nrfx_timer and nrfx_saadc #defines-> undefined variable issue nrf connect sdk
Hi Team,
I've recently transitioned from using Texas Instruments modules to Nordic modules for its low energy, specifically the NRF52832 DK with the NRF Connect SDK. Therefore, I am novice in zephyr environment.
I am in the process of developing a sensor which could send 400 samples per second via Bluetooth hence the ADC must process 400 samples every second without any CPU intervention.
After days of exploring I understood that I need to use PPI and timers to enable the ADC to work autonomously. However, I struggled to find relevant documentation or examples specifically tailored for the NRF Connect SDK.  Eventually I found this https://github.com/haakonsh/NCS_SAADC_example/tree/master which incorporated nrfx_saadc, nrfx_ppi and nrfx_timer to employ ADC autonomously.
When I attempted to use the provided code in my Visual Studio Code environment, I encountered numerous errors related to undefined identifiers for the nrfx_saadc and nrfx_timer headers. Additionally, several other headers required by the SAADC and timer modules themselves also resulted in undefined errors.
Below is the main.c
 * Copyright (c) 2019 Nordic Semiconductor ASA
#include <zephyr/kernel.h>
#include <nrfx_ppi.h>
#include "nrfx_saadc.h"
#include <nrfx_timer.h>
#include <hal/nrf_timer.h>
#include <helpers/nrfx_gppi.h>
#define __ZEPHYR__ 1
LOG_MODULE_REGISTER(nrfx_sample, LOG_LEVEL_INF);
#define SAADC_CHANNEL_NUM 	0
#define SAMPLES_IN_BUFFER 	8
#define SAMPLE_RATE 		10000UL
#define TIMER1_INST_IDX 1
int16_t saadc_buf1[SAMPLES_IN_BUFFER];
int16_t saadc_buf2[SAMPLES_IN_BUFFER];
const nrfx_timer_t timer1_inst = NRFX_TIMER_INSTANCE(TIMER1_INST_IDX); //ERROR identifier "NRFX_TIMER1_INST_IDX" is undefined
void saadc_evt_handler(nrfx_saadc_evt_t const * p_event)
	nrfx_err_t err = NRFX_SUCCESS;
	static uint8_t counter = 0;
	if(p_event->type == NRFX_SAADC_EVT_DONE)
		printk("SAADC sampled: \n");
		for(uint8_t i = 0; i < p_event->data.done.size; i++)
			printk("%hi\n", p_event->data.done.p_buffer[i]);
	else if(p_event->type == NRFX_SAADC_EVT_CALIBRATEDONE)
		printk("SAADC calibrated.\n");
	else if(p_event->type == NRFX_SAADC_EVT_BUF_REQ)
		printk("SAADC buffer requested\n");
		counter++;
		if(counter%2)
			err = nrfx_saadc_buffer_set(saadc_buf1, SAMPLES_IN_BUFFER);
			if(err != NRFX_SUCCESS)
				LOG_ERR("Error! Could not set buffer2: %d\n", err);
			err = nrfx_saadc_buffer_set(saadc_buf2, SAMPLES_IN_BUFFER);
				LOG_ERR("Error! Could not set buffer1: %d\n", err);
	else if(p_event->type == NRFX_SAADC_EVT_FINISHED)
		printk("SAADC finished sampling\n\n");
void timer1_evt_handler(nrf_timer_event_t event_type, void * p_context)
