Hello folks,
Help would be much appreciated. I'm trying to port the nRF Desktop example.
I'll start with the environment.
===== Environment =====
- Windows 11 Machine (MINGW bash terminal)
- VSCode 1.86 + NRF Connect for VSCode v2023.11.301
- Toolchain and SDK for nrfConnect v2.5.0
===== Hardware =====
- Xiao BLE Sense (nRF52840)
===== Objective =====
- Port the nRF Desktop example (which works like a charm on the nRF52840dk) to our production board -- the Xiao BLE Sense
This is a large undertaking, and as such, I'm trying to minimize the amount of content that actually GETS ported.
So my simplified objective is:
- Replicate the nRF Desktop Bluetooth functionality (CAF-custom BLE Bond, State, Adv, Peer Control) minimally on Xiao BLE Sense
===== What I've tried so far =====
I wanted a minimal version of nRF Desktop, so I carefully started paring down the functionality.
- I cloned the nrf_desktop sample under the name "mini_desktop" and built it for the nRF52840dk.
- I went into prj.conf and gradually disabled KConfig options that were not included in the orange items from my simplified objective.
- Checked the build summary (nRF Connect extension tab)
- Source files -- the files that were no longer included due to KConfig were removed (placed in temp subdirectory and excluded from CMakeLists)
- Config files -- same as above
- Went through KConfig options, fragments, and h files from configuration
- Temporarily disabled each file, re-enabling any file that caused build faults
- Ended up with a significantly smaller build with the following structure
mini_desktop/ ┣ configuration/ ┃ ┣ common/ ┃ ┃ ┣ dev_descr.h ┃ ┃ ┣ hid_keyboard_leds.h ┃ ┃ ┣ hid_keymap.h ┃ ┃ ┣ hid_report_consumer_ctrl.h ┃ ┃ ┣ hid_report_desc.c ┃ ┃ ┣ hid_report_desc.h ┃ ┃ ┣ hid_report_keyboard.h ┃ ┃ ┣ hid_report_mouse.h ┃ ┃ ┣ hid_report_system_ctrl.h ┃ ┃ ┣ hid_report_user_config.h ┃ ┃ ┣ led_state.h ┃ ┃ ┣ port_state.h ┃ ┃ ┗ settings_loader_def.h ┃ ┣ nrf52840dk_nrf52840/ ┃ ┃ ┣ app.overlay ┃ ┃ ┣ buttons_def.h ┃ ┃ ┣ click_detector_def.h ┃ ┃ ┣ hid_keyboard_leds_def.h ┃ ┃ ┣ hid_keyboard_leds_def_keyboard.h ┃ ┃ ┣ hid_keymap_def.h ┃ ┃ ┣ hid_keymap_def_keyboard.h ┃ ┃ ┣ led_state_def.h ┃ ┃ ┣ pm_static.yml ┃ ┃ ┣ pm_static_fast_pair.yml ┃ ┃ ┣ pm_static_release.yml ┃ ┃ ┣ port_state_def.h ┃ ┃ ┗ prj.conf ┃ ┗ xiao_ble_sense/ ┃ ┣ app.overlay ┃ ┣ buttons_def.h ┃ ┣ click_detector_def.h ┃ ┣ hid_keyboard_leds_def.h ┃ ┣ hid_keyboard_leds_def_keyboard.h ┃ ┣ hid_keymap_def.h ┃ ┣ hid_keymap_def_keyboard.h ┃ ┣ led_state_def.h ┃ ┣ pm_static.yml ┃ ┣ pm_static_fast_pair.yml ┃ ┣ pm_static_release.yml ┃ ┣ port_state_def.h ┃ ┗ prj.conf ┣ dts/ ┃ ┗ bindings/ ┃ ┗ battery-charger.yaml ┣ src/ ┃ ┣ events/ ┃ ┃ ┣ battery_event.c ┃ ┃ ┣ battery_event.h ┃ ┃ ┣ ble_dongle_peer_event.c ┃ ┃ ┣ ble_dongle_peer_event.h ┃ ┃ ┣ ble_event.c ┃ ┃ ┣ ble_event.h ┃ ┃ ┣ CMakeLists.txt ┃ ┃ ┣ config_event.c ┃ ┃ ┣ config_event.h ┃ ┃ ┣ cpu_load_event.c ┃ ┃ ┣ cpu_load_event.h ┃ ┃ ┣ hids_event.c ┃ ┃ ┣ hids_event.h ┃ ┃ ┣ hid_event.c ┃ ┃ ┣ hid_event.h ┃ ┃ ┣ Kconfig ┃ ┃ ┣ motion_event.c ┃ ┃ ┣ motion_event.h ┃ ┃ ┣ passkey_event.c ┃ ┃ ┣ passkey_event.h ┃ ┃ ┣ selector_event.c ┃ ┃ ┣ selector_event.h ┃ ┃ ┣ usb_event.c ┃ ┃ ┣ usb_event.h ┃ ┃ ┣ wheel_event.c ┃ ┃ ┗ wheel_event.h ┃ ┣ hw_interface/ ┃ ┃ ┣ board.c ┃ ┃ ┣ CMakeLists.txt ┃ ┃ ┣ Kconfig ┃ ┃ ┗ Kconfig.board ┃ ┣ modules/ ┃ ┃ ┣ bas.c ┃ ┃ ┣ ble_bond.c ┃ ┃ ┣ CMakeLists.txt ┃ ┃ ┣ dev_descr.c ┃ ┃ ┣ hids.c ┃ ┃ ┣ hid_state.c ┃ ┃ ┣ hid_state_pm.c ┃ ┃ ┣ Kconfig ┃ ┃ ┣ Kconfig.bas ┃ ┃ ┣ Kconfig.ble_bond ┃ ┃ ┣ Kconfig.caf_ble_adv.default ┃ ┃ ┣ Kconfig.caf_ble_state.default ┃ ┃ ┣ Kconfig.caf_power_manager.default ┃ ┃ ┣ Kconfig.caf_settings_loader.default ┃ ┃ ┣ Kconfig.dev_descr ┃ ┃ ┣ Kconfig.hids ┃ ┃ ┣ Kconfig.hid_forward ┃ ┃ ┣ Kconfig.hid_state ┃ ┃ ┣ Kconfig.led_state ┃ ┃ ┗ led_state.c ┃ ┣ util/ ┃ ┃ ┣ bt_le_adv_prov_uuid16.c ┃ ┃ ┣ CMakeLists.txt ┃ ┃ ┣ config_channel_transport.c ┃ ┃ ┣ config_channel_transport.h ┃ ┃ ┣ hwid.c ┃ ┃ ┣ hwid.h ┃ ┃ ┗ Kconfig ┃ ┗ main.c ┣ CMakeLists.txt ┣ Kconfig ┣ Kconfig.ble ┣ Kconfig.debug ┣ Kconfig.defaults ┣ Kconfig.hid ┣ nrf_desktop.ld ┣ README.rst ┗ sample.yaml
And the following prj.conf
# # Copyright (c) 2019 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # ################################################################################ # Application Configuration # (Leave alone, disabled by default) CONFIG_DESKTOP_INIT_LOG_MOTION_EVENT=n CONFIG_DESKTOP_INIT_LOG_HID_REPORT_EVENT=n CONFIG_DESKTOP_INIT_LOG_HID_REPORT_SENT_EVENT=n CONFIG_CAF_INIT_LOG_KEEP_ALIVE_EVENTS=n # Bluetooth role defines CONFIG_DESKTOP_ROLE_HID_PERIPHERAL=y CONFIG_DESKTOP_PERIPHERAL_TYPE_MOUSE=y CONFIG_DESKTOP_DEVICE_PID=0x52DE CONFIG_DESKTOP_HID_BOOT_INTERFACE_MOUSE=y # (Disable 01) Motion Buttons # CONFIG_DESKTOP_MOTION_BUTTONS_ENABLE=y # CONFIG_DESKTOP_MOTION_BUTTONS_UP_KEY_ID=0 # CONFIG_DESKTOP_MOTION_BUTTONS_DOWN_KEY_ID=3 # CONFIG_DESKTOP_MOTION_BUTTONS_LEFT_KEY_ID=2 # CONFIG_DESKTOP_MOTION_BUTTONS_RIGHT_KEY_ID=1 CONFIG_CAF_BUTTONS=y CONFIG_CAF_BUTTONS_POLARITY_INVERSED=y CONFIG_CAF_BUTTONS_PM_KEEP_ALIVE=n CONFIG_CAF_CLICK_DETECTOR=y CONFIG_CAF_LEDS=y # (Disable 03) USB # CONFIG_DESKTOP_USB_ENABLE=y CONFIG_DESKTOP_BLE_USE_DEFAULT_ID=y CONFIG_DESKTOP_BLE_PEER_CONTROL=y CONFIG_DESKTOP_BLE_PEER_CONTROL_BUTTON=0x0000 CONFIG_DESKTOP_BLE_PEER_ERASE_ON_START=y # (Disable 04) LOW LATENCY # CONFIG_DESKTOP_BLE_SECURITY_FAIL_TIMEOUT_S=10 # CONFIG_DESKTOP_BLE_LOW_LATENCY_LOCK=y # CONFIG_DESKTOP_HFCLK_LOCK_ENABLE=y # # (Change 06) Manually disabling DESKTOP_LATENCY # CONFIG_DESKTOP_BLE_LATENCY_ENABLE=n # (Disable 02) DFU tasks # CONFIG_DESKTOP_CONFIG_CHANNEL_ENABLE=y # CONFIG_DESKTOP_CONFIG_CHANNEL_DFU_ENABLE=y ################################################################################ # Zephyr Configuration CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=1536 CONFIG_ISR_STACK_SIZE=1536 CONFIG_MAIN_STACK_SIZE=840 CONFIG_BT_RX_STACK_SIZE=2048 CONFIG_BT_HCI_TX_STACK_SIZE_WITH_PROMPT=y CONFIG_BT_HCI_TX_STACK_SIZE=1536 CONFIG_BOOT_BANNER=n CONFIG_NUM_COOP_PRIORITIES=10 CONFIG_NUM_PREEMPT_PRIORITIES=11 CONFIG_HEAP_MEM_POOL_SIZE=512 CONFIG_SYS_CLOCK_TICKS_PER_SEC=1000 CONFIG_SYSTEM_CLOCK_NO_WAIT=y CONFIG_HW_STACK_PROTECTION=y CONFIG_RESET_ON_FATAL_ERROR=n CONFIG_GPIO=y CONFIG_REBOOT=y CONFIG_SPEED_OPTIMIZATIONS=y CONFIG_PWM=y CONFIG_LED=y CONFIG_LED_PWM=y CONFIG_BT_MAX_PAIRED=2 CONFIG_BT_ID_MAX=3 # (Disable 05) Low Latency reduction part 2 # CONFIG_BT_CTLR_SDC_LLPM=y # CONFIG_BT_CTLR_TX_PWR_DYNAMIC_CONTROL=y # CONFIG_BT_CONN_TX_MAX=4 CONFIG_ENTROPY_CC3XX=n ################################################################################ # Assert (Default) CONFIG_ASSERT=y CONFIG_ASSERT_LEVEL=2 ################################################################################ # Force enable logging (user) CONFIG_SERIAL=y CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y CONFIG_LOG=y CONFIG_LOG_DEFAULT_LEVEL=3 # Desktop Logging (default) CONFIG_DESKTOP_LOG=y # (Value Changed above @Force Enable Logging) # CONFIG_SERIAL=n # CONFIG_CONSOLE=n # CONFIG_UART_CONSOLE=n ################################################################################ # Bootloader Configuration # CONFIG_SECURE_BOOT=y # CONFIG_BUILD_S1_VARIANT=y # CONFIG_FW_INFO=y # CONFIG_FW_INFO_FIRMWARE_VERSION=1 # CONFIG_SB_SIGNING_KEY_FILE="b0_private.pem"
===== Git repository containing mini-desktop =====
As I type this all out, I'm realizing that the easiest thing for me to do would be to provide a link to a git repository.
Here are my current efforts https://github.com/FinnWBiggs/mini_desktop
===== The Problem =====
Building for xiao fails during linking as follows:
[308/316] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\Users\finnb\Documents\auli\mini_desktop\build_xiao\zephyr && C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.exe -E true""
c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/subsys/random/libsubsys__random.a(rand32_xoshiro128.c.obj): in function `xoshiro128_initialize':
C:/ncs/v2.5.0/zephyr/subsys/random/rand32_xoshiro128.c:51: undefined reference to `__device_dts_ord_101'
collect2.exe: error: ld returned 1 exit status
===== Seeking source of problem =====
Exploring the nature of __device_dts_ord_101 leads me to check devicetree_generated.h
Item 101 of that list is /soc/crypto@5002a000, which I can validate exists in my device tree specifications
That node is specified at "C:\ncs\v2.5.0\zephyr\dts\arm\nordic\nrf52840.dtsi" and has the status "okay".
===== Conclusion =====
What should I do to finish porting mini-desktop to the Xiao BLE Sense?
Thank you for any help you can provide
- Finn
