I have the following problem.
I have a custom board where I have BMI270 connected with SPI.
I use the nrfx_spim library.
I get error codes as a success when I try to write and read to SPI, however, I always get 0x00.
So I assume the problem has to be with the configuration of the hardware. The board is professionally made by a manufacturer, so the problem is not here, but rather in my configuration.
Here is my dts file part with the configuration for SPI, I tried using BMI270 predefined profile, and also manually, but none of them worked for me.
On my board connections are:
BMI270 SDO/MISO -> P0.20
BMI270 SDI/MOSI -> P0.22
BMI270 SCK -> P0.24
BMI270 CS -> P1.00
&gpio0 { status = "okay"; }; &gpio1 { status = "okay"; }; &spi1 { status = "okay"; bmi270@0 { compatible = "bosch,bmi270"; reg = <0>; spi-max-frequency = <DT_FREQ_M(10)>; }; pinctrl-0 = <&spi1_default>; pinctrl-names = "default"; cs-gpios = <&gpio1 0 (GPIO_ACTIVE_LOW)>; // P1.00 as CS, active low }; &pinctrl { spi1_default: spi1_default { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 24)>, <NRF_PSEL(SPIM_MOSI, 0, 22)>, <NRF_PSEL(SPIM_MISO, 0, 20)>; }; }; };
I also tried enabling and disabling those CONFIG flags
CONFIG_SPI=y CONFIG_BMI270=y
and finally my main.c looks like this
#include <zephyr/kernel.h> #include "SEGGER_RTT.h" #include "SEGGER_RTT_printf.c" #include "nrfx_spim.h" // SPI instance index. You can have multiple instances for different peripherals. #define SPI_INSTANCE_ID 0 #define SPI_CS_PIN 32 // Create an SPI configuration structure nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG( NRF_GPIO_PIN_MAP(0, 24), // SCK pin NRF_GPIO_PIN_MAP(0, 22), // MOSI pin NRF_GPIO_PIN_MAP(0, 20), // MISO pin NRF_GPIO_PIN_MAP(1, 0) // CS pin ); nrfx_spim_t spi_instance = NRFX_SPIM_INSTANCE(SPI_INSTANCE_ID); void spi_write(uint8_t *data, size_t length) { nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TX(data, length); nrfx_spim_xfer(&spi_instance, &xfer_desc, 0); } void spi_read(uint8_t *command, size_t command_length, uint8_t *response, size_t response_length) { nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(command, command_length, response, response_length); nrfx_spim_xfer(&spi_instance, &xfer_desc, 0); } static uint8_t bmi270_read_register(uint8_t reg_addr) { // Assuming the sensor uses single-byte addresses uint8_t tx_buf[] = {0x80 | 0x00, 0x00}; // 0x80 for read, followed by dummy byte uint8_t rx_buf[2] = {0}; // Prepare transfer nrfx_spim_xfer_desc_t xfer_desc_tx = NRFX_SPIM_XFER_TX(tx_buf, sizeof(tx_buf)); nrfx_spim_xfer_desc_t xfer_desc_rx = NRFX_SPIM_XFER_RX(rx_buf, sizeof(rx_buf)); // Transfer nrfx_err_t err_code = nrfx_spim_xfer(&spi_instance, &xfer_desc_tx, 0); if (err_code != NRFX_SUCCESS) { // Initialization failed SEGGER_RTT_WriteString(0, "Sending failed!\n"); return -1; } else { SEGGER_RTT_WriteString(0, "Sending has been done successfully!\n"); } k_sleep(K_MSEC(2000)); err_code = nrfx_spim_xfer(&spi_instance, &xfer_desc_rx, 0); if (err_code != NRFX_SUCCESS) { // Initialization failed SEGGER_RTT_WriteString(0, "Reading failed!\n"); return -1; } else { SEGGER_RTT_WriteString(0, "Reading has been done successfully!\n"); } // The received data is in rx_buf[1] return rx_buf[1]; } int main(void) { nrfx_err_t err_code = nrfx_spim_init(&spi_instance, &spi_config, NULL, NULL); if (err_code != NRFX_SUCCESS) { // Initialization failed SEGGER_RTT_WriteString(0, "SPI init failed!\n"); return -1; } else { SEGGER_RTT_WriteString(0, "SPI init performed successfully!\n"); } uint8_t data_buffer_from_SPI = bmi270_read_register(0x00); //for(int i = 0; i < sizeof(data_buffer_from_SPI); i++) //{ SEGGER_RTT_printf(0, "BMI270 data0: 0x%02X\n", data_buffer_from_SPI); //} }
Everything looks good when checking error codes.
More from my trial and error:
-it didn't work below 125kH as it is not supported, so I got this exception
-when I added the CONFIG_SENSOR=y flag it didn't want to build
I think that's what I have now, I am pretty sure I have a problem with hardware configuration, but I don't know where.
When I ran this application on the nRF52840 DK board, I got the same output, even though there are no SPI devices connected, but the write and read were fine just 0xFF as well.
Thank you for any help :D
