I have a strange problem and don't know how to solve it.
We use a nRF52840 (with SDK15.3), at this a TMP117 is connected by TWI. As the temperature is measured only every 2 seconds the power of the TMP117 is switched on and off at the begin and at the end of the function.
The configuration of the TMP117 shall start the conversion and make 8 measures, each takes 15,5 ms. So after 124 ms the job is done and the nRF52840 could read the result. The strange thing is: When powering, configuring and starting the measurement at the TMP117 I use a nrf_delay of 140 ms and want to read the measured value. Now I have a strange behaviour: With this delay I read out a perfect temperature, only while the delay the supply current increases by at least 500 µA. With a longer delay this increase is even more. When eliminating this delay of course the TMP117 has not already valid values, so I read 0 - but no current increase. What can I do to read out good sensor values without current increase?
Unfortunately I can't deliver a oscillogram; due to space limitations at the PCB and the footprints of the TMP117 and the used module containing the nRF52840 I have no access to SCL or SDA...
Thanks for any good idea...
matthK
The function is realized like this:
#ifdef TMP117_SENSOR
Enable_Vcc_Temp(); // switch on Vcc for TMP117
#ifdef I2C_BUS_ACTIVE
Enable_TWI_Pull_Up(); // Configure SCL and SDA P0->DIR as input, Conf = 0x60C for SDA and SCL
twi_init_and_enable();
NRF_LOG_INFO("TWI init done");
TMP117_set_mode();
nrf_delay_ms(140);
if (bProblemAtTWIBus == false)
read_temp_sensor_data();
// while(!NRF_TWIM1->EVENTS_RXDREADY){}; // necessary for Power down
NRF_TWIM1->TASKS_STOP = 1;
twi_disable();
twi_uninit();
Disable_TWI_Pull_Up();
Disable_Vcc_Temp();
*(volatile uint32_t *)0x40004FFC = 0; // workaround from Nordic for erratum 89
*(volatile uint32_t *)0x40004FFC; // workaround from Nordic for erratum 89
*(volatile uint32_t *)0x40004FFC = 1; // workaround from Nordic for erratum 89
