nrf52833 DK hci uart le scan enable returns error
I am using an nrf52833 DK connected to a raspberry PI 4B on uart (used uart1 so I can also do debug/log on J-LINK)
Built and flashed the hci_uart sample on the board (with uart1 configuration on different pins)
On raspberry PI I have succesfully attached the serial port to hci1 (using basically the same code from blueZ btattach with baud 115200 and no flow control)
Then,  I have tried to start a passive le scan (similar to 'hcitool lescan --privacy --passive --duplicates' command).
Also tried without --privacy or --duplicates or --passive. Same result.
When I am executing LE Set Scan Enable the response is Invalid HCI Command Parameters (0x12).
< HCI Command: LE Set Scan Parameters (0x08|0x000b) plen 7 #5575 [hci1] 8594.745437
Type: Passive (0x00)
Interval: 10.000 msec (0x0010)
Window: 10.000 msec (0x0010)
Own address type: Random (0x01)
Filter policy: Accept all advertisement (0x00)
> HCI Event: Command Complete (0x0e) plen 4 #5576 [hci1] 8594.747200
LE Set Scan Parameters (0x08|0x000b) ncmd 1
Status: Success (0x00)
< HCI Command: LE Set Scan Enable (0x08|0x000c) plen 2 #5577 [hci1] 8594.747343
Scanning: Enabled (0x01)
Filter duplicates: Disabled (0x00)
> HCI Event: Command Complete (0x0e) plen 4 #5578 [hci1] 8594.748648
LE Set Scan Enable (0x08|0x000c) ncmd 1
Status: Invalid HCI Command Parameters (0x12)
Here is the full btmon output on raspberry PI with the entire execution (including hci attach)
@ RAW Open: poltys_tool (privileged) version 2.22        {0x0003} 8593.647634
@ RAW Close: poltys_tool        {0x0003} 8593.647716
= New Index: 00:00:00:00:00:00 (Primary,UART,hci1)        [hci1] 8593.651327
= Open Index: 00:00:00:00:00:00        [hci1] 8593.651641
< HCI Command: Reset (0x03|0x0003) plen 0        #5483 [hci1] 8593.651707
@ RAW Open: poltys_tool (privileged) version 2.22        {0x0003} 8593.652305
@ RAW Close: poltys_tool        {0x0003} 8593.652486
@ RAW Open: poltys_tool (privileged) version 2.22        {0x0003} 8593.652872
> HCI Event: Command Complete (0x0e) plen 4        #5484 [hci1] 8593.653079
      Reset (0x03|0x0003) ncmd 1
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0        #5485 [hci1] 8593.653178
@ RAW Close: poltys_tool        {0x0003} 8593.653853
@ RAW Open: poltys_tool (privileged) version 2.22        {0x0003} [hci1] 8593.654397
@ RAW Open: poltys_tool (privileged) version 2.22        {0x0004} 8593.654457
> HCI Event: Command Complete (0x0e) plen 12        #5486 [hci1] 8593.655306
      Read Local Supported Features (0x04|0x0003) ncmd 1
        Features: 0x00 0x00 0x00 0x00 0x60 0x00 0x00 0x00
          BR/EDR Not Supported
          LE Supported (Controller)
< HCI Command: Read Local Version Information (0x04|0x0001) plen 0        #5487 [hci1] 8593.655394
> HCI Event: Command Complete (0x0e) plen 12        #5488 [hci1] 8593.659027
      Read Local Version Information (0x04|0x0001) ncmd 1
        HCI version: Reserved (0x0d) - Revision 4354 (0x1102)
        LMP version: Reserved (0x0d) - Subversion 4354 (0x1102)
        Manufacturer: Nordic Semiconductor ASA (89)
< HCI Command: Read BD ADDR (0x04|0x0009) plen 0        #5489 [hci1] 8593.659137
> HCI Event: Command Complete (0x0e) plen 10        #5490 [hci1] 8593.660788
      Read BD ADDR (0x04|0x0009) ncmd 1
        Address: 00:00:00:00:00:00 (OUI 00-00-00)
< HCI Command: Read Local Supported Commands (0x04|0x0002) plen 0        #5491 [hci1] 8593.660892
> HCI Event: Command Complete (0x0e) plen 68        #5492 [hci1] 8593.667577
