Bug in partition_manager_output.py leading to incorrect PM_FOREACH_AFFILIATED_TO_disk
I have noticed while trying to use LitteFS with USB Mass Storage a bug with partition_manager_output.py when using the affiliated key in pm_static.yml.
The documentation suggested the following:
fatfs_storage:
    affiliation: disk
    extra_params: {
        disk_name: "SD",
        disk_cache_size: 4096,
        disk_sector_size: 512,
        disk_read_only: 0
    placement:
        before: [end]
        align: {start: 4096}
    inside: [nonsecure_storage]
However if this this used the output produced by `partition_manager_output.py` in `pm.config` and `pm_config.h` is:
PM_FOREACH_AFFILIATED_TO_d(fn)= fn(LITTLEFS_STORAGE)
PM_FOREACH_AFFILIATED_TO_i(fn)= fn(LITTLEFS_STORAGE)
PM_FOREACH_AFFILIATED_TO_s(fn)= fn(LITTLEFS_STORAGE)
PM_FOREACH_AFFILIATED_TO_k(fn)= fn(LITTLEFS_STORAGE)
(This is taken from my code, so its LITTLEFS_STORAGE, not FATFS_STORAGE but the issue is the same).
This issue is fixed with the above `pm_static.yml` is modified to:
fatfs_storage:
    affiliation:
        - disk
    extra_params: {
        disk_name: "SD",
        disk_read_only: 0
    placement:
        before: [end]
with the "disk" being indented.
This is due to the following piece of code in partition_manager_output.py:
for paf in partition['affiliation']:
    ptd = affiliations.get(paf)
    if not ptd:
        affiliations[paf] = list()
    if ptd not in affiliations[paf]:
        affiliations[paf].append(name)
Which assumes `partition['affiliation']` would be a list and not a single string.
This issue appears in the same way as this issue.
I hope this issue can be resolved in future updates and help other people with similar issues.
