340_audio_dk_nrf5340_cpunet"
    # end of Board Options
    # CONFIG_SOC_SERIES_APOLLO4X is not set
    # CONFIG_SOC_SERIES_BEETLE is not set
    # CONFIG_SOC_SERIES_ARM_DESIGNSTART is not set
    # CONFIG_SOC_SERIES_FVP_AEMV8R_AARCH32 is not set
    # CONFIG_SOC_SERIES_MPS2 is not set
    # CONFIG_SOC_SERIES_MPS3 is not set
    # CONFIG_SOC_SERIES_MUSCA_B1 is not set
    # CONFIG_SOC_SERIES_MUSCA_S1 is not set
    # CONFIG_SOC_SERIES_AST10X0 is not set
    # CONFIG_SOC_SERIES_SAMC20 is not set
    # CONFIG_SOC_SERIES_SAMC21 is not set
    # CONFIG_SOC_SERIES_SAMD20 is not set
    # CONFIG_SOC_SERIES_SAMD21 is not set
    # CONFIG_SOC_SERIES_SAMD51 is not set
    # CONFIG_SOC_SERIES_SAME51 is not set
    # CONFIG_SOC_SERIES_SAME53 is not set
    # CONFIG_SOC_SERIES_SAME54 is not set
    # CONFIG_SOC_SERIES_SAML21 is not set
    # CONFIG_SOC_SERIES_SAMR21 is not set
    # CONFIG_SOC_SERIES_SAMR34 is not set
    # CONFIG_SOC_SERIES_SAMR35 is not set
    # CONFIG_SOC_SERIES_SAM3X is not set
    # CONFIG_SOC_SERIES_SAM4E is not set
    # CONFIG_SOC_SERIES_SAM4L is not set
    # CONFIG_SOC_SERIES_SAM4S is not set
    # CONFIG_SOC_SERIES_SAME70 is not set
    # CONFIG_SOC_SERIES_SAMV71 is not set
    # CONFIG_SOC_SERIES_VALKYRIE is not set
    # CONFIG_SOC_SERIES_VIPER is not set
    # CONFIG_SOC_SERIES_PSOC62 is not set
    # CONFIG_SOC_SERIES_PSOC63 is not set
    # CONFIG_SOC_SERIES_GD32A50X is not set
    # CONFIG_SOC_SERIES_GD32E10X is not set
    # CONFIG_SOC_SERIES_GD32E50X is not set
    # CONFIG_SOC_SERIES_GD32F3X0 is not set
    # CONFIG_SOC_SERIES_GD32F403 is not set
    # CONFIG_SOC_SERIES_GD32F4XX is not set
    # CONFIG_SOC_SERIES_GD32L23X is not set
    # CONFIG_SOC_SERIES_PSOC_60 is not set
    # CONFIG_SOC_SERIES_PSOC_61 is not set
    # CONFIG_SOC_SERIES_PSOC_62 is not set
    # CONFIG_SOC_SERIES_PSOC_63 is not set
    # CONFIG_SOC_SERIES_PSOC_64 is not set
    # CONFIG_SOC_SERIES_XMC_4XXX is not set
    # CONFIG_SOC_SERIES_CYCLONE5 is not set
    # CONFIG_SOC_SERIES_MEC1501X is not set
    # CONFIG_SOC_SERIES_MEC172X is not set
    # CONFIG_SOC_SERIES_NRF51X is not set
    # CONFIG_SOC_SERIES_NRF52X is not set
    CONFIG_SOC_SERIES_NRF53X=y
    # CONFIG_SOC_SERIES_NRF91X is not set
    # CONFIG_SOC_SERIES_NPCX4 is not set
    # CONFIG_SOC_SERIES_NPCX7 is not set
    # CONFIG_SOC_SERIES_NPCX9 is not set
    # CONFIG_SOC_SERIES_M46X is not set
    # CONFIG_SOC_SERIES_M48X is not set
    # CONFIG_SOC_SERIES_IMX_6X_M4 is not set
    # CONFIG_SOC_SERIES_IMX7_M4 is not set
    # CONFIG_SOC_SERIES_IMX8ML_M7 is not set
    # CONFIG_SOC_SERIES_IMX8MM_M4 is not set
    # CONFIG_SOC_SERIES_IMX8MQ_M4 is not set
    # CONFIG_SOC_SERIES_IMX_RT5XX is not set
    # CONFIG_SOC_SERIES_IMX_RT6XX is not set
    # CONFIG_SOC_SERIES_IMX_RT is not set
    # CONFIG_SOC_SERIES_KINETIS_K2X is not set
    # CONFIG_SOC_SERIES_KINETIS_K6X is not set
    # CONFIG_SOC_SERIES_KINETIS_K8X is not set
    # CONFIG_SOC_SERIES_KINETIS_KE1XF is not set
    # CONFIG_SOC_SERIES_KINETIS_KL2X is not set
    # CONFIG_SOC_SERIES_KINETIS_KV5X is not set
    # CONFIG_SOC_SERIES_KINETIS_KWX is not set
    # CONFIG_SOC_SERIES_LPC11U6X is not set
    # CONFIG_SOC_SERIES_LPC51U68 is not set
    # CONFIG_SOC_SERIES_LPC54XXX is not set
    # CONFIG_SOC_SERIES_LPC55XXX is not set
    # CONFIG_SOC_SERIES_S32K3_M7 is not set
    # CONFIG_SOC_SERIES_S32ZE_R52 is not set
    # CONFIG_SOC_EOS_S3 is not set
    # CONFIG_SOC_SERIES_RCAR_GEN3 is not set
    # CONFIG_SOC_SERIES_DA1469X is not set
    # CONFIG_SOC_SERIES_RP2XXX is not set
    # CONFIG_SOC_SERIES_EFM32GG11B is not set
    # CONFIG_SOC_SERIES_EFM32GG12B is not set
    # CONFIG_SOC_SERIES_EFM32HG is not set
    # CONFIG_SOC_SERIES_EFM32JG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG12B is not set
    # CONFIG_SOC_SERIES_EFM32PG1B is not set
    # CONFIG_SOC_SERIES_EFM32WG is not set
    # CONFIG_SOC_SERIES_EFR32BG13P is not set
    # CONFIG_SOC_SERIES_EFR32BG22 is not set
    # CONFIG_SOC_SERIES_EFR32BG27 is not set
    # CONFIG_SOC_SERIES_EFR32FG13P is not set
    # CONFIG_SOC_SERIES_EFR32FG1P is not set
    # CONFIG_SOC_SERIES_EFR32MG12P is not set
    # CONFIG_SOC_SERIES_EFR32MG21 is not set
    # CONFIG_SOC_SERIES_EFR32MG24 is not set
    # CONFIG_SOC_SERIES_STM32C0X is not set
    # CONFIG_SOC_SERIES_STM32F0X is not set
    # CONFIG_SOC_SERIES_STM32F1X is not set
    # CONFIG_SOC_SERIES_STM32F2X is not set
    # CONFIG_SOC_SERIES_STM32F3X is not set
    # CONFIG_SOC_SERIES_STM32F4X is not set
    # CONFIG_SOC_SERIES_STM32F7X is not set
    # CONFIG_SOC_SERIES_STM32G0X is not set
    # CONFIG_SOC_SERIES_STM32G4X is not set
    # CONFIG_SOC_SERIES_STM32H5X is not set
    # CONFIG_SOC_SERIES_STM32H7X is not set
    # CONFIG_SOC_SERIES_STM32L0X is not set
    # CONFIG_SOC_SERIES_STM32L1X is not set
    # CONFIG_SOC_SERIES_STM32L4X is not set
    # CONFIG_SOC_SERIES_STM32L5X is not set
    # CONFIG_SOC_SERIES_STM32MP1X is not set
    # CONFIG_SOC_SERIES_STM32U5X is not set
    # CONFIG_SOC_SERIES_STM32WBX is not set
    # CONFIG_SOC_SERIES_STM32WBAX is not set
    # CONFIG_SOC_SERIES_STM32WLX is not set
    # CONFIG_SOC_SERIES_AM62X_M4 is not set
    # CONFIG_SOC_TI_LM3S6965 is not set
    # CONFIG_SOC_SERIES_CC13X2_CC26X2 is not set
    # CONFIG_SOC_SERIES_CC13X2X7_CC26X2X7 is not set
    # CONFIG_SOC_SERIES_CC32XX is not set
    # CONFIG_SOC_SERIES_MSP432P4XX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXX is not set
    # CONFIG_SOC_SERIES_XILINX_XC7ZXXXS is not set
    # CONFIG_SOC_XILINX_ZYNQMP_RPU is not set
    # Hardware Configuration
    CONFIG_CPU_HAS_ARM_MPU=y
    CONFIG_CPU_HAS_NRF_IDAU=y
    CONFIG_NRF_SPU_RAM_REGION_SIZE=0x2000
    CONFIG_HAS_SWO=y
    CONFIG_SOC_FAMILY="nordic_nrf"
    CONFIG_GPIO_INIT_PRIORITY=40
    CONFIG_SOC_FAMILY_NRF=y
    CONFIG_HAS_HW_NRF_CC312=y
    CONFIG_HAS_HW_NRF_CLOCK=y
    CONFIG_HAS_HW_NRF_CTRLAP=y
    CONFIG_HAS_HW_NRF_DCNF=y
    CONFIG_HAS_HW_NRF_DPPIC=y
    CONFIG_HAS_HW_NRF_EGU0=y
    CONFIG_HAS_HW_NRF_EGU1=y
    CONFIG_HAS_HW_NRF_EGU2=y
    CONFIG_HAS_HW_NRF_EGU3=y
    CONFIG_HAS_HW_NRF_EGU4=y
    CONFIG_HAS_HW_NRF_EGU5=y
    CONFIG_HAS_HW_NRF_GPIO0=y
    CONFIG_HAS_HW_NRF_GPIO1=y
    CONFIG_HAS_HW_NRF_GPIOTE=y
    CONFIG_HAS_HW_NRF_I2S0=y
    CONFIG_HAS_HW_NRF_IPC=y
    CONFIG_HAS_HW_NRF_KMU=y
    CONFIG_HAS_HW_NRF_MUTEX=y
    CONFIG_HAS_HW_NRF_NFCT=y
    CONFIG_HAS_HW_NRF_NVMC_PE=y
    CONFIG_HAS_HW_NRF_OSCILLATORS=y
    CONFIG_HAS_HW_NRF_POWER=y
    CONFIG_HAS_HW_NRF_PWM0=y
    CONFIG_HAS_HW_NRF_PWM1=y
    CONFIG_HAS_HW_NRF_PWM2=y
    CONFIG_HAS_HW_NRF_REGULATORS=y
    CONFIG_HAS_HW_NRF_RESET=y
    CONFIG_HAS_HW_NRF_SAADC=y
    CONFIG_HAS_HW_NRF_SPIM4=y
    CONFIG_HAS_HW_NRF_SPU=y
    CONFIG_HAS_HW_NRF_TWIM1=y
    CONFIG_HAS_HW_NRF_UARTE0=y
    CONFIG_HAS_HW_NRF_UARTE3=y
    CONFIG_HAS_HW_NRF_USBD=y
    CONFIG_HAS_HW_NRF_USBREG=y
    CONFIG_HAS_HW_NRF_VMC=y
    CONFIG_HAS_HW_NRF_WDT0=y
    CONFIG_SOC_NRF5340_CPUAPP=y
    CONFIG_SOC_NRF5340_CPUAPP_QKAA=y
    # CONFIG_SOC_NRF5340_CPUNET_QKAA is not set
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND_NEEDED=y
    CONFIG_SOC_NRF53_ANOMALY_160_WORKAROUND=y
    CONFIG_SOC_NRF53_RTC_PRETICK=y
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_FROM_NET=10
    CONFIG_SOC_NRF53_RTC_PRETICK_IPC_CH_TO_NET=11
    CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND=y
    # CONFIG_SOC_NRF53_ANOMALY_168_WORKAROUND_FOR_EXECUTION_FROM_RAM is not set
    CONFIG_SOC_DCDC_NRF53X_APP=y
    CONFIG_SOC_DCDC_NRF53X_NET=y
    CONFIG_SOC_DCDC_NRF53X_HV=y
    CONFIG_SOC_ENABLE_LFXO=y
    # CONFIG_SOC_LFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_LFXO_CAP_INT_6PF is not set
    CONFIG_SOC_LFXO_CAP_INT_7PF=y
    # CONFIG_SOC_LFXO_CAP_INT_9PF is not set
    CONFIG_SOC_HFXO_CAP_DEFAULT=y
    # CONFIG_SOC_HFXO_CAP_EXTERNAL is not set
    # CONFIG_SOC_HFXO_CAP_INTERNAL is not set
    CONFIG_NRF_ENABLE_CACHE=y
    CONFIG_NRF53_SYNC_RTC=y
    # CONFIG_SYNC_RTC_LOG_LEVEL_OFF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_ERR is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_WRN is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_INF is not set
    # CONFIG_SYNC_RTC_LOG_LEVEL_DBG is not set
    CONFIG_SYNC_RTC_LOG_LEVEL_DEFAULT=y
    CONFIG_SYNC_RTC_LOG_LEVEL=3
    CONFIG_NRF53_SYNC_RTC_INIT_PRIORITY=90
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=1
    CONFIG_NRF53_SYNC_RTC_LOG_TIMESTAMP=y
    CONFIG_NRF53_SYNC_RTC_IPM_OUT=7
    CONFIG_NRF53_SYNC_RTC_IPM_IN=8
    CONFIG_IPM_MSG_CH_8_ENABLE=y
    CONFIG_IPM_MSG_CH_8_RX=y
