Hi experts,
I need nrf51822 to send thousands of packets (notification) to Master Control Panel (PC), and expect for high data rate. So, I turned the connection interval from 100 ms to 20 ms in Master Control Panel. Unfortunately, the connection is broken after about 5 seconds. Everything is ok if the connection interval is 100ms.
my device configuration is like
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(10, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(200, UNIT_1_25_MS)
#define SLAVE_LATENCY 10
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(5000, UNIT_10_MS)
It seems the reason of timeout is I can't send packets as soon as possible. While the connection interval is 20 ms, the actual data rate is about 30 packets per seconds. The low data rate should be because I need read data from SPI Flash for sending.
I'm very confused why it happened. If I didn't send any notification, the connection was always on; but it timeout if I sent notification not fast enough.
Wondering for your help!
