Writing to the nrf9160's OTP register at runtime
Hi, I'm developing a non-secure application for the nrf9160 based on AWS IoT sample based on NCS 2.5.2. I want to store some persistent data on the OTP registers of the flash. I've managed to program them though JLink, and also based on this ticket  RE: Programming and reading OTP I've managed to read from them from the non-secure application.
However I don't see API to write to the OTP/UICR from the non-secure application. Is that supported? Or is it possible to be done using some patch similarly to the reading?
Greetings,
Mihail
  • Hi Mihail,
    Writing to OTP (or may other part of the UICR) from non-secure is not allowed. What is it you want to do it? Could you acomplish what you need to do in a different way? If not, the only way you can write to UICR from non-secure is to make a custom secure service in TF-M and use that. You can refer to TF-M secure peripheral partition as an examle of this (ignoring the parts of the sample that involves the peripheral devices).
    Einar
  • Hi Einar,
    thank you for the quick response.
    I want to store the `CLIENT_ID` for AWS on the OTP. Until now I've used `CONFIG_AWS_IOT_CLIENT_ID_STATIC`, however I have a different `CLIENT_ID` for each device. Means that I have to build a separate binary for each device, only changing the client id config. If I use `CONFIG_AWS_IOT_CLIENT_ID_APP`, then I can make an "universal" firmware update that can be updated to all of the devices.
    Due to space constraints, the debug and test connectors are located on a part of the PCB that breaks off after programming the device, before assembly. This means that for a small number of test devices, I've broken off the JLink connector and I can only update them OTA.
    I was wondering if I can somehow put an OTA update that's going to write the `CLIENT_ID` into the OTP, and from then on use an "universal" firmware image for all devices. I have done that in the past with an application on the nrf52. I have been able to put BLE OTA application, that wrote the BLE name of the device in the UICR->CUSTOMER registers. However it didn't use TF-M, so I didn't have anything preventing me from doing that.
    In hindsight, I should have put a storage partition in the flash layout, but I think that I can no longer change that, since I have already built a bootloader and I have to use the `pm_static.yml` from it.
    For all the future devices I can program the `CLIENT_ID` to OTP from JLink, so it won't be an issue. For the existing test devices I think my best option would be to keep creating a separate binary for each of them. I don't think that creating a custom TF-M service makes sense in this scenario.
    Greetings
