device reset after OTA update, no MCUBOO rtt logs
I come after this post.
After following these steps i was unable to view RTT logs of the MCUBOOT.
I am at Zephyr 2.6.99, nrd sdk 1.7.1 and working on OTA updates for a custum nrf52840 circuit board, that has RTT logging.
The debbugger is a J-link EDU debugger. I am getting my applications RTT logs normaly, but no logs from MCUBoot.
I was able to perform an OTA update with the nrf52840 dongle, and on my custom nrf52840 circuit board with the
smp sample provided inside ~/ncs/zephyr/samples/subsys/mgmt/mcumgr/smp_svr by sendins an update
with the Device Manager APP.
I am having trouble performing an OTA update with my application. After i integrated the SMP service,
i see the advertisement, i follow the same steps, as with the SMP sample, and my device just resets after the
upload is fineshed. Show i want to be able to see MCUBOOT logs for debugging perpuses.
For the record, i also read the flash memory before and after the OTA update with nrf's Connect programmer.
With the smp_srv sample, after the update i can see that slot0 and slot1 have swapped places.
With my smp integration, the flash remains unchanged before and after the OTA update. Meaning that slot1 is empty
and slot0 has the origian application binary.
SMP samples's binary is 178KB , as well as the ota update binary
My application's size with the smp service integrated is 300KB , and ota binary is 301KB
Here is my flash partitioning:
&flash0 {
	partitions {
		#address-cells = <1>;
		#size-cells = <1>;
		boot_partition: partition@0 {
			label = "mcuboot";
			reg = <0x000000000 0x0000C000>;
		slot0_partition: partition@c000 {
			label = "image-0";
			reg = <0x0000C000 0x00067000>;
		slot1_partition: partition@73000 {
			label = "image-1";
			reg = <0x00073000 0x00067000>;
		scratch_partition: partition@da000 {
			label = "image-scratch";
			reg = <0x000da000 0x0001e000>;
		 * The flash starting at 0x000f8000 and ending at
		 * 0x000fffff is reserved for use by the application.
		 * Storage partition will be used by FCB/LittleFS/NVS
		 * if enabled.
		storage_partition: partition@f8000 {
			label = "storage";
			reg = <0x000f8000 0x00008000>;
    Check out this post
    If that cannot help, please provide the child_image\mcuboot.conf.
    Amanda H.
  • Hello Amanda,
    as i said, i  allready followed the changes of the post that you provided.
    The only change i had to was to comment:
    CONFIG_BOOT_ENCRYPT_IMAGE=n
    in prf.conf of bootloader
    since at build time i got this error:ncs/bootloader/mcuboot/boot/zephyr/prj.conf:7: warning: attempt to assign the value 'n' to the undefined symbol BOOT_ENCRYPT_IMAGE
    error: Aborting due to Kconfig warnings
    Here is my child_image\mcuboot.conf:
    CONFIG_PM_PARTITION_SIZE_MCUBOOT=0x10000
    # Disable UART Console and enable the RTT console
    CONFIG_UART_CONSOLE=n
    CONFIG_RTT_CONSOLE=y
    CONFIG_USE_SEGGER_RTT=y
    # Config logger
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    CONFIG_MULTITHREADING=y
    Thank you for your time!
    Did you modify the updated application? If so, what is that?
    Could elaborate on the detail what is the difference between the original and updated image? Is any config changed?
    If you update the image without modification, it will not be valied.
    apogatz98 said:
    Can i use the latest NCS sdk while i am at Zephyr 2.6.99, or shoud they updated together ?
    Do you mean to update from NCS v1.7.1 to the latest NCS? If so, it's possible with the same memory lay by pm_static.yml.
    apogatz98 said:
    We have tried to move to a newer Zephyr version, so we can enjoy the latest NCS sdk, but the transition is rough since we are using I2C DMA and the custom driver used fot that is written with NCS sdk 1.7.1.
    If you want to move to the latest NCS, you have to migrate the custom driver to be compatible with the latest version. Here are the Migration guides, but I would suggest migrating to v2.0.0 for the first step since there are some big changes in v2.0.0.  Make sure the application can run with the latest NCS without issue, and then add the DFU features to test.
    Amanda H.
  • Did you modify the updated application? If so, what is that?
    Hello Amanda. The only difference between the main application binary and the update binary is essentially:
    1)The build time. The update binary is built a few minutes later than the the main binary
    2)A print statement in the main function:
    - The update binary spams with a k timer every 2 seconds "I am a OTA Update"
    - The main binaryu spams with a ktimer every 2 seconds "I am an SMP Server"
    The ota update contains the same smp server, it's just a debug message to distinguish them.
    Everythings else, is the same, even the pm_static.yml.
    Keep in mind that all the above, do work with the smp_srv sample. My current issue with my application is that the either the update proccess stops (device manager progress bar freezes) or if the update is sent successfully i get the error:
    Image in the secondary slot is not valid!
    And the device resets to the main application.
    I mean, generally, is it possible to update from NCS v1..7.1 to the latest NCS but keeping the same Zephyr version?
    I think the oppostie questions makes more sense. Can i update to the latest Zephyr version but keep the NCS version 1.7.1.?
    Did you have the same changes with your application? As I explained, updating an unmodified image would get that error.
    No, the NCS only supports the corresponding Zephyr version.
    -Amanda H.
  • Hello Amanda,
    i just figured out that the whole issue was caused due to the following configs
    CONFIG_BT_BUF_ACL_RX_SIZE=256
    CONFIG_BT_L2CAP_TX_MTU=252
    , in my application, these values where set to 512.
    Now OTA works as expected.
    Thank you for your effort, and continuous support! This
    ticket can be closed.
