Add open-source drivers/libraries to projects using CMake and ExternalProject_Add()
Hi
I have been studying the nRF Connect SDK and taking the courses at Nordic Dev Academy. In the Zephyr Fundamentals course, as I don't have the sensors used in lesson 6 about I2C, I decided to use the sensors I have with me: the BNO055 IMU sensor.
But I'm also trying to dig even deeper and explore CMake at the same time.
I solve the exercise using the Bosch BNO055 IMU sensor, but I believe this question applies to any type of open-source library that I want to integrate into my projects. First, I downloaded the bno055.c and bno055.h files from the Bosch BNO055 IMU sensor github repository, added the files to my project directory and in the main.c file I included the header file:
#include "bno055.h"
I then integrated the bno055 driver into my project using functions from the Zephyr I2C API such as i2c_write(), i2c_read(), and i2c_write_read(). I was able to build the project without any problems and flash my nRF52840DK.
However, I want to set up a build system using the CMakeLists.txt file to make sure I can download and integrate the sensor files at build time and thus ensure that the project is always tracking the sensor's github repository. This is important in situations where the library has a bug fix or some improvement and automatically the project is updated with the new improvements in the next build process.
So, for this I configured the following CMakeLists.txt file:
make_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(my_project)
# Add your application source files
target_sources(app PRIVATE src/main.c)
# Include ExternalProject module
include(ExternalProject)
# Set the directory where the external project will be downloaded and built
set(EXTERNAL_INSTALL_LOCATION ${CMAKE_BINARY_DIR}/external)
# Define the ExternalProject for the external repository
    BNO055_driver
    PREFIX ${EXTERNAL_INSTALL_LOCATION}/BNO055_driver
    GIT_REPOSITORY "https://github.com/boschsensortec/BNO055_driver.git"
    GIT_TAG master
    UPDATE_COMMAND ""  # Skip update step
    CONFIGURE_COMMAND ""  # Skip configure step
    BUILD_COMMAND ""  # Skip build step
    INSTALL_COMMAND ""  # Skip install step
# Get the source directory of the external project
ExternalProject_Get_Property(BNO055_driver SOURCE_DIR)
# Include the directory containing the header file
include_directories(${SOURCE_DIR})
# Optionally, you can add a dependency on the external project to ensure it's built before your application
add_dependencies(app BNO055_driver)
When I build the project, the build system is able to download the files from the github repository to my laptop but then the build system stops and have the following error:
-- Configuring done (4.4s)
-- Generating done (0.1s)
-- Build files have been written to: /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build
[1/183] Preparing syscall dependency handling
[4/183] Generating include/generated/version.h
-- Zephyr version: 3.3.99 (/opt/nordic/ncs/v2.4.0/zephyr), build: v3.3.99-ncs1
[159/183] Performing download step (git clone) for 'BNO055_driver'
Cloning into 'BNO055_driver'...
Already on 'master'
Your branch is up to date with 'origin/master'.
[173/183] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr/zephyr_pre0.map
: && ccache /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc  -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/soc/arm/nordic_nrf/nrf52/libsoc__arm__nordic_nrf__nrf52.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/i2c/libdrivers__i2c.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  modules/segger/libmodules__segger.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v7e-m/nofp"  -L/Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -mcpu=cortex-m4  -mthumb  -mabi=aapcs  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  -Wl,-no-pie  /opt/nordic/ncs/v2.4.0/nrfxlib/crypto/nrf_cc310_platform/lib/cortex-m4/soft-float/no-interrupts/libnrf_cc310_platform_0.9.17.a && cd /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr && /opt/homebrew/Cellar/cmake/3.26.3/bin/cmake -E echo
/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(main.c.obj): in function `main':
/Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/src/main.c:35: undefined reference to `bno055_init'
collect2: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake --build /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build
Bellow you can see the directory of main.c and the directory where the CMake download the bno055.c and bno55.h files:
fund_less6_exer1_exer2/fund_less6_exer2/build/external/BNO055_driver/src/BNO055_driver/bno055.h
fund_less6_exer1_exer2/fund_less6_exer2/build/external/BNO055_driver/src/BNO055_driver/bno055.c
    With this line in CMake:
    You are placing it in your build-folder/external/ with the folder structure as explained in the cmake documentation:
    https://cmake.org/cmake/help/latest/module/ExternalProject.html#directory-options
    To point to that specific folder, based on the documentation provided here:
    https://cmake.org/cmake/help/latest/module/ExternalProject.html#obtaining-project-properties
    You should add this as the include dir:
    zephyr_include_directories(${SOURCE_DIR})
    Håkon
  • Hi
    Thanks for your response. Unfortunately, adding the instructions you suggested didn't solve the problem.