      Read Local Supported Commands (0x04|0x0002) ncmd 1
        Commands: 66 entries
          Disconnect (Octet 0 - Bit 5)
          Read Remote Version Information (Octet 2 - Bit 7)
          Set Event Mask (Octet 5 - Bit 6)
          Reset (Octet 5 - Bit 7)
          Read Transmit Power Level (Octet 10 - Bit 2)
          Set Controller To Host Flow Control (Octet 10 - Bit 5)
          Host Buffer Size (Octet 10 - Bit 6)
          Host Number of Completed Packets (Octet 10 - Bit 7)
          Read Local Version Information (Octet 14 - Bit 3)
          Read Local Supported Features (Octet 14 - Bit 5)
          Read BD ADDR (Octet 15 - Bit 1)
          Read RSSI (Octet 15 - Bit 5)
          Set Event Mask Page 2 (Octet 22 - Bit 2)
          LE Set Event Mask (Octet 25 - Bit 0)
          LE Read Buffer Size (Octet 25 - Bit 1)
          LE Read Local Supported Features (Octet 25 - Bit 2)
          LE Set Random Address (Octet 25 - Bit 4)
          LE Set Advertising Parameters (Octet 25 - Bit 5)
          LE Read Advertising Channel TX Power (Octet 25 - Bit 6)
          LE Set Advertising Data (Octet 25 - Bit 7)
          LE Set Scan Response Data (Octet 26 - Bit 0)
          LE Set Advertise Enable (Octet 26 - Bit 1)
          LE Set Scan Parameters (Octet 26 - Bit 2)
          LE Set Scan Enable (Octet 26 - Bit 3)
          LE Create Connection (Octet 26 - Bit 4)
          LE Create Connection Cancel (Octet 26 - Bit 5)
          LE Read White List Size (Octet 26 - Bit 6)
          LE Clear White List (Octet 26 - Bit 7)
          LE Add Device To White List (Octet 27 - Bit 0)
          LE Remove Device From White List (Octet 27 - Bit 1)
          LE Connection Update (Octet 27 - Bit 2)
          LE Set Host Channel Classification (Octet 27 - Bit 3)
          LE Read Channel Map (Octet 27 - Bit 4)
          LE Read Remote Used Features (Octet 27 - Bit 5)
          LE Encrypt (Octet 27 - Bit 6)
          LE Rand (Octet 27 - Bit 7)
          LE Start Encryption (Octet 28 - Bit 0)
          LE Long Term Key Request Reply (Octet 28 - Bit 1)
          LE Long Term Key Request Neg Reply (Octet 28 - Bit 2)
          LE Read Supported States (Octet 28 - Bit 3)
          LE Receiver Test (Octet 28 - Bit 4)
          LE Transmitter Test (Octet 28 - Bit 5)
          LE Test End (Octet 28 - Bit 6)
          Read Authenticated Payload Timeout (Octet 32 - Bit 4)
          Write Authenticated Payload Timeout (Octet 32 - Bit 5)
          LE Set Data Length (Octet 33 - Bit 6)
          LE Read Suggested Default Data Length (Octet 33 - Bit 7)
          LE Write Suggested Default Data Length (Octet 34 - Bit 0)
          LE Read Local P-256 Public Key (Octet 34 - Bit 1)
          LE Generate DHKey (Octet 34 - Bit 2)
          LE Add Device To Resolving List (Octet 34 - Bit 3)
          LE Remove Device From Resolving List (Octet 34 - Bit 4)
          LE Clear Resolving List (Octet 34 - Bit 5)
          LE Read Resolving List Size (Octet 34 - Bit 6)
          LE Set Address Resolution Enable (Octet 35 - Bit 1)
          LE Set Resolvable Private Address Timeout (Octet 35 - Bit 2)
          LE Read Maximum Data Length (Octet 35 - Bit 3)
          LE Read PHY (Octet 35 - Bit 4)
          LE Set Default PHY (Octet 35 - Bit 5)
          LE Set PHY (Octet 35 - Bit 6)
          LE Enhanced Receiver Test (Octet 35 - Bit 7)
          LE Enhanced Transmitter Test (Octet 36 - Bit 0)
          LE Read Transmit Power (Octet 38 - Bit 7)
          LE Set Privacy Mode (Octet 39 - Bit 2)
          Octet 41 - Bit 2
