Sidewalk SubGhz fail/locks SX1262 on v1.16 with RAK4630
Dear Support
We currently use a custom PCB board with RAK4630 (NRF52840 + Semtech SX1262)
We started to try with RAK sample located here
https://github.com/RAKWireless/RAK4630-Amazon-Sidewalk-Example
We used the sample rak4631_sid_dut because it's easier with the shell to pass and test sidewalk commands using serial terminal
Of course we applied both RAK patches for this to work
1) The correct the RF Antenna SW by setting up GPIO 5 instead of 7 (see RAK4630 schematics)
GPIO 7 should not be used because RF Control switch RX/TX direction is toggled by DIO2 of semtech and RAK state this in the documentation
2) Fix TCXO Setting in  sidewalk/subsys/config/common/src/app_subGHz_config.c file as follow
	.tcxo = {
		.ctrl = SX126X_TCXO_CTRL_DIO3,
		.voltage = RADIO_SX126X_TCXO_CTRL_3_3V,
		.timeout = 320,
Until there all is working perfectly fine we can use BLE and LoRa so send our packet and peak consumption when sending LoRa packet is correct
Now we tried to update and move to latest samples from nrf 2.6-rc1 and sidewalk 1.16
github.com/.../sdk-sidewalk
We started from fresh workspace and applied again both previous patches from RAK, then we copied the overlay of the rak4631_nrf52840 board from previous RAK sample repository of course
sid_semtech: &spi1 {
    clock-frequency = <DT_FREQ_M(1)>;
    /delete-property/ cs-gpios;
    lora: lora@0 {
        status = "disabled";
    semtech_sx1262_gpios{
        compatible = "gpio-keys";
        semtech_sx1262_cs: cs {
            gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
            label = "semtech_sx1262 CS";
        semtech_sx1262_reset_gpios: reset {
            gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
            label = "semtech_sx1262 Reset";
        semtech_sx1262_busy_gpios: busy {
            gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
            label = "semtech_sx1262 Busy";
        semtech_sx1262_antenna_enable_gpios: antena_enable {
            gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>;
            label = "semtech_sx1262 Antena Enable";
        semtech_sx1262_dio1_gpios: dio1 {
            gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
            label = "semtech_sx1262 DIO1";
Building sample sid_end_device with overlay "overlay-dut.conf" (to be able to have shell) is fine, flash is fine and we can use dut  with BLE without any issue
But unfortunately as soon as we try to use sub_ghz semtech chip get locks in consumption of 30mA and only way top recover it to power cycle
sid stop and sid deinit does not recover semtech chip.
What is strange is that all is working fine with board nrf52840dk_nrf52840 + semtech SX1262 shield.
As the rak4631 overlay file is the same than in RAK sample that is working fine, we can assume that semtech pin definition of rak4631 overlay are correct and the issue is coming from something going wrong (changed) into SW stack (hard coded pin matching nrf52840dk + semtech and not other board?)
When we tried zephyr class A lorawan sample with rak4631 board it worked like a charm so this confirm that we can exclude any hardware issue since this issue is present only on sidewalk new version v1.6
Since sidewalk stack is not open source we can't investigate further on our side (we'd loved to) so any sidewalk nrf guru's help would be very appreciated
I'm posting there because issues are disabled on  github.com/.../sdk-sidewalk
  • Would it be possible to change the log level(set build optimization to debug) to debug and try again?  Does the same issue happen if you use BLE?
    Regards
    Runar
  • Sure here the log files with debug just after a factory reset, as you can see LoRa link never goes UP
    correct we have no issues in BLE
    *** Booting nRF Connect SDK v3.5.99-ncs1 ***
    nrf                  v2.6.0
    zephyr               v3.5.99-ncs1
    sidewalk             v2.6.0-dirty
    Sidewalk SDK        = 1.16.1.28
    build time          = 2024-03-18 09:36:05.880472+00:00
    board               = rak4631_nrf52840
    [00:00:00.011,688] <dbg> sid_storage: sid_pal_storage_kv_init: Initialized KV storage
    uart:~$ sid init 4
    [00:00:06.082,916] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 8 (SID_EVENT_LAST), context = 0x20017ffc, k_msgq_put result 0
    [00:00:06.083,221] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:06.083,496] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:06.083,648] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:06.083,984] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:06.084,197] <dbg> sid_ble: ble_adapter_init: Sidewalk -> BLE
    [00:00:06.084,228] <inf> sid_ble: Enable BT
    [00:00:06.084,838] <inf> bt_sdc_hci_driver: SoftDevice Controller build revision:
                                                36 f0 e5 0e 87 68 48 fb  02 fd 9f 82 cc 32 e5 7b |6....hH. .....2.{
                                                91 b1 5c ed                                      |..\.
