[Zigbee] OTA compatibility & custom memory configuration
Setup:
NCS v2.4.1
nrf52840DK (ZR)
I am looking for clarification regarding that small note [Developing with ZBOSS]:
The memory configuration must not be changed between firmware versions if the firmware is going to be upgraded using the OTA DFU.
  1. Is it valid for all configs or only for part of them ?
  2. How this works under the hood ?
  3. Is OTA incompatibility still valid if I am using static partition layout ?
  4. Do I really need to put my custom memory configuration header after zboss_api.h everywhere I am using the zboss_api.h ? Can it be done in other way in Cmake for eg. ?
I look forward to hearing from you,
Pawel
  • Hi Pawel,
    This link is to the documentation of an old ZBOSS version. The most recent -- and the one applicable for NCS v2.4.1 is found here (ZBOSS 3.11.2.1 for production). Please update bookmarks if you have an older version of the documentation saved. This can save you some confusion in the future.
    It's valid for all the configs.
    What are your referring to here? The memory configuration layout, the OTA DFU process? Please elaborate.
    Yes, the requirement for using the same memory configuration for future firmware versions applies when you are using a static partition layout. Note that static partition is recommended when you are planning to do DFU in the future.
    No, not everywhere. It is needed in your main application file (often named main.c) and the memory configuration header needs to be included after including zboss_api.h. See the Where to include header files section of the documentation.
    No, the method is as described in the documentation: including it in the main application file after zboss_api.h is included.
    Maria
  • Hi Maria,
    Thank you for fast response.
    Regarding "How it works under the hood" I meant the memory configuration layout. I would like to know what is causing the OTA incompatibility.
    Additionaly: Is it possible to build app without zboss_product_config partition ? I am not going to use it anyway and at this point 1kB of memory is simply being lost.
    I am satisfied with answers for other questions:)
    Pawel
  • Hi Pawel,
    I have forwarded this question to the developers and will update you when I have any updates.
    The system part of the production configuration is mandatory, and the application-specific part is optional. See more in the Production configuration part of the Programming principles documentation.
    Great!
    Maria
  • Thank you,
    Regarding zboss_product_config as far as I can see ZBOSS NVRAM does not have an API for writing to that partition.
    It seems that it should not be a problem of using NVS on top of it with additional offset of 128Bytes.
    Based on: https://github.com/NordicSemiconductor/pc-nrfutil/blob/master/nordicsemi/zigbee/prod_config.py#L54
    The idea is to do not waste the memory space, so by adding the 128B offset in NVS the ZBOSS will not even notice that something is placed inside its zboss_product_config partition and because there is no API for writing to that memory space my data should be safe.
    What do you think about it ?
    Pawel
  • I do not recommend using zboss_product_config for storing other data.
    I have sent these questions to the developers:
    • What is the minimum allowed size for zboss_product_config?
    • Can zboss_product_config be completely removed?
    I included the last question because the list of data which can be saved to zboss_product_config does not seem like a requirement. This was my assumption when I first read it.
    This data is:
    • 802.15.4 channel mask
    • Device IEEE address
    • Definition of the maximum TX power per channel per page
    • Install code of the device
    These data points need to be saved to your device if you are using them -- and the zboss_product_config is a suitable place to store them.
    I want to also let you know that your question about the memory configuration layout will be looked into when possible. Note that it can still take some time.
    Maria
1 2 3