    CONFIG_NRF_SOC_SECURE_SUPPORTED=y
    CONFIG_NRF_APPROTECT_USE_UICR=y
    # CONFIG_NRF_APPROTECT_LOCK is not set
    # CONFIG_NRF_APPROTECT_USER_HANDLING is not set
    CONFIG_NRF_SECURE_APPROTECT_USE_UICR=y
    # CONFIG_NRF_SECURE_APPROTECT_LOCK is not set
    # CONFIG_NRF_SECURE_APPROTECT_USER_HANDLING is not set
    # CONFIG_NRF_TRACE_PORT is not set
    # CONFIG_BUILD_OUTPUT_INFO_HEADER is not set
    # CONFIG_SOC_LOG_LEVEL_OFF is not set
    # CONFIG_SOC_LOG_LEVEL_ERR is not set
    # CONFIG_SOC_LOG_LEVEL_WRN is not set
    # CONFIG_SOC_LOG_LEVEL_INF is not set
    # CONFIG_SOC_LOG_LEVEL_DBG is not set
    CONFIG_SOC_LOG_LEVEL_DEFAULT=y
    CONFIG_SOC_LOG_LEVEL=3
    # end of Hardware Configuration
    CONFIG_SOC_COMPATIBLE_NRF=y
    CONFIG_SOC_COMPATIBLE_NRF53X=y
    CONFIG_SOC_COMPATIBLE_NRF5340_CPUAPP=y
    # ARM Options
    CONFIG_ARCH="arm"
    CONFIG_CPU_CORTEX=y
    # CONFIG_CODE_DATA_RELOCATION_SRAM is not set
    CONFIG_ARM_ON_ENTER_CPU_IDLE_HOOK=y
    CONFIG_ARM_ON_EXIT_CPU_IDLE=y
    CONFIG_CPU_CORTEX_M=y
    # CONFIG_ARM_ZIMAGE_HEADER is not set
    CONFIG_ISA_THUMB2=y
    CONFIG_ASSEMBLER_ISA_THUMB2=y
    CONFIG_COMPILER_ISA_THUMB2=y
    CONFIG_STACK_ALIGN_DOUBLE_WORD=y
    # CONFIG_RUNTIME_NMI is not set
    CONFIG_FAULT_DUMP=2
    CONFIG_BUILTIN_STACK_GUARD=y
    CONFIG_ARM_STACK_PROTECTION=y
    CONFIG_ARM_STORE_EXC_RETURN=y
    CONFIG_FP_HARDABI=y
    # CONFIG_FP_SOFTABI is not set
    CONFIG_FP16=y
    CONFIG_FP16_IEEE=y
    # CONFIG_FP16_ALT is not set
    CONFIG_CPU_CORTEX_M33=y
    CONFIG_CPU_CORTEX_M_HAS_SYSTICK=y
    CONFIG_CPU_CORTEX_M_HAS_DWT=y
    CONFIG_CPU_CORTEX_M_HAS_BASEPRI=y
    CONFIG_CPU_CORTEX_M_HAS_VTOR=y
    CONFIG_CPU_CORTEX_M_HAS_SPLIM=y
    CONFIG_CPU_CORTEX_M_HAS_PROGRAMMABLE_FAULT_PRIOS=y
    CONFIG_CPU_CORTEX_M_HAS_CMSE=y
    CONFIG_ARMV7_M_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_MAINLINE=y
    CONFIG_ARMV8_M_SE=y
    CONFIG_ARMV7_M_ARMV8_M_FP=y
    CONFIG_ARMV8_M_DSP=y
    # ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_GEN_ISR_TABLES=y
    # CONFIG_ZERO_LATENCY_IRQS is not set
    # CONFIG_SW_VECTOR_RELAY is not set
    # CONFIG_CORTEX_M_DWT is not set
    # CONFIG_CORTEX_M_DEBUG_MONITOR_HOOK is not set
    # CONFIG_TRAP_UNALIGNED_ACCESS is not set
    # end of ARM Cortex-M0/M0+/M1/M3/M4/M7/M23/M33 options
    CONFIG_NULL_POINTER_EXCEPTION_DETECTION_NONE=y
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_DWT is not set
    # CONFIG_NULL_POINTER_EXCEPTION_DETECTION_MPU is not set
    CONFIG_ARM_TRUSTZONE_M=y
    CONFIG_GEN_IRQ_VECTOR_TABLE=y
    CONFIG_ARM_MPU=y
    CONFIG_ARM_MPU_REGION_MIN_ALIGN_AND_SIZE=32
    # CONFIG_MPU_STACK_GUARD is not set
    # CONFIG_MPU_ALLOW_FLASH_WRITE is not set
    # CONFIG_MPU_DISABLE_BACKGROUND_MAP is not set
    # CONFIG_CUSTOM_SECTION_ALIGN is not set
    CONFIG_CUSTOM_SECTION_MIN_ALIGN_SIZE=32
    # end of ARM Options
    CONFIG_ARM=y
    CONFIG_ARCH_IS_SET=y
    # General Architecture Options
    # CONFIG_SEMIHOST is not set
    # CONFIG_ARCH_LOG_LEVEL_OFF is not set
    # CONFIG_ARCH_LOG_LEVEL_ERR is not set
    # CONFIG_ARCH_LOG_LEVEL_WRN is not set
    # CONFIG_ARCH_LOG_LEVEL_INF is not set
    # CONFIG_ARCH_LOG_LEVEL_DBG is not set
    CONFIG_ARCH_LOG_LEVEL_DEFAULT=y
    CONFIG_ARCH_LOG_LEVEL=3
    CONFIG_LITTLE_ENDIAN=y
    # CONFIG_TRUSTED_EXECUTION_SECURE is not set
    # CONFIG_TRUSTED_EXECUTION_NONSECURE is not set
    CONFIG_HW_STACK_PROTECTION=y
    # CONFIG_USERSPACE is not set
    CONFIG_KOBJECT_TEXT_AREA=256
    CONFIG_KOBJECT_DATA_AREA_RESERVE_EXTRA_PERCENT=100
    CONFIG_KOBJECT_RODATA_AREA_EXTRA_BYTES=16
    CONFIG_GEN_PRIV_STACKS=y
    # CONFIG_STACK_GROWS_UP is not set
    # Interrupt Configuration
    # CONFIG_DYNAMIC_INTERRUPTS is not set
    CONFIG_ARCH_IRQ_VECTOR_TABLE_ALIGN=4
    CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_ADDRESS=y
    # CONFIG_IRQ_VECTOR_TABLE_JUMP_BY_CODE is not set
    CONFIG_GEN_SW_ISR_TABLE=y
    CONFIG_ARCH_SW_ISR_TABLE_ALIGN=4
    CONFIG_GEN_IRQ_START_VECTOR=0
    # CONFIG_EXTRA_EXCEPTION_INFO is not set
    # CONFIG_SIMPLIFIED_EXCEPTION_CODES is not set
    # end of Interrupt Configuration
    # end of General Architecture Options
    CONFIG_ARCH_HAS_SINGLE_THREAD_SUPPORT=y
    CONFIG_ARCH_HAS_TIMING_FUNCTIONS=y
    CONFIG_ARCH_HAS_TRUSTED_EXECUTION=y
    CONFIG_ARCH_HAS_STACK_PROTECTION=y
    CONFIG_ARCH_HAS_USERSPACE=y
    CONFIG_ARCH_HAS_EXECUTABLE_PAGE_BIT=y
    CONFIG_ARCH_HAS_RAMFUNC_SUPPORT=y
    CONFIG_ARCH_HAS_NESTED_EXCEPTION_DETECTION=y
    CONFIG_ARCH_SUPPORTS_COREDUMP=y
    CONFIG_ARCH_SUPPORTS_ARCH_HW_INIT=y
    CONFIG_ARCH_HAS_EXTRA_EXCEPTION_INFO=y
    CONFIG_ARCH_HAS_THREAD_LOCAL_STORAGE=y
    CONFIG_ARCH_HAS_SUSPEND_TO_RAM=y
    CONFIG_ARCH_HAS_THREAD_ABORT=y
    CONFIG_ARCH_HAS_CODE_DATA_RELOCATION=y
    CONFIG_CPU_HAS_TEE=y
    CONFIG_CPU_HAS_FPU=y
    CONFIG_CPU_HAS_MPU=y
    CONFIG_MPU=y
    # CONFIG_MPU_LOG_LEVEL_OFF is not set
    # CONFIG_MPU_LOG_LEVEL_ERR is not set
    # CONFIG_MPU_LOG_LEVEL_WRN is not set
    # CONFIG_MPU_LOG_LEVEL_INF is not set
    # CONFIG_MPU_LOG_LEVEL_DBG is not set
    CONFIG_MPU_LOG_LEVEL_DEFAULT=y
    CONFIG_MPU_LOG_LEVEL=3
    CONFIG_MPU_REQUIRES_NON_OVERLAPPING_REGIONS=y
    CONFIG_MPU_GAP_FILLING=y
    CONFIG_SRAM_REGION_PERMISSIONS=y
    # Floating Point Options
    # end of Floating Point Options
    # Cache Options
    # end of Cache Options
    CONFIG_TOOLCHAIN_HAS_BUILTIN_FFS=y
    # General Kernel Options
    # CONFIG_KERNEL_LOG_LEVEL_OFF is not set
    # CONFIG_KERNEL_LOG_LEVEL_ERR is not set
    # CONFIG_KERNEL_LOG_LEVEL_WRN is not set
    # CONFIG_KERNEL_LOG_LEVEL_INF is not set
    # CONFIG_KERNEL_LOG_LEVEL_DBG is not set
    CONFIG_KERNEL_LOG_LEVEL_DEFAULT=y
    CONFIG_KERNEL_LOG_LEVEL=3
    CONFIG_MULTITHREADING=y
    CONFIG_NUM_COOP_PRIORITIES=16
    CONFIG_NUM_PREEMPT_PRIORITIES=15
    CONFIG_COOP_ENABLED=y
    CONFIG_PREEMPT_ENABLED=y
    CONFIG_PRIORITY_CEILING=-127
    # CONFIG_SCHED_DEADLINE is not set
    # CONFIG_SCHED_CPU_MASK is not set
    CONFIG_ISR_STACK_SIZE=2048
    CONFIG_THREAD_STACK_INFO=y
    # CONFIG_THREAD_CUSTOM_DATA is not set
    # CONFIG_DYNAMIC_THREAD is not set
    CONFIG_ERRNO=y
    CONFIG_SCHED_DUMB=y
    # CONFIG_SCHED_SCALABLE is not set
    # CONFIG_SCHED_MULTIQ is not set
    # CONFIG_WAITQ_SCALABLE is not set
    CONFIG_WAITQ_DUMB=y
    # Kernel Debugging and Metrics
    CONFIG_BOOT_BANNER=y
    CONFIG_BOOT_DELAY=0
    CONFIG_THREAD_MAX_NAME_LEN=32
    CONFIG_INSTRUMENT_THREAD_SWITCHING=y
    CONFIG_THREAD_RUNTIME_STATS=y
    # CONFIG_THREAD_RUNTIME_STATS_USE_TIMING_FUNCTIONS is not set
    CONFIG_SCHED_THREAD_USAGE=y
    # CONFIG_SCHED_THREAD_USAGE_ANALYSIS is not set
    CONFIG_SCHED_THREAD_USAGE_ALL=y
    CONFIG_SCHED_THREAD_USAGE_AUTO_ENABLE=y
    # end of Kernel Debugging and Metrics
    # Work Queue Options
    CONFIG_SYSTEM_WORKQUEUE_PRIORITY=-1
    # CONFIG_SYSTEM_WORKQUEUE_NO_YIELD is not set
    # end of Work Queue Options
    # Barrier Operations
    CONFIG_BARRIER_OPERATIONS_ARCH=y
    # end of Barrier Operations
    # Atomic Operations
    CONFIG_ATOMIC_OPERATIONS_BUILTIN=y
    # end of Atomic Operations
    # Timer API Options
    CONFIG_TIMESLICING=y
    CONFIG_TIMESLICE_SIZE=0
    CONFIG_TIMESLICE_PRIORITY=0
    # CONFIG_TIMESLICE_PER_THREAD is not set
    CONFIG_POLL=y
    # end of Timer API Options
    # Other Kernel Object Options
    # CONFIG_MEM_SLAB_TRACE_MAX_UTILIZATION is not set
    CONFIG_NUM_MBOX_ASYNC_MSGS=10
    # CONFIG_EVENTS is not set
    # CONFIG_PIPES is not set
    CONFIG_KERNEL_MEM_POOL=y
    # end of Other Kernel Object Options
    CONFIG_ARCH_HAS_CUSTOM_SWAP_TO_MAIN=y
    CONFIG_SWAP_NONATOMIC=y
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_TIMEOUT_64BIT=y
    CONFIG_SYS_CLOCK_MAX_TIMEOUT_DAYS=365
    CONFIG_XIP=y
    # Initialization Priorities
    CONFIG_KERNEL_INIT_PRIORITY_OBJECTS=30
    CONFIG_KERNEL_INIT_PRIORITY_DEFAULT=40
    CONFIG_KERNEL_INIT_PRIORITY_DEVICE=50
    CONFIG_APPLICATION_INIT_PRIORITY=90
    # end of Initialization Priorities
    # Security Options
    # end of Security Options
    # SMP Options
    CONFIG_MP_NUM_CPUS=1
    # end of SMP Options
    CONFIG_TICKLESS_KERNEL=y
    CONFIG_TOOLCHAIN_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # CONFIG_THREAD_LOCAL_STORAGE is not set
    # end of General Kernel Options
    # Device Options
    # CONFIG_DEVICE_DEPS is not set
    # end of Device Options
    # Virtual Memory Support
    # end of Virtual Memory Support
    # Device Drivers
    CONFIG_ADC_SHELL=y
