im trying to use TWIM to get some data from BME280. The problem is that it always responds with 0x00, when it should be 0x60.
I kinda don't know whats the problem there:
#include <zephyr/kernel.h> #include <nrfx_twim.h> #include <nrfx_timer.h> #include <zephyr/device.h> #include <nrfx.h> #include <zephyr/devicetree.h> #include <nrfx_twis.h> #include <zephyr/logging/log.h> #include <zephyr/logging/log_ctrl.h> #include <helpers/nrfx_gppi.h> #include <nrfx_ppi.h> //BME 280 DEFINES START #define BME280_I2C_ADDRESS 0x76 #define BME280_REG_ID 0xD0 #define BME280_REG_TEMP_COMP_START 0x88 #define BME280_CHIP_ID 0x60 #define BME280_REG_PRESS_MSB 0xF7 struct{ uint8_t chip_id; }bme280_data; uint8_t read_buf_id[1]; uint8_t read_buf_temp[6]; uint8_t write_reg_buffer[1]; uint8_t read_meas_buf[9]; //BME280 DEFINES END LOG_MODULE_REGISTER(LOGGING_FORTWIM); // TIMERS DEFINES START #define TIMER_INST_IDX 0 #define TIME_TO_WAIT_MS 3300UL // TIMERS DEFINES END // TWIM TWIS DEFINES START #define TWIM_INST_IDX 0 #define MASTER_SCL_PIN 3 #define MASTER_SDA_PIN 4 static nrfx_twim_t m_twim_inst = NRFX_TWIM_INSTANCE(TWIM_INST_IDX); //uint8_t channel; nrfx_timer_t timer_inst = NRFX_TIMER_INSTANCE(TIMER_INST_IDX); static void twim_handler(nrfx_twim_evt_t const * p_event, void * p_context) { if (p_event->type == NRFX_TWIM_EVT_DONE) { char * p_msg = p_context; LOG_INF("%s", p_msg); } if(p_event->type == NRFX_TWIM_EVT_BUS_ERROR){ LOG_INF("BUS ERROR"); } if(p_event->type == NRFX_TWIM_EVT_ADDRESS_NACK){ LOG_INF("ADDRESS NACK\n"); } else { LOG_INF("--> Master event: %d.", p_event->type); } } static void timer_handler(nrf_timer_event_t event_type, void *p_context) { LOG_INF("TIMER INTERRUPT HANDLER\n"); // LOG_INF("xPEP DZIALA"); } void register_read(uint8_t slave_addr, uint32_t reg_num, uint8_t * rx_buffer, uint8_t bytes_to_read) { nrfx_twim_xfer_desc_t twim_xfer_desc = NRFX_TWIM_XFER_DESC_TXRX(slave_addr, // BME280 I2C write_reg_buffer, //what address to access??? 1, //Amount rx_buffer, // Rx buffer bytes_to_read); nrfx_twim_xfer(&m_twim_inst, &twim_xfer_desc, 0); while (nrfx_twim_is_busy(&m_twim_inst)) {} } static void Timer_init(void) { nrfx_err_t err; (void)err; uint32_t base_frequency = NRF_TIMER_BASE_FREQUENCY_GET(timer_inst.p_reg); nrfx_timer_config_t config = NRFX_TIMER_DEFAULT_CONFIG(base_frequency); config.bit_width = NRF_TIMER_BIT_WIDTH_32; err = nrfx_timer_init(&timer_inst, &config, timer_handler); nrfx_timer_clear(&timer_inst); uint32_t desired_ticks = nrfx_timer_ms_to_ticks(&timer_inst, TIME_TO_WAIT_MS); nrfx_timer_extended_compare(&timer_inst, NRF_TIMER_CC_CHANNEL0, desired_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, false); } int main(void) { LOG_INIT(); nrfx_err_t status; (void)status; Timer_init(); void * p_context = "--> Master event: done - transfer completed"; write_reg_buffer[0]=BME280_REG_ID; nrfx_twim_config_t twim_config = NRFX_TWIM_DEFAULT_CONFIG(MASTER_SCL_PIN, MASTER_SDA_PIN); status = nrfx_twim_init(&m_twim_inst, &twim_config, twim_handler, p_context); nrfx_twim_enable(&m_twim_inst); //register_read(BME280_I2C_ADDRESS, write_reg_buffer, read_buf_id, 1); nrfx_twim_xfer_desc_t twim_xfer_desc = NRFX_TWIM_XFER_DESC_TXRX(BME280_I2C_ADDRESS, // BME280 I2C write_reg_buffer, 1, read_buf_id, 1); status = nrfx_twim_xfer(&m_twim_inst, &twim_xfer_desc, 0); if (status != NRFX_SUCCESS) { LOG_ERR("Error during TWI transfer: %d", status); } bme280_data.chip_id=read_buf_id[0]; LOG_INF("ctrl buff: 0x%02x", bme280_data.chip_id); // status = nrfx_gppi_channel_alloc(&channel); // nrfx_gppi_channel_endpoints_setup( // channel, // nrfx_timer_event_address_get(&timer_inst, NRF_TIMER_EVENT_COMPARE0), // nrfx_twim_start_task_address_get(NRF_TWIM0, NRF_TWIM_TASK_STARTRX) // ); IRQ_DIRECT_CONNECT(NRFX_IRQ_NUMBER_GET(NRF_TWIM_INST_GET(TWIM_INST_IDX)), IRQ_PRIO_LOWEST, NRFX_TWIM_INST_HANDLER_GET(TWIM_INST_IDX), 0); IRQ_DIRECT_CONNECT(NRFX_IRQ_NUMBER_GET(NRF_TIMER_INST_GET(TIMER_INST_IDX)), IRQ_PRIO_LOWEST, NRFX_TIMER_INST_HANDLER_GET(TIMER_INST_IDX), 0); while (1) { LOG_PROCESS(); } }
My BME280 is connected like this:
SCL: 3 / SDA: 4 / GND GND / Vcc Vdd / CSB&SDO GND
