SPI4 with multiple CS
I have an nRF5340 and need to use the
spi4
device for an SPI bus with multiple devices on it. Each, of course, has a CS pin.
I have to use spi4 because I have uart0, uart1, i2c2, and i2c3 (and there is no "4" device for either UART or I2C). I don't necessarily care about the > 8MHz high-speed capabilities of SPI4, I just need it to act like a regular SPI device with multiple CS pins.
It's rather unclear from the documentation and other posts on this forum how to configure this properly. It appears there's a hardware CS pin (P0.11), which suggests that only a single device can be used (one hardware CS pin means 1 device)? Is it possible to disregard that hardware pin though, and instead use multiple GPIOs for CS pins, like so:
&spi4 {
	status = "okay";
	pinctrl-0 = <&spi0_default>;
	pinctrl-1 = <&spi0_sleep>;
	cs-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>, // 0
	<&gpio0 30 GPIO_ACTIVE_LOW>, // 1
	<&gpio0 7 GPIO_ACTIVE_LOW>, // 2
	<&gpio1 0 GPIO_ACTIVE_LOW>, // 3
	<&gpio0 26 GPIO_ACTIVE_LOW>, // 4
	<&gpio0 27 GPIO_ACTIVE_LOW>; // 5
If I want to use SPI4 in this way (regular speed, multiple CS/devices), and that's actually possible, how would I configure the PIN_CNF[p].MCUSEL and H0H1 values that are mentioned in the "SPI4" bullet at the top of the nRF5340 pinout page? i.e. what values should they have, and as importantly, how do I set them?
    The SPIM driver in Zephyr does not currently support the HW SS pin, it is set to NOT_CONNECTED. The SW control of CS pin should work the same for SPIM4 as the other instances when used through Zephyr SPI driver.
    By default, all pins are assigned to the Application core. If you do not need the 32 MHz mode and dedicated pins, you can leave the MCUSEL field as is and assigned the SPIM pins using the PSEL registers like other instances. The H0H1 values can be configured in the pinctrl in devicetree, e.g. like this.
    Jørgen
  • Thanks Jørgen. If I did want to use the 32MHz mode though, do I need to do anything with MCUSEL register (it mentions using the "Peripheral option" for this pin, but it's not clear what that is or how to set it)?
    And to clarify, I can use the 32MHz mode with multiple devices on the same bus, correct?
  • The driver does not support assigning the dedicated pins to SPIM4, so this must be handled outside of the driver. You should be able to use the dedicated pins similar to this:
    #include "nrf_gpio.h"
    #define SPIM4_SCK  NRF_GPIO_PIN_MAP(0,8)
    #define SPIM4_MOSI NRF_GPIO_PIN_MAP(0,0)
    #define SPIM4_MISO NRF_GPIO_PIN_MAP(0,10)
    nrf_gpio_cfg(SPIM4_SCK, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
    nrf_gpio_cfg(SPIM4_MOSI, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
    nrf_gpio_cfg(SPIM4_MISO, NRF_GPIO_PIN_DIR_OUTPUT, NRF_GPIO_PIN_INPUT_DISCONNECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_H0H1, NRF_GPIO_PIN_NOSENSE);
    nrf_gpio_pin_control_select(SPIM4_SCK, NRF_GPIO_PIN_SEL_PERIPHERAL);
    nrf_gpio_pin_control_select(SPIM4_MOSI, NRF_GPIO_PIN_SEL_PERIPHERAL);
    nrf_gpio_pin_control_select(SPIM4_MISO, NRF_GPIO_PIN_SEL_PERIPHERAL);
    The CS/SS pin should still be controlled by SW in the driver.
    I have not tried this, so let me know if it works or not.
  • I'm a bit confused. This manual assignment of the dedicated pins is only necessary for 32MHz mode, or also for 8MHz mode?
    I don't understand why the driver doesn't support assigning the dedicated pins to SPIM4, when (according to the pin assignment table) they are explicitly dedicated to SPIM4. I feel like I'm missing something here.
    Is there a sample somewhere for using 32MHz mode?
    32 Mbps mode is only supported on the dedicated pins. 8 Mbps mode and lower can be supported on other pins, but you should make sure to use pins not marked as "standard drive, low frequency IO only" in Pin assignments.
    The nrfx_spim driver does support setting the dedicated pins, but not through the MCUSEL register. It will simply verify that the correct pins are used if 32 MHz mode is configured. The Zephyr driver uses skip_gpio_cfg/skip_psel_cfg to handle this in the pinctrl library, so this is skipped when using nRF Connect SDK. If you set the dedicated pins correctly in devicetree and enable the drive mode as I stated previously, this should also work.
    The pins are not dedicated to SPIM4, they can be used for any other peripheral when SPIM4 is not used in 32 Mbps mode, and other pins can be used with SPIM4 when lower frequencies are used. Only in high-speed mode is it required to use the dedicated pins with SPIM4.
    Unfortunately, I'm not aware of any official sample showing this.