    [00:00:06.087,615] <inf> bt_hci_core: HW Platform: Nordic Semiconductor (0x0002)
    [00:00:06.087,646] <inf> bt_hci_core: HW Variant: nRF52x (0x0002)
    [00:00:06.087,677] <inf> bt_hci_core: Firmware: Standard Bluetooth controller (0x00) Version 54.58864 Build 1214809870
    [00:00:06.114,532] <inf> bt_hci_core: Identity: D3:0E:34:E3:3F:73 (random)
    [00:00:06.114,562] <inf> bt_hci_core: HCI: version 5.4 (0x0d) revision 0x118f, manufacturer 0x0059
    [00:00:06.114,593] <inf> bt_hci_core: LMP: version 5.4 (0x0d) subver 0x118f
    [00:00:06.114,593] <inf> sid_ble: BT initialized
    [00:00:06.114,654] <dbg> sid_ble: ble_adapter_start_service: Sidewalk -> BLE
    [00:00:06.114,654] <dbg> sid_ble: ble_adapter_set_callback: Sidewalk -> BLE
    [00:00:06.114,685] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_mtu_cb_set: BLE -> Sidewalk
    [00:00:06.178,039] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0039 key
    [00:00:06.178,161] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/002f key
    [00:00:06.178,314] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0015 key
    [00:00:06.178,527] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:06.178,558] <inf> sid_cli: sid_init returned 0
    uart:~$ sid start
    [00:00:12.522,827] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 10 (UNKNOWN), context = 0x200180bc, k_msgq_put result 0
    [00:00:12.523,132] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:12.523,284] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:12.523,406] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:12.523,468] <dbg> sid_ble: ble_adapter_set_adv_data: Sidewalk -> BLE
    [00:00:12.523,468] <dbg> sid_ble: ble_adapter_start_advertisement: Sidewalk -> BLE
    [00:00:12.525,085] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:12.525,177] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:12.525,329] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:12.525,512] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:12.525,573] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 2 (SID_EVENT_NEW_STATUS), context = 0x200180bc, k_msgq_put result 0
    [00:00:12.525,604] <inf> app: Status changed: not ready
    [00:00:12.525,787] <inf> app: Device Unregistered, Time Sync Fail, Link status: {BLE: Down, FSK: Down, LoRa: Down}
    [00:00:12.525,787] <inf> sid_cli: sid_start returned 0
    [00:00:12.525,939] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:12.526,092] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:12.526,245] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:15.003,265] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_mtu_changed: BLE -> Sidewalk
    [00:00:15.003,356] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_conn_connected: BLE -> Sidewalk
    [00:00:15.003,417] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.003,448] <inf> sid_ble_conn: BT Connected
    [00:00:15.474,700] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_mtu_changed: BLE -> Sidewalk
    [00:00:15.489,746] <dbg> sid_ble_ama_srv: ama_srv_notif_changed: Notification enabled
    [00:00:15.489,776] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_changed: BLE -> Sidewalk
    [00:00:15.489,868] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.490,203] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:15.504,760] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:15.504,791] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:15.504,852] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.512,237] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=11].
    [00:00:15.512,268] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:15.512,329] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.513,122] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:15.527,313] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:15.527,343] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:15.527,435] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.527,496] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=11].
    [00:00:15.527,496] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:15.527,679] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.528,320] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:15.542,327] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:15.542,327] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:15.542,449] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.542,480] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=11].
    [00:00:15.542,480] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:15.542,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.543,365] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:15.557,250] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:15.557,281] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:15.557,342] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:15.557,525] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.854,858] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=35].
    [00:00:16.854,858] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:16.854,949] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:16.855,316] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:16.855,743] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.855,957] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.856,109] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.856,292] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.856,445] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.856,628] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.866,577] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:16.884,765] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:16.884,765] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:16.884,826] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:16.973,388] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.973,541] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.973,724] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.974,029] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.974,243] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:16.974,914] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.004,760] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:17.004,791] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:17.004,852] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.007,171] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.007,324] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.007,507] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.007,812] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.007,965] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:17.008,422] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.034,759] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:17.034,790] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:17.034,851] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.380,065] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=85].
    [00:00:17.380,096] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:17.380,218] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.380,615] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:17.381,042] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.381,286] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.381,439] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.381,683] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.381,866] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.409,790] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:17.409,820] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:17.409,881] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.425,201] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=98].
    [00:00:17.425,231] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:17.425,292] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.425,476] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:17.425,903] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.426,147] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.426,269] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.445,159] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.445,281] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.445,495] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.445,800] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.445,953] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:17.454,650] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:17.454,650] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:17.454,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.469,757] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:17.469,787] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:17.469,848] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.484,863] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=36].
