Flashing nRF5340DK via VSCode works, but via Programmer fails
Hi
I have an application, based on nrf/samples/bluetooth/peripheral_uart.
Using VS Code I can build the app, and flash it to my nRF5340 DK board ((PCA10095 - 2.0.0 - 2022.4), and it runs.
However, if I use the nRF Connect for Desktop's Programmer to flash the build\zephyr\merged.hex file, the application does not successfully start.
VS Code setup:
Version: 1.87.0 (user setup)
Commit: 019f4d1419fbc8219a181fab7892ebccf7ee29a2
Date: 2024-02-27T23:41:44.469Z
Electron: 27.3.2
ElectronBuildId: 26836302
Chromium: 118.0.5993.159
Node.js: 18.17.1
V8: 11.8.172.18-electron.0
OS: Windows_NT x64 10.0.19045
nRF Connect for VS Code: v2024.2.214
Application, based on nrf/samples/bluetooth/peripheral_uart
Build Configuration: nrf5340dk_nrf5340_cpuapp_ns
Programmer setup:
nRF Connect for Desktop v4.4.0
Programmer v4.2.0
Steps taken:
Open the Programmer
Auto read memory: On
Auto reset: On
Enable MCUboot: Off
Select Device: nRF5340 DK
Clear Files
Add file: merged.hex
Erase & write
Serial output when I use VS Code (successfully)
Starting Nordic UART service example
*** Booting Zephyr OS build v3.3.99-ncs1-1 ***
[00:00:00.471,099] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.471,099] <inf> fs_nvs: alloc wra: 0, fe8
[00:00:00.471,130] <inf> fs_nvs: data wra: 0, 0
[00:00:00.494,628] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
[00:00:00.494,689] <inf> bt_hci_core: HW Variant: nRF53x (0x0003)
[00:00:00.494,720] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 224.11902 Build 2231721665
[00:00:00.496,032] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:00.497,406] <inf> bt_hci_core: Identity: EF:BF:5A:B8:62:7F (random)
[00:00:00.497,436] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x2077, manufacturer 0x0059
[00:00:00.497,497] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x2077
Serial output when I use Programmer (unsuccessfully)
[00:00:00.316,406] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.316,467] <inf> fs_nvs: alloc wra: 0, fe8
[00:00:00.316,497] <inf> fs_nvs: data wra: 0, 0
[00:00:00.317,840] <inf> peripheral_uart: led_button_thread - start
[00:00:01.317,901] <err> bt_hci_driver: Endpoint binding failed with -11
[00:00:01.317,932] <err> bt_hci_core: HCI driver open failed (-11)
This is the same board that I have a problem flahsing via VS Code every 2nd tiume, and I have to open a command window at:
C:\Program Files\Nordic Semiconductor\nrf-command-line-tools\bin>
and run this command:
nrfjprog --recover
I tried doing this before flashing with the Programmer, but it still failed.
  • Here is the log output from the Programmer:
    2024-03-05T15:44:44.366Z DEBUG Application data folder: C:\Users\me\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2024-03-05T15:44:44.412Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:44:44.412Z DEBUG App pc-nrfconnect-programmer v4.2.0 (official)
    2024-03-05T15:44:44.412Z DEBUG App path: C:\Users\me\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2024-03-05T15:44:44.412Z DEBUG nRFConnect 4.4.0, required by the app is (>=4.3.0)
    2024-03-05T15:44:44.412Z DEBUG nRFConnect path: C:\Users\me\AppData\Local\Programs\nrfconnect\resources\app.asar
    2024-03-05T15:44:44.412Z DEBUG HomeDir: C:\Users\me
    2024-03-05T15:44:44.412Z DEBUG TmpDir: C:\Users\me\AppData\Local\Temp
    2024-03-05T15:44:44.988Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:44:44.992Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:44:45.477Z INFO Using nrfutil-device version: 2.0.3
    2024-03-05T15:44:45.477Z INFO Using nrf-device-lib version: 0.17.3
    2024-03-05T15:44:45.477Z INFO Using nrfjprog DLL version: 10.23.1
    2024-03-05T15:44:45.477Z INFO Using JLink version: JLink_V7.88j
    2024-03-05T15:44:45.629Z INFO Getting serialport options from persistent store 001050071243.pc-nrfconnect-programmer
    2024-03-05T15:44:45.630Z DEBUG Sending usage data "device connected"
    2024-03-05T15:44:58.445Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:44:59.602Z INFO Using nrfutil device to communicate with target via JLink
    2024-03-05T15:44:59.602Z INFO JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Nov  7 2022 16:22:01
    2024-03-05T15:44:59.602Z INFO Device family NRF53_FAMILY
    2024-03-05T15:44:59.602Z INFO Device version NRF5340_xxAA_ENGD
    2024-03-05T15:44:59.603Z INFO Board version PCA10095
    2024-03-05T15:44:59.610Z DEBUG Sending usage data "device selected"
    2024-03-05T15:44:59.610Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:44:59.773Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:45:00.635Z INFO Reading readback protection status for Application core
    2024-03-05T15:45:00.637Z INFO Reading readback protection status for Application core 0%
    2024-03-05T15:45:00.649Z INFO Reading readback protection status for Application core 100%
    2024-03-05T15:45:00.649Z INFO Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2024-03-05T15:45:00.649Z INFO Reading readback protection status for Application core completed