    CONFIG_ADC_CONFIGURABLE_INPUTS=y
    # CONFIG_ADC_ASYNC is not set
    # CONFIG_ADC_LOG_LEVEL_OFF is not set
    # CONFIG_ADC_LOG_LEVEL_ERR is not set
    # CONFIG_ADC_LOG_LEVEL_WRN is not set
    # CONFIG_ADC_LOG_LEVEL_INF is not set
    # CONFIG_ADC_LOG_LEVEL_DBG is not set
    CONFIG_ADC_LOG_LEVEL_DEFAULT=y
    CONFIG_ADC_LOG_LEVEL=3
    CONFIG_ADC_NRFX_SAADC=y
    # CONFIG_AUXDISPLAY is not set
    # CONFIG_AUDIO is not set
    # CONFIG_BBRAM is not set
    # Bluetooth HCI Driver Options
    # CONFIG_BT_H4 is not set
    # CONFIG_BT_H5 is not set
    CONFIG_BT_RPMSG=y
    # CONFIG_BT_SPI is not set
    # CONFIG_BT_STM32_IPM is not set
    # CONFIG_BT_ESP32 is not set
    # CONFIG_BT_B91 is not set
    # CONFIG_BT_PSOC6_BLESS is not set
    # CONFIG_BT_NO_DRIVER is not set
    CONFIG_BT_DRV_TX_STACK_SIZE=256
    CONFIG_BT_DRV_RX_STACK_SIZE=256
    # CONFIG_CACHE is not set
    # CONFIG_CAN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_OFF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_ERR is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_WRN is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_INF is not set
    # CONFIG_CLOCK_CONTROL_LOG_LEVEL_DBG is not set
    CONFIG_CLOCK_CONTROL_LOG_LEVEL_DEFAULT=y
    CONFIG_CLOCK_CONTROL_LOG_LEVEL=3
    CONFIG_CLOCK_CONTROL_NRF=y
    # CONFIG_CLOCK_CONTROL_NRF_SHELL is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_250PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_150PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_100PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_75PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_K32SRC_50PPM=y
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_30PPM is not set
    # CONFIG_CLOCK_CONTROL_NRF_K32SRC_20PPM is not set
    CONFIG_CLOCK_CONTROL_NRF_ACCURACY=50
    # CONFIG_CLOCK_CONTROL_FIXED_RATE_CLOCK is not set
    CONFIG_CONSOLE=y
    CONFIG_CONSOLE_INPUT_MAX_LINE_LEN=128
    CONFIG_CONSOLE_HAS_DRIVER=y
    # CONFIG_CONSOLE_HANDLER is not set
    CONFIG_CONSOLE_INIT_PRIORITY=60
    CONFIG_UART_CONSOLE=y
    # CONFIG_UART_CONSOLE_DEBUG_SERVER_HOOKS is not set
    # CONFIG_UART_CONSOLE_MCUMGR is not set
    # CONFIG_RAM_CONSOLE is not set
    # CONFIG_IPM_CONSOLE_SENDER is not set
    # CONFIG_IPM_CONSOLE_RECEIVER is not set
    # CONFIG_UART_MCUMGR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_OFF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_ERR is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_WRN is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_INF is not set
    # CONFIG_UART_CONSOLE_LOG_LEVEL_DBG is not set
    CONFIG_UART_CONSOLE_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_CONSOLE_LOG_LEVEL=3
    # CONFIG_GSM_MUX is not set
    # CONFIG_EFI_CONSOLE is not set
    # CONFIG_COREDUMP_DEVICE is not set
    # CONFIG_COUNTER is not set
    # CONFIG_CRYPTO is not set
    # CONFIG_DAC is not set
    # CONFIG_DAI is not set
    # CONFIG_DISK_DRIVER_RAM is not set
    # CONFIG_DISK_DRIVER_FLASH is not set
    CONFIG_SD_INIT_PRIORITY=90
    CONFIG_SDMMC_VOLUME_NAME="SD"
    # CONFIG_SDMMC_LOG_LEVEL_OFF is not set
    # CONFIG_SDMMC_LOG_LEVEL_ERR is not set
    # CONFIG_SDMMC_LOG_LEVEL_WRN is not set
    # CONFIG_SDMMC_LOG_LEVEL_INF is not set
    # CONFIG_SDMMC_LOG_LEVEL_DBG is not set
    CONFIG_SDMMC_LOG_LEVEL_DEFAULT=y
    CONFIG_SDMMC_LOG_LEVEL=3
    # CONFIG_DISK_DRIVER_MMC is not set
    # CONFIG_DISPLAY is not set
    # CONFIG_DMA is not set
    # CONFIG_EDAC is not set
    # CONFIG_EEPROM is not set
    # CONFIG_ESPI is not set
    # CONFIG_FPGA is not set
    # CONFIG_FUEL_GAUGE is not set
    # CONFIG_GPIO_LOG_LEVEL_OFF is not set
    # CONFIG_GPIO_LOG_LEVEL_ERR is not set
    # CONFIG_GPIO_LOG_LEVEL_WRN is not set
    # CONFIG_GPIO_LOG_LEVEL_INF is not set
    # CONFIG_GPIO_LOG_LEVEL_DBG is not set
    CONFIG_GPIO_LOG_LEVEL_DEFAULT=y
    CONFIG_GPIO_LOG_LEVEL=3
    # CONFIG_GPIO_SHELL is not set
    # CONFIG_GPIO_GET_DIRECTION is not set
    # CONFIG_GPIO_GET_CONFIG is not set
    CONFIG_GPIO_HOGS=y
    CONFIG_GPIO_HOGS_INIT_PRIORITY=41
    # CONFIG_GPIO_ENABLE_DISABLE_INTERRUPT is not set
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRFX_INTERRUPT=y
    # CONFIG_HWINFO is not set
    # CONFIG_I2C_SHELL is not set
    # CONFIG_I2C_DUMP_MESSAGES is not set
    # CONFIG_I2C_CALLBACK is not set
    # CONFIG_I2C_RTIO is not set
    CONFIG_I2C_TARGET=y
    CONFIG_I2C_TARGET_INIT_PRIORITY=60
    CONFIG_I2C_TARGET_BUFFER_MODE=y
    # CONFIG_I2C_EEPROM_TARGET is not set
    CONFIG_I2C_NRFX=y
    CONFIG_I2C_NRFX_TWIM=y
    CONFIG_I2C_NRFX_TRANSFER_TIMEOUT=500
    CONFIG_I2C_TARGET_IT8XXX2_MAX_BUF_SIZE=256
    CONFIG_I2C_INIT_PRIORITY=50
    # CONFIG_I2C_LOG_LEVEL_OFF is not set
    # CONFIG_I2C_LOG_LEVEL_ERR is not set
    # CONFIG_I2C_LOG_LEVEL_WRN is not set
    # CONFIG_I2C_LOG_LEVEL_INF is not set
    # CONFIG_I2C_LOG_LEVEL_DBG is not set
    CONFIG_I2C_LOG_LEVEL_DEFAULT=y
    CONFIG_I2C_LOG_LEVEL=3
    # CONFIG_I2S is not set
    # CONFIG_I3C is not set
    # CONFIG_SMBUS is not set
    # Interrupt controller drivers
    CONFIG_INTC_INIT_PRIORITY=40
    # CONFIG_INTC_LOG_LEVEL_OFF is not set
    # CONFIG_INTC_LOG_LEVEL_ERR is not set
    # CONFIG_INTC_LOG_LEVEL_WRN is not set
    # CONFIG_INTC_LOG_LEVEL_INF is not set
    # CONFIG_INTC_LOG_LEVEL_DBG is not set
    CONFIG_INTC_LOG_LEVEL_DEFAULT=y
    CONFIG_INTC_LOG_LEVEL=3
    # CONFIG_MULTI_LEVEL_INTERRUPTS is not set
    CONFIG_1ST_LEVEL_INTERRUPT_BITS=8
    CONFIG_2ND_LEVEL_INTERRUPT_BITS=8
    CONFIG_3RD_LEVEL_INTERRUPT_BITS=8
    # CONFIG_INTC_ESP32 is not set
    # CONFIG_PLIC_SUPPORTS_EDGE_IRQ is not set
    # end of Interrupt controller drivers
    # CONFIG_IPM is not set
    # CONFIG_KSCAN is not set
    # CONFIG_LED is not set
    # CONFIG_LED_STRIP is not set
    # CONFIG_LORA is not set
    CONFIG_MBOX=y
    CONFIG_MBOX_INIT_PRIORITY=40
    # CONFIG_MBOX_LOG_LEVEL_OFF is not set
    # CONFIG_MBOX_LOG_LEVEL_ERR is not set
    # CONFIG_MBOX_LOG_LEVEL_WRN is not set
    # CONFIG_MBOX_LOG_LEVEL_INF is not set
    # CONFIG_MBOX_LOG_LEVEL_DBG is not set
    CONFIG_MBOX_LOG_LEVEL_DEFAULT=y
    CONFIG_MBOX_LOG_LEVEL=3
    # CONFIG_MDIO is not set
    # CONFIG_MFD is not set
    # Miscellaneous Drivers
    # CONFIG_GROVE_LCD_RGB is not set
    # end of Miscellaneous Drivers
    # CONFIG_MM_DRV is not set
    # CONFIG_NEURAL_NET_ACCEL is not set
    # CONFIG_PCIE is not set
    # CONFIG_PCIE_ENDPOINT is not set
    # CONFIG_PECI is not set
    # CONFIG_PINCTRL_LOG_LEVEL_OFF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_ERR is not set
    # CONFIG_PINCTRL_LOG_LEVEL_WRN is not set
    # CONFIG_PINCTRL_LOG_LEVEL_INF is not set
    # CONFIG_PINCTRL_LOG_LEVEL_DBG is not set
    CONFIG_PINCTRL_LOG_LEVEL_DEFAULT=y
    CONFIG_PINCTRL_LOG_LEVEL=3
    CONFIG_PINCTRL_STORE_REG=y
    # CONFIG_PINCTRL_DYNAMIC is not set
    CONFIG_PINCTRL_NRF=y
    # CONFIG_PM_CPU_OPS is not set
    # CONFIG_POWER_DOMAIN is not set
    # CONFIG_PS2 is not set
    # CONFIG_PTP_CLOCK is not set
    CONFIG_PWM=y
    # CONFIG_PWM_LOG_LEVEL_OFF is not set
    # CONFIG_PWM_LOG_LEVEL_ERR is not set
    # CONFIG_PWM_LOG_LEVEL_WRN is not set
    # CONFIG_PWM_LOG_LEVEL_INF is not set
    # CONFIG_PWM_LOG_LEVEL_DBG is not set
    CONFIG_PWM_LOG_LEVEL_DEFAULT=y
    CONFIG_PWM_LOG_LEVEL=3
    CONFIG_PWM_INIT_PRIORITY=50
    CONFIG_PWM_SHELL=y
    # CONFIG_PWM_CAPTURE is not set
    CONFIG_PWM_NRFX=y
    CONFIG_REGULATOR_THREAD_SAFE_REFCNT=y
    CONFIG_REGULATOR_SHELL=y
    # CONFIG_REGULATOR_LOG_LEVEL_OFF is not set
    # CONFIG_REGULATOR_LOG_LEVEL_ERR is not set
    # CONFIG_REGULATOR_LOG_LEVEL_WRN is not set
    # CONFIG_REGULATOR_LOG_LEVEL_INF is not set
    # CONFIG_REGULATOR_LOG_LEVEL_DBG is not set
    CONFIG_REGULATOR_LOG_LEVEL_DEFAULT=y
    CONFIG_REGULATOR_LOG_LEVEL=3
    # CONFIG_RETAINED_MEM is not set
    # CONFIG_RTC is not set
    # CONFIG_SDHC is not set
    # CONFIG_SENSOR_LOG_LEVEL_OFF is not set
    # CONFIG_SENSOR_LOG_LEVEL_ERR is not set
    # CONFIG_SENSOR_LOG_LEVEL_WRN is not set
    # CONFIG_SENSOR_LOG_LEVEL_INF is not set
    # CONFIG_SENSOR_LOG_LEVEL_DBG is not set
    CONFIG_SENSOR_LOG_LEVEL_DEFAULT=y
    CONFIG_SENSOR_LOG_LEVEL=3
    CONFIG_SENSOR_INIT_PRIORITY=90
    CONFIG_SENSOR_ASYNC_API=y
    CONFIG_SENSOR_SHELL=y
    # CONFIG_SENSOR_SHELL_BATTERY is not set
    CONFIG_SENSOR_SHELL_TRIG_PRINT_TIMEOUT_MS=5000
    # CONFIG_SENSOR_INFO is not set
    # Device Drivers
    # CONFIG_ICM42688_DECODER is not set
    CONFIG_INA23X=y
    CONFIG_INA230=y