    [00:00:17.484,863] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:17.484,924] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.485,290] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:17.485,717] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.485,931] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.486,083] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.514,770] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:17.514,770] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:17.514,831] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.552,062] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.552,215] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.552,398] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.552,764] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:17.552,917] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:17.553,314] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:17.561,401] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:17.561,431] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:17.561,614] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:17.574,768] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:17.574,768] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:17.574,859] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:18.114,959] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=63].
    [00:00:18.114,990] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:18.115,112] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:18.115,417] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:18.115,844] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.116,943] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.117,095] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.117,279] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.117,767] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.117,919] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.118,103] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.118,255] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.118,988] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.119,110] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:18.130,065] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:18.130,096] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:18.130,157] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:18.130,523] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:18.144,775] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:18.144,805] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:18.144,866] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:18.744,964] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=59].
    [00:00:18.744,964] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:18.745,086] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:18.745,391] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:18.745,849] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.746,551] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.746,704] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.772,003] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.772,308] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.772,613] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.774,291] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:18.774,444] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:18.789,642] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:18.789,672] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:18.789,733] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:18.789,794] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:18.791,412] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:18.791,442] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:18.791,503] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:18.804,779] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:18.804,779] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:18.804,840] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:19.420,135] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=79].
    [00:00:19.420,135] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:19.420,227] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:19.420,410] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:19.420,959] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.421,325] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.421,600] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.435,119] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=96].
    [00:00:19.435,119] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:19.435,211] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:19.435,638] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:19.435,638] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:19.435,699] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:19.435,882] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:19.436,431] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.436,798] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.437,072] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.455,780] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.456,054] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.456,359] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.456,848] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.457,000] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:19.464,660] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:19.464,660] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:19.464,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:19.479,797] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:19.479,797] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:19.479,888] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:19.494,842] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=34].
    [00:00:19.494,873] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:19.494,934] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:19.495,147] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:19.495,819] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.496,185] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.496,459] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.524,780] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:19.524,780] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:19.524,841] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:19.562,469] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.562,744] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.563,049] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.563,446] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:19.563,598] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:19.584,777] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:19.584,777] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:19.584,838] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.184,967] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=59].
    [00:00:20.184,997] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:20.185,119] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.185,394] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:20.185,974] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.187,194] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.187,469] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.187,805] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.188,385] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.188,659] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.188,995] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.189,239] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.190,185] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.190,307] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:20.232,574] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:20.232,604] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:20.232,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.233,062] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.279,785] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:20.279,785] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:20.279,846] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.659,912] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=51].
    [00:00:20.659,942] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:20.660,034] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.660,369] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:20.660,949] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.661,773] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.662,048] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.662,567] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.662,841] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.663,146] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.664,703] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.664,855] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:20.683,624] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.683,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.685,516] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.685,943] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.686,279] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.686,370] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 2 (SID_EVENT_NEW_STATUS), context = 0x200180f4, k_msgq_put result 0
    [00:00:20.686,370] <inf> app: Status changed: not ready
    [00:00:20.686,553] <inf> app: Device Is registered, Time Sync Fail, Link status: {BLE: Up, FSK: Down, LoRa: Down}
    [00:00:20.686,950] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.687,347] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/002b key
    [00:00:20.687,377] <dbg> sid_ble: ble_adapter_stop_advertisement: Sidewalk -> BLE
    [00:00:20.687,744] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.688,110] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.688,476] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0020 key
    [00:00:20.688,842] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0021 key
    [00:00:20.690,124] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.690,155] <dbg> sid_ble: ble_adapter_set_adv_data: Sidewalk -> BLE
    [00:00:20.690,155] <dbg> sid_ble: ble_adapter_start_advertisement: Sidewalk -> BLE
    [00:00:20.691,162] <err> sid_ble: Advertising failed to start (err -12)
