LTE Modem log configuration
Hi there,
I need to collect modem logs to investigate LTE-M connectivity issues in specific countries.
I have been using the command AT%XMODEMTRACE=1,2 to activate them and I am using Wireshark to visualize them.
I am limited in the amount of data I am able to collect and I would like to reduce the verbosity of the logs to the following subset : AT, NAS-EPS, LTE RRC, IP (actually I would need to only collect the traces that can be viewed with Wireshark).
The documentation about the AT%XMODEMTRACE command advises to connect with the support team in order to use the <bitmap_id> and <bitmap> fields and there is no documentation about these fields.
Can you advise me what parameters I should use to limit to the logs to the subset mentioned above ?
Thanks a lot,
Yann
  • Hi Yannick,
    Håkon is out for Easter vacation and I am handling your case now.
    I have just forwarded your questions to our modem team and will provide you an update later. There might be some delay due to Easter holiday.
    Could you further explain why you are limited in the amount of data you can collect? Do you use flash as modem trace backend?
    Charlie
  • Hi Yann.P,
    Could you try the following configurations? It figures out this bit_map configuration is heavily related to our modem source codes. We are not able to provide more details to explain the configuration. Our modem team provides the bit_maps configuration according to your request now.
    AT%XMODEMTRACE=2,,4,"06"
    AT%XMODEMTRACE=2,,0,"00000000000000000000f00000000000"
    AT%XMODEMTRACE=2,,3,"000000000000000000000000002004000000000000a001000000000000000000000000000000000000"
    Please let me know if it works as expected on your setup. Feel free to contact if you need more help.
    Charlie
  • Thank you very much Charlie.
    I will test that and will keep you updated.
    And to answer your first question : yes, we redirect modem trace to an external flash to be able to analyse them at the end of our roaming tests.
    Thanks again
    Yannick
  • Hello   !
    I have been able to successfully test the commands you gave me.
    It works really great to reduce the size of the modem logs, so thank you very much.
    The configuration is almost perfect but I would also like to have the IP traffic and the AT commands in the modem logs.
    Would it be possible to have a new set of command to have almost the same configuration but that would add IP traffic and AT command to the modem logs ?
    Thank you very much,
    Yannick
  • Hi Yannick,
    Thanks for the feedback. Please try the following commands, which will add AT and at least some IP traces.
    peer buffers: AT%XMODEMTRACE=2,,4,"06"
    buffers: AT%XMODEMTRACE=2,,0,"00000000000000000000f00000000000"
    trace groups:AT%XMODEMTRACE=2,,3,"000000000000000000000000002004100300000000a001e00100000000000000000000000000"
    Charlie