    # CONFIG_INA230_TRIGGER is not set
    CONFIG_VCMP_IT8XXX2_INIT_PRIORITY=90
    CONFIG_TMP112_FULL_SCALE_RUNTIME=y
    CONFIG_TMP112_SAMPLING_FREQUENCY_RUNTIME=y
    # Capabilities
    CONFIG_SERIAL_HAS_DRIVER=y
    CONFIG_SERIAL_SUPPORT_ASYNC=y
    CONFIG_SERIAL_SUPPORT_INTERRUPT=y
    # CONFIG_UART_LOG_LEVEL_OFF is not set
    # CONFIG_UART_LOG_LEVEL_ERR is not set
    # CONFIG_UART_LOG_LEVEL_WRN is not set
    # CONFIG_UART_LOG_LEVEL_INF is not set
    # CONFIG_UART_LOG_LEVEL_DBG is not set
    CONFIG_UART_LOG_LEVEL_DEFAULT=y
    CONFIG_UART_LOG_LEVEL=3
    CONFIG_UART_USE_RUNTIME_CONFIGURE=y
    CONFIG_UART_ASYNC_API=y
    # CONFIG_UART_LINE_CTRL is not set
    # CONFIG_UART_DRV_CMD is not set
    # CONFIG_UART_WIDE_DATA is not set
    # CONFIG_UART_PIPE is not set
    # Serial Drivers
    CONFIG_UART_NRFX=y
    CONFIG_UART_NRFX_UARTE=y
    CONFIG_UART_ASYNC_TX_CACHE_SIZE=8
    CONFIG_UART_0_ENHANCED_POLL_OUT=y
    CONFIG_UART_0_ASYNC=y
    # CONFIG_UART_0_NRF_PARITY_BIT is not set
    CONFIG_UART_0_NRF_TX_BUFFER_SIZE=32
    # CONFIG_UART_0_NRF_HW_ASYNC is not set
    # CONFIG_UART_0_NRF_ASYNC_LOW_POWER is not set
    CONFIG_UART_3_ASYNC=y
    CONFIG_UART_3_ENHANCED_POLL_OUT=y
    # CONFIG_UART_3_NRF_PARITY_BIT is not set
    CONFIG_UART_3_NRF_TX_BUFFER_SIZE=32
    # CONFIG_UART_3_NRF_HW_ASYNC is not set
    # CONFIG_UART_3_NRF_ASYNC_LOW_POWER is not set
    CONFIG_UART_ENHANCED_POLL_OUT=y
    CONFIG_SPI_ASYNC=y
    # CONFIG_SPI_RTIO is not set
    # CONFIG_SPI_SLAVE is not set
    # CONFIG_SPI_EXTENDED_MODES is not set
    CONFIG_SPI_INIT_PRIORITY=70
    CONFIG_SPI_COMPLETION_TIMEOUT_TOLERANCE=200
    # CONFIG_SPI_LOG_LEVEL_OFF is not set
    # CONFIG_SPI_LOG_LEVEL_ERR is not set
    # CONFIG_SPI_LOG_LEVEL_WRN is not set
    # CONFIG_SPI_LOG_LEVEL_INF is not set
    # CONFIG_SPI_LOG_LEVEL_DBG is not set
    CONFIG_SPI_LOG_LEVEL_DEFAULT=y
    CONFIG_SPI_LOG_LEVEL=3
    CONFIG_SPI_NRFX=y
    CONFIG_SPI_NRFX_SPIM=y
    CONFIG_SPI_NRFX_WAKE_TIMEOUT_US=200
    # CONFIG_SYSCON is not set
    # Timer drivers
    # CONFIG_TIMER_READS_ITS_FREQUENCY_AT_RUNTIME is not set
    # CONFIG_SYSTEM_CLOCK_SLOPPY_IDLE is not set
    CONFIG_SYSTEM_CLOCK_INIT_PRIORITY=0
    CONFIG_TICKLESS_CAPABLE=y
    CONFIG_SYSTEM_TIMER_HAS_DISABLE_SUPPORT=y
    # CONFIG_NRF_RTC_TIMER_TRIGGER_OVERFLOW is not set
    # CONFIG_SYSTEM_CLOCK_NO_WAIT is not set
    # CONFIG_SYSTEM_CLOCK_WAIT_FOR_AVAILABILITY is not set
    CONFIG_SYSTEM_CLOCK_WAIT_FOR_STABILITY=y
    # end of Timer drivers
    # CONFIG_USB_BC12 is not set
    # CONFIG_UDC_DRIVER is not set
    # CONFIG_UHC_DRIVER is not set
    # CONFIG_UVB is not set
    # CONFIG_USB_DEVICE_DRIVER is not set
    # CONFIG_USBC_TCPC_DRIVER is not set
    # CONFIG_USBC_LOG_LEVEL_OFF is not set
    # CONFIG_USBC_LOG_LEVEL_ERR is not set
    # CONFIG_USBC_LOG_LEVEL_WRN is not set
    # CONFIG_USBC_LOG_LEVEL_INF is not set
    # CONFIG_USBC_LOG_LEVEL_DBG is not set
    CONFIG_USBC_LOG_LEVEL_DEFAULT=y
    CONFIG_USBC_LOG_LEVEL=3
    # CONFIG_USBC_VBUS_DRIVER is not set
    # CONFIG_VIDEO is not set
    # CONFIG_VIRTUALIZATION is not set
    # CONFIG_W1 is not set
    # CONFIG_WDT_DISABLE_AT_BOOT is not set
    # CONFIG_WDT_LOG_LEVEL_OFF is not set
    # CONFIG_WDT_LOG_LEVEL_ERR is not set
    # CONFIG_WDT_LOG_LEVEL_WRN is not set
    # CONFIG_WDT_LOG_LEVEL_INF is not set
    # CONFIG_WDT_LOG_LEVEL_DBG is not set
    CONFIG_WDT_LOG_LEVEL_DEFAULT=y
    CONFIG_WDT_LOG_LEVEL=3
    CONFIG_WDT_NRFX=y
    CONFIG_WDT_SHELL=y
    # CONFIG_HWSPINLOCK is not set
    CONFIG_REQUIRES_FULL_LIBC=y
    CONFIG_FULL_LIBC_SUPPORTED=y
    CONFIG_MINIMAL_LIBC_SUPPORTED=y
    CONFIG_NEWLIB_LIBC_SUPPORTED=y
    CONFIG_PICOLIBC_SUPPORTED=y
    # C Library
    # CONFIG_PICOLIBC is not set
    CONFIG_NEWLIB_LIBC=y
    # CONFIG_EXTERNAL_LIBC is not set
    CONFIG_HAS_NEWLIB_LIBC_NANO=y
    CONFIG_COMMON_LIBC_ABORT=y
    # CONFIG_COMMON_LIBC_MALLOC is not set
    CONFIG_NEWLIB_LIBC_MIN_REQUIRED_HEAP_SIZE=2048
    # CONFIG_NEWLIB_LIBC_FLOAT_SCANF is not set
    # CONFIG_NEWLIB_LIBC_HEAP_LISTENER is not set
    CONFIG_STDOUT_CONSOLE=y
    # end of C Library
    # C++ Language Support
    # CONFIG_CPP is not set
    # Deprecated
    # CONFIG_CPLUSPLUS is not set
    # CONFIG_LIB_CPLUSPLUS is not set
    # end of Deprecated
    # end of C++ Language Support
    # CONFIG_CRC is not set
    # Additional libraries
    # Hash Function Support
    # CONFIG_SYS_HASH_FUNC32 is not set
    # end of Hash Function Support
    # Hashmap (Hash Table) Support
    # CONFIG_SYS_HASH_MAP is not set
    # end of Hashmap (Hash Table) Support
    # OS Support Library
    # CONFIG_JSON_LIBRARY is not set
    CONFIG_RING_BUFFER=y
    CONFIG_NOTIFY=y
    # CONFIG_BASE64 is not set
    # CONFIG_PRINTK_SYNC is not set
    CONFIG_MPSC_PBUF=y
    CONFIG_ONOFF=y
    # CONFIG_SPSC_PBUF is not set
    # CONFIG_SHARED_MULTI_HEAP is not set
    # CONFIG_WINSTREAM is not set
    # CONFIG_MPSC_CLEAR_ALLOCATED is not set
    CONFIG_HAS_POWEROFF=y
    # CONFIG_POWEROFF is not set
    CONFIG_CBPRINTF_COMPLETE=y
    # CONFIG_CBPRINTF_NANO is not set
    CONFIG_CBPRINTF_FULL_INTEGRAL=y
    # CONFIG_CBPRINTF_REDUCED_INTEGRAL is not set
    CONFIG_CBPRINTF_FP_SUPPORT=y
    # CONFIG_CBPRINTF_FP_A_SUPPORT is not set
    # CONFIG_CBPRINTF_FP_ALWAYS_A is not set
    CONFIG_CBPRINTF_N_SPECIFIER=y
    # CONFIG_CBPRINTF_LIBC_SUBSTS is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_OFF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_ERR is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_WRN is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_INF is not set
    # CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DBG is not set
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL_DEFAULT=y
    CONFIG_CBPRINTF_PACKAGE_LOG_LEVEL=3
    # CONFIG_CBPRINTF_PACKAGE_LONGDOUBLE is not set
    # Heap and Memory Allocation
    # CONFIG_SYS_HEAP_VALIDATE is not set
    CONFIG_SYS_HEAP_ALLOC_LOOPS=3
    # CONFIG_SYS_HEAP_RUNTIME_STATS is not set
    # CONFIG_SYS_HEAP_LISTENER is not set
    # CONFIG_SYS_HEAP_SMALL_ONLY is not set
    # CONFIG_SYS_HEAP_BIG_ONLY is not set
    CONFIG_SYS_HEAP_AUTO=y
    CONFIG_SYS_MEM_BLOCKS=y
    # CONFIG_SYS_MEM_BLOCKS_LISTENER is not set
    # CONFIG_SYS_MEM_BLOCKS_RUNTIME_STATS is not set
    # end of Heap and Memory Allocation
    # end of OS Support Library
    # CONFIG_POSIX_API is not set
    # CONFIG_POSIX_CLOCK is not set
    # CONFIG_EVENTFD is not set
    # CONFIG_FNMATCH is not set
    # CONFIG_POSIX_FS is not set
    # CONFIG_GETOPT_LONG is not set
    # CONFIG_POSIX_MQUEUE is not set
    CONFIG_SEM_VALUE_MAX=32767
    # CONFIG_POSIX_SIGNAL is not set
    # CONFIG_TIMER is not set
    CONFIG_MAX_TIMER_COUNT=5
    CONFIG_TIMER_CREATE_WAIT=100
    CONFIG_TIMER_DELAYTIMER_MAX=20
    # CONFIG_POSIX_UNAME is not set
    # CONFIG_OPENAMP_RSC_TABLE is not set
    # CONFIG_SMF is not set
    CONFIG_ACPI_HID_LEN_MAX=12
    CONFIG_LIBGCC_RTLIB=y
    # end of Additional libraries
    # Subsystems and OS Services
    CONFIG_BT_HCI=y
    # CONFIG_BT_CUSTOM is not set
    # CONFIG_BT_HCI_RAW is not set
    # CONFIG_BT_HCI_RAW_H4 is not set
    # CONFIG_BT_HCI_RAW_CMD_EXT is not set
    CONFIG_BT_CONN_TX=y
    # CONFIG_BT_PER_ADV_SYNC_TRANSFER_SENDER is not set
    # CONFIG_BT_SCA_UPDATE is not set
    CONFIG_BT_ISO=y
    # CONFIG_BT_ISO_PERIPHERAL is not set
    # CONFIG_BT_ISO_CENTRAL is not set
    CONFIG_BT_ISO_BROADCAST=y
    CONFIG_BT_ISO_TX_FRAG_COUNT=2
    CONFIG_BT_ISO_TX_MTU=251
    CONFIG_BT_ISO_RX_BUF_COUNT=1
    CONFIG_BT_ISO_RX_MTU=251
    # CONFIG_BT_ISO_ADVANCED is not set
    # Bluetooth buffer configuration
    # end of Bluetooth buffer configuration
    # Bluetooth Host
    # Published Audio Capabilities (PAC) options
    # end of Published Audio Capabilities (PAC) options
    # L2CAP Options
    # end of L2CAP Options
    # ATT and GATT Options
    # end of ATT and GATT Options
    # GATT Services
    # end of GATT Services
    # end of Bluetooth Host
    # CONFIG_BT_SHELL is not set
    # CONFIG_BT_EAD is not set
    CONFIG_BT_LOG=y
    # Bluetooth logging
    CONFIG_BT_LOG_LEGACY=y
    # Bluetooth legacy logging options
    # CONFIG_BT_DEBUG_HCI_DRIVER is not set
    # [DEPRECATED] Audio
    # CONFIG_BT_DEBUG_AICS is not set
    # CONFIG_BT_DEBUG_AICS_CLIENT is not set
    # CONFIG_BT_BAP_DEBUG_STREAM is not set
    # CONFIG_BT_DEBUG_BAP_BROADCAST_SOURCE is not set
    # CONFIG_BT_DEBUG_CAP_INITIATOR is not set
    # CONFIG_BT_DEBUG_CSIP_SET_MEMBER is not set