    [00:00:20.695,617] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.697,052] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.697,998] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:20.698,272] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.707,580] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:20.707,611] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:20.707,672] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:20.754,791] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:20.754,791] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:20.754,852] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:21.134,765] <dbg> sid_ble_ama_srv: ama_srv_notif_changed: Notification disabled
    [00:00:21.134,796] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_changed: BLE -> Sidewalk
    [00:00:21.134,887] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:21.230,072] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_conn_disconnected: BLE -> Sidewalk
    [00:00:21.230,133] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:21.230,194] <inf> sid_ble_conn: BT Disconnected Reason: 0x13 = REMOTE_USER_TERM_CONN
    [00:00:21.230,621] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.230,987] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.231,384] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.231,750] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.232,727] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.232,757] <dbg> sid_ble: ble_adapter_set_adv_data: Sidewalk -> BLE
    [00:00:21.232,757] <dbg> sid_ble: ble_adapter_start_advertisement: Sidewalk -> BLE
    [00:00:21.234,436] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.234,497] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 2 (SID_EVENT_NEW_STATUS), context = 0x2001809c, k_msgq_put result 0
    [00:00:21.234,497] <inf> app: Status changed: not ready
    [00:00:21.234,680] <inf> app: Device Is registered, Time Sync Fail, Link status: {BLE: Down, FSK: Down, LoRa: Down}
    [00:00:21.291,076] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:21.291,290] <dbg> sid_ble: ble_adapter_stop_advertisement: Sidewalk -> BLE
    [00:00:21.291,900] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.292,266] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.293,212] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.293,243] <dbg> sid_ble: ble_adapter_set_adv_data: Sidewalk -> BLE
    [00:00:21.293,273] <dbg> sid_ble: ble_adapter_start_advertisement: Sidewalk -> BLE
    [00:00:21.294,952] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.295,379] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.295,776] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.297,027] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:21.297,119] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:23.685,638] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.256,988] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_mtu_changed: BLE -> Sidewalk
    [00:00:24.257,049] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_conn_connected: BLE -> Sidewalk
    [00:00:24.257,110] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.257,141] <inf> sid_ble_conn: BT Connected
    [00:00:24.692,260] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_mtu_changed: BLE -> Sidewalk
    [00:00:24.714,813] <dbg> sid_ble_ama_srv: ama_srv_notif_changed: Notification enabled
    [00:00:24.714,813] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_changed: BLE -> Sidewalk
    [00:00:24.714,935] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.715,545] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:24.729,980] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:24.730,010] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:24.730,072] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.744,781] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=11].
    [00:00:24.744,781] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:24.744,873] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.750,122] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:24.774,963] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:24.774,963] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:24.775,024] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.775,054] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=11].
    [00:00:24.775,085] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    --- 3 messages dropped ---
    [00:00:24.775,146] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.775,787] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:24.804,870] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:24.804,870] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:24.804,992] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.805,023] <dbg> sid_ble_ama_srv: ama_srv_on_write: Data received for AMA_SERVICE [len=11].
    [00:00:24.805,053] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_data_write: BLE -> Sidewalk
    [00:00:24.805,236] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.808,990] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:24.834,808] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:24.834,808] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:24.834,869] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.835,296] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.880,462] <dbg> sid_ble: ble_adapter_send_data: Sidewalk -> BLE
    [00:00:24.881,103] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.882,812] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.883,209] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.885,437] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.885,498] <dbg> sid_ble: ble_adapter_disconnect: Sidewalk -> BLE
    [00:00:24.886,108] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.886,199] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 2 (SID_EVENT_NEW_STATUS), context = 0x20018144, k_msgq_put result 0
    [00:00:24.886,199] <inf> app: Status changed: ready
    [00:00:24.886,352] <inf> app: Device Is registered, Time Sync Success, Link status: {BLE: Up, FSK: Down, LoRa: Down}
    [00:00:24.886,444] <inf> app: Link mode on BLE = {Cloud: True, Mobile: False}
    [00:00:24.895,507] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.895,935] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.896,331] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0022 key
    [00:00:24.896,697] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/001d key
    [00:00:24.909,698] <dbg> sid_ble_srv: notification_sent: Notification sent.
    [00:00:24.909,729] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_sent: BLE -> Sidewalk
    [00:00:24.909,790] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.911,956] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.912,261] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.924,896] <dbg> sid_ble_ama_srv: ama_srv_notif_changed: Notification disabled
    [00:00:24.924,926] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_notification_changed: BLE -> Sidewalk
    [00:00:24.924,987] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.925,018] <dbg> sid_ble_adapter_callbacks: sid_ble_adapter_conn_disconnected: BLE -> Sidewalk
    [00:00:24.925,079] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.925,109] <inf> sid_ble_conn: BT Disconnected Reason: 0x16 = LOCALHOST_TERM_CONN
    [00:00:24.925,231] <dbg> sid_ble: ble_adapter_stop_advertisement: Sidewalk -> BLE
    [00:00:24.925,598] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.925,933] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.926,361] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.926,727] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.929,840] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.929,901] <dbg> sid_ble: ble_adapter_set_adv_data: Sidewalk -> BLE
    [00:00:24.929,931] <dbg> sid_ble: ble_adapter_start_advertisement: Sidewalk -> BLE
    [00:00:24.931,610] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:24.931,701] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 2 (SID_EVENT_NEW_STATUS), context = 0x2001801c, k_msgq_put result 0
    [00:00:24.931,701] <inf> app: Status changed: not ready
    [00:00:24.931,854] <inf> app: Device Is registered, Time Sync Success, Link status: {BLE: Down, FSK: Down, LoRa: Down}
    [00:00:24.939,300] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:24.939,483] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:25.885,559] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:25.886,108] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:25.886,505] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:25.887,054] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/001d key
    [00:00:25.888,854] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:25.888,977] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:30.311,126] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:30.311,309] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:30.311,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.885,772] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.931,671] <dbg> sid_ble_advert: change_advertisement_interval: BLE -> BLE
    [00:01:05.885,955] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.886,138] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.886,505] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.887,023] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:05.887,420] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:05.888,488] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:05.888,610] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.312,805] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.312,957] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.313,354] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:25.886,657] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:45.886,840] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:45.887,023] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:45.887,390] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:45.887,908] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:45.888,305] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:45.889,373] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:45.889,495] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:50.532,592] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:50.532,775] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:50.533,172] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    uart:~$ sid last_status
    [00:02:05.887,573] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:02:06.399,291] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 14 (UNKNOWN), context = (nil), k_msgq_put result 0
    [00:02:06.399,597] <inf> sid_cli: Device Is registered, Time Sync Success, Link status: {BLE: Down, FSK: Down, LoRa: Down}
  • Thanks for the logs. Could you try with sid init 6 as it is LoRa + FSK without BLE and  we can see if the error is reproduced. It seems to be something with Semtech / LoRa / FSK, as BLE seems to work as expected which fits your reasoning.
