DFU not working for Nrf52840 DK using onboard external flash
Hi Team,
I want to do the firmware upgrade during bootup the system. Currently New Image is transferred from another BLE device and stored on the External Flash. During Bootup, MCUBoot has to check the Image available on External flash and update the firmware if it is valid Image. Using nrf connect SDK v2.5.0.
I have configured the Prj.conf file as
CONFIG_SERIAL=y
CONFIG_UART_ASYNC_API=y
#Enable MCUBOOT bootloader build in the application
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_FLASH=y
CONFIG_SPI=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_DEVICE_NAME="BLE"
CONFIG_BT_DEVICE_APPEARANCE=1282
CONFIG_BT_SMP=y
CONFIG_BT_SETTINGS=y
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_DK_LIBRARY=y
CONFIG_BT_SMP_APP_PAIRING_ACCEPT=y
CONFIG_BT_SMP_ALLOW_UNAUTH_OVERWRITE=y
# RTC
CONFIG_NRFX_RTC2=y
CONFIG_COUNTER=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_USER_PHY_UPDATE=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_BUF_ACL_RX_SIZE=2004
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_L2CAP_TX_BUF_COUNT=10
CONFIG_BT_L2CAP_TX_MTU=2000
CONFIG_BT_L2CAP_DYNAMIC_CHANNEL=y
CONFIG_BT_CONN_TX_MAX=10
CONFIG_BT_BUF_ACL_TX_COUNT=10
CONFIG_BT_BUF_ACL_TX_SIZE=2004
CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
CONFIG_BT_CTLR_PHY_2M=y
CONFIG_BT_CTLR_RX_BUFFERS=2
CONFIG_BT_CTLR_SDC_MAX_CONN_EVENT_LEN_DEFAULT=4000000
# Disable notes and warnings
CONFIG_LOG_MODE_MINIMAL=y
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
mcuboot.conf
CONFIG_SPI_NOR=y
CONFIG_BOOT_MAX_IMG_SECTORS=256
CONFIG_BOOT_VALIDATE_SLOT0=n
CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
CONFIG_MULTITHREADING=y
nrf52849dk_nfr52840.overlay (placed same folder of proj.conf)
chosen {
nordic,pm-ext-flash = &mx25r64;
py_static.yaml
EMPTY_0:
address: 0xfe000
end_address: 0x100000
placement:
after:
- settings_storage
region: flash_primary
app:
address: 0x10200
end_address: 0xfc000
external_flash:
address: 0x0
end_address: 0x800000
region: external_flash
littlefs_storage:
address: 0x0
device: w25q64
filesystem: littlefs
placement:
before:
- end
mcuboot:
address: 0x0
placement:
before:
- mcuboot_primary
mcuboot_pad:
address: 0x10000
end_address: 0x10200
placement:
align:
start: 0x4000
before:
- mcuboot_primary_app
mcuboot_primary:
address: 0x10000
orig_span: &id001
- app
- mcuboot_pad
span: *id001
mcuboot_primary_app:
address: 0x10200
orig_span: &id002
- app
span: *id002
mcuboot_secondary:
address: 0x1000000
device: DT_CHOSEN(nordic_pm_ext_flash)
end_address: 0x10ec000
placement:
align:
start: 0x4
share_size:
- mcuboot_primary
otp:
address: 0xff8100
end_address: 0xff83fc
region: otp
pcd_sram:
address: 0x20000000
end_address: 0x20002000
placement:
after:
- start
region: sram_primary
rpmsg_nrf53_sram:
address: 0x20070000
end_address: 0x20080000
placement:
before:
- end
settings_storage:
address: 0xfc000
end_address: 0xfe000
placement:
align:
start: 0x4000
before:
- end
sram_primary:
address: 0x20002000
end_address: 0x20070000
Bootloader is not able to do the firmware upgrade after system reset. Following message are printed on terminal.
*** Booting nRF Connect SDK v2.5.0 ***
I: Starting bootloader
W: Failed reading sectors; BOOT_MAX_IMG_SECTORS=256 - too small?
W: Cannot upgrade: not a compatible amount of sectors
I: Bootloader chainload address offset: 0xc000
Please help to resolve the issue.