    # CONFIG_BT_DEBUG_CSIP_SET_COORDINATOR is not set
    # CONFIG_BT_DEBUG_HAS is not set
    # CONFIG_BT_DEBUG_MCS is not set
    # CONFIG_BT_DEBUG_MCC is not set
    # CONFIG_MCTL_DEBUG is not set
    # CONFIG_BT_DEBUG_MICP_MIC_DEV is not set
    # CONFIG_BT_DEBUG_MICP_MIC_CTLR is not set
    # CONFIG_BT_DEBUG_MPL is not set
    # CONFIG_BT_DEBUG_TBS is not set
    # CONFIG_BT_DEBUG_TBS_CLIENT is not set
    # CONFIG_BT_DEBUG_VCP_VOL_REND is not set
    # CONFIG_BT_DEBUG_VCP_VOL_CTLR is not set
    # CONFIG_BT_DEBUG_VOCS is not set
    # CONFIG_BT_DEBUG_VOCS_CLIENT is not set
    # end of [DEPRECATED] Audio
    # [DEPRECATED] Others
    # CONFIG_BT_DEBUG_ATT is not set
    # CONFIG_BT_DEBUG_GATT is not set
    # CONFIG_BT_DEBUG_L2CAP is not set
    # CONFIG_BT_DEBUG_DF is not set
    # CONFIG_BT_DEBUG_HCI_CORE is not set
    # CONFIG_BT_DEBUG_CONN is not set
    # CONFIG_BT_DEBUG_ISO is not set
    # CONFIG_BT_DEBUG_SERVICE is not set
    # end of [DEPRECATED] Others
    # [DEPRECATED] BR/EDR
    # end of [DEPRECATED] BR/EDR
    # [DEPRECATED] Mesh
    # CONFIG_BT_MESH_DEBUG is not set
    # CONFIG_BT_MESH_DEBUG_NET is not set
    # CONFIG_BT_MESH_DEBUG_RPL is not set
    # CONFIG_BT_MESH_DEBUG_TRANS is not set
    # CONFIG_BT_MESH_DEBUG_BEACON is not set
    # CONFIG_BT_MESH_DEBUG_CRYPTO is not set
    # CONFIG_BT_MESH_DEBUG_KEYS is not set
    # CONFIG_BT_MESH_DEBUG_PROV is not set
    # CONFIG_BT_MESH_DEBUG_PROVISIONER is not set
    # CONFIG_BT_MESH_DEBUG_PROV_DEVICE is not set
    # CONFIG_BT_MESH_DEBUG_ACCESS is not set
    # CONFIG_BT_MESH_DEBUG_MODEL is not set
    # CONFIG_BT_MESH_DEBUG_ADV is not set
    # CONFIG_BT_MESH_DEBUG_LOW_POWER is not set
    # CONFIG_BT_MESH_DEBUG_FRIEND is not set
    # CONFIG_BT_MESH_DEBUG_CFG is not set
    # end of [DEPRECATED] Mesh
    # [DEPRECATED] Services
    # CONFIG_BT_DEBUG_OTS_CLIENT is not set
    # end of [DEPRECATED] Services
    # end of Bluetooth legacy logging options
    # CONFIG_BT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_LOG_LEVEL_INF is not set
    # CONFIG_BT_LOG_LEVEL_DBG is not set
    CONFIG_BT_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL=3
    CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_DRIVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_RPA_LOG_LEVEL=3
    CONFIG_BT_RPA_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_RPA_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RPA_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RPA_LOG_LEVEL_INF is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RPA_LOG_LEVEL_DEFAULT is not set
    # Audio
    CONFIG_BT_AICS_LOG_LEVEL=3
    CONFIG_BT_AICS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AICS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AICS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AICS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AICS_LOG_LEVEL_INF is not set
    # CONFIG_BT_AICS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AICS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AICS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AICS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_STREAM_LOG_LEVEL=3
    CONFIG_BT_BAP_STREAM_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_STREAM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INHERIT=y
    CONFIG_BT_AUDIO_CODEC_LOG_LEVEL=3
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_INF is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AUDIO_CODEC_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ASCS_LOG_LEVEL=3
    CONFIG_BT_ASCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ASCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ASCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL=3
    CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_UNICAST_SERVER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL=3
    CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_UNICAST_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_SOURCE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_SINK_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL=3
    CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_SCAN_DELEGATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL=3
    CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_BROADCAST_ASSISTANT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_BAP_ISO_LOG_LEVEL_INHERIT=y
    CONFIG_BT_BAP_ISO_LOG_LEVEL=3
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_BAP_ISO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL=3
    CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_ACCEPTOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_INITIATOR_LOG_LEVEL=3
    CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_INITIATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CAP_STREAM_LOG_LEVEL_INHERIT=y
    CONFIG_BT_CAP_STREAM_LOG_LEVEL=3
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_INF is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CAP_STREAM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_MEMBER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_COORDINATOR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CSIP_SET_MEMBER_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HAS_LOG_LEVEL=3
    CONFIG_BT_HAS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_HAS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HAS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HAS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HAS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MCS_LOG_LEVEL=3
    CONFIG_BT_MCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MCC_LOG_LEVEL=3
    CONFIG_BT_MCC_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MCC_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MCC_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MCC_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MCC_LOG_LEVEL_INF is not set
    # CONFIG_BT_MCC_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MCC_LOG_LEVEL_DEFAULT is not set
    CONFIG_MCTL_LOG_LEVEL=3
    CONFIG_MCTL_LOG_LEVEL_INHERIT=y
    # CONFIG_MCTL_LOG_LEVEL_OFF is not set
    # CONFIG_MCTL_LOG_LEVEL_ERR is not set
    # CONFIG_MCTL_LOG_LEVEL_WRN is not set
    # CONFIG_MCTL_LOG_LEVEL_INF is not set
    # CONFIG_MCTL_LOG_LEVEL_DBG is not set
    # CONFIG_MCTL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL=3
    CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MICP_MIC_DEV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL=3
    CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_INF is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MICP_MIC_CTLR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MPL_LOG_LEVEL=3
    CONFIG_BT_MPL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MPL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_PACS_LOG_LEVEL=3
    CONFIG_BT_PACS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_PACS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_PACS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_PACS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_PACS_LOG_LEVEL_INF is not set
    # CONFIG_BT_PACS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_PACS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_TBS_LOG_LEVEL=3
    CONFIG_BT_TBS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_TBS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TBS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TBS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TBS_LOG_LEVEL_INF is not set
    # CONFIG_BT_TBS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TBS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_TBS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_TBS_CLIENT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VCP_VOL_REND_LOG_LEVEL=3
    CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_INF is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VCP_VOL_REND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL=3
    CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_INF is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VCP_VOL_CTLR_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VOCS_LOG_LEVEL=3
    CONFIG_BT_VOCS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VOCS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_INF is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VOCS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_VOCS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_VOCS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # end of Audio