    Regards
    Runar
  • For sure, I already tried this one but here the log files, pay attention looks like going to a huge send
    nrf                  v2.6.0
    zephyr               v3.5.99-ncs1
    [00:00:00.011,413] <dbg> sid_storage: sid_pal_storage_kv_init: Initialized KV storage
    uart:~$ sid init 6
    [00:00:11.024,871] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 8 (SID_EVENT_LAST), context = 0x20017ffc, k_msgq_put result 0
    [00:00:11.025,390] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:11.025,909] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:11.026,275] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:11.026,947] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:11.027,313] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/002b key
    [00:00:11.087,707] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0003 key
    [00:00:11.088,043] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/002e key
    [00:00:11.088,378] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/002c key
    [00:00:11.088,745] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0025 key
    [00:00:11.089,263] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:11.089,294] <inf> sid_cli: sid_init returned 0
    uart:~$ sid start
    [00:00:16.185,363] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 10 (UNKNOWN), context = 0x20017ffc, k_msgq_put result 0
    [00:00:16.185,791] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:16.186,126] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.186,492] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.186,889] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.187,286] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.187,377] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 2 (SID_EVENT_NEW_STATUS), context = 0x20017ffc, k_msgq_put result 0
    [00:00:16.187,377] <inf> app: Status changed: not ready
    [00:00:16.187,530] <inf> app: Device Is registered, Time Sync Fail, Link status: {BLE: Down, FSK: Down, LoRa: Down}
    [00:00:16.187,561] <inf> sid_cli: sid_start returned 0
    [00:00:16.187,957] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.188,323] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0020 key
    [00:00:16.188,659] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0021 key
    [00:00:16.189,025] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/001c key
    [00:00:16.190,307] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.190,673] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:16.191,070] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.299,652] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.306,884] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.307,312] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.307,525] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.307,861] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.308,197] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.308,441] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.308,776] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.309,143] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.309,509] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.338,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.338,806] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.367,401] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.367,858] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.368,316] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.368,713] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.370,178] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:00:36.370,300] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.401,763] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.401,824] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.464,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.464,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.643,463] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.643,646] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.644,226] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.769,439] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.769,592] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.770,233] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.779,724] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.779,785] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.842,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.842,773] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.905,700] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.905,792] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.968,719] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:36.968,780] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.031,707] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.031,768] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.210,449] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.210,601] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.211,212] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.220,733] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.220,794] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.283,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.283,782] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.346,771] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.346,832] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.525,482] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.525,634] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.526,000] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.535,705] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.535,766] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.598,693] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.598,785] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.661,743] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.661,834] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.724,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.724,792] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.787,719] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.787,780] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.850,769] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.850,830] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.913,696] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.913,757] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.976,745] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:37.976,837] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.039,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.039,764] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.102,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.102,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.165,740] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.165,802] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.228,698] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.228,759] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.291,778] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.291,870] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.354,766] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.354,827] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.417,724] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.417,785] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.480,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.480,773] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.543,701] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.543,762] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.606,719] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.606,811] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.669,738] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.669,799] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.732,696] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.732,757] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.795,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.795,776] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.858,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.858,764] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.921,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.921,844] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.984,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:38.984,802] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.047,698] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.047,760] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.110,748] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.110,809] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.173,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.173,767] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.236,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.236,755] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.299,743] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.299,804] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.362,701] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.362,762] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.425,689] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.425,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.488,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.488,769] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.551,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.551,788] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.614,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.614,807] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.677,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.677,764] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.740,692] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.740,753] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.803,710] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.803,771] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.866,760] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.866,821] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.929,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.929,779] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.992,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:39.992,767] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.055,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.055,755] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.118,713] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.118,774] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.181,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.181,793] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.244,689] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.244,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.307,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.307,769] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.370,697] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.370,758] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.433,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.433,776] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.496,734] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.496,795] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.559,692] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.559,753] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.622,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.622,802] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.685,699] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.685,760] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.748,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.748,779] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.811,737] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.811,798] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.874,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.874,755] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.937,713] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:40.937,774] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.000,701] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.000,762] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.063,690] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.063,751] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.126,770] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.126,831] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.189,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.189,788] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.252,716] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.252,777] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.315,704] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.315,765] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.378,692] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.378,753] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.441,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.441,802] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.504,730] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.504,791] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.567,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.567,779] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.630,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.630,767] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.693,725] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.693,786] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.756,744] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.756,805] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.819,763] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.819,824] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.882,720] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.882,781] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.945,739] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:41.945,800] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.008,697] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.008,758] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.071,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.071,807] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.134,735] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.134,796] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.197,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.197,784] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.260,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.260,772] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.323,699] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.323,760] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.386,779] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.386,840] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.449,737] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.449,798] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.512,725] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.512,786] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.575,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.575,775] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.638,702] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.638,763] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.701,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.701,812] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.764,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.764,770] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.827,697] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.827,758] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.890,716] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.890,777] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.953,704] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:42.953,765] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.016,