          Octet 45 - Bit 6
< HCI Command: LE Read Local Supported Features (0x08|0x0003) plen 0        #5493 [hci1] 8593.667664
> HCI Event: Command Complete (0x0e) plen 12        #5494 [hci1] 8593.669486
      LE Read Local Supported Features (0x08|0x0003) ncmd 1
        Features: 0xfd 0x49 0x00 0x00 0x00 0x00 0x00 0x00
          LE Encryption
          Extended Reject Indication
          Slave-initiated Features Exchange
          LE Ping
          LE Data Packet Length Extension
          LL Privacy
          Extended Scanner Filter Policies
          LE 2M PHY
          LE Coded PHY
          Channel Selection Algorithm #2
< HCI Command: LE Read Buffer Size (0x08|0x0002) plen 0        #5495 [hci1] 8593.669564
> HCI Event: Command Complete (0x0e) plen 7        #5496 [hci1] 8593.670991
      LE Read Buffer Size (0x08|0x0002) ncmd 1
        Data packet length: 27
        Num data packets: 3
< HCI Command: LE Read Supported States (0x08|0x001c) plen 0        #5497 [hci1] 8593.671064
> HCI Event: Command Complete (0x0e) plen 12        #5498 [hci1] 8593.672884
      LE Read Supported States (0x08|0x001c) ncmd 1
        States: 0x000000ff000300ff
          Non-connectable Advertising State
          Scannable Advertising State
          Connectable Advertising State
          High Duty Cycle Directed Advertising State
          Passive Scanning State
          Active Scanning State
          Initiating State
            and Connection State (Master Role)
          Connection State (Slave Role)
            and Initiating State
            and Master Role & Slave Role
          Low Duty Cycle Directed Advertising State
            and Connection State (Slave Role)
            and Slave Role & Slave Role
< HCI Command: Set Event Mask (0x03|0x0001) plen 8        #5499 [hci1] 8593.672962
        Mask: 0x200080000204e890
          Disconnection Complete
          Encryption Change
          Read Remote Version Information Complete
          Command Complete
          Command Status
          Hardware Error
          Data Buffer Overflow
          Encryption Key Refresh Complete
          LE Meta
> HCI Event: Command Complete (0x0e) plen 4        #5500 [hci1] 8593.674788
      Set Event Mask (0x03|0x0001) ncmd 1
< HCI Command: LE Set Event Mask (0x08|0x0001) plen 8        #5501 [hci1] 8593.674863
        Mask: 0x0000000000080fdf
          LE Connection Complete
          LE Advertising Report
          LE Connection Update Complete
          LE Read Remote Used Features Complete
          LE Data Length Change
          LE Read Local P-256 Public Key Complete
          LE Generate DHKey Complete
          LE Enhanced Connection Complete
          LE Direct Advertising Report
          LE PHY Update Complete
          LE Channel Selection Algorithm
> HCI Event: Command Complete (0x0e) plen 4        #5502 [hci1] 8593.676690
      LE Set Event Mask (0x08|0x0001) ncmd 1
< HCI Command: LE Read Advertising Channel TX Power (0x08|0x0007) plen 0        #5503 [hci1] 8593.676759
> HCI Event: Command Complete (0x0e) plen 5        #5504 [hci1] 8593.678002
      LE Read Advertising Channel TX Power (0x08|0x0007) ncmd 1
        TX power: 0 dbm (0x00)
< HCI Command: LE Read Transmit Power (0x08|0x004b) plen 0        #5505 [hci1] 8593.678071
> HCI Event: Command Complete (0x0e) plen 6        #5506 [hci1] 8593.679584
      LE Read Transmit Power (0x08|0x004b) ncmd 1
        Min Tx power: -40 dBm
        Max Tx power: 8 dBm
< HCI Command: LE Read White List Size (0x08|0x000f) plen 0        #5507 [hci1] 8593.679654
