nRF Mesh Reply Attack Problem
I am developing a vendor specific Mesh Model, I have already integrated the mesh model sucessfully to my network and is able to send data from each node by multiple hops. I am facing some issues from the mesh model.
1. During data transmission if the device resets, reply attack happens and that data wont be received
2. This is my config. I have done everything I can can to increase the throughput, please advise if there are any other way to increase speed to accommodate my payload size. My payload from one node is 240bytes.
[12:21] Jeslin James
CONFIG_ADC=y
CONFIG_ADC_ASYNC=y
CONFIG_GPIO=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_PRINTK=y
CONFIG_PWM=y
CONFIG_LOG_PRINTK=y
CONFIG_LOG_MODE_IMMEDIATE=y
CONFIG_PWM_LOG_LEVEL_DBG=y
CONFIG_NEWLIB_LIBC=y
CONFIG_ADC_NRFX_SAADC=y
CONFIG_NRFX_SAADC=y
CONFIG_LOG=y
CONFIG_PM=y
CONFIG_PM_DEVICE=y
#RTC lib enabling
CONFIG_I2C=y
CONFIG_BT=y
CONFIG_BT_PERIPHERAL=y
CONFIG_BT_USER_DATA_LEN_UPDATE=y
CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=n
CONFIG_BT_BUF_ACL_RX_SIZE=498
CONFIG_BT_ATT_PREPARE_COUNT=2
CONFIG_BT_L2CAP_TX_MTU=484
CONFIG_BT_BUF_ACL_TX_COUNT=10
CONFIG_BT_BUF_ACL_TX_SIZE=37
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_FLASH=y
CONFIG_SPI=y
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NVS=y
CONFIG_NVS_LOG_LEVEL_DBG=y
CONFIG_REBOOT=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
#Enable timer1
CONFIG_NRFX_TIMER1=y
CONFIG_W1=y
CONFIG_SENSOR_LOG_LEVEL_DBG=y
#Floating point support
CONFIG_CBPRINTF_FP_SUPPORT=y
CONFIG_CBPRINTF_COMPLETE=y
CONFIG_BT_DEVICE_NAME="VISENSE_IRMTR"
CONFIG_HEAP_MEM_POOL_SIZE=4096
CONFIG_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_NVS=y
CONFIG_NVS_LOOKUP_CACHE=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_NVS_NAME_CACHE=y
CONFIG_HWINFO=y
CONFIG_DK_LIBRARY=y
CONFIG_PM_SINGLE_IMAGE=y
CONFIG_PM_PARTITION_SIZE_SETTINGS_STORAGE=0x8000
CONFIG_SOC_FLASH_NRF_PARTIAL_ERASE=y
# Temperature sensor
CONFIG_SENSOR=y
CONFIG_TEMP_NRF5=y
# Bluetooth configuration
CONFIG_BT=y
CONFIG_BT_COMPANY_ID=0x1234
CONFIG_BT_L2CAP_TX_BUF_COUNT=8
CONFIG_BT_OBSERVER=y
CONFIG_BT_SETTINGS=y
CONFIG_BT_EXT_ADV=y
# 5 sets are used by Bluetooth mesh, 1 is needed for the sample advs.
CONFIG_BT_EXT_ADV_MAX_ADV_SET=6
CONFIG_BT_MAX_CONN=3
CONFIG_BT_ID_MAX=2
# Disable unused Bluetooth features
CONFIG_BT_CTLR_DUP_FILTER_LEN=0
CONFIG_BT_CTLR_LE_ENC=n
CONFIG_BT_PHY_UPDATE=n
CONFIG_BT_CTLR_CHAN_SEL_2=n
# CONFIG_BT_CTLR_MIN_USED_CHAN=n
CONFIG_BT_CTLR_PRIVACY=n
# Bluetooth mesh configuration
CONFIG_BT_MESH=y
CONFIG_BT_MESH_RELAY=y
CONFIG_BT_MESH_FRIEND=y
CONFIG_BT_MESH_ADV_BUF_COUNT=13
CONFIG_BT_MESH_TX_SEG_MAX=22
CONFIG_BT_MESH_RX_SEG_MAX=22
CONFIG_BT_MESH_PB_GATT=y
CONFIG_BT_MESH_GATT_PROXY=y
CONFIG_BT_MESH_PROXY_USE_DEVICE_NAME=y
CONFIG_BT_MESH_DK_PROV=y
CONFIG_BT_MESH_SUBNET_COUNT=2
CONFIG_BT_MESH_APP_KEY_COUNT=3
# CONFIG_BT_MESH_CRPL=10
CONFIG_BT_MESH_MSG_CACHE_SIZE=32
CONFIG_BT_MESH_CRPL=1000
CONFIG_BT_MESH_RELAY_RETRANSMIT_COUNT=2
CONFIG_BT_MESH_TX_SEG_MSG_COUNT=5
CONFIG_BT_MESH_RX_SEG_MSG_COUNT=6
CONFIG_BT_MESH_TX_SEG_RETRANS_COUNT=4
CONFIG_BT_MESH_MODEL_KEY_COUNT=1
CONFIG_BT_MESH_MODEL_GROUP_COUNT=1
CONFIG_BT_MESH_SEG_BUFS=128
CONFIG_BT_MESH_ADV_EXT=y
#PMIC
CONFIG_NRF_FUEL_GAUGE=y
#CONFIG_SHELL=y
3. My most vexing issue is even with 0 hops sending 240 bytes payload in a single send, I am facing a delay of 2 seconds, The time taken to start the transmission from the callback of START and to reach the callback of END of the message i am getting a delay of 2 seconds. This is too long for my implementation, kindly advice on ways to reduce it.
