npm1300 problem
hi professor,
    The npm1300 is used for power management  on my borad.When VBAT and VBUS are connected simultaneously, the bulk 2 output power supply varies between 1V and 3.3V.When only VBUS is connected, the bulk 2 output voltage is fixed at 3.3V, which meets my expectations.
    The chip version i am using is CAAACA 2335A1.Does this version of the chip have such characteristics that VBAT must be connected?
Here are the DTS fragments:
&arduino_i2c {
npm1300_ek_pmic: pmic@6b {
compatible = "nordic,npm1300";
reg = <0x6b>;
npm1300_ek_gpio: gpio-controller {
compatible = "nordic,npm1300-gpio";
gpio-controller;
#gpio-cells = <2>;
ngpios = <5>;
npm1300_ek_regulators: regulators {
compatible = "nordic,npm1300-regulator";
/* limits are set to min/max allowed values */
npm1300_ek_buck1: BUCK1 {
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <3300000>;
/delete-property/ regulator-init-microvolt;
npm1300_ek_buck2: BUCK2 {
regulator-min-microvolt = <1000000>;
regulator-init-microvolt = <3300000>;
regulator-always-on;
regulator-boot-on;
/delete-property/ retention-microvolt;
/delete-property/ enable-gpios;
/delete-property/ retention-gpios;
/delete-property/ pwm-gpios;
npm1300_ek_ldo1: LDO1 {
/delete-property/ regulator-min-microvolt;
/delete-property/ regulator-max-microvolt;
/delete-property/ regulator-initial-mode;
npm1300_ek_ldo2: LDO2 {
regulator-init-microvolt = <1800000>;
regulator-initial-mode = <NPM1300_LDSW_MODE_LDO>;
regulator-boot-on;
npm1300_ek_charger: charger {
compatible = "nordic,npm1300-charger";
term-microvolt = <4200000>;
term-warm-microvolt = <4000000>;
current-microamp = <400000>;
dischg-limit-microamp = <1000000>;
vbus-limit-microamp = <500000>;
thermistor-ohms = <10000>;
thermistor-beta = <3380>;
charging-enable;
vbatlow-charge-enable;
npm1300_ek_buttons: buttons {
compatible = "gpio-keys";
pmic_button0: pmic_button_0 {
gpios = < &npm1300_ek_gpio 0 GPIO_ACTIVE_HIGH>;
label = "Pmic button switch 0";
zephyr,code = <INPUT_KEY_0>;
npm1300_ek_leds: leds {
compatible = "nordic,npm1300-led";
nordic,led0-mode = "host";
nordic,led1-mode = "charging";
nordic,led2-mode = "error";
  •  hi,I'm sorry for the late reply.As shown as the picture,The picture one is VBUSOUT, the picture two is bulk2 and the last picture is vbusin.
  • hi,
    The parts related to npm1300 include the following code and dts.
    static const struct device *regulators = DEVICE_DT_GET(DT_NODELABEL(npm1300_ek_regulators));
    static const struct device *charger = DEVICE_DT_GET(DT_NODELABEL(npm1300_ek_charger));
    static const struct device *leds = DEVICE_DT_GET(DT_NODELABEL(npm1300_ek_leds));
    static const struct device *pmic = DEVICE_DT_GET(DT_NODELABEL(npm1300_ek_pmic));
    static float max_charge_current;
    static float term_charge_current;
    static int64_t ref_time;
    static const struct battery_model battery_model = {
    #include "lq_25C.inc"
    /********************thread define*******************************/
    #define PMIC_STACK_SIZE 1024
    #define PMIC_PRIORITY 2
    K_THREAD_STACK_DEFINE(pmic_stack_area, PMIC_STACK_SIZE);
    struct k_thread pmic_thread_data;
    static int read_sensors(const struct device *charger, float *voltage, float *current, float *temp)
        struct sensor_value value;
        int ret;
        ret = sensor_sample_fetch(charger);
        if (ret < 0) {
            return ret;
        sensor_channel_get(charger, SENSOR_CHAN_GAUGE_VOLTAGE, &value);
        *voltage = (float)value.val1 + ((float)value.val2 / 1000000);
        sensor_channel_get(charger, SENSOR_CHAN_GAUGE_TEMP, &value);
        *temp = (float)value.val1 + ((float)value.val2 / 1000000);
        sensor_channel_get(charger, SENSOR_CHAN_GAUGE_AVG_CURRENT, &value);
        *current = (float)value.val1 + ((float)value.val2 / 1000000);
        return 0;
    int fuel_gauge_init(const struct device *charger)
        struct nrf_fuel_gauge_init_parameters parameters = { .model = &battery_model };
        int ret;
        memset(&gBatteryStatus, 0x00,sizeof(gBatteryStatus));
        ret = read_sensors(charger, &parameters.v0, &parameters.i0, &parameters.t0);
        if (ret < 0) {
            return ret;