> HCI Event: Command Complete (0x0e) plen 5        #5508 [hci1] 8593.680873
      LE Read White List Size (0x08|0x000f) ncmd 1
< HCI Command: LE Clear White List (0x08|0x0010) plen 0        #5509 [hci1] 8593.680942
> HCI Event: Command Complete (0x0e) plen 4        #5510 [hci1] 8593.682072
      LE Clear White List (0x08|0x0010) ncmd 1
< HCI Command: LE Read Resolving List Size (0x08|0x002a) plen 0        #5511 [hci1] 8593.682141
> HCI Event: Command Complete (0x0e) plen 5        #5512 [hci1] 8593.683358
      LE Read Resolving List Size (0x08|0x002a) ncmd 1
< HCI Command: LE Clear Resolving List (0x08|0x0029) plen 0        #5513 [hci1] 8593.683432
> HCI Event: Command Complete (0x0e) plen 4        #5514 [hci1] 8593.684566
      LE Clear Resolving List (0x08|0x0029) ncmd 1
< HCI Command: LE Set Resolvable Private Address Timeout (0x08|0x002e) plen 2        #5515 [hci1] 8593.684645
        Timeout: 900 seconds
> HCI Event: Command Complete (0x0e) plen 4        #5516 [hci1] 8593.685938
      LE Set Resolvable Private Address Timeout (0x08|0x002e) ncmd 1
< HCI Command: LE Read Maximum Data Length (0x08|0x002f) plen 0        #5517 [hci1] 8593.686015
> HCI Event: Command Complete (0x0e) plen 12        #5518 [hci1] 8593.688481
      LE Read Maximum Data Length (0x08|0x002f) ncmd 1
        Max TX octets: 251
        Max TX time: 2704
        Max RX octets: 251
        Max RX time: 2704
< HCI Command: LE Read Suggested Default Data Length (0x08|0x0023) plen 0        #5519 [hci1] 8593.688574
> HCI Event: Command Complete (0x0e) plen 8        #5520 [hci1] 8593.690052
      LE Read Suggested Default Data Length (0x08|0x0023) ncmd 1
        TX octets: 27
        TX time: 328
< HCI Command: Set Event Mask Page 2 (0x03|0x0063) plen 8        #5521 [hci1] 8593.690140
        Mask: 0x0000000000800000
          Authenticated Payload Timeout Expired
> HCI Event: Command Complete (0x0e) plen 4        #5522 [hci1] 8593.691970
      Set Event Mask Page 2 (0x03|0x0063) ncmd 1
< HCI Command: LE Write Suggested Default Data Length (0x08|0x0024) plen 4        #5523 [hci1] 8593.692056
        TX octets: 251
        TX time: 2704
> HCI Event: Command Complete (0x0e) plen 4        #5524 [hci1] 8593.693530
      LE Write Suggested Default Data Length (0x08|0x0024) ncmd 1
< HCI Command: LE Set Default PHY (0x08|0x0031) plen 3        #5525 [hci1] 8593.693603
        All PHYs preference: 0x00
        TX PHYs preference: 0x01
          LE 1M
        RX PHYs preference: 0x01
          LE 1M
> HCI Event: Command Complete (0x0e) plen 4        #5526 [hci1] 8593.694987
      LE Set Default PHY (0x08|0x0031) ncmd 1
= Index Info: 00:00:00:00:00:00 (Nordic Semiconductor ASA)        [hci1] 8593.695363
= Close Index: 00:00:00:00:00:00        [hci1] 8593.695429
@ MGMT Event: Index Added (0x0004) plen 0        {0x0002} [hci1] 8593.695442
@ MGMT Event: Index Added (0x0004) plen 0        {0x0001} [hci1] 8593.695442
@ MGMT Command: Read Controller Information (0x0004) plen 0        {0x0001} [hci1] 8593.695679
@ MGMT Event: Command Complete (0x0001) plen 283        {0x0001} [hci1] 8593.695717
      Read Controller Information (0x0004) plen 280
        Version: Reserved (0x0d)
        Supported settings: 0x0001be1b
          Powered
          Connectable
          Discoverable
          Bondable
          Low Energy
          Advertising
          Secure Connections
          Debug Keys
          Privacy
          Static Address
          PHY Configuration
        Current settings: 0x00000200
          Low Energy
        Class: 0x000000