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.016,815] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.079,742] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.079,803] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.142,730] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.142,791] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.205,780] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.205,841] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.268,707] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.268,768] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.331,726] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.331,817] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.394,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.394,775] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.457,702] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.457,763] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.520,690] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.520,751] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.583,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.583,770] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.646,728] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.646,820] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.709,747] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.709,808] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.772,705] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.772,766] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.835,693] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.835,754] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.898,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.898,773] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.961,761] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:43.961,853] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.024,749] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.024,810] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.087,707] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.087,768] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.150,695] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.150,756] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.213,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.213,775] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.276,763] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.276,824] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.339,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.339,782] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.402,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.402,770] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.465,698] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.465,759] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.528,717] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.528,778] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.591,766] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.591,827] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.654,724] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.654,785] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.717,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.717,773] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.780,700] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.780,761] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.843,688] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.843,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.906,738] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.906,829] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.969,726] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:44.969,787] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.032,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.032,775] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.095,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.095,764] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.158,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.158,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.221,771] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.221,832] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.284,759] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.284,820] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.347,717] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.347,778] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.410,705] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.410,766] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.473,693] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.473,754] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.536,743] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.536,834] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.599,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.599,792] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.662,689] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.662,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.725,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.725,769] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.788,696] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.788,757] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.851,745] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.851,837] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.914,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.914,764] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.977,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:45.977,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.040,710] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.040,771] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.103,698] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.103,759] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.375,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.375,793] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.418,701] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.418,762] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.481,689] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.481,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.544,677] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.544,738] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.607,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.607,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.670,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.670,776] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.733,673] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.733,734] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.796,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.796,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.859,680] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.859,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.922,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.922,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.985,687] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:46.985,748] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.048,675] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.048,736] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.111,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.111,755] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.174,682] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.174,743] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.237,670] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.237,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.300,720] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.300,781] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.363,677] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.363,739] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.426,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.426,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.489,685] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.489,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.552,673] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.552,734] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.615,692] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.615,753] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.678,680] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.678,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.741,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.741,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.804,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.804,779] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.867,675] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.867,736] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.930,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.930,755] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.993,713] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:47.993,774] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.056,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.056,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.119,689] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.119,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.182,678] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.182,739] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.245,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.245,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.308,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.308,776] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.371,673] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.371,734] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.434,692] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.434,753] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.497,680] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.497,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.560,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.560,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.623,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.623,779] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.686,676] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.686,737] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.749,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.749,755] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.812,683] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.812,744] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.875,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.875,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.938,720] <dbg> sidewalk_app: nd: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:48.938,781] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.001,678] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.001,739] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.064,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.064,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.127,685] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.127,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.190,704] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.190,765] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.253,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.253,784] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.316,680] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.316,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.379,669] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.379,730] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.442,687] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.442,749] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.505,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.505,767] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.568,695] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.568,756] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    631,713] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.631,774] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.694,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.694,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.757,690] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.757,751] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.820,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.820,770] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.883,697] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.883,758] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.946,685] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:49.946,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.009,674] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.009,735] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.072,692] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.072,753] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.135,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.135,772] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.198,699] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.198,760] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.261,688] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.261,749] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.324,707] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.324,768] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.387,695] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.387,756] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.450,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.450,775] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.513,702] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.513,763] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.576,690] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.576,751] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.639,678] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.639,739] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.702,667] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.702,728] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.765,716] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.765,777] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.828,674] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.828,735] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.891,693] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.891,754] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.954,681] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:50.954,742] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.017,669] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.017,730] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.080,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.080,780] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.143,707] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.143,768] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.206,695] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.206,756] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.269,683] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.269,744] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.332,672] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.332,733] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.395,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.395,782] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.458,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.458,770] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.521,667] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.521,728] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.584,686] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.584,747] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.647,674] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.647,735] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.710,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.710,784] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.773,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.773,773] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.836,669] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.836,730] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.899,688] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.899,749] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.962,677] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:51.962,738] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.025,726] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.025,787] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.088,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.088,775] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.151,672] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.151,733] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.214,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.214,782] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.277,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.277,770] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.340,698] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.340,759] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.403,717] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.403,778] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.466,674] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.466,735] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.529,693] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.529,754] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.592,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.592,773] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.655,700] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.655,792] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.718,719] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.718,780] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.781,677] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.781,738] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.844,665] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.844,726] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.907,684] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.907,745] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.970,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:52.970,794] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.033,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.033,782] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.096,679] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.096,740] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.159,667] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.159,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.222,686] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.222,747] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.285,705] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.285,797] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.348,724] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.348,785] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.411,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.411,773] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.474,670] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.474,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.537,689] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.537,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.600,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.600,769] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.663,696] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.663,757] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.726,684] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.726,745] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.789,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.789,764] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.852,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.852,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.915,740] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.915,802] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.978,698] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:53.978,759] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.041,687] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.041,748] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.104,675] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.104,736] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.167,724] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.167,785] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.230,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.230,773] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.293,670] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.293,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.356,719] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.356,781] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.419,677] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.419,738] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.482,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.482,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.545,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.545,776] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.608,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.608,764] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.671,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.671,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.734,680] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.734,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.797,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.797,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.860,717] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.860,778] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.923,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.923,767] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.986,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:54.986,755] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.049,682] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.049,743] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.112,670] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.112,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.175,720] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.175,781] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.238,677] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.238,739] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.301,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.301,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.364,685] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.364,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.427,673] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.427,734] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.490,722] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.490,783] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.553,680] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.553,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.616,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.616,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.679,687] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.679,748] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.742,675] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.742,736] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.805,725] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.805,786] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.868,682] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.868,743] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.931,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.931,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.994,689] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:55.994,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.057,678] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.057,739] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.120,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.120,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.183,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.183,776] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.454,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.454,772] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.498,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.498,779] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.561,645] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.561,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.624,694] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.624,755] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.687,683] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.687,744] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.750,701] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.750,762] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.813,659] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.813,720] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.876,647] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.876,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.939,697] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:56.939,758] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.002,685] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.002,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.065,643] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.065,704] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.128,662] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.128,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.191,650] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.191,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.254,699] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.254,760] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.317,687] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.317,749] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.380,645] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.380,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.443,664] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.443,725] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.506,652] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.506,713] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.569,702] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.569,763] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.632,690] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.632,751] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.695,648] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.695,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.758,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.758,728] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.821,655] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.821,716] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.884,674] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.884,735] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.947,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:57.947,784] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.010,650] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.010,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.073,699] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.073,760] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.136,657] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.136,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.199,676] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.199,737] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.262,695] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.262,756] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.325,653] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.325,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.388,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.388,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.451,660] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.451,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.514,678] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.514,739] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.577,697] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.577,758] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.640,655] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.640,716] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.703,643] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.703,704] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.766,662] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.766,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.829,681] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.829,742] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.892,700] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.892,761] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.955,657] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:58.955,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.018,646] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.018,707] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.081,665] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.081,726] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.144,683] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.144,744] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.207,702] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.207,763] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.270,660] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.270,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.333,648] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.333,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.396,667] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.396,728] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.459,686] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.459,747] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.522,674] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.522,735] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.585,662] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.585,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.648,651] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.648,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.711,669] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.711,730] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.774,688] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.774,749] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.837,677] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.837,738] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.900,665] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.900,726] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.963,653] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:00:59.963,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.026,672] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.026,733] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.089,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.089,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.152,679] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.152,740] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.215,728] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.278,656] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.278,717] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