LTE Modem log configuration
Hi there,
I need to collect modem logs to investigate LTE-M connectivity issues in specific countries.
I have been using the command AT%XMODEMTRACE=1,2 to activate them and I am using Wireshark to visualize them.
I am limited in the amount of data I am able to collect and I would like to reduce the verbosity of the logs to the following subset : AT, NAS-EPS, LTE RRC, IP (actually I would need to only collect the traces that can be viewed with Wireshark).
The documentation about the AT%XMODEMTRACE command advises to connect with the support team in order to use the <bitmap_id> and <bitmap> fields and there is no documentation about these fields.
Can you advise me what parameters I should use to limit to the logs to the subset mentioned above ?
Thanks a lot,
Yann
