Device stops receiving after sending custom Zigbee commands
I am currently developing a Zigbee (router) device that has a custom cluster with custom commands. I can send 10-20 custom commands to this device successfully (and receive them) but after this, the Zboss loop seems to freeze and won't receive anything anymore. Also, read/write attribute commands to for example the basic cluster don't get received anymore. Do you have any idea what could be the reason for this? The only thing you can do hereafter is reboot the board. Sometime after you get the problem, a lot of data is printed/spammed in the console by the NRF chip. Constantly the same data it seems. Small sample of the logs:
D: de ad 16 02 4b ff 03 4c |....K..L
D: 18 00 6d 05 18 00 00 00 |..m.....
D: 08 00 00 00 30 00 00 00 |....0...
D:
D: de ad 16 02 4b ff 04 4c |....K..L
D:
D: de ad 16 02 4b ff 05 4c |....K..L
D:
D: de ad 16 02 4b ff 06 4c |....K..L
D:
D: de ad 16 02 4b ff 07 4c |....K..L
D: 08 00 00 00             |....
D:
D: 30 00 00 00 de ad 16 02 |0.......
D: 4b ff 08 4c 18 00 6d 05 |K..L..m.
D: 18 00 00 00 08 00 00 00 |........
D: 30 00 00 00             |0...
D:
D: de ad 16 02 4b ff 09 4c |....K..L
D:
D: de ad 16 02 4b ff 0a 4c |....K..L
D:
D: de ad 16 02 4c ff 0b 4c |....L..L
D:
D: de ad 16 02 4c ff 0c 4c |....L..L
D:
D: de ad 16 02 4c ff 0d 4c |....L..L
D:
D: de ad 16 02 4c ff 0e 4c |....L..L
D:
D: de ad 16 02 4c ff 0f 4c |....L..L
D:
D: de ad 16 02 4c ff 10 4c |....L..L
I am using a custom-developed board with a BT840 module which has an NRF52840 onboard. Here is a simplified example of my code: https://github.com/pieterjanbuntinx/test-nrf-custom-commands . In here the buttons and LEDs don't work (other pinouts on my board, I have removed most code for this on here).
As the coordinator, I am using a custom board with an Espressif chip but I was also able to reproduce the problem with the shell example on an NRF dev board. It can be reproduced by repeatedly executing the following command:
zcl cmd <short_addr> 2 0xfc00 0x00f1 -i -l 0x050301000004
Thanks in advance.
Pieter-Jan
  • I am using NRF connect in vscode and sdk version v2.5.2
  • Hi Pieter-Jan,
    Please do a sniffer log of the network which includes the network startup, the successful messages, and the freeze. Upload the sniffer log as a .pcap file in a reply. See this guide on how to do sniffer logs for 802.15.4. If your network key differs from the keys in the guide, you need to share your key with us to enable us to decrypt the packets.
    If you don't want the network key to be shared publicly, I can make the ticket private. Just let me know!
    Maria
  • Hi Maria,
    Thank you for your response.
    I've attached the sniffer capture. The network keys should be the default Nordic keys or just the ones of my dev board, so it does not really matter if I share them.
    From No. 159 on you can see that I am sending a custom command with id 0xf1. Up to and including No. 241, I always get an ACK from the device. After this, none are sent anymore.
    Best Regards,
    Pieter-Jan
    custom_command_problem.pcapng
  • Hi Pieter-Jan,
    From the sniffer log we can see that the device still ACKs packets on a the MAC layer after it stops APS ACKs. Your hypothesis that the ZBOSS thread freezes could be a possibility. To get more logging and statistics for the active threads of your application you can use the Thread analyzer.
    Getting some information on what is happening before the freeze is helpful, so if you can configure your application to a higher logging level and debug it, this can help to close in on what the cause is.
    I do not have any hardware to test right now, but I will test this as soon as I can.
    Maria
  • Hi Maria,
    Sorry for the late response. I have enabled the thread analyzer and the stack usage of all the threads seems fine to me. When the problem occurs, the thread analyzer quits printing. I have added a print statement to the main thread that prints a message every second. This also stops working. Are there any other debug logs I can enable to help me debug this?
    Thanks!
    Pieter-Jan
    Below you can find the log:
    SEGGER J-Link V7.94e - Real time terminal output
    SEGGER J-Link (unknown) V1.0, SN=1050065421
    Process: JLink.exe
    I: nRF5 802154 radio initialized
    D: Function: zb_trans_set_auto_ack, enabled: 1
    D:
    D: de ad 0a 02 00 00 00 00 |........
    D: 77 00 b3 00             |w...
    D:
    D: de ad 26 02 00 00 01 00 |..&.....
    D: 77 00 b7 00 08 10 00 00 |w.......
    D: 00 01 00 00 10 00 00 00 |........
    D: 0c 03 00 00 84 02 00 00 |........
    D: 98 01 00 00 68 02 00 00 |....h...
    D:
    D: de ad 0e 02 00 00 02 00 |........
    D: 77 00 c0 00 02 00 00 00 |w.......
    D:
    D: de ad 0e 02 00 00 03 00 |........
    D: 77 00 c2 00 c0 02 00 00 |w.......
    D:
    D: de ad 0e 02 00 00 04 00 |........
    D: 77 00 c8 00 50 04 00 00 |w...P...
    D:
    D: de ad 0e 02 00 00 05 00 |........
    D: 77 00 cb 00 90 01 00 00 |w.......
    D:
    D: de ad 0e 02 00 00 06 00 |........
    D: 77 00 ce 00 70 00 00 00 |w...p...
    D:
    D: de ad 0e 02 01 00 07 00 |........
    D: 77 00 d1 00 04 00 00 00 |w.......
