When there is a lot of traffic on the SPI-bus (connected to an SD-card), we see the following error:
`<err> spi_nrfx_spim: Update exceeds current buffer`
Why does it happen? How can we try to avoid it?
Thanks in advance
Thanks in advance
Thanks for the quick reply. I unfortunately can not share the entire code. I can give some context.
We are using the spi driver to talk to an sd card. We use the sdmmc-subsystem and access it over the disk-access-API.
The disc-access-API is used for different things (the sd-card has a filesystem and a raw partition).
We have cherry picked this fix: https://github.com/zephyrproject-rtos/zephyr/pull/67209 to allow for better sharing of the resource (without the fix, if two threads try to access the sd-card concurrently, one of them would fail).
Do you have any hints as to what that error (spi_nrfx_spim: Update exceeds current buffer) might mean?
If possible, I could try to reduce the code later to something I could share, but it is likely difficult.
I can't say that I've seen this error before. Can you set a breakpoint here and share what ctx-tx_len and len is set to when the error happens?
regards
Jared
I will try.
len=8 and ctx->tx_len=1
