MacBook M1. Latest macOS. SDK v2.5.2. Building blinky w/ CONFIG_BOOTLOADER_MCUBOOT=1 enabled.
Doesn't matter if I start an nrfutil shell* or my normal settings.
* nrfutil toolchain-manager launch --shell --ncs-version v2.5.0
$ west build -b circuitdojo_feather_nrf9160_ns [0/222] Performing build step for 'tfm' [4/8] Linking C executable bin/tfm_s.axf Memory region Used Size Region Size %age Used FLASH: 31544 B 32256 B 97.79% RAM: 18832 B 32 KB 57.47% [8/8] Generating ../bin/tfm_s.elf [1/222] Performing build step for 'mcuboot_subimage' [18/124] Generating zephyr/autogen-pubkey.c FAILED: zephyr/autogen-pubkey.c cd .../nrf-sdk-test-2024-02-28/blinky/build/mcuboot && /opt/nordic/ncs/toolchains/20d68df7e5/bin/python3 /opt/nordic/ncs/v2.5.2/bootloader/mcuboot/scripts/imgtool.py getpub -k /opt/nordic/ncs/v2.5.2/bootloader/mcuboot/root-ec-p256.pem > .../nrf-sdk-test-2024-02-28/blinky/build/mcuboot/zephyr/autogen-pubkey.c Traceback (most recent call last): File "/opt/nordic/ncs/v2.5.2/bootloader/mcuboot/scripts/imgtool.py", line 19, in <module> from imgtool import main File "/opt/nordic/ncs/v2.5.2/bootloader/mcuboot/scripts/imgtool/main.py", line 26, in <module> from imgtool import image, imgtool_version File "/opt/nordic/ncs/v2.5.2/bootloader/mcuboot/scripts/imgtool/image.py", line 35, in <module> from cryptography.hazmat.primitives.kdf.hkdf import HKDF File "/Users/me/Library/Python/3.9/lib/python/site-packages/cryptography/hazmat/primitives/kdf/hkdf.py", line 13, in <module> from cryptography.hazmat.primitives import constant_time, hashes, hmac File "/Users/me/Library/Python/3.9/lib/python/site-packages/cryptography/hazmat/primitives/hmac.py", line 12, in <module> from cryptography.hazmat.backends.openssl.hmac import _HMACContext File "/Users/me/Library/Python/3.9/lib/python/site-packages/cryptography/hazmat/backends/openssl/__init__.py", line 6, in <module> from cryptography.hazmat.backends.openssl.backend import backend File "/Users/me/Library/Python/3.9/lib/python/site-packages/cryptography/hazmat/backends/openssl/backend.py", line 63, in <module> from cryptography.hazmat.bindings.openssl import binding File "/Users/me/Library/Python/3.9/lib/python/site-packages/cryptography/hazmat/bindings/openssl/binding.py", line 14, in <module> from cryptography.hazmat.bindings._openssl import ffi, lib ImportError: dlopen(/Users/me/Library/Python/3.9/lib/python/site-packages/_cffi_backend.cpython-39-darwin.so, 0x0002): tried: '/Users/me/Library/Python/3.9/lib/python/site-packages/_cffi_backend.cpython-39-darwin.so' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')), '/System/Volumes/Preboot/Cryptexes/OS/Users/me/Library/Python/3.9/lib/python/site-packages/_cffi_backend.cpython-39-darwin.so' (no such file), '/Users/me/Library/Python/3.9/lib/python/site-packages/_cffi_backend.cpython-39-darwin.so' (mach-o file, but is an incompatible architecture (have 'arm64', need 'x86_64')) [29/124] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj ninja: build stopped: subcommand failed. [2/222] Performing install step for 'tfm' -- Install configuration: "RelWithDebInfo" [36/222] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.5.2/modules/crypto/mbedtls/library/gcm.c.obj FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf cd .../nrf-sdk-test-2024-02-28/blinky/build/mcuboot && /opt/nordic/ncs/toolchains/20d68df7e5/Cellar/cmake/3.20.5/bin/cmake --build . -- [48/222] Building C object modules/nrf/subsys/nrf_security/src/CMakeFiles/mbedcrypto.dir/opt/nordic/ncs/v2.5.2/modules/crypto/mbedtls/library/gcm.c.obj ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/20d68df7e5/bin/cmake --build .../nrf-sdk-test-2024-02-28/blinky/build $
The provided Python is x86_64, my system is aarch64.
As you can see, the build system uses its own Python, but links to my system files.
The provided toolchain Python should use its own site-packges.
This is a clean install of v2.5.2 from nRF Connect Desktop.
Thanks in advance,
- Mikael
