SDK v2.5.99-dev1 has many compile errors
I am working on a Mac mini, Apple M2 chipset, macOS Sonoma 14.2.1.   I am using Visual Studio Code Version: 1.86.2 (Universal) Commit: 903b1e9d8990623e3d7da1df3d33db3e42d80eda
Date: 2024-02-13T19:42:13.651Z Electron: 27.2.3 ElectronBuildId: 26908389 Chromium: 118.0.5993.159 Node.js: 18.17.1 V8: 11.8.172.18-electron.0 OS: Darwin arm64 23.2.0
I have been developing code on the nRF52840 DK for several months using SDK v2.5.0.   I recently downloaded SDK v2.5.99-dev1
After successfully building with SDK v2.5.0, I remove the build directory, change the active SDK to 2.5.99-dev1, create a new Build configuration (the same way I did for v2.5.0 SDK), and then build.   I get many compile errors like this:
../../../../../../../opt/nordic/ncs/v2.5.99-dev1/modules/lib/matter/zzz_generated/app-common/app-common/zap-generated/cluster-objects.cpp: In member function 'CHIP_ERROR chip::app::Clusters::UnitTesting::Structs::TestFabricScoped::DecodableType::Decode(chip::TLV::TLVReader&)':
../../../../../../../opt/nordic/ncs/v2.5.99-dev1/modules/lib/matter/zzz_generated/app-common/app-common/zap-generated/cluster-objects.cpp:20334:37: error: 'class chip::app::Clusters::detail::StructDecodeIterator' has no member named 'Next'
20334 |         auto __element = __iterator.Next();
../../../../../../../opt/nordic/ncs/v2.5.99-dev1/modules/lib/matter/zzz_generated/app-common/app-common/zap-generated/cluster-objects.cpp:20335:18: error: 'holds_alternative' is not a member of 'std'
20335 |         if (std::holds_alternative<CHIP_ERROR>(__element))
  • Andreas,
    Thanks for the suggestions.  I tried the following on my Mac OS system.  I went into /opt/nordic/ncs/ and moved my existing v2.6.0-rc1 directory to Saved.v2.6.0-rc1 (to save my work).   I then started up the Toolchain manager and installed the v2.6.0-rc1 tool chain.  This installed the /opt/nordic/ncs/toolchains files AND the ~/nrf/v2.6.0-rc1 SDF.   I then opened up VSCode and set the active toolchain and SDK to point to these versions of v2.6.0-rc1.   I got the following error on my first build:
    Cannot file file: /opt/nordic/v2.6.0-rc1/nrf/samples/matter/common/src/led_widget.h
    I had several other iterations of similar errors.  I fixed these by running these shell commands:
    cd /opt/nordic/v2.6.0-rc1/nrf/samples/matter/common/src
    ln -s app/fabric_table_delegate.h .
    ln -s board/led_* .
    ln -s bt_nus/bt_nus_service.* .
    ln -s dfu/ota/ota_util.* .
    ln -s pwm/pwm_device.* .
    ln -s persistent_storage/persistent_storage_* .
    This allowed me to get past the compile errors.  However the build now fails during the "Generating new Factory Data..." step.  I will attach the error message below.
  • [10/774] Generating new Factory Data...
    FAILED: zephyr/factory_data.json /Users/puzl/nrf/PuzLLabs_Thread/build/zephyr/factory_data.json
    cd /Users/puzl/nrf/PuzLLabs_Thread/build/modules/connectedhomeip && /opt/nordic/ncs/toolchains/da6f6379ec/opt/[email protected]/bin/python3.9 /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/nrfconnect/generate_nrfconnect_chip_factory_data.py --sn 11223344556677889900 --date 2022-01-01 --vendor_id 65521 --product_id 32768 --vendor_name PuzL\ Labs --product_name PuzL\ Detect --hw_ver 0 --hw_ver_str prerelease --dac_cert /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/credentials/development/attestation/Matter-Development-DAC-FFF1-8000-Cert.der --dac_key /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/credentials/development/attestation/Matter-Development-DAC-FFF1-8000-Key.der --pai_cert /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/credentials/development/attestation/Matter-Development-PAI-FFF1-noPID-Cert.der --spake2_it 1000 --spake2_salt U1BBS0UyUCBLZXkgU2FsdA== --discriminator 0xF00 --passcode 20202021 --include_passcode --overwrite --product_finish other --generate_onboarding --enable_key 00112233445566778899AABBCCDDEEFF -o /Users/puzl/nrf/PuzLLabs_Thread/build/zephyr/factory_data.json -s /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/nrfconnect/nrfconnect_factory_data.schema
    [INFO] Generating SPAKE2+ Verifier...