	// Nothing to do here, the timer's IRQ is not enabled
void timer_init(void)
	uint32_t base_frequency = NRF_TIMER_BASE_FREQUENCY_GET(timer1_inst.p_reg);
	nrfx_timer_config_t timer_cfg = NRFX_TIMER_DEFAULT_CONFIG(base_frequency); //ERROR identifier "NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY" is undefined
	timer_cfg.bit_width = (nrf_timer_bit_width_t)NRF_TIMER_BIT_WIDTH_32;
    timer_cfg.mode = NRF_TIMER_MODE_TIMER;
    timer_cfg.p_context = &timer1_inst;
	err = nrfx_timer_init(&timer1_inst, &timer_cfg, timer1_evt_handler);
	// #if defined(__ZEPHYR__)
    // IRQ_DIRECT_CONNECT(NRFX_IRQ_NUMBER_GET(NRF_TIMER_INST_GET(TIMER1_INST_IDX)), IRQ_PRIO_LOWEST,
    // NRFX_TIMER_INST_HANDLER_GET(TIMER1_INST_IDX), 0);
    // #endif
		LOG_ERR("Error! Could not initialize TIMER1: %d\n", err);
	nrfx_timer_extended_compare(&timer1_inst, NRF_TIMER_CC_CHANNEL0, SAMPLE_RATE, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false);
void saadc_init(void)
	nrfx_saadc_channel_t saadc_channel = NRFX_SAADC_DEFAULT_CHANNEL_SE(NRF_SAADC_INPUT_AIN0, SAADC_CHANNEL_NUM); //ERROR identifier "NRF_SAADC_REFERENCE_INTERNAL" is undefined
	nrfx_saadc_adv_config_t saadc_adv_cfg = NRFX_SAADC_DEFAULT_ADV_CONFIG;
	saadc_adv_cfg.start_on_end = true;
	err = nrfx_saadc_init(IRQ_PRIO_LOWEST); //ERROR identifier "IRQ_PRIO_LOWEST" is undefined
		LOG_ERR("Error! Could not initialize SAADC: %d\n", err);
	err = nrfx_saadc_offset_calibrate(NULL);
		LOG_ERR("Error! Could not calibrate offset: %d\n", err);
	err = nrfx_saadc_channel_config(&saadc_channel);
		LOG_ERR("Error! Could not configure SAADC channels: %d\n", err);
	err = nrfx_saadc_advanced_mode_set((1 << SAADC_CHANNEL_NUM), NRF_SAADC_RESOLUTION_10BIT, &saadc_adv_cfg, saadc_evt_handler);
		LOG_ERR("Error! Could not set advanced SAADC mode: %d\n", err);
	err = nrfx_saadc_mode_trigger();
		LOG_ERR("Error! Could trigger mode: %d\n", err);
int main()
	printk("nrfx_saadc sample on %s\n", CONFIG_BOARD); //ERROR printk identifier undefined - surprisingly printk other than main() has no error
	nrfx_err_t err;
	/* Connect SAADC IRQ to nrfx_saadc_irq_handler */
	IRQ_CONNECT(SAADC_IRQn, IRQ_PRIO_LOWEST, nrfx_isr, nrfx_saadc_irq_handler, 0); //ERROR IRQ_PRIO_LOWEST, nrfx_isr identifier undefined
	timer_init();
	saadc_init();
	/* Allocate a PPI channel. */
	nrf_ppi_channel_t channel;
	err = nrfx_ppi_channel_alloc(&channel);
	if (err != NRFX_SUCCESS) {
		LOG_ERR("PPI channel allocation error: %08x", err);
		return -1;
	/* Configure endpoints of the channel so that the TIMER1 CAPTURE0
	 * event is connected with the SAADC SAMPLE task. This means that each time
	 * TIMER1 reaches it's set compare value, the SAADC will sample all
	 * enabled channel once.