.341,644] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.341,705] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.404,693] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.404,754] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.467,681] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.467,742] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.530,670] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.530,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.593,658] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.593,719] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.656,646] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.656,707] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.719,726] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.719,787] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.782,653] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.782,714] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.845,642] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.845,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.908,660] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.908,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.971,649] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:00.971,710] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.034,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.034,820] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.097,717] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.097,778] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.160,644] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.160,705] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.223,663] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.223,724] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.286,651] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.286,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.349,700] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.349,792] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.412,689] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.412,750] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.475,646] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.475,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.538,665] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.538,726] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.601,654] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.601,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.664,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.664,764] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.727,691] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.727,752] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.790,649] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.790,710] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.853,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.853,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.916,656] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.916,717] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.979,675] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:01.979,736] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.042,663] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.042,724] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.105,651] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.105,712] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.168,670] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.168,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.231,658] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.231,719] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.294,677] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.294,738] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.357,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.357,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.420,654] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.420,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.483,642] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.483,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.546,661] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.546,722] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.609,680] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.609,741] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.672,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.672,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.735,656] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.735,717] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.798,645] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.798,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.861,663] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.861,724] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.924,652] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.924,713] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.987,670] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:02.987,731] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.050,659] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.050,720] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.113,647] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.113,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.176,696] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.176,757] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.239,654] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.239,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.302,642] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.302,703] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.365,661] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.365,722] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.428,649] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.428,710] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.491,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.491,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.554,656] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.554,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.617,645] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.617,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.680,664] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.680,725] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.743,652] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.743,713] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.806,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.806,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.869,659] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.869,720] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.932,647] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.932,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.995,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:03.995,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.058,654] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.058,715] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.121,643] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.121,704] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.184,661] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.184,722] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.247,650] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.247,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.310,668] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.310,729] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.373,657] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.373,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.436,645] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.436,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.499,664] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.499,725] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.562,683] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.562,744] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.625,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.625,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.688,659] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.688,720] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.751,647] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.751,708] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.814,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.814,727] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.877,685] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.877,746] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.940,643] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:04.940,704] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.003,662] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.003,723] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.066,650] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.066,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.129,669] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.129,730] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.192,687] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.192,749] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.255,645] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.255,706] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.318,664] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.318,725] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.381,652] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.381,713] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.444,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.444,732] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.507,690] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.507,751] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.570,648] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.570,709] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.633,666] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.633,728] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.696,655] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.696,716] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.759,674] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.759,735] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.822,692] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.822,753] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.885,650] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.885,711] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.948,669] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:05.948,730] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.011,657] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.011,718] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.074,676] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.074,737] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.137,695] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.137,756] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.200,592] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.200,653] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.263,610] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.263,671] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.370,391] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.370,819] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.371,307] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.371,704] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.372,802] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.372,955] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.533,721] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.533,782] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.534,637] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.535,064] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.535,400] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.535,614] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.535,919] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.536,315] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.536,560] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:06.536,895] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.537,261] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:06.537,628] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.186,950] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:16.187,377] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.187,744] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.188,110] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.188,476] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.188,842] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.189,208] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.189,575] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.189,941] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.190,093] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:16.248,687] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0039 key
    [00:01:16.249,053] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/002f key
    [00:01:16.249,389] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0015 key
    [00:01:16.249,633] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:16.250,030] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.250,457] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.250,793] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.251,068] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:16.251,373] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.252,349] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.252,716] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.253,112] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.253,479] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.253,845] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.310,119] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:16.310,546] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.311,004] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.311,401] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.312,316] <dbg> settings_utils: settings_utils_load_immediate_value: loaded sidewalk/storage/0000/0027 key
    [00:01:16.312,408] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:21.307,495] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    [00:01:21.307,678] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 0 (SID_EVENT_SIDEWALK), context = (nil), k_msgq_put result 0
    uart:~$ sid last_status
    [00:01:33.783,538] <dbg> sidewalk_app: sidewalk_event_send: sidewalk_event_send event = 14 (UNKNOWN), context = (nil), k_msgq_put result 0
    [00:01:33.783,843] <inf> sid_cli: Device Is registered, Time Sync Fail, Link status: {BLE: Down, FSK: Down, LoRa: Down}
  • Thanks again for the logs. Its interesting that we no longer see the error -35 but we now see a large amount of SID_EVENT_SIDEWALK events. This specific event is emitted when a callback from Sidewalk stack is called called on_sidewalk_event This callback tells the application that it has to call sid_process() and that what we do in handling of this event. This suggests that the issue is somewhere inside sidewalk libraries, One possibility is that there is some infinite loop or unmet condition resulting in continuously calling the sid_process but nothing is changing.
    We suspect the issue is related to the FSK driver as LoRa + BLE Did not show such behavior ( LoRa didn't work, but it didn't call for sid_process like in this example). Since we don't have the same module is a bit hard to debug. We are looking into if there were any changes in the drivers form 1.14 to 1.16. What you might try to, is to check if the driver from 1.14 will fix the issue ( replace the library libsid_pal_radio_sx126x_impl.a to the one from the working version)
    This may not work at all, but it is worth to try.
    Regards
    Runar
