CI/CD west build using docker container
Hi everyone,
I am using a Bitbucket Pipeline for my firmware build process, I am using a Nordic docker pre-built image for performing the goal.
If I launch the docker run with my local PC the build process is successful, the following command is sent:
docker run -v ${PWD}:/workdir/app --rm nordicplayground/nrfconnect-sdk:main west build /workdir/app -p always -b nrf52840dk_nrf52840 --build-dir /workdir/app/build -DDTC_OVERLAY_FILE=/workdir/app/app.overlay
The same command, during the pipeline execution remains stuck to a certain file and the build process seems paused (in fact the stage fails due to a timeout error after a while).
In the pipeline docker logs I can see a log of this type:
time="2024-03-12T08:21:22.514957944Z" level=info msg="loading plugin \"io.containerd.ttrpc.v1.pause\"..." runtime=io.containerd.runc.v2 type=io.containerd.ttrpc.v1
And the container seems to be paused.
What do you think the problem is located? Is it something related to the pipeline settings or am I configuring the system in the wrong way? To do it I followed this guide:
https://github.com/NordicPlayground/nrf-docker/tree/saga
Thank you in advance
