My device is getting reset when left idle for sometime. On checking the logs, I see that the nrf_power_resetreas_get() returns reset reason as 0x01. I am using NRF SDK 17.1.0.
What does reset value 0x01 signify?
The reset reason comes from the RESETREAS register.
0x01 means bit A is set, which means a pin reset was detected.
Jørgen
My device was left idle without any BLE interrupts. Any idea about what might be the possible causes of pin reset?
This bit should only be set if the reset pin was pulled low. This should not be caused by SW.
Is this on a custom board? Have you enabled the reset pin on the chip? Is the reset pin connected to anything?
Yes this is a custom board. No I haven't enabled the reset pin.
Can you confirm that reset pin is not enabled by reading out PSELRESET[0] and PSELRESET[1] registers?
E.g., if enabled it should have this values, if disabled, they should be 0xFFFFFFFF.
nrfjprog --memrd 0x10001200 --w 32 0x10001200: 00000015 |....| nrfjprog --memrd 0x10001204 --w 32 0x10001204: 00000015 |....|