    The error looks the same:
    -- west build: making build dir /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build pristine
    -- Application: /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2
    -- CMake version: 3.26.3
    -- Using NCS Toolchain 2.4.0 for building. (/opt/nordic/ncs/toolchains/4ef6631da0/cmake)
    -- Found Python3: /opt/nordic/ncs/toolchains/4ef6631da0/bin/python3 (found suitable exact version "3.9.6") found components: Interpreter
    -- Cache files will be written to: /Users/my_user/Library/Caches/zephyr
    -- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
    -- Board: nrf52840dk_nrf52840
    -- Found host-tools: zephyr 0.16.0 (/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.0 (/opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk)
    -- Found Dtc: /opt/nordic/ncs/toolchains/4ef6631da0/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
    -- Found BOARD.dts: /opt/nordic/ncs/v2.4.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
    -- Found devicetree overlay: /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/nrf52840dk_nrf52840.overlay
    -- Generated zephyr.dts: /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr/dts.cmake
    Parsing /opt/nordic/ncs/v2.4.0/zephyr/Kconfig
    Loaded configuration '/opt/nordic/ncs/v2.4.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
    Merged configuration '/Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/prj.conf'
    Configuration saved to '/Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr/.config'
    Kconfig header saved to '/Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
    -- Found assembler: /opt/nordic/ncs/toolchains/4ef6631da0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    CMake Warning at /opt/nordic/ncs/v2.4.0/zephyr/CMakeLists.txt:838 (message):
      No SOURCES given to Zephyr library: lib__libc__common
      Excluding target from build.
    -- Configuring done (5.0s)
    [63/183] Performing download step (git clone) for 'BNO055_driver'
    Already on 'master'
  • You'll need to add the c-file manually as well. Try something like this:
    target_sources(app PRIVATE ${SOURCE_DIR}/bno055.c)
    Håkon
  • I just follow your suggestion and the error now is different:
    CMake Error at /opt/nordic/ncs/v2.4.0/zephyr/cmake/modules/extensions.cmake:424 (add_library):
      Cannot find source file:
        /Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build/external/BNO055_driver/src/BNO055_driver/bno055.c
      /opt/nordic/ncs/v2.4.0/zephyr/cmake/modules/kernel.cmake:210 (zephyr_library_named)
      /opt/nordic/ncs/v2.4.0/zephyr/cmake/modules/zephyr_default.cmake:124 (include)
      /opt/nordic/ncs/v2.4.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      /opt/nordic/ncs/v2.4.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
      CMakeLists.txt:2 (find_package)
    CMake Generate step failed.  Build files cannot be regenerated correctly.
    FATAL ERROR: command exited with status 1: /opt/homebrew/bin/cmake -DWEST_PYTHON=/opt/nordic/ncs/toolchains/4ef6631da0/opt/[email protected]/bin/python3.9 -B/Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2/build -GNinja -DBOARD=nrf52840dk_nrf52840 -S/Users/my_user/Documents/Projects/nRFConnectSDK-ZephyrRTOS-Fundamentals/fund_less6_exer1_exer2/fund_less6_exer2
    Where did you place the line in CMakeLists.txt?
    Can you share your full .txt file?
    Håkon
