Sidewalk SubGhz fail/locks SX1262 on v1.16 with RAK4630
Dear Support
We currently use a custom PCB board with RAK4630 (NRF52840 + Semtech SX1262)
We started to try with RAK sample located here
https://github.com/RAKWireless/RAK4630-Amazon-Sidewalk-Example
We used the sample rak4631_sid_dut because it's easier with the shell to pass and test sidewalk commands using serial terminal
Of course we applied both RAK patches for this to work
1) The correct the RF Antenna SW by setting up GPIO 5 instead of 7 (see RAK4630 schematics)
GPIO 7 should not be used because RF Control switch RX/TX direction is toggled by DIO2 of semtech and RAK state this in the documentation
2) Fix TCXO Setting in  sidewalk/subsys/config/common/src/app_subGHz_config.c file as follow
	.tcxo = {
		.ctrl = SX126X_TCXO_CTRL_DIO3,
		.voltage = RADIO_SX126X_TCXO_CTRL_3_3V,
		.timeout = 320,
Until there all is working perfectly fine we can use BLE and LoRa so send our packet and peak consumption when sending LoRa packet is correct
Now we tried to update and move to latest samples from nrf 2.6-rc1 and sidewalk 1.16
github.com/.../sdk-sidewalk
We started from fresh workspace and applied again both previous patches from RAK, then we copied the overlay of the rak4631_nrf52840 board from previous RAK sample repository of course
sid_semtech: &spi1 {
    clock-frequency = <DT_FREQ_M(1)>;
    /delete-property/ cs-gpios;
    lora: lora@0 {
        status = "disabled";
    semtech_sx1262_gpios{
        compatible = "gpio-keys";
        semtech_sx1262_cs: cs {
            gpios = <&gpio1 10 GPIO_ACTIVE_LOW>;
            label = "semtech_sx1262 CS";
        semtech_sx1262_reset_gpios: reset {
            gpios = <&gpio1 6 GPIO_ACTIVE_LOW>;
            label = "semtech_sx1262 Reset";
        semtech_sx1262_busy_gpios: busy {
            gpios = <&gpio1 14 GPIO_ACTIVE_HIGH>;
            label = "semtech_sx1262 Busy";
        semtech_sx1262_antenna_enable_gpios: antena_enable {
            gpios = <&gpio1 5 GPIO_ACTIVE_HIGH>;
            label = "semtech_sx1262 Antena Enable";
        semtech_sx1262_dio1_gpios: dio1 {
            gpios = <&gpio1 15 GPIO_ACTIVE_HIGH>;
            label = "semtech_sx1262 DIO1";
Building sample sid_end_device with overlay "overlay-dut.conf" (to be able to have shell) is fine, flash is fine and we can use dut  with BLE without any issue
But unfortunately as soon as we try to use sub_ghz semtech chip get locks in consumption of 30mA and only way top recover it to power cycle
sid stop and sid deinit does not recover semtech chip.
What is strange is that all is working fine with board nrf52840dk_nrf52840 + semtech SX1262 shield.
As the rak4631 overlay file is the same than in RAK sample that is working fine, we can assume that semtech pin definition of rak4631 overlay are correct and the issue is coming from something going wrong (changed) into SW stack (hard coded pin matching nrf52840dk + semtech and not other board?)
When we tried zephyr class A lorawan sample with rak4631 board it worked like a charm so this confirm that we can exclude any hardware issue since this issue is present only on sidewalk new version v1.6
Since sidewalk stack is not open source we can't investigate further on our side (we'd loved to) so any sidewalk nrf guru's help would be very appreciated
I'm posting there because issues are disabled on  github.com/.../sdk-sidewalk
