Problem with getting "Error retrieving channel allocation"
I'm running the nrf5340_audio_dk and using version 2.6.0-rc1. When connecting one NRF5430 as headset to another NRF5340 gateway, running BIS mode everything works fine. But, when connecting to a couple of different auracast gateways I'm getting the following error:
<err> broadcast_sink: Error retrieving channel allocation: -61
Added some debug in broadcast_sink.c to see the actual value received, line 172:
ret = bt_audio_codec_cfg_get_chan_allocation(codec, &codec_info->chan_allocation);
LOG_INF("Got channel allocation: %x", codec_info->chan_allocation);
if (ret) {
LOG_ERR("Error retrieving channel allocation: %d", ret);
//return;
When using the NRF5340 as gateway I get the value "3" from the above added line. The same output gives "0" for my other auracast sources. I had to comment out the "return" statement in order to make it run (se above).
Anyone seen this before?
Henrik