      File "/opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/nrfconnect/generate_nrfconnect_chip_factory_data.py", line 577, in <module>
        main()
      File "/opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/nrfconnect/generate_nrfconnect_chip_factory_data.py", line 573, in main
        generator.generate_json()
      File "/opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/nrfconnect/generate_nrfconnect_chip_factory_data.py", line 277, in generate_json
        spake_2_verifier = self._generate_spake2_verifier()
      File "/opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/nrfconnect/generate_nrfconnect_chip_factory_data.py", line 380, in _generate_spake2_verifier
        return generate_verifier(self._args.passcode, self._args.spake2_salt, self._args.spake2_it)
      File "/opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/spake2p/spake2p.py", line 51, in generate_verifier
        return w0.to_bytes(NIST256p.baselen, byteorder='big') + L.to_bytes('uncompressed')
    AttributeError: 'Point' object has no attribute 'to_bytes'
    [12/774] cd /Users/puzl/nrf/PuzLLabs_Thread/build/modules/openthread/build && /opt/nordic/ncs/toolchains/da6f6379ec/Cellar/cmake/3.21.0/bin/cmake -DLIST="OPENTHREAD_CONFIG_RADIO_LINK_IEEE_802_15_4_ENABLE=1;OPENTHREAD_CONFIG_TMF_ANYCAST_LOCATOR_ENABLE=0;OPENTHREAD_CONFIG_ASSERT_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_ENABLE=0;OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0;OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0;OPENTHREAD_CONFIG_BLE_TCAT_ENABLE=0;OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=0;OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=0;OPENTHREAD_CONFIG_BORDER_ROUTING_ENABLE=0;OPENTHREAD_CONFIG_BORDER_ROUTING_DHCP6_PD_ENABLE=0;OPENTHREAD_CONFIG_IP6_BR_COUNTERS_ENABLE=0;OPENTHREAD_CONFIG_CHANNEL_MANAGER_ENABLE=0;OPENTHREAD_CONFIG_CHANNEL_MONITOR_ENABLE=0;OPENTHREAD_CONFIG_COAP_API_ENABLE=1;OPENTHREAD_CONFIG_COAP_BLOCKWISE_TRANSFER_ENABLE=0;OPENTHREAD_CONFIG_COAP_OBSERVE_API_ENABLE=0;OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=0;OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=0;OPENTHREAD_CONFIG_MAC_CSL_AUTO_SYNC_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_DEBUG_ENABLE=0;OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_ENABLE=1;OPENTHREAD_CONFIG_MAC_CSL_RECEIVER_LOCAL_TIME_SYNC=0;OPENTHREAD_CONFIG_DATASET_UPDATER_ENABLE=0;OPENTHREAD_CONFIG_MLE_DEVICE_PROPERTY_LEADER_WEIGHT_ENABLE=0;OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=0;OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=0;OPENTHREAD_CONFIG_DIAG_ENABLE=0;OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DNS_CLIENT_OVER_TCP_ENABLE=0;OPENTHREAD_CONFIG_DNS_DSO_ENABLE=0;OPENTHREAD_CONFIG_DNS_UPSTREAM_QUERY_ENABLE=0;OPENTHREAD_CONFIG_DNSSD_SERVER_ENABLE=0;OPENTHREAD_CONFIG_DUA_ENABLE=1;OPENTHREAD_CONFIG_ECDSA_ENABLE=1;OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1;OPENTHREAD_POSIX_CONFIG_FIREWALL_ENABLE=0;OPENTHREAD_CONFIG_HISTORY_TRACKER_ENABLE=0;OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1;OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=0;OPENTHREAD_CONFIG_JOINER_ENABLE=0;OPENTHREAD_CONFIG_MLE_LINK_METRICS_INITIATOR_ENABLE=0;OPENTHREAD_CONFIG_LINK_METRICS_MANAGER_ENABLE=0;OPENTHREAD_CONFIG_MLE_LINK_METRICS_SUBJECT_ENABLE=0;OPENTHREAD_CONFIG_LINK_RAW_ENABLE=0;OPENTHREAD_CONFIG_LOG_LEVEL_DYNAMIC_ENABLE=0;OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=0;OPENTHREAD_CONFIG_MESH_DIAG_ENABLE=0;OPENTHREAD_CONFIG_MESSAGE_USE_HEAP_ENABLE=0;OPENTHREAD_CONFIG_MLE_LONG_ROUTES_ENABLE=0;OPENTHREAD_CONFIG_MLR_ENABLE=1;OPENTHREAD_CONFIG_MULTIPAN_RCP_ENABLE=0;OPENTHREAD_CONFIG_MULTIPLE_INSTANCE_ENABLE=0;OPENTHREAD_CONFIG_NAT64_BORDER_ROUTING_ENABLE=0;OPENTHREAD_CONFIG_NAT64_TRANSLATOR_ENABLE=0;OPENTHREAD_CONFIG_NEIGHBOR_DISCOVERY_AGENT_ENABLE=0;OPENTHREAD_CONFIG_NETDATA_PUBLISHER_ENABLE=0;OPENTHREAD_CONFIG_TMF_NETDIAG_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_OPERATIONAL_DATASET_AUTO_INIT=1;OPENTHREAD_CONFIG_OTNS_ENABLE=0;OPENTHREAD_CONFIG_PING_SENDER_ENABLE=1;OPENTHREAD_CONFIG_PLATFORM_BOOTLOADER_MODE_ENABLE=0;OPENTHREAD_CONFIG_PLATFORM_KEY_REFERENCES_ENABLE=1;OPENTHREAD_CONFIG_PLATFORM_NETIF_ENABLE=0;OPENTHREAD_CONFIG_PLATFORM_POWER_CALIBRATION_ENABLE=0;OPENTHREAD_CONFIG_PLATFORM_UDP_ENABLE=0;OPENTHREAD_CONFIG_REFERENCE_DEVICE_ENABLE=0;OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=0;OPENTHREAD_SETTINGS_RAM=0;OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1;OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=0;OPENTHREAD_CONFIG_SRP_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_SRP_SERVER_ENABLE=0;OPENTHREAD_CONFIG_TCP_ENABLE=0;OPENTHREAD_CONFIG_TIME_SYNC_ENABLE=0;OPENTHREAD_CONFIG_RADIO_LINK_TREL_ENABLE=0;OPENTHREAD_CONFIG_MAC_OUTGOING_BEACON_PAYLOAD_ENABLE=0;OPENTHREAD_CONFIG_TX_QUEUE_STATISTICS_ENABLE=0;OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=0;OPENTHREAD_CONFIG_UPTIME_ENABLE=0;OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_3;OPENTHREAD_CONFIG_DEVICE_POWER_SUPPLY=OT_POWER_SUPPLY_EXTERNAL;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;PACKAGE_NAME="OPENTHREAD";OPENTHREAD_CONFIG_NCP_HDLC_ENABLE=1;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=1;_ANSI_SOURCE;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=1;__PROGRAM_START;NRF52840_XXAA;ZCBOR_ASSERTS;MBEDTLS_CONFIG_FILE="nrf-config.h";MBEDTLS_PSA_CRYPTO_CONFIG_FILE="nrf-psa-crypto-want-config.h";MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE="nrf-psa-crypto-config.h";NRF_802154_SERIALIZATION_HOST=0;NRF_802154_USE_RAW_API=1;NRF_802154_PENDING_SHORT_ADDRESSES=16;NRF_802154_PENDING_EXTENDED_ADDRESSES=16;NRF_802154_RX_BUFFERS=16;NRF_802154_TX_STARTED_NOTIFY_ENABLED=1;NRF_802154_ACK_TIMEOUT_ENABLED=1;NRF_802154_CCA_CORR_LIMIT_DEFAULT=2;NRF_802154_CCA_CORR_THRESHOLD_DEFAULT=45;NRF_802154_CCA_ED_THRESHOLD_DEFAULT=45;NRF_802154_SECURITY_KEY_STORAGE_SIZE=3;NRF_802154_CCA_MODE_DEFAULT=NRF_RADIO_CCA_MODE_ED;NRF_802154_ENCRYPTION_ENABLED=1;NRF_802154_SECURITY_WRITER_ENABLED=1;NRF_802154_IE_WRITER_ENABLED=1;NRF_802154_INTERNAL_RADIO_IRQ_HANDLING=0;NRF_802154_CARRIER_FUNCTIONS_ENABLED=0;NRF_802154_ENERGY_DETECTED_VERSION=1;NRF_802154_PLATFORM_ASSERT_INCLUDE="nrf_802154_assert_zephyr.h";NRF_802154_ECB_PRIORITY=-1;NRF_802154_SWI_PRIORITY=1" -P /opt/nordic/ncs/v2.6.0-rc1/modules/lib/openthread/etc/cmake/print.cmake
    PACKAGE_NAME=OPENTHREAD
    KERNEL
    __ZEPHYR__=1
    _FORTIFY_SOURCE=1
    _ANSI_SOURCE
    __PROGRAM_START
    NRF52840_XXAA
    ZCBOR_ASSERTS
    MBEDTLS_CONFIG_FILE=nrf-config.h
    MBEDTLS_PSA_CRYPTO_CONFIG_FILE=nrf-psa-crypto-want-config.h
    MBEDTLS_PSA_CRYPTO_USER_CONFIG_FILE=nrf-psa-crypto-config.h
    NRF_802154_PLATFORM_ASSERT_INCLUDE=nrf_802154_assert_zephyr.h
    FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/da6f6379ec/bin/cmake --build /Users/puzl/nrf/PuzLLabs_Thread/build
     *  The terminal process terminated with exit code: 1.
