How can i enable dcdc regulator
Hi everybody,
I want to try dcdc module. I want to figure out How can i reduce current consumption.
I have a this 2 configuration in sdk_config.h
1)
// <e> POWER_ENABLED - nrf_drv_power - POWER peripheral driver - legacy layer
#ifndef POWER_ENABLE
#define POWER_ENABLED 0
// <o> POWER_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef POWER_CONFIG_IRQ_PRIORITY
#define POWER_CONFIG_IRQ_PRIORITY 6
// <q> POWER_CONFIG_DEFAULT_DCDCEN  - The default configuration of main DCDC regulator
// <i> This settings means only that components for DCDC regulator are installed and it can be enabled.
#ifndef POWER_CONFIG_DEFAULT_DCDCEN
#define POWER_CONFIG_DEFAULT_DCDCEN 1
// <q> POWER_CONFIG_DEFAULT_DCDCENHV  - The default configuration of High Voltage DCDC regulator
#ifndef POWER_CONFIG_DEFAULT_DCDCENHV
#define POWER_CONFIG_DEFAULT_DCDCENHV 0
// </e>
2)
// <e> NRFX_POWER_ENABLED - nrfx_power - POWER peripheral driver
#ifndef NRFX_POWER_ENABLED
#define NRFX_POWER_ENABLED 0
// <o> NRFX_POWER_CONFIG_IRQ_PRIORITY  - Interrupt priority
// <0=> 0 (highest)
// <1=> 1
// <2=> 2
// <3=> 3
// <4=> 4
// <5=> 5
// <6=> 6
// <7=> 7
#ifndef NRFX_POWER_CONFIG_IRQ_PRIORITY
#define NRFX_POWER_CONFIG_IRQ_PRIORITY 6
// <q> NRFX_POWER_CONFIG_DEFAULT_DCDCEN  - The default configuration of main DCDC regulator
#ifndef NRFX_POWER_CONFIG_DEFAULT_DCDCEN
#define NRFX_POWER_CONFIG_DEFAULT_DCDCEN 1
// <q> NRFX_POWER_CONFIG_DEFAULT_DCDCENHV  - The default configuration of High Voltage DCDC regulator
#ifndef NRFX_POWER_CONFIG_DEFAULT_DCDCENHV
#define NRFX_POWER_CONFIG_DEFAULT_DCDCENHV 0
// </e>
What is the differences between these two configurations?
and is this enough for enable dcdc regülator.
  • The reason some of the definitions say NRFX while others doesn't is only for backwards compatibility. If you open your application project, and search for the apply_old_config.h.
    In the end, it is the NRFX_POWER_CONFIG_DEFAULT_DCDCEN that is being used, but it may not be the same as you define it to be in the sdk_config.h. You can see in the apply_old_config.h file that if the POWER_ENABLED is defined (it can be set to 0 but still be defined), it will undef NRFX_POWER_CONFIG_DEFAULT_DCDCEN and then redefine it to be equal to POWER_CONFIG_DEFAULT_DCDCEN.
    However, I never remember which way this goes without looking it up in the apply_old_config.h file, so I ususally just set them to be equal in sdk_config.h.
    You may also need to add the file SDK\modules\nrfx\drivers\src\nrfx_power.c, if you have not already included it. You also need to call nrf_drv_power_init(NULL), and include the files needed for this, such as SDK\integration\nrfx\legacy\nrf_drv_power.c
    When this is called, it will call nrfx_power_init() with p_config.dcdcen = NRFX_POWER_CONFIG_DEFAULT_DCDCEN.
    To verify that the DCDC is enabled, you can read the DCDCEN register using nrfjprog:
    nrfjprog --memrd 0x40000578
    and it should say 0x00000001 if it is enabled, and 0x00000000 if it is disabled.
    Hope that helps. Let me know if you are stuck.
    Edvin
  • is this function necessery?
        err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE);
    is nrfx just for old version ? can i remove it from sdk_config.h?
    where should i use nrfx_power_init()? begining of main function or anywhere else?
  • no. NRFX is the new drivers. Keep them. You can remove the old ones if you like.
    The apply_old_config.h is located in SDK17.1.0\integration\nrfx\legacy\apply_old_config.h
    Yes. If you have enabled the softdevice, you can use sd_power_dcdc_mode_set(), if not, you can use the nrf_drv_power_init(NULL),
    Edvin
  • I am using SDK17 and nrf52810 custom board. I tried to manage enable DCDC Regulator. For this, i removed old version config sentences, i changed the sdk_config.h :
    #define NRFX_POWER_ENABLED 1
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    // </e>
    end then i call this function respectively. is there any wrong thing in enable process?
    ret_code_t err_code = nrf_sdh_enable_request();
    err_code = nrfx_drv_power_init(NULL);
    err_code = sd_power_dcdc_mode_set(NRF_POWER_DCDC_ENABLE); APP_ERROR_CHECK(err_code);
    err_code  = nrf_sdh_ble_enable(&ram_start);