          Major class: Miscellaneous
          Minor class: 0x00
        Name:
        Short name:
@ MGMT Command: Remove UUID (0x0011) plen 16        {0x0001} [hci1] 8593.697372
        UUID: 00000000-0000-0000-0000-000000000000
@ MGMT Event: Command Complete (0x0001) plen 6        {0x0001} [hci1] 8593.697430
      Remove UUID (0x0011) plen 3
        Class: 0x000000
          Minor class: 0x00
@ MGMT Command: Remove Device (0x0034) plen 7        {0x0001} [hci1] 8593.697897
        BR/EDR Address: 00:00:00:00:00:00 (OUI 00-00-00)
@ MGMT Event: Command Complete (0x0001) plen 10        {0x0001} [hci1] 8593.697916
@ MGMT Command: Set Static Address (0x002b) plen 6        {0x0001} [hci1] 8593.698037
        Address: E6:CC:03:E8:BF:84 (Static)
@ MGMT Event: Command Complete (0x0001) plen 7        {0x0001} [hci1] 8593.698046
      Set Static Address (0x002b) plen 4
        Current settings: 0x00008200
          Low Energy
          Static Address
@ MGMT Event: New Settings (0x0006) plen 4        {0x0002} [hci1] 8593.698052
          Low Energy
          Static Address
@ MGMT Command: Set Secure Connections (0x002d) plen 1        {0x0001} [hci1] 8593.698170
        Secure Connections: Enabled (0x01)
@ MGMT Event: Command Complete (0x0001) plen 7        {0x0001} [hci1] 8593.698182
      Set Secure Connections (0x002d) plen 4
        Current settings: 0x00008a00
          Low Energy
          Secure Connections
          Static Address
@ MGMT Event: New Settings (0x0006) plen 4        {0x0002} [hci1] 8593.698189
          Low Energy
          Secure Connections
          Static Address
@ MGMT Command: Set Privacy (0x002f) plen 17        {0x0001} [hci1] 8593.698319
        Privacy: Disabled (0x00)
        Key: 00000000000000000000000000000000
@ MGMT Event: Command Complete (0x0001) plen 7        {0x0001} [hci1] 8593.698329
      Set Privacy (0x002f) plen 4
          Low Energy
          Secure Connections
          Static Address
@ MGMT Command: Set Bondable (0x0009) plen 1        {0x0001} [hci1] 8593.698442
        Bondable: Enabled (0x01)
@ MGMT Event: Command Complete (0x0001) plen 7        {0x0001} [hci1] 8593.698450
      Set Bondable (0x0009) plen 4
        Current settings: 0x00008a10
          Bondable
          Low Energy
          Secure Connections
          Static Address
@ MGMT Event: New Settings (0x0006) plen 4        {0x0002} [hci1] 8593.698457
          Bondable
          Low Energy
          Secure Connections
          Static Address
@ MGMT Command: Set IO Capability (0x0018) plen 1        {0x0001} [hci1] 8593.698603
        Capability: KeyboardDisplay (0x04)
@ MGMT Event: Command Complete (0x0001) plen 3        {0x0001} [hci1] 8593.698615
      Set IO Capability (0x0018) plen 0
@ MGMT Command: Add UUID (0x0010) plen 17        {0x0001} [hci1] 8593.698731
        UUID: 00001800-0000-1000-8000-00805f9b34fb
        Service class: 0x00
@ MGMT Event: Command Complete (0x0001) plen 6        {0x0001} [hci1] 8593.698819
      Add UUID (0x0010) plen 3
        Class: 0x000000
          Minor class: 0x00
@ MGMT Command: Add UUID (0x0010) plen 17        {0x0001} [hci1] 8593.699074
        UUID: 00001801-0000-1000-8000-00805f9b34fb
        Service class: 0x00
@ MGMT Event: Command Complete (0x0001) plen 6        {0x0001} [hci1] 8593.699123
        Class: 0x000000
          Minor class: 0x00
@ MGMT Command: Read Advertising Features (0x003d) plen 0        {0x0001} [hci1] 8593.699213
@ MGMT Event: Command Complete (0x0001) plen 11        {0x0001} [hci1] 8593.699225