  • Good morning from Norway,
    Do you see the same error with a pristine sample from the SDK, as well as your custom firmware based on the Matter template? How about other non-matter samples?
    What build configuration have you selected, i.e did you use west build with any other parameters added? If you've used the nRF Connect extension to build, could you post a screen shot of the build configuration?
    The error you're getting seems to be connected to the SPAKE2+ verifier specifically.
    If you're using a SPAKE2+ from your 2.5 based custom project using Matter v1.1 into the NCS v2.6.0 using Matter v1.2, could you verify if anything has changed w.r.t formatting or other things?
    Andreas
  • Hello again,
    I was able to perform the following experiment with the v2.6.0 SDK:
    1.  WELCOME -> Create a new application -> Copy a sample -> Matter Template
    2. Add Build Configuration
        Board = nrf52840dk_nrf52840
        Configuration = prj.conf
        Add Devicetree overlays:  boards/nrf52840dk_nrf52840.overlay
    3. Build Configuration
    I seem to get the same failure as last time:
    -- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0-rc1/zephyr), build: v3.5.99-ncs1-rc1
    [173/173] Linking C executable zephyr/zephyr.elf
    Memory region         Used Size  Region Size  %age Used
               FLASH:       26618 B        28 KB     92.84%
                 RAM:         18 KB       256 KB      7.03%
            IDT_LIST:          0 GB        32 KB      0.00%
    [11/732] Generating new Factory Data...
    FAILED: zephyr/factory_data.json /Users/puzl/nrf/template_1/build/zephyr/factory_data.json
    cd /Users/puzl/nrf/template_1/build/modules/connectedhomeip && /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/nrfconnect/generate_nrfconnect_chip_factory_data.py --sn 11223344556677889900 --date 2022-01-01 --vendor_id 65521 --product_id 32768 --vendor_name Nordic\ Semiconductor\ ASA --product_name not-specified --hw_ver 0 --hw_ver_str prerelease --dac_cert /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/credentials/development/attestation/Matter-Development-DAC-FFF1-8000-Cert.der --dac_key /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/credentials/development/attestation/Matter-Development-DAC-FFF1-8000-Key.der --pai_cert /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/credentials/development/attestation/Matter-Development-PAI-FFF1-noPID-Cert.der --spake2_it 1000 --spake2_salt U1BBS0UyUCBLZXkgU2FsdA== --discriminator 0xF00 --passcode 20202021 --include_passcode --overwrite --product_finish other --generate_onboarding --enable_key 00112233445566778899AABBCCDDEEFF -o /Users/puzl/nrf/template_1/build/zephyr/factory_data.json -s /opt/nordic/ncs/v2.6.0-rc1/modules/lib/matter/scripts/tools/nrfconnect/nrfconnect_factory_data.schema
        main()
    Any further thoughts?
    Gene
  • I have a similar issue:
    [22:08:04] nRF Command Line Tools 10.24.0 are up to date
    [22:08:09] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.6.0 ===========
    Package Using the nRF Connect SDK v2.6.0 at /home/kammutierspule/ncs/v2.6.0
    Clock3 dtc is outdated. Found 1.5.0, but 1.5.1-1 is required by the SDK.
