Disconnection procedure after LL conn. parameter update leads to supervision timeout
Hi all
We use the nRF51822 with the S130 V1.0.0 in the peripheral role and a Galaxy S5 in the central role. As soon as the S5 connects to the nRF, we send a connection parameter update request (L2CAP) to the S5 for increasing the communication speed. This request is accepted by the S5 and it sends afterwards the corresponding LL connection update request with an Instant value of 0x0011.
Now it happens sometimes, that we have to close the connection before the new connection parameters take effect (before the instant). The nRF sends the LL_TERMINATE_IND packet and waits for the BLE_GAP_EVT_DISCONNECTED event. But this event occurs first after the supervision timeout has expired (7000ms).
With a BLE sniffer I can see that the S5 sends an empty PDU after the LL_TERMINATE_IND which confirms the connection termination procedure. Therefore I don't see any reason why the disconnected event doesn't occur immediately.
When our application doesn't send the connection parameter update request after connection establishment, the BLE_GAP_EVT_DISCONNECTED event occurs right after the nRF has sent the LL_TERMINATE_IND packet.
Does anyone know this behavior?
EDIT: Added sniffer trace from Frontline BPA sniffer. supervision_timeout_at_disconnect.zip
EDIT: Another sniffer trace in which the last try was successful. supervision_timeout_at_disconnect_S5_2.zip
EDIT: Added sniffer trace in which the connection is terminated before the instant. disconnect_successful_S5.zip
Kind regards
  • Hi Remo,
    I tried many different scenarios here but non of them showed the issue you were having. You can have a look at the trace attached here (using Nordic sniffer ), you can use Wireshark to open (you need to run Nordic sniffer to install the plugin)
    You can find that the advertising started right after the LL_TERMINATE_IND packet, suggesting that the Disconnected event was received right after packet.
    trace_PUpdate_Disconnect.pcapng
  • Hi Hung.
    I think it depends on when the LL_TERMINATE_IND is sent and when the new connection parameters would by applied. I added a new sniffer trace in which the nRF sends the LL_TERMINATE_IND packet two connection intervals before the Instant. In this case the BLE_GAP_EVT_DISCONNECTED event occurs right afterwards.
    So far, I tested following cases (the Instant was always 0x0011):
    • nRF sends LL_TERMINATE_IND in connection event 15 -> Good
    • nRF sends LL_TERMINATE_IND in connection event 16 -> Fail
    • nRF sends LL_TERMINATE_IND in connection event 17 -> Good
    Can you please try to terminate the connection two intervals before the instant and check if you can reproduce it?
    Kind regards
  • Hi Hung.
    Kind regards