	nrfx_gppi_channel_endpoints_setup(channel,
		nrfx_timer_event_address_get(&timer1_inst, NRF_TIMER_EVENT_COMPARE0),
		nrf_saadc_task_address_get(NRF_SAADC, NRF_SAADC_TASK_SAMPLE));
	err = nrfx_ppi_channel_enable(channel);
		LOG_ERR("Failed to enable PPI channel, error: %08x", err);
		return -1;
	printk("PPI configured\n");
	nrfx_timer_enable(&timer1_inst);
	printk("TIMER1 started\n");
	while(1)
Below is the Kconfig
# Copyright (c) 2021 Nordic Semiconductor ASA
config NRFX_DPPI
	default HAS_HW_NRF_DPPIC
config NRFX_PPI
	default HAS_HW_NRF_PPI
config NRFX_SAADC
    bool "Enable SAADC driver"
    depends on HAS_HW_NRF_SAADC && HAS_NRFX
config NRFX_TIMER
	bool "Enable TIMER driver"
	depends on HAS_HW_NRF_TIMER0 || HAS_HW_NRF_TIMER1 || \
		   HAS_HW_NRF_TIMER2 || HAS_HW_NRF_TIMER3 || \
		   HAS_HW_NRF_TIMER4
config NRFX_TIMER1
	bool "Enable TIMER1 instance"
	depends on HAS_HW_NRF_TIMER1
	select NRFX_TIMER
source "Kconfig.zephyr"
Below is the prj.conf
CONFIG_LOG=y
CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=100
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_ASSERT=y
CONFIG_RESET_ON_FATAL_ERROR=n
CONFIG_ADC=n
CONFIG_NRFX_SAADC=y
CONFIG_NRFX_TIMER1=y
CONFIG_PICOLIBC=y
Below is the CMakeLists.txt
cmake_minimum_required(VERSION 3.20.0)
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(adcgit)
target_sources(app PRIVATE src/main.c)
target_include_directories(app PRIVATE ../../../common)
I haven't configured the timing for 400 samples here as I couldn't figure out these errors.
I referred to almost all the Nordic forums and tried everything with no success. Kindly guide me in resolving this issue ASAP. I appreciate any help provided in this regard.
  • Hey Vidar!
    This code works.
    I want to fill the ADC buffer in background while my main tasks processes it. Does using PPI solve that use case?
    Moreover, I dont find any official documentation for ADC with PPI using the connect SDK. Even if the connect SDK  uses old NRF52 NRFx library, I dont see any proper documentation that walks through examples for sampling ADC using PPI or in background.
    Where can I find proper ADC continuous mode sampling  docs/examples for NRF connect SDK?
    thanks,
    Srinidhi
  • // I am trying to use an internal timer to sample ADC in continuous mode. But, this code repeatedly reboots after adc trigger function call. I am confused on how to sample ADC in continuous mode using nrf connect sdk at a particular sampling rate. Why is that nordic does not have any proper documentation on how to use ADC in  continuous mode
    CODE
    #define SAADC_BUF_SIZE         1024
    #define SAADC_BUF_COUNT        2
    #define SAADC_SAMPLE_FREQUENCY 8000
    static uint32_t next_free_buf_index(void)
        static uint32_t buffer_index = -1;
        buffer_index = (buffer_index + 1) % SAADC_BUF_COUNT;
        return buffer_index;
        printk("saadc event handler\n");
            counter++;
            if(counter%2)
        static nrf_saadc_value_t samples[SAADC_BUF_COUNT][SAADC_BUF_SIZE];
        // int SAADC_SAMPLE_FREQUENCY = 8000;
        uint32_t adc_cc_value = 16000000 / SAADC_SAMPLE_FREQUENCY;
        if(adc_cc_value < 80 || adc_cc_value > 2047)
          //  NRF_LOG_ERROR("SAMPLERATE frequency outside legal range. Consider using a timer to trigger the ADC instead.");
            LOG_ERR(" sampling rate outside range ");
        saadc_adv_cfg.internal_timer_cc = adc_cc_value;
        //err = nrfx_saadc_buffer_set(&samples[next_free_buf_index()][0], SAADC_BUF_SIZE);
        // err= nrfx_saadc_buffer_set(&samples[next_free_buf_index()][0], SAADC_BUF_SIZE);
        //err = nrfx_saadc_buffer_set(saadc_buf2, SAMPLES_IN_BUFFER);
        printk(" triggering adc \n");
        printk(" inited ADC\n");
    int main()
        nrfx_err_t err;
        saadc_init();
        printk(" looping \n");
        while(1)
    OUTPUT
  • The sample is already set up to perform sampling in the background. Each sampling task is triggered in the background by TIMER events.
