Proxy Settings for nRF Connect SDK 4.4.0
I stuck with installing Toolchain Manager (and some other components) behind a Proxy from inside a newly installed nRF Connect SDK 4.4.0.
Unfortunately I do not know where and how to set "--detect-proxy" or HTTP_PROXY environment (see error message below).
The target of the link inside documentation sends me to a non existing page (404)
This is the error message
Unable to install downloadable app.
Show technical details
Error: Failed with exit code 1.
Failed to bootstrap core functionality before executing command.
HTTP request to default bootstrap resource
  raw.githubusercontent.com/.../
master/bootstrap.json
failed.
Please check that your internet connection is functioning. If you use a proxy,
please try the --detect-proxy flag or manually set the appropriate HTTP_PROXY-
style environment variable(s).
To use a custom bootstrap config, set NRFUTIL_BOOTSTRAP_CONFIG_URL.
To bootstrap directly from a nrfutil-core package tarball, set
NRFUTIL_BOOTSTRAP_TARBALL_PATH.
Caused by:
    0: error sending request for url (raw.githubusercontent.com/.../bootstrap.json): error trying to connect: proxy authentication required
    1: error trying to connect: proxy authentication required
    2: proxy authentication required.