        /* Store charge nominal and termination current, needed for ttf calculation */
        sensor_channel_get(charger, SENSOR_CHAN_GAUGE_DESIRED_CHARGING_CURRENT, &value);
        max_charge_current = (float)value.val1 + ((float)value.val2 / 1000000);
        term_charge_current = max_charge_current / 10.f;
        nrf_fuel_gauge_init(&parameters, NULL);
        ref_time = k_uptime_get();
        return 0;
    int fuel_gauge_update(const struct device *charger)
        float voltage;
        float current;
        float temp;
        float soc;
        float tte;
        float ttf;
        float delta;
        int ret;
        struct sensor_value error;
        struct sensor_value status;
        //static int led_set = 0;
        static int buzzer_count = 0;
        ret = read_sensors(charger, &voltage, &current, &temp);
        if (ret < 0) {
            printk("Error: Could not read from charger device\n");
            return ret;
        delta = (float) k_uptime_delta(&ref_time) / 1000.f;
        soc = nrf_fuel_gauge_process(voltage, current, temp, delta, NULL);
        tte = nrf_fuel_gauge_tte_get();
        ttf = nrf_fuel_gauge_ttf_get(-max_charge_current, -term_charge_current);
        sensor_channel_get(charger, SENSOR_CHAN_NPM1300_CHARGER_STATUS, &status);
        sensor_channel_get(charger, SENSOR_CHAN_NPM1300_CHARGER_ERROR, &error);
        printk("V: %.3f, I: %.3f, T: %.2f, ", voltage, current, temp);
        printk("SoC: %.2f, TTE: %.0f, TTF: %.0f\n", soc, tte, ttf);
        printk("Charger Status: %d, Error: %d\n", status.val1, error.val1);
        return 0;
    * function:pmic_thread_run
    * description:pmic thread run
    *      err = k_sem_take(&ble_sem, K_FOREVER);
    * date:k_sched_lock(); k_sched_unlock();
    static void pmic_thread_run(void *p1, void *p2, void *p3)
        if (!device_is_ready(charger))
            printk("Charger device not ready.\n");
            return 0;
        if (fuel_gauge_init(charger) < 0) {
            printk("Could not initialise fuel gauge.\n");
            return 0;
        printk("PMIC device ok\n");
        led_on(leds, 0U);
        while (1)
            fuel_gauge_update(charger);
            k_msleep(PMIC_SLEEP_TIME_MS);
        return;
    * function:pmic_init
    * description:pmic module init
    int pmic_init(void)
        k_tid_t my_tid;
        if (!device_is_ready(leds)) {
            printk("Error: led device is not ready\n");
            return;
        if (!device_is_ready(pmic)) {
            printk("Pmic device not ready.\n");
            return;
        if (!device_is_ready(regulators)) {
            printk("Error: Regulator device is not ready\n");
            return 0;
        led_off(leds, 0U);
        my_tid = k_thread_create(&pmic_thread_data, pmic_stack_area,
                                     K_THREAD_STACK_SIZEOF(pmic_stack_area),
                                     pmic_thread_run,
                                     NULL, NULL, NULL,
                                     PMIC_PRIORITY, 0, K_NO_WAIT);
        k_thread_name_set(&pmic_thread_data, "pmic_thread");
        return 0;
  • Hi sun yang, sorry for the delay.
    Thank you for the traces. Feedback from the PMIC team is that this might be errata 24:
    [Errata 24] BUCK, CONTROL: Restart fails after reset with VBUS and VBAT connected.
    Could you try the suggested workaround?
  • Hi
    i'm currently designing around a nPM1300 + nRF52840
    please you confirm that the topic above applies to engineering samples of the nPM1300, and not revision 1 of nPM1300 ?
    the errata 24 is supposed to have been fixed in rev1 so there is no more risk of a faulty power cycling or shipmode exit right ?
    best regards
    bob
  • Hi Bob, sorry for the late reply.
    Our PMIC team is pointing towards errata 24, however, Sun Yang has not confirmed whether the workaround works.
    Yes, anomaly 24 has been fixed in Revision 1. None of the remaining errata for Revision 1 are related to shipmode exit or difficulties power cycling the device. Anomaly [32] leads to reduced efficency in Hysteretic mode.
    You are very much welcome to open a new ticket in case you would like to further discuss the details of your project.
    Håkon
