While working on the DFU, I can't get MCUBoot to complete a slot swap ... The device always is reset due to the watchdog.
The watchdog is setup in the app. I know that once it is started, it can't be stopped; which is shy the bootloader should feed it.
If I don't enable the watchdog in the app, everything works fine.
I already added the following config to mcuboot.conf, but it does not help.
CONFIG_BOOT_WATCHDOG_FEED=y CONFIG_WATCHDOG=y
Since I wasn't sure of the usage, I also added this to mcuboot_config.h
#define MCUBOOT_WATCHDOG_FEED()
do {
wdt_feed(wdt, wdt_channel_id);
} while (0)
What am I missing ? Is there a specific setting I need to have when enabling the watchdog. I currently use wdt_install_timeout(), wdt_setup() and wdt_feed().
Thanks.