    D:
    D: de ad 0e 02 01 00 08 00 |........
    D: 77 00 d8 00 30 00 00 00 |w...0...
    D:
    D: de ad 12 02 01 00 09 00 |........
    D: 77 00 db 00 dc 03 00 00 |w.......
    D: 0c 00 00 00             |....
    D:
    D: de ad 0ePrint Main loop
    Print Main loop
    Print Main loop
    D: Received new Zigbee event: 0x02
    D: Function: zb_trans_get_next_packet
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
     zboss               : STACK: unused 868 usage 1116 / 1984 (56 %); CPU: 3 %
          : Total CPU cycles used: 12074
     thread_analyzer     : STACK: unused 560 usage 464 / 1024 (45 %); CPU: 0 %
          : Total CPU cycles used: 206
     mcumgr smp          : STACK: unused 1856 usage 192 / 2048 (9 %); CPU: 0 %
     rx_q[0]             : STACK: unused 1424 usage 176 / 1600 (11 %); CPU: 0 %
          : Total CPU cycles used: 3
     nrf5_rx             : STACK: unused 400 usage 336 / 736 (45 %); CPU: 0 %
          : Total CPU cycles used: 9
     sysworkq            : STACK: unused 1720 usage 264 / 1984 (13 %); CPU: 0 %
          : Total CPU cycles used: 8
     MPSL Work           : STACK: unused 536 usage 424 / 960 (44 %); CPU: 0 %
          : Total CPU cycles used: 299
     idle                : STACK: unused 272 usage 48 / 320 (15 %); CPU: 95 %
          : Total CPU cycles used: 320813
     main                : STACK: unused 1312 usage 672 / 1984 (33 %); CPU: 0 %
          : Total CPU cycles used: 851
     ISR0                : STACK: unused 872 usage 1240 / 2112 (58 %)
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    D: Function: zb_trans_transmit, channel: 21
    D: Received new Zigbee event: 0x01
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
     zboss               : STACK: unused 868 usage 1116 / 1984 (56 %); CPU: 1 %
          : Total CPU cycles used: 12787
          : Total CPU cycles used: 423
     idle                : STACK: unused 272 usage 48 / 320 (15 %); CPU: 97 %
          : Total CPU cycles used: 647736
          : Total CPU cycles used: 881
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 13161
     thread_analyzer     : STACK: unused 528 usage 496 / 1024 (48 %); CPU: 0 %
          : Total CPU cycles used: 640
     idle                : STACK: unused 272 usage 48 / 320 (15 %); CPU: 98 %
          : Total CPU cycles used: 974996
          : Total CPU cycles used: 911
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 13994
          : Total CPU cycles used: 862
          : Total CPU cycles used: 5
          : Total CPU cycles used: 16
          : Total CPU cycles used: 1301822
          : Total CPU cycles used: 941
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
     zboss               : STACK: unused 868 usage 1116 / 1984 (56 %); CPU: 0 %
          : Total CPU cycles used: 14310
          : Total CPU cycles used: 1079
          : Total CPU cycles used: 1629142
          : Total CPU cycles used: 971
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 15484
          : Total CPU cycles used: 1296
          : Total CPU cycles used: 19
     idle                : STACK: unused 272 usage 48 / 320 (15 %); CPU: 99 %
          : Total CPU cycles used: 1955589
          : Total CPU cycles used: 1001
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 15782
          : Total CPU cycles used: 1514
          : Total CPU cycles used: 7
          : Total CPU cycles used: 23
          : Total CPU cycles used: 2282920
          : Total CPU cycles used: 1032
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 16062
          : Total CPU cycles used: 1732
          : Total CPU cycles used: 2610273
          : Total CPU cycles used: 1062
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 16385
          : Total CPU cycles used: 1950
          : Total CPU cycles used: 2937576
          : Total CPU cycles used: 1092
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 16666
          : Total CPU cycles used: 2169
          : Total CPU cycles used: 30
          : Total CPU cycles used: 3264917
          : Total CPU cycles used: 1122
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 16933
          : Total CPU cycles used: 2386
          : Total CPU cycles used: 3592281
          : Total CPU cycles used: 1152
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    I: Received
    D: Function: zb_trans_buffer_free
    Print Main loop
    I: Received
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 17551
          : Total CPU cycles used: 2604
          : Total CPU cycles used: 41
          : Total CPU cycles used: 3919273
          : Total CPU cycles used: 1182
    I: Received
    I: Received
    Print Main loop
    I: Received
    Print Main loop
    I: Received
    I: Received
    Print Main loop
    I: Received
    I: Received
    Print Main loop
    I: Received
    I: Received
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 19159
          : Total CPU cycles used: 2821
          : Total CPU cycles used: 24
          : Total CPU cycles used: 76
          : Total CPU cycles used: 4245226
          : Total CPU cycles used: 1212
    I: Received
    Print Main loop
    I: Received
    Print Main loop
    I: Received
    I: Received
    Print Main loop
    I: Received
    I: Received
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Print Main loop
    Thread analyze:
          : Total CPU cycles used: 20310
          : Total CPU cycles used: 3039
          : Total CPU cycles used: 31
          : Total CPU cycles used: 4571664
          : Total CPU cycles used: 1242
    Print Main loop
    I: Received
    Print Main loop
    D:
    D: de ad 0a 02 6b 24 13 00 |....k$..
    D: 49 01 0b 03             |I...
    D:
    D: de ad 16 02 6b 24 14 00 |....k$..
    D: 18 00 6d 05 16 00 00 00 |..m.....
    D: 02 00 00 00 30 00 00 00 |....0...
    I: Received
    Print Main loop
    I: Received
    I: Received
    Print Main loop
