Unable to Flash Blinky
I just got started with the nRF5340 DK.  I went through the example which instructs how to load the "Blinky" applications, build it, and then flash it to the Board.
Everything works except for flashing it to the board.  I get the following error:
* Executing task: nRF Connect: Build: blinky/build (active)
Building blinky
west build --build-dir c:/nordic/myapps/blinky/build c:/nordic/myapps/blinky
[0/16] Performing build step for 'tfm'
ninja: no work to do.
* Terminal will be reused by tasks, press any key to close it.
* Executing task: nRF Connect: Flash: blinky/build (active)
Flashing build to 1050099720
west flash -d c:\nordic\myapps\blinky\build --skip-rebuild --dev-id 1050099720
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: c:\nordic\myapps\blinky\build\zephyr\merged.hex
ERROR: No debuggers were discovered.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 41: nrfjprog --program 'c:\nordic\myapps\blinky\build\zephyr\merged.hex' --sectorerase --verify -f NRF53 --coprocessor CP_APPLICATION --snr 1050099720
* The terminal process terminated with exit code: 41.
  • On one hand, I'm very glad to hear that the same process worked for you, too. If you upgrade to 7.94k as I did, does it continue working? It did for me.
    On the other hand, I'm hoping Nordic can shed some light on WHY this would be a problem at all, especially if you were using the J-Link installed by the Command Line Tools. That's a problem, especially for a beginner.
    In case it matters, the onboard firmware on my DKs was from fall 2022. After all my tinkering and getting everything working, I upgraded the DKs to the latest J-Link firmware (2023-10-30). Everything still working.
    Looking forward to hearing what Nordic thinks happened here. Really hoping they can reproduce the problem to investigate it fully.
  • I had the same issue going through the nRF Connect SDK Fundamentals course.
    I had installed J-Link 7.96g and got the error "ERROR: No debuggers were discovered."
    I ran nrfjprog -i and saw no devices connected
    Uninstalled J-Link and installed 7.88j and the device showed up and I was able to flash.
    Uninstalled J-Link and reinstalled latest and the device still shows up. Something missing in that later version I guess.
    Gonna leave a note in the course feedback.
  • I had an identical experience as robbsadler. New laptop.  Issue was resolved by rolling back to J-link v7.88.  Also uninstalled v7.88 and re-installed 7.96h.  Issue remained solved.
    Seems like a pattern.
  • I had the same issue and resolved it by installing J-link v7.88. Definitely a pattern.
  • I had a problem with the 7.94e that got installed automatically with the nRF Command Line Tools install.  I went to segger.com and download the latest Jlink software and documentation pack (7.96I as of this post).  All of sudden my nRF5340DK Jlink shows up in the JLink Configurator.  So I guess it was a driver issue with the older version of Jlink.  Now it's working.