    # Others
    CONFIG_BT_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ATT_LOG_LEVEL=3
    CONFIG_BT_ATT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_GATT_LOG_LEVEL=3
    CONFIG_BT_GATT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_GATT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_GATT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_GATT_LOG_LEVEL_INF is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_GATT_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_L2CAP_LOG_LEVEL=3
    CONFIG_BT_L2CAP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_L2CAP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_INF is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_L2CAP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_EAD_LOG_LEVEL_INHERIT=y
    CONFIG_BT_EAD_LOG_LEVEL=3
    # CONFIG_BT_EAD_LOG_LEVEL_OFF is not set
    # CONFIG_BT_EAD_LOG_LEVEL_ERR is not set
    # CONFIG_BT_EAD_LOG_LEVEL_WRN is not set
    # CONFIG_BT_EAD_LOG_LEVEL_INF is not set
    # CONFIG_BT_EAD_LOG_LEVEL_DBG is not set
    # CONFIG_BT_EAD_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_DF_LOG_LEVEL=3
    CONFIG_BT_DF_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_DF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_DF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_DF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_DF_LOG_LEVEL_INF is not set
    # CONFIG_BT_DF_LOG_LEVEL_DBG is not set
    # CONFIG_BT_DF_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SETTINGS_LOG_LEVEL=3
    CONFIG_BT_SETTINGS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL=2
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INHERIT is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_ERR is not set
    CONFIG_BT_HCI_CORE_LOG_LEVEL_WRN=y
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_INF is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HCI_CORE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CONN_LOG_LEVEL=3
    CONFIG_BT_CONN_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CONN_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CONN_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CONN_LOG_LEVEL_INF is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CONN_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_ISO_LOG_LEVEL=3
    CONFIG_BT_ISO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_ISO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_ISO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_ISO_LOG_LEVEL_INF is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_ISO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_KEYS_LOG_LEVEL=3
    CONFIG_BT_KEYS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SMP_LOG_LEVEL=3
    CONFIG_BT_SMP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SMP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SMP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SMP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SMP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SERVICE_LOG_LEVEL=3
    CONFIG_BT_SERVICE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SERVICE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_CTLR_ISOAL_LOG_LEVEL=3
    CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_INF is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_CTLR_ISOAL_LOG_LEVEL_DEFAULT is not set
    # end of Others
    # BR/EDR
    CONFIG_BT_RFCOMM_LOG_LEVEL=3
    CONFIG_BT_RFCOMM_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_RFCOMM_LOG_LEVEL_OFF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_ERR is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_WRN is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_INF is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DBG is not set
    # CONFIG_BT_RFCOMM_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_HFP_HF_LOG_LEVEL=3
    CONFIG_BT_HFP_HF_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_HFP_HF_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_INF is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DBG is not set
    # CONFIG_BT_HFP_HF_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_AVDTP_LOG_LEVEL=3
    CONFIG_BT_AVDTP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_AVDTP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_INF is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_AVDTP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_A2DP_LOG_LEVEL=3
    CONFIG_BT_A2DP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_A2DP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_INF is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_A2DP_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_SDP_LOG_LEVEL=3
    CONFIG_BT_SDP_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_SDP_LOG_LEVEL_OFF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_ERR is not set
    # CONFIG_BT_SDP_LOG_LEVEL_WRN is not set
    # CONFIG_BT_SDP_LOG_LEVEL_INF is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DBG is not set
    # CONFIG_BT_SDP_LOG_LEVEL_DEFAULT is not set
    # end of BR/EDR
    # Mesh
    CONFIG_BT_MESH_LOG_LEVEL=3
    CONFIG_BT_MESH_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_NET_LOG_LEVEL=3
    CONFIG_BT_MESH_NET_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_NET_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_NET_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_RPL_LOG_LEVEL=3
    CONFIG_BT_MESH_RPL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_RPL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_TRANS_LOG_LEVEL=3
    CONFIG_BT_MESH_TRANS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_TRANS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_BEACON_LOG_LEVEL=3
    CONFIG_BT_MESH_BEACON_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_BEACON_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL=3
    CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CRYPTO_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_KEYS_LOG_LEVEL=3
    CONFIG_BT_MESH_KEYS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_KEYS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROV_LOG_LEVEL=3
    CONFIG_BT_MESH_PROV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL=3
    CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROVISIONER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL=3
    CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROV_DEVICE_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL=3
    CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ACCESS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_MODEL_LOG_LEVEL=3
    CONFIG_BT_MESH_MODEL_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_MODEL_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_DFU_LOG_LEVEL=3
    CONFIG_BT_MESH_DFU_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_DFU_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_ADV_LOG_LEVEL=3
    CONFIG_BT_MESH_ADV_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_ADV_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL=3
    CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_LOW_POWER_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL=3
    CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_FRIEND_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_PROXY_LOG_LEVEL=3
    CONFIG_BT_MESH_PROXY_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_PROXY_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL=3
    CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_SETTINGS_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CDB_LOG_LEVEL=3
    CONFIG_BT_MESH_CDB_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CDB_LOG_LEVEL_DEFAULT is not set
    CONFIG_BT_MESH_CFG_LOG_LEVEL=3
    CONFIG_BT_MESH_CFG_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_OFF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_ERR is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_WRN is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_INF is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DBG is not set
    # CONFIG_BT_MESH_CFG_LOG_LEVEL_DEFAULT is not set
    # end of Mesh
    # Services
    # CONFIG_BT_BAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_BAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_BAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_BAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_BAS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_BAS_LOG_LEVEL=3
