SPI Flash - Parition Manager - QSPI config causing build errors
Hello! My starting point for this issue is a custom board using an nrf52832 and a SPI flash chip (MX25R1635F).
So far I have been able to initialize the SPI flash (the JEDEC ID is read and verified successfully), but I want to use it with the FCB system (currently working fine on internal flash).
I followed the instructions here  (or at least I tried to) to set up a partition in external flash that I can then reference when initializing the FCB. When I build, I'm getting hundreds of lines of errors, most along these lines:
error: unknown type name 'NRF_QSPI_Type'; did you mean 'NRF_SPI_Type'?
  967 | NRF_STATIC_INLINE void nrf_qspi_cinstr_long_transfer_start(NRF_QSPI_Type *                p_reg,
      |                                                            NRF_SPI_Type
Along with
zephyr/drivers/flash/nrf_qspi_nor.c:69:2: error: #error "No size specified. 'size' or 'size-in-bytes' must be set"
   69 | #error "No size specified. 'size' or 'size-in-bytes' must be set"
This led me to try setting `CONFIG_NORDIC_QSPI_NOR=n` explicitly in my proj.conf, but it's still showing the same errors (even with PM_OVERRIDE_EXTERNAL_DRIVER_CHECK). When I look in the .config file in the build folder (snippet below), it's getting set back to `y`, but I can't find any clue as to why.
# Nordic nRF Connect
CONFIG_BOOT_BANNER_STRING="Booting nRF Connect SDK"
CONFIG_MBEDTLS_LIBRARY_NRF_SECURITY=y
CONFIG_WARN_EXPERIMENTAL=y
CONFIG_PRIVILEGED_STACK_SIZE=1024
CONFIG_MCUMGR_TRANSPORT_NETBUF_SIZE=2475
CONFIG_BT_BUF_CMD_TX_COUNT=2
CONFIG_ENTROPY_GENERATOR=y
CONFIG_INIT_ARCH_HW_AT_BOOT=y
CONFIG_NORDIC_QSPI_NOR=y
CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
# CONFIG_GETOPT is not set
# CONFIG_NCS_SAMPLES_DEFAULTS is not set
Here are the rest of the relevant config snippets:
The flash device is configured in my overlay as below
	chosen {
		nordic,pm-ext-flash = &mx25r1635;
	zephyr,user {
		io-channels = <&adc 0>, <&adc 1>;
		tc-bias-gpios = <&gpio0 27 GPIO_ACTIVE_HIGH>;
	aliases {
		mx25r16 = &mx25r1635;
/* other configs */
&spi0 {
	status = "okay";
	compatible = "nordic,nrf-spi";
	clock-frequency = <8000000>;
	pinctrl-0 = <&spi0_default>;
	pinctrl-1 = <&spi0_sleep>;
	cs-gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
	mx25r1635: mx25r1635@0 {
		compatible = "jedec,spi-nor";
		/* 16777216 bits = 2 Mbytes */
		size = <0x1000000>;
		reg = <0>;
		spi-max-frequency = <33000000>;
		jedec-id = [c2 28 15];
		status = "okay";
		wp-gpios = <&gpio0 14 GPIO_ACTIVE_LOW>;
		hold-gpios = <&gpio0 11 GPIO_ACTIVE_LOW>;
		has-dpd;
		dpd-wakeup-sequence = <30000 20 45000>;
		t-enter-dpd = <10000>;
		mxicy,mx25r-power-mode = "high-performance";
I have the following pm_static.yml
nvs_storage:
  address: 0x7B000
  end_address: 0x7D000
  region: flash_primary
internal_fcb:
  address: 0x7D000
  end_address: 0x80000
external_fcb:
  address: 0x000000
  device: MX25R16
  end_address: 0x1000000
  region: external_flash
The following is a snippet from my prj.conf
# Internal Flash/NVS
CONFIG_MPU_ALLOW_FLASH_WRITE=y
CONFIG_FLASH=y
CONFIG_IMG_MANAGER=y
CONFIG_STREAM_FLASH=y
CONFIG_FLASH_MAP=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_NVS=y
CONFIG_MPU=y
CONFIG_SOC_FLASH_NRF_UICR=y
CONFIG_SOC_FLASH_NRF_EMULATE_ONE_BYTE_WRITE_ACCESS=y
# SPI Flash
CONFIG_SPI=y
# CONFIG_SOC_NRF52832_ALLOW_SPIM_DESPITE_PAN_58=y
CONFIG_SPI_NOR=y
CONFIG_PPI_TRACE=y
CONFIG_FCB=y
CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK=y
A handful of items in there were gleaned from various support tickets, but many of them may have been out of date. Anyway, I appreciate any guidance you can provide.
Thank you!