    2024-03-05T15:45:00.696Z INFO Reading readback protection status for Network core
    2024-03-05T15:45:00.697Z INFO Reading readback protection status for Network core 0%
    2024-03-05T15:45:00.712Z INFO Reading readback protection status for Network core 100%
    2024-03-05T15:45:00.712Z INFO Network core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2024-03-05T15:45:00.713Z INFO Reading readback protection status for Network core completed
    2024-03-05T15:45:01.037Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:45:01.198Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:45:02.069Z INFO Loading core information for Application core
    2024-03-05T15:45:02.070Z INFO Loading core information for Application core 0%
    2024-03-05T15:45:02.101Z INFO Loading core information for Application core 100%
    2024-03-05T15:45:02.101Z INFO Loading core information for Application core completed
    2024-03-05T15:45:02.148Z INFO Loading core information for Network core
    2024-03-05T15:45:02.149Z INFO Loading core information for Network core 0%
    2024-03-05T15:45:02.179Z INFO Loading core information for Network core 100%
    2024-03-05T15:45:02.179Z INFO Loading core information for Network core completed
    2024-03-05T15:45:02.194Z INFO Reading memory for Application core
    2024-03-05T15:45:02.195Z INFO Reading memory for Application core 0%
    2024-03-05T15:45:09.544Z INFO Reading memory for Application core 100%
    2024-03-05T15:45:09.845Z INFO Reading memory for Application core completed
    2024-03-05T15:45:09.846Z INFO Parse memory regions for Application core
    2024-03-05T15:45:09.850Z INFO Reading memory for Network core
    2024-03-05T15:45:09.851Z INFO Reading memory for Network core 0%
    2024-03-05T15:45:09.852Z INFO Parse memory regions for Application core
    2024-03-05T15:45:11.480Z INFO Reading memory for Network core 100%
    2024-03-05T15:45:11.612Z INFO Reading memory for Network core completed
    2024-03-05T15:45:11.613Z INFO Parse memory regions for Application core
    2024-03-05T15:45:11.613Z INFO Parse memory regions for Network core
    2024-03-05T15:45:11.853Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:45:12.009Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:45:12.849Z INFO Reading readback protection status for Application core
    2024-03-05T15:45:12.850Z INFO Reading readback protection status for Application core 0%
    2024-03-05T15:45:12.865Z INFO Reading readback protection status for Application core 100%
    2024-03-05T15:45:12.865Z INFO Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2024-03-05T15:45:12.866Z INFO Reading readback protection status for Application core completed
    2024-03-05T15:45:12.911Z INFO Reading readback protection status for Network core
    2024-03-05T15:45:12.911Z INFO Reading readback protection status for Network core 0%
    2024-03-05T15:45:12.927Z INFO Reading readback protection status for Network core 100%
    2024-03-05T15:45:12.927Z INFO Network core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2024-03-05T15:45:12.927Z INFO Reading readback protection status for Network core completed
    2024-03-05T15:45:13.190Z INFO Device is loaded and ready for further operation
    2024-03-05T15:46:14.137Z INFO Parsing HEX file:  C:\Users\me\Downloads\merged.hex
    2024-03-05T15:46:14.139Z INFO File was last modified at  3/5/2024, 7:30:23 AM
    2024-03-05T15:46:14.197Z INFO Update files regions according to Application core
    2024-03-05T15:46:14.197Z INFO Parse memory regions for file
    2024-03-05T15:46:14.197Z INFO Update files regions according to Network core
    2024-03-05T15:46:43.399Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:46:43.589Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:46:44.412Z INFO Recovering Application core
    2024-03-05T15:46:44.413Z INFO Recovering Application core 0%
    2024-03-05T15:46:45.684Z INFO Recovering Application core 100%
    2024-03-05T15:46:45.685Z INFO Recovering Application core completed
    2024-03-05T15:46:45.779Z INFO Recovering Network core
    2024-03-05T15:46:45.781Z INFO Recovering Network core 0%
    2024-03-05T15:46:47.032Z INFO Recovering Network core 100%
    2024-03-05T15:46:47.033Z INFO Recovering Network core completed
    2024-03-05T15:46:47.094Z INFO Writing HEX to Application core
    2024-03-05T15:46:47.686Z INFO Writing HEX to Application core 33.333333333333336%
    2024-03-05T15:46:47.687Z INFO Writing HEX to Application core 33.33333333333333%
    2024-03-05T15:46:49.457Z INFO Writing HEX to Application core 100%
    2024-03-05T15:46:49.465Z INFO Writing HEX to Application core completed
    2024-03-05T15:46:49.465Z INFO Reading memory for Application core
    2024-03-05T15:46:49.468Z INFO Reading memory for Application core 0%
    2024-03-05T15:46:56.718Z INFO Reading memory for Application core 100%
    2024-03-05T15:46:56.988Z INFO Reading memory for Application core completed
    2024-03-05T15:46:56.990Z INFO Parse memory regions for Application core
    2024-03-05T15:46:56.993Z INFO Reading memory for Network core