      Read Advertising Features (0x003d) plen 8
        Flags: 0x0001f07f
          Switch into Connectable mode
          Advertise as Discoverable
          Advertise as Limited Discoverable
          Add Flags field to Advertising Data
          Add TX Power field to Advertising Data
          Add Appearance field to Scan Response
          Add Local Name in Scan Response
          Unknown advertising flag (0x0001f000)
        Advertising data length: 31
        Scan response length: 31
        Max instances: 5
        Instances: 0
@ MGMT Command: Set Local Name (0x000f) plen 260        {0x0001} [hci1] 8593.699334
        Short name:
@ MGMT Event: Command Complete (0x0001) plen 263        {0x0001} [hci1] 8593.699744
        Short name:
@ MGMT Event: Local Name Changed (0x0008) plen 260        {0x0002} [hci1] 8593.699760
        Short name:
@ MGMT Command: Add UUID (0x0010) plen 17        {0x0001} [hci1] 8593.699962
        UUID: 0000110e-0000-1000-8000-00805f9b34fb
        Service class: 0x00
@ MGMT Event: Command Complete (0x0001) plen 6        {0x0001} [hci1] 8593.699995
        Class: 0x000000
          Minor class: 0x00
@ MGMT Command: Add UUID (0x0010) plen 17        {0x0001} [hci1] 8593.700099
        UUID: 0000110c-0000-1000-8000-00805f9b34fb
        Service class: 0x00
@ MGMT Event: Command Complete (0x0001) plen 6        {0x0001} [hci1] 8593.700138
        Class: 0x000000
          Minor class: 0x00
@ MGMT Command: Unblock Device (0x0027) plen 7        {0x0001} [hci1] 8593.700334
@ MGMT Event: Device Unblocked (0x0015) plen 7        {0x0002} [hci1] 8593.700345
@ MGMT Event: Command Complete (0x0001) plen 10        {0x0001} [hci1] 8593.700361
@ MGMT Command: Load Long Term Keys (0x0013) plen 2        {0x0001} [hci1] 8593.700484
        Keys: 0
@ MGMT Event: Command Complete (0x0001) plen 3        {0x0001} [hci1] 8593.700502
      Load Long Term Keys (0x0013) plen 0
@ MGMT Command: Load Identity Resolving Keys (0x0030) plen 2        {0x0001} [hci1] 8593.700625
        Keys: 0
@ MGMT Event: Command Complete (0x0001) plen 3        {0x0001} [hci1] 8593.700637
      Load Identity Resolving Keys (0x0030) plen 0
@ MGMT Command: Load Connection Parameters (0x0035) plen 2        {0x0001} [hci1] 8593.700743
        Parameters: 0
@ MGMT Event: Command Complete (0x0001) plen 3        {0x0001} [hci1] 8593.700756
      Load Connection Parameters (0x0035) plen 0
@ MGMT Command: Add UUID (0x0010) plen 17        {0x0001} [hci1] 8593.700865
        UUID: 00001200-0000-1000-8000-00805f9b34fb
        Service class: 0x00
@ MGMT Event: Command Complete (0x0001) plen 6        {0x0001} [hci1] 8593.700912
        Class: 0x000000
          Minor class: 0x00
@ MGMT Command: Set Device ID (0x0028) plen 8        {0x0001} [hci1] 8593.701288
        Device ID: USB Implementer's Forum assigned (0x0002)
          Vendor: Linux Foundation (0x1d6b)
          Product: 0x0246
          Version: 5.3.6 (0x0536)
@ MGMT Event: Command Complete (0x0001) plen 3        {0x0001} [hci1] 8593.701297
      Set Device ID (0x0028) plen 0
@ MGMT Command: Set Local Name (0x000f) plen 260        {0x0001} [hci1] 8593.701412
        Short name:
@ MGMT Event: Command Complete (0x0001) plen 263        {0x0001} [hci1] 8593.701421
        Short name:
@ MGMT Command: Unknown (0x0046) plen 36        {0x0001} [hci1] 8593.701532
        02 00 01 bf 01 fb 9d 4e f3 bc 36 d8 74 f5 39 41  .......N..6.t.9A
        38 68 4c 02 a5 99 ba e4 e1 7c a6 18 22 8e 07 56  8hL......|.."..V
        b4 e8 5f 01                                      .._.