    # CONFIG_BT_HRS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_HRS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_HRS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_HRS_LOG_LEVEL_INF is not set
    # CONFIG_BT_HRS_LOG_LEVEL_DBG is not set
    CONFIG_BT_HRS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_HRS_LOG_LEVEL=3
    # CONFIG_BT_TPS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_TPS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_TPS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_TPS_LOG_LEVEL_INF is not set
    # CONFIG_BT_TPS_LOG_LEVEL_DBG is not set
    CONFIG_BT_TPS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_TPS_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_IAS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_IAS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_IAS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_IAS_LOG_LEVEL_INF is not set
    # CONFIG_BT_IAS_LOG_LEVEL_DBG is not set
    CONFIG_BT_IAS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_IAS_LOG_LEVEL=3
    CONFIG_BT_OTS_CLIENT_LOG_LEVEL=3
    CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INHERIT=y
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_OFF is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_ERR is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_WRN is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_INF is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_DBG is not set
    # CONFIG_BT_OTS_CLIENT_LOG_LEVEL_DEFAULT is not set
    # CONFIG_BT_OTS_LOG_LEVEL_OFF is not set
    # CONFIG_BT_OTS_LOG_LEVEL_ERR is not set
    # CONFIG_BT_OTS_LOG_LEVEL_WRN is not set
    # CONFIG_BT_OTS_LOG_LEVEL_INF is not set
    # CONFIG_BT_OTS_LOG_LEVEL_DBG is not set
    CONFIG_BT_OTS_LOG_LEVEL_DEFAULT=y
    CONFIG_BT_OTS_LOG_LEVEL=3
    # end of Services
    # end of Bluetooth logging
    CONFIG_BT_COMPANY_ID=0x05F1
    # Controller Area Network (CAN) bus subsystem
    # CONFIG_ISOTP is not set
    # end of Controller Area Network (CAN) bus subsystem
    # CONFIG_CONSOLE_SUBSYS is not set
    # System Monitoring Options
    # CONFIG_THREAD_ANALYZER is not set
    # end of System Monitoring Options
    # Debugging Options
    CONFIG_DEBUG=y
    CONFIG_STACK_USAGE=y
    CONFIG_STACK_SENTINEL=y
    CONFIG_PRINTK=y
    CONFIG_EARLY_CONSOLE=y
    # CONFIG_ASSERT is not set
    # CONFIG_FORCE_NO_ASSERT is not set
    CONFIG_ASSERT_VERBOSE=y
    # CONFIG_ASSERT_NO_FILE_INFO is not set
    # CONFIG_ASSERT_NO_COND_INFO is not set
    # CONFIG_ASSERT_NO_MSG_INFO is not set
    # CONFIG_ASSERT_TEST is not set
    # CONFIG_OVERRIDE_FRAME_POINTER_DEFAULT is not set
    CONFIG_DEBUG_INFO=y
    CONFIG_EXCEPTION_STACK_TRACE=y
    CONFIG_DEBUG_THREAD_INFO=y
    # CONFIG_DEBUG_COREDUMP is not set
    # end of Debugging Options
    CONFIG_DISK_ACCESS=y
    # CONFIG_DISK_LOG_LEVEL_OFF is not set
    # CONFIG_DISK_LOG_LEVEL_ERR is not set
    # CONFIG_DISK_LOG_LEVEL_WRN is not set
    # CONFIG_DISK_LOG_LEVEL_INF is not set
    # CONFIG_DISK_LOG_LEVEL_DBG is not set
    CONFIG_DISK_LOG_LEVEL_DEFAULT=y
    CONFIG_DISK_LOG_LEVEL=3
    # CONFIG_DSP is not set
    # CONFIG_EMUL is not set
    # CONFIG_CHARACTER_FRAMEBUFFER is not set
    # File Systems
    # CONFIG_FS_LOG_LEVEL_OFF is not set
    # CONFIG_FS_LOG_LEVEL_ERR is not set
    # CONFIG_FS_LOG_LEVEL_WRN is not set
    # CONFIG_FS_LOG_LEVEL_INF is not set
    # CONFIG_FS_LOG_LEVEL_DBG is not set
    CONFIG_FS_LOG_LEVEL_DEFAULT=y
    CONFIG_FS_LOG_LEVEL=3
    CONFIG_APP_LINK_WITH_FS=y
    CONFIG_FILE_SYSTEM_MAX_TYPES=2
    CONFIG_FILE_SYSTEM_MAX_FILE_NAME=-1
    # CONFIG_FILE_SYSTEM_SHELL is not set
    # CONFIG_FILE_SYSTEM_MKFS is not set
    # ELM FAT file system settings
    # CONFIG_FS_FATFS_READ_ONLY is not set
    CONFIG_FS_FATFS_MKFS=y
    CONFIG_FS_FATFS_MOUNT_MKFS=y
    CONFIG_FS_FATFS_MAX_ROOT_ENTRIES=512
    CONFIG_FS_FATFS_NUM_FILES=4
    CONFIG_FS_FATFS_NUM_DIRS=4
    # CONFIG_FS_FATFS_LFN_MODE_BSS is not set
    CONFIG_FS_FATFS_LFN_MODE_STACK=y
    # CONFIG_FS_FATFS_LFN_MODE_HEAP is not set
    CONFIG_FS_FATFS_FF_USE_LFN=2
    CONFIG_FS_FATFS_CODEPAGE=437
    CONFIG_FS_FATFS_MAX_SS=512
    CONFIG_FS_FATFS_MIN_SS=512
    CONFIG_FS_FATFS_WINDOW_ALIGNMENT=1
    # CONFIG_FS_FATFS_REENTRANT is not set
    # end of ELM FAT file system settings
    # CONFIG_FILE_SYSTEM_LITTLEFS is not set
    # CONFIG_FILE_SYSTEM_EXT2 is not set
    # CONFIG_EXT2_LOG_LEVEL_OFF is not set
    # CONFIG_EXT2_LOG_LEVEL_ERR is not set
    # CONFIG_EXT2_LOG_LEVEL_WRN is not set
    # CONFIG_EXT2_LOG_LEVEL_INF is not set
    # CONFIG_EXT2_LOG_LEVEL_DBG is not set
    CONFIG_EXT2_LOG_LEVEL_DEFAULT=y
    CONFIG_EXT2_LOG_LEVEL=3
    # end of File Systems
    # Inter Processor Communication
    # CONFIG_RPMSG_SERVICE is not set
    CONFIG_IPC_SERVICE=y
    CONFIG_IPC_SERVICE_REG_BACKEND_PRIORITY=46
    CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_WQ_STACK_SIZE=1024
    CONFIG_IPC_SERVICE_BACKEND_RPMSG_NUM_ENDPOINTS_PER_INSTANCE=2
    CONFIG_IPC_SERVICE_RPMSG=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS=y
    CONFIG_IPC_SERVICE_STATIC_VRINGS_MEM_ALIGNMENT=4
    # CONFIG_IPC_SERVICE_ICMSG is not set
    # CONFIG_IPC_SERVICE_ICMSG_ME is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_OFF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_ERR is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_WRN is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_INF is not set
    # CONFIG_IPC_SERVICE_LOG_LEVEL_DBG is not set
    CONFIG_IPC_SERVICE_LOG_LEVEL_DEFAULT=y
    CONFIG_IPC_SERVICE_LOG_LEVEL=3
    # end of Inter Processor Communication
    # CONFIG_JWT is not set
    # Logging
    CONFIG_LOG=y
    CONFIG_LOG_CORE_INIT_PRIORITY=0
    CONFIG_LOG_MODE_DEFERRED=y
    # CONFIG_LOG_MODE_IMMEDIATE is not set
    # CONFIG_LOG_MODE_MINIMAL is not set
    # CONFIG_LOG_FRONTEND is not set
    # CONFIG_LOG_CUSTOM_HEADER is not set
    # CONFIG_LOG_MULTIDOMAIN is not set
    # Logging levels filtering
    CONFIG_LOG_RUNTIME_FILTERING=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_LOG_OVERRIDE_LEVEL=0
    CONFIG_LOG_MAX_LEVEL=4
    # end of Logging levels filtering
    # Processing
    CONFIG_LOG_PRINTK=y
    CONFIG_LOG_MODE_OVERFLOW=y
    # CONFIG_LOG_BLOCK_IN_THREAD is not set
    CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=10
    CONFIG_LOG_PROCESS_THREAD=y
    CONFIG_LOG_PROCESS_THREAD_STARTUP_DELAY_MS=0
    CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=1000
    CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=768
    # CONFIG_LOG_PROCESS_THREAD_CUSTOM_PRIORITY is not set
    CONFIG_LOG_TRACE_SHORT_TIMESTAMP=y
    # CONFIG_LOG_TIMESTAMP_64BIT is not set
    # CONFIG_LOG_SPEED is not set
    # end of Processing
    # Output Formatting
    # Prepend non-hexdump log message with function name
    # CONFIG_LOG_FUNC_NAME_PREFIX_ERR is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_WRN is not set
    # CONFIG_LOG_FUNC_NAME_PREFIX_INF is not set
    CONFIG_LOG_FUNC_NAME_PREFIX_DBG=y
    # end of Prepend non-hexdump log message with function name
    # CONFIG_LOG_MIPI_SYST_ENABLE is not set
    # CONFIG_LOG_THREAD_ID_PREFIX is not set
    # CONFIG_LOG_CUSTOM_FORMAT_SUPPORT is not set
    CONFIG_LOG_BACKEND_SHOW_COLOR=y
    # CONFIG_LOG_INFO_COLOR_GREEN is not set
    CONFIG_LOG_TAG_MAX_LEN=2
    CONFIG_LOG_TAG_DEFAULT="--"
    CONFIG_LOG_BACKEND_FORMAT_TIMESTAMP=y
    # CONFIG_LOG_OUTPUT_FORMAT_LINUX_TIMESTAMP is not set
    # CONFIG_LOG_OUTPUT_FORMAT_CUSTOM_TIMESTAMP is not set
    # end of Output Formatting
    # Backends
    # CONFIG_LOG_BACKEND_FS is not set
    # CONFIG_LOG_BACKEND_SWO is not set
    CONFIG_LOG_BACKEND_UART=y
    # CONFIG_LOG_BACKEND_UART_ASYNC is not set
    CONFIG_LOG_BACKEND_UART_BUFFER_SIZE=1
    CONFIG_LOG_BACKEND_UART_AUTOSTART=y
    CONFIG_LOG_BACKEND_UART_OUTPUT_TEXT=y
    # CONFIG_LOG_BACKEND_UART_OUTPUT_DICTIONARY is not set
    # CONFIG_LOG_BACKEND_UART_OUTPUT_CUSTOM is not set
    CONFIG_LOG_BACKEND_UART_OUTPUT_DEFAULT=0
    # CONFIG_LOG_BACKEND_IPC_SERVICE is not set
    # end of Backends
    # Misc
    CONFIG_LOG_DOMAIN_ID=0
    CONFIG_LOG_CMDS=y
    CONFIG_LOG_USE_VLA=y
    # CONFIG_LOG_ALWAYS_RUNTIME is not set
    # CONFIG_LOG_FMT_SECTION is not set
    # CONFIG_LOG_USE_TAGGED_ARGUMENTS is not set
    CONFIG_LOG_MEM_UTILIZATION=y
    CONFIG_LOG_FAILURE_REPORT_PERIOD=1000
    # end of Misc
    CONFIG_LOG_OUTPUT=y
    # end of Logging
    # Device Management
    # Host command handler subsystem
