Hi Support team,
I met NET_EVENT_L4_CONNECTED timeout sometimes when I used the Zephyr cellular modem driver(Ublox R4 modem) on net-core of the nRF5340 to communicate with the network.
Most of the time communication can be successful. but when the NET_EVENT_L4_CONNECTED can not be received, what's the best solution to reconnect to the network? Could you give some guidance on this?
I tried several ways, but none of them worked well, and some fatal errors occurred in the thread 'net_mgmt'.
After powering on the modem, and bringing up the net-interface, most of the time the NET_EVENT_L4_CONNECTED can be received. When it can not be received and the net_mgmt_event_wait_on_iface() time out, I tried different ways:
1. Reset net-interface, and wait for NET_EVENT_L4_CONNECTED again:
rc = net_if_down(iface); rc = net_if_up(iface);
Result: There was a MPU FAULT when did net_if_up() and the system reset, After resetting system, can get the NET_EVENT_L4_CONNECTED, and then works well.
[00:02:00.503,051] <err> mqtttest: [mqtt_sure_connect] L4 was not connected in time, try again rc = -116 [00:02:02.003,387] <err> os: ***** MPU FAULT ***** [00:02:02.003,417] <err> os: Instruction Access Violation [00:02:02.003,448] <err> os: r0/a1: 0x21007920 r1/a2: 0xd0010004 r2/a3: 0x210017b4 [00:02:02.003,448] <err> os: r3/a4: 0x21003604 r12/ip: 0xaaaaaaaa r14/lr: 0x0100e8a9 [00:02:02.003,479] <err> os: xpsr: 0x20000000 [00:02:02.003,479] <err> os: Faulting instruction address (r15/pc): 0x21003604 [00:02:02.003,509] <err> os: >>> ZEPHYR FATAL ERROR 20: Unknown error on CPU 0 [00:02:02.003,570] <err> os: Current thread: 0x210026f0 (net_mgmt) [00:02:02.332,794] <err> fatal_error: Resetting system
2. Repower the modem, and wait for NET_EVENT_L4_CONNECTED again:
pm_device_action_run(modem, PM_DEVICE_ACTION_SUSPEND); pm_device_action_run(modem, PM_DEVICE_ACTION_RESUME);
Result: It will be timeout forever, and the NET_EVENT_L4_CONNECTED can NOT be received after many tries.
3. Repower the modem and reset the net-interface, and wait for NET_EVENT_L4_CONNECTED again:
net_if_down(iface); pm_device_action_run(modem, PM_DEVICE_ACTION_SUSPEND); pm_device_action_run(modem, PM_DEVICE_ACTION_RESUME); net_if_up(iface);
Result: There was a 'BUS FAULT' or an 'Unaligned memory access' when did net_if_up() and the system reset. After one or two resettings, can get the NET_EVENT_L4_CONNECTED, and then works well.
(3.1)
[00:02:09.267,974] <err> os: ***** USAGE FAULT ***** [00:02:09.268,005] <err> os: Unaligned memory access [00:02:09.268,035] <err> os: r0/a1: 0x00000101 r1/a2: 0x00000103 r2/a3: 0x210017b4 [00:02:09.268,035] <err> os: r3/a4: 0xd0010004 r12/ip: 0xaaaaaaaa r14/lr: 0x0100e8e7 [00:02:09.268,066] <err> os: xpsr: 0xa1000000 [00:02:09.268,066] <err> os: Faulting instruction address (r15/pc): 0x0100e966 [00:02:09.268,127] <err> os: >>> ZEPHYR FATAL ERROR 31: Unknown error on CPU 0 [00:02:09.268,157] <err> os: Current thread: 0x210026f0 (net_mgmt) [00:02:09.665,588] <err> fatal_error: Resetting system
(3.2)
[00:02:00.761,108] <err> mqtttest: [mqtt_sure_connect] L4 was not connected in time, try again rc = -116 [00:02:01.261,260] <err> os: ***** BUS FAULT ***** [00:02:01.261,260] <err> os: Precise data bus error [00:02:01.261,291] <err> os: BFAR Address: 0x260100 [00:02:01.261,291] <err> os: r0/a1: 0x00000027 r1/a2: 0x00000027 r2/a3: 0x00260100 [00:02:01.261,322] <err> os: r3/a4: 0xd0010003 r12/ip: 0xaaaaaaaa r14/lr: 0x0100e8bb [00:02:01.261,322] <err> os: xpsr: 0x21000000 [00:02:01.261,352] <err> os: Faulting instruction address (r15/pc): 0x0100e93a [00:02:01.261,383] <err> os: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0 [00:02:01.261,413] <err> os: Current thread: 0x210026f0 (net_mgmt) [00:02:01.657,073] <err> fatal_error: Resetting system
Yanpeng Wu