@ MGMT Event: Command Complete (0x0001) plen 3        {0x0001} [hci1] 8593.701547
      Unknown (0x0046) plen 0
= Open Index: 00:00:00:00:00:00        [hci1] 8594.695653
< HCI Command: Reset (0x03|0x0003) plen 0        #5527 [hci1] 8594.695697
> HCI Event: Command Complete (0x0e) plen 4        #5528 [hci1] 8594.696948
< HCI Command: Read Local Supported Features (0x04|0x0003) plen 0        #5529 [hci1] 8594.697043
> HCI Event: Command Complete (0x0e) plen 12        #5530 [hci1] 8594.698867
< HCI Command: Read Local Version Information (0x04|0x0001) plen 0        #5531 [hci1] 8594.698956
> HCI Event: Command Complete (0x0e) plen 12        #5532 [hci1] 8594.700779
< HCI Command: Read BD ADDR (0x04|0x0009) plen 0        #5533 [hci1] 8594.700867
> HCI Event: Command Complete (0x0e) plen 10        #5534 [hci1] 8594.702525
< HCI Command: Read Local Supported Commands (0x04|0x0002) plen 0        #5535 [hci1] 8594.702612
> HCI Event: Command Complete (0x0e) plen 68        #5536 [hci1] 8594.709282
          Octet 41 - Bit 2
          Octet 45 - Bit 6
< HCI Command: LE Read Local Supported Features (0x08|0x0003) plen 0        #5537 [hci1] 8594.709397
> HCI Event: Command Complete (0x0e) plen 12        #5538 [hci1] 8594.711229
          LE Encryption
          LE Ping
          LL Privacy
          LE 2M PHY
          LE Coded PHY
< HCI Command: LE Read Buffer Size (0x08|0x0002) plen 0        #5539 [hci1] 8594.711720
> HCI Event: Command Complete (0x0e) plen 7        #5540 [hci1] 8594.713457
        Num data packets: 3
< HCI Command: LE Read Supported States (0x08|0x001c) plen 0        #5541 [hci1] 8594.713569
> HCI Event: Command Complete (0x0e) plen 12        #5542 [hci1] 8594.715402
          Initiating State
< HCI Command: Set Event Mask (0x03|0x0001) plen 8        #5543 [hci1] 8594.715510
          Encryption Change
          Command Complete
          Command Status
          Hardware Error
          LE Meta
> HCI Event: Command Complete (0x0e) plen 4        #5544 [hci1] 8594.717356
< HCI Command: LE Set Event Mask (0x08|0x0001) plen 8        #5545 [hci1] 8594.717460
> HCI Event: Command Complete (0x0e) plen 4        #5546 [hci1] 8594.719301
< HCI Command: LE Read Advertising Channel TX Power (0x08|0x0007) plen 0        #5547 [hci1] 8594.719461
> HCI Event: Command Complete (0x0e) plen 5        #5548 [hci1] 8594.720726
< HCI Command: LE Read Transmit Power (0x08|0x004b) plen 0        #5549 [hci1] 8594.720819
> HCI Event: Command Complete (0x0e) plen 6        #5550 [hci1] 8594.722135
        Max Tx power: 8 dBm
< HCI Command: LE Read White List Size (0x08|0x000f) plen 0        #5551 [hci1] 8594.722222
> HCI Event: Command Complete (0x0e) plen 5        #5552 [hci1] 8594.723490
< HCI Command: LE Clear White List (0x08|0x0010) plen 0        #5553 [hci1] 8594.723574
> HCI Event: Command Complete (0x0e) plen 4        #5554 [hci1] 8594.724707