    2024-03-05T15:46:56.993Z INFO Reading memory for Network core 0%
    2024-03-05T15:46:56.995Z INFO Parse memory regions for Application core
    2024-03-05T15:46:58.682Z INFO Reading memory for Network core 100%
    2024-03-05T15:46:58.820Z INFO Reading memory for Network core completed
    2024-03-05T15:46:58.821Z INFO Parse memory regions for Application core
    2024-03-05T15:46:58.821Z INFO Parse memory regions for Network core
    2024-03-05T15:46:58.824Z INFO Loading core information for Application core
    2024-03-05T15:46:58.825Z INFO Loading core information for Application core 0%
    2024-03-05T15:46:58.825Z INFO Loading core information for Application core 100%
    2024-03-05T15:46:58.825Z INFO Loading core information for Application core completed
    2024-03-05T15:46:58.828Z INFO Update files regions according to Application core
    2024-03-05T15:46:58.828Z INFO Parse memory regions for file
    2024-03-05T15:46:58.828Z INFO Update files regions according to Network core
    2024-03-05T15:46:58.828Z INFO Parse memory regions for Application core
    2024-03-05T15:46:58.828Z INFO Parse memory regions for Network core
    2024-03-05T15:46:58.902Z INFO Loading core information for Network core
    2024-03-05T15:46:58.903Z INFO Update files regions according to Application core
    2024-03-05T15:46:58.903Z INFO Parse memory regions for file
    2024-03-05T15:46:58.903Z INFO Update files regions according to Network core
    2024-03-05T15:46:58.904Z INFO Parse memory regions for Application core
    2024-03-05T15:46:58.904Z INFO Parse memory regions for Network core
    2024-03-05T15:46:58.905Z INFO Loading core information for Network core 0%
    2024-03-05T15:46:58.951Z INFO Loading core information for Network core 100%
    2024-03-05T15:46:58.952Z INFO Loading core information for Network core completed
    2024-03-05T15:46:58.955Z INFO Update files regions according to Application core
    2024-03-05T15:46:58.955Z INFO Parse memory regions for file
    2024-03-05T15:46:58.956Z INFO Update files regions according to Network core
    2024-03-05T15:46:58.956Z INFO Parse memory regions for file
    2024-03-05T15:46:58.956Z INFO Parse memory regions for Application core
    2024-03-05T15:46:58.956Z INFO Parse memory regions for Network core
    2024-03-05T15:46:59.342Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:47:00.510Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:47:00.521Z INFO Update files regions according to Application core
    2024-03-05T15:47:00.521Z INFO Parse memory regions for file
    2024-03-05T15:47:00.522Z INFO Update files regions according to Network core
    2024-03-05T15:47:00.522Z INFO Parse memory regions for file
    2024-03-05T15:47:00.684Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:47:01.501Z INFO Reading readback protection status for Application core
    2024-03-05T15:47:01.502Z INFO Reading readback protection status for Application core 0%
    2024-03-05T15:47:01.517Z INFO Reading readback protection status for Application core 100%
    2024-03-05T15:47:01.517Z INFO Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2024-03-05T15:47:01.517Z INFO Reading readback protection status for Application core completed
    2024-03-05T15:47:01.563Z INFO Reading readback protection status for Network core
    2024-03-05T15:47:01.564Z INFO Reading readback protection status for Network core 0%
    2024-03-05T15:47:01.582Z INFO Reading readback protection status for Network core 100%
    2024-03-05T15:47:01.582Z INFO Network core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2024-03-05T15:47:01.582Z INFO Reading readback protection status for Network core completed
    2024-03-05T15:47:01.838Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:47:02.009Z DEBUG Sending usage data "running nrfutil device"
    2024-03-05T15:47:02.791Z INFO Reading readback protection status for Application core
    2024-03-05T15:47:02.791Z INFO Reading readback protection status for Application core 0%
    2024-03-05T15:47:02.806Z INFO Reading readback protection status for Application core 100%
    2024-03-05T15:47:02.806Z INFO Application core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2024-03-05T15:47:02.806Z INFO Reading readback protection status for Application core completed
    2024-03-05T15:47:02.853Z INFO Reading readback protection status for Network core
    2024-03-05T15:47:02.854Z INFO Reading readback protection status for Network core 0%
    2024-03-05T15:47:02.868Z INFO Reading readback protection status for Network core 100%
    2024-03-05T15:47:02.868Z INFO Network core protection status 'NRFDL_PROTECTION_STATUS_NONE'
    2024-03-05T15:47:02.868Z INFO Reading readback protection status for Network core completed
    The merged.hex file is only for the application core, so you are missing the network core. You either need to use the merged_domains.hex file, or both GENERATED_CP_NETWORK_merged_domains.hex and GENERATED_CP_APPLICATION_merged_domains.hex.
  • Thank you for the quick (and correct) response :)