    # CONFIG_EC_HOST_CMD is not set
    # end of Host command handler subsystem
    # CONFIG_OSDP is not set
    # end of Device Management
    # CONFIG_MODBUS is not set
    # CONFIG_MODEM_MODULES is not set
    # Networking
    # CONFIG_NET_BUF_LOG is not set
    # CONFIG_NET_BUF_LOG_LEVEL_OFF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_ERR is not set
    # CONFIG_NET_BUF_LOG_LEVEL_WRN is not set
    # CONFIG_NET_BUF_LOG_LEVEL_INF is not set
    # CONFIG_NET_BUF_LOG_LEVEL_DBG is not set
    CONFIG_NET_BUF_LOG_LEVEL_DEFAULT=y
    CONFIG_NET_BUF_LOG_LEVEL=3
    # CONFIG_NET_BUF_POOL_USAGE is not set
    # CONFIG_NETWORKING is not set
    # end of Networking
    # Power Management
    # end of Power Management
    # Portability
    # end of Portability
    # Random Number Generators
    # CONFIG_TEST_RANDOM_GENERATOR is not set
    # end of Random Number Generators
    CONFIG_RTIO=y
    CONFIG_RTIO_EXECUTOR_SIMPLE=y
    CONFIG_RTIO_EXECUTOR_CONCURRENT=y
    # CONFIG_RTIO_SUBMIT_SEM is not set
    # CONFIG_RTIO_CONSUME_SEM is not set
    CONFIG_RTIO_SYS_MEM_BLOCKS=y
    # CONFIG_RTIO_LOG_LEVEL_OFF is not set
    # CONFIG_RTIO_LOG_LEVEL_ERR is not set
    # CONFIG_RTIO_LOG_LEVEL_WRN is not set
    # CONFIG_RTIO_LOG_LEVEL_INF is not set
    # CONFIG_RTIO_LOG_LEVEL_DBG is not set
    CONFIG_RTIO_LOG_LEVEL_DEFAULT=y
    CONFIG_RTIO_LOG_LEVEL=3
    # SD
    # CONFIG_MMC_STACK is not set
    # CONFIG_SDMMC_STACK is not set
    # CONFIG_SDIO_STACK is not set
    # end of SD
    CONFIG_SHELL=y
    # CONFIG_SHELL_LOG_LEVEL_OFF is not set
    # CONFIG_SHELL_LOG_LEVEL_ERR is not set
    # CONFIG_SHELL_LOG_LEVEL_WRN is not set
    # CONFIG_SHELL_LOG_LEVEL_INF is not set
    # CONFIG_SHELL_LOG_LEVEL_DBG is not set
    CONFIG_SHELL_LOG_LEVEL_DEFAULT=y
    CONFIG_SHELL_LOG_LEVEL=3
    CONFIG_SHELL_BACKENDS=y
    # CONFIG_SHELL_BACKEND_SERIAL is not set
    # CONFIG_SHELL_BACKEND_DUMMY is not set
    # CONFIG_SHELL_MINIMAL is not set
    # CONFIG_SHELL_THREAD_PRIORITY_OVERRIDE is not set
    CONFIG_SHELL_STACK_SIZE=1024
    CONFIG_SHELL_BACKSPACE_MODE_DELETE=y
    CONFIG_SHELL_CMD_BUFF_SIZE=128
    CONFIG_SHELL_PRINTF_BUFF_SIZE=30
    CONFIG_SHELL_DEFAULT_TERMINAL_WIDTH=80
    CONFIG_SHELL_DEFAULT_TERMINAL_HEIGHT=24
    CONFIG_SHELL_ARGC_MAX=20
    CONFIG_SHELL_TAB=y
    CONFIG_SHELL_TAB_AUTOCOMPLETION=y
    CONFIG_SHELL_ASCII_FILTER=y
    # CONFIG_SHELL_WILDCARD is not set
    CONFIG_SHELL_ECHO_STATUS=y
    # CONFIG_SHELL_START_OBSCURED is not set
    CONFIG_SHELL_VT100_COMMANDS=y
    CONFIG_SHELL_VT100_COLORS=y
    # CONFIG_SHELL_GETOPT is not set
    CONFIG_SHELL_METAKEYS=y
    CONFIG_SHELL_HELP=y
    CONFIG_SHELL_HELP_OPT_PARSE=y
    # CONFIG_SHELL_HELP_ON_WRONG_ARGUMENT_COUNT is not set
    CONFIG_SHELL_HISTORY=y
    CONFIG_SHELL_HISTORY_BUFFER=512
    # CONFIG_SHELL_STATS is not set
    # CONFIG_SHELL_CMDS is not set
    CONFIG_SHELL_CMD_ROOT=""
    CONFIG_SHELL_LOG_BACKEND=y
    CONFIG_SHELL_LOG_FORMAT_TIMESTAMP=y
    CONFIG_SHELL_AUTOSTART=y
    CONFIG_KERNEL_SHELL=y
    CONFIG_KERNEL_SHELL_REBOOT_DELAY=0
    # CONFIG_DEVICE_SHELL is not set
    CONFIG_DEVMEM_SHELL=y
    # Storage
    # end of Storage
    CONFIG_TASK_WDT_CHANNELS=5
    CONFIG_TASK_WDT_HW_FALLBACK=y
    CONFIG_TASK_WDT_MIN_TIMEOUT=100
    # Testing
    # CONFIG_ZTEST is not set
    # CONFIG_ZTEST_MOCKING is not set
    # CONFIG_ZTRESS is not set
    # CONFIG_TEST is not set
    CONFIG_COVERAGE_GCOV_HEAP_SIZE=16384
    # CONFIG_TEST_USERSPACE is not set
    # end of Testing
    # CONFIG_TIMING_FUNCTIONS is not set
    # CONFIG_TRACING is not set
    # CONFIG_USB_DEVICE_STACK_NEXT is not set
    # CONFIG_USB_HOST_STACK is not set
    # CONFIG_USBC_STACK is not set
    CONFIG_ZBUS_CHANNELS_SYS_INIT_PRIORITY=5
    # CONFIG_ZBUS_CHANNEL_NAME is not set
    # CONFIG_ZBUS_OBSERVER_NAME is not set
    # CONFIG_ZBUS_ASSERT_MOCK is not set
    # CONFIG_ZBUS_LOG_LEVEL_OFF is not set
    # CONFIG_ZBUS_LOG_LEVEL_ERR is not set
    # CONFIG_ZBUS_LOG_LEVEL_WRN is not set
    # CONFIG_ZBUS_LOG_LEVEL_INF is not set
    # CONFIG_ZBUS_LOG_LEVEL_DBG is not set
    CONFIG_ZBUS_LOG_LEVEL_DEFAULT=y
    CONFIG_ZBUS_LOG_LEVEL=3
    # end of Subsystems and OS Services
    CONFIG_TOOLCHAIN_ZEPHYR_0_16=y
    CONFIG_TOOLCHAIN_ZEPHYR_SUPPORTS_THREAD_LOCAL_STORAGE=y
    # Build and Link Features
    # Linker Options
    # CONFIG_LINKER_ORPHAN_SECTION_PLACE is not set
    CONFIG_LINKER_ORPHAN_SECTION_WARN=y
    # CONFIG_LINKER_ORPHAN_SECTION_ERROR is not set
    CONFIG_HAS_FLASH_LOAD_OFFSET=y
    CONFIG_LD_LINKER_SCRIPT_SUPPORTED=y
    CONFIG_LD_LINKER_TEMPLATE=y
    # CONFIG_CMAKE_LINKER_GENERATOR is not set
    # CONFIG_HAVE_CUSTOM_LINKER_SCRIPT is not set
    CONFIG_KERNEL_ENTRY="__start"
    CONFIG_LINKER_SORT_BY_ALIGNMENT=y
    CONFIG_SRAM_OFFSET=0
    # Linker Sections
    # CONFIG_LINKER_USE_BOOT_SECTION is not set
    # CONFIG_LINKER_USE_PINNED_SECTION is not set
    CONFIG_LINKER_GENERIC_SECTIONS_PRESENT_AT_BOOT=y
    CONFIG_LINKER_LAST_SECTION_ID=y
    CONFIG_LINKER_LAST_SECTION_ID_PATTERN=0xE015E015
    CONFIG_LINKER_USE_RELAX=y
    # end of Linker Sections
    # end of Linker Options
    # Compiler Options
    # CONFIG_CODING_GUIDELINE_CHECK is not set
    # CONFIG_COMPILER_FREESTANDING is not set
    # CONFIG_SIZE_OPTIMIZATIONS is not set
    CONFIG_SPEED_OPTIMIZATIONS=y
    # CONFIG_DEBUG_OPTIMIZATIONS is not set
    # CONFIG_NO_OPTIMIZATIONS is not set
    # CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # CONFIG_COMPILER_SAVE_TEMPS is not set
    CONFIG_COMPILER_TRACK_MACRO_EXPANSION=y
    CONFIG_COMPILER_COLOR_DIAGNOSTICS=y
    # CONFIG_FORTIFY_SOURCE_NONE is not set
    CONFIG_FORTIFY_SOURCE_COMPILE_TIME=y
    # CONFIG_FORTIFY_SOURCE_RUN_TIME is not set
    CONFIG_COMPILER_OPT=""
    # CONFIG_MISRA_SANE is not set
    # end of Compiler Options
    # CONFIG_ASSERT_ON_ERRORS is not set
    # CONFIG_NO_RUNTIME_CHECKS is not set
    CONFIG_RUNTIME_ERROR_CHECKS=y
    # Build Options
    CONFIG_KERNEL_BIN_NAME="zephyr"
    CONFIG_OUTPUT_STAT=y
    # CONFIG_OUTPUT_SYMBOLS is not set
    # CONFIG_OUTPUT_DISASSEMBLY is not set
    CONFIG_OUTPUT_PRINT_MEMORY_USAGE=y
    # CONFIG_CLEANUP_INTERMEDIATE_FILES is not set
    # CONFIG_BUILD_NO_GAP_FILL is not set
    # CONFIG_BUILD_OUTPUT_EXE is not set
    # CONFIG_BUILD_OUTPUT_S19 is not set
    # CONFIG_BUILD_OUTPUT_UF2 is not set
    # CONFIG_BUILD_OUTPUT_STRIPPED is not set
    # CONFIG_BUILD_ALIGN_LMA is not set
    # CONFIG_APPLICATION_DEFINED_SYSCALL is not set
    # CONFIG_MAKEFILE_EXPORTS is not set
    # CONFIG_BUILD_OUTPUT_META is not set
    CONFIG_BUILD_OUTPUT_STRIP_PATHS=y
    CONFIG_CHECK_INIT_PRIORITIES=y
    # CONFIG_CHECK_INIT_PRIORITIES_FAIL_ON_WARNING is not set
    # CONFIG_EMIT_ALL_SYSCALLS is not set
    # end of Build Options
    CONFIG_DEPRECATED=y
    CONFIG_WARN_DEPRECATED=y
    CONFIG_EXPERIMENTAL=y
    CONFIG_ENFORCE_ZEPHYR_STDINT=y
    # end of Build and Link Features
    # Boot Options
    # CONFIG_IS_BOOTLOADER is not set
    # CONFIG_BOOTLOADER_BOSSA is not set
    # end of Boot Options
    # Compatibility
    CONFIG_COMPAT_INCLUDES=y
    # end of Compatibility
    The ESP is also on this board, with a UART connection between the Nordic and the ESP32.
    Yes I am able to make a central connection to the two buds, but then I start to get audio breakups.  I have also noticed audio breakups in a couple of drivers where we use K_Timers as callbacks to do work.  This never occurred with the 2.1.2 SDK, but now do with the 2.5.2
    Please be specific when you describe the problem you are seeing - what is it that you start that causes the audio breakups?
    In the log you have previously shared it seems that you might be running out of memory for your broadcaster - could you double your CONFIG_AUDIO_DATAPATH_STACK_SIZE and see if that makes any difference in the issue?
    Is your logger reporting underruns when this occurs? What kind of processing are you doing in the callbacks - is it anything CPU intensive or time consuming, like flash writes for instance?
    Since we last spoke we have updated the project to use the SoftDevice Controller as default, instead of the LE Audio Controller, on the ncs main. Could you re-try this with the project based on ncs-main (or the v2.6.0-rc1 tag), to see if you still see the issue then?
    Karl
  • You can close this.  Will open new tickets as necessary.  Thanks.
  • Alright - please do not hesitate to open another ticket if you should encounter any other issues or questions in the future! :)
    Karl