< HCI Command: LE Read Resolving List Size (0x08|0x002a) plen 0        #5555 [hci1] 8594.724790
> HCI Event: Command Complete (0x0e) plen 5        #5556 [hci1] 8594.726010
< HCI Command: LE Clear Resolving List (0x08|0x0029) plen 0        #5557 [hci1] 8594.726093
> HCI Event: Command Complete (0x0e) plen 4        #5558 [hci1] 8594.727228
< HCI Command: LE Set Resolvable Private Address Timeout (0x08|0x002e) plen 2        #5559 [hci1] 8594.727307
> HCI Event: Command Complete (0x0e) plen 4        #5560 [hci1] 8594.728608
< HCI Command: LE Read Maximum Data Length (0x08|0x002f) plen 0        #5561 [hci1] 8594.728696
> HCI Event: Command Complete (0x0e) plen 12        #5562 [hci1] 8594.730518
        Max TX octets: 251
        Max TX time: 2704
        Max RX octets: 251
        Max RX time: 2704
< HCI Command: LE Read Suggested Default Data Length (0x08|0x0023) plen 0        #5563 [hci1] 8594.730605
> HCI Event: Command Complete (0x0e) plen 8        #5564 [hci1] 8594.732078
        TX octets: 27
        TX time: 328
< HCI Command: Set Event Mask Page 2 (0x03|0x0063) plen 8        #5565 [hci1] 8594.732161
> HCI Event: Command Complete (0x0e) plen 4        #5566 [hci1] 8594.733991
< HCI Command: LE Write Suggested Default Data Length (0x08|0x0024) plen 4        #5567 [hci1] 8594.734074
        TX octets: 251
        TX time: 2704
> HCI Event: Command Complete (0x0e) plen 4        #5568 [hci1] 8594.735551
< HCI Command: LE Set Default PHY (0x08|0x0031) plen 3        #5569 [hci1] 8594.735637
          LE 1M
          LE 1M
> HCI Event: Command Complete (0x0e) plen 4        #5570 [hci1] 8594.737024
= Index Info: 00:00:00:00:00:00 (Nordic Semiconductor ASA)        [hci1] 8594.737089
< HCI Command: LE Set Advertising Data (0x08|0x0008) plen 32        #5571 [hci1] 8594.737156
        Length: 6
        Flags: 0x04
        TX power: 0 dBm
> HCI Event: Command Complete (0x0e) plen 4        #5572 [hci1] 8594.741112
      LE Set Advertising Data (0x08|0x0008) ncmd 1
< HCI Command: LE Set Scan Response Data (0x08|0x0009) plen 32        #5573 [hci1] 8594.741203
        Length: 13
        Name (short): dcc-debug-
> HCI Event: Command Complete (0x0e) plen 4        #5574 [hci1] 8594.745158
      LE Set Scan Response Data (0x08|0x0009) ncmd 1
@ MGMT Event: New Settings (0x0006) plen 4        {0x0002} [hci1] 8594.745226
        Current settings: 0x00008a11
          Powered
          Bondable
          Low Energy
          Secure Connections
          Static Address
@ MGMT Event: New Settings (0x0006) plen 4        {0x0001} [hci1] 8594.745226
          Powered
          Bondable
          Low Energy
          Secure Connections
          Static Address
@ RAW Close: poltys_tool        {0x0004} 8594.745346
        Status: Invalid HCI Command Parameters (0x12)        [hci1] 8594.829497
