nRF52840
NCS v2.5.0
We are using the nRF52840 for our application. The application uses PWM for it's buzzer, a PWM for it's LEDs, and also uses two uarts, a spi, and an I2C. We've run into an issue where when UART0 is being used there are odd spikes in the data lines. For example, the UART data will look fine but each time the line goes low we can see >10 small spikes on the line. It looks a lot like cross talk but we can't find anything and we've had it working fine at other times. In addition, the spikes have an extremely regular and precise period. Finally, occasionally the UART works great, and in this case I the buzzer starts clicking and doesn't work right anymore. This leads me to believe that there is some interaction between PWM0 and UART0? I'm not sure and we have spent a while on this one.
I can send oscilloscope captures if needed.
Thanks so much for your reply,
Nathan
