Hello everyone!
I have a custom board featuring nRF5340 and nRF7002. In this board, I gather data from 10 sensors at around 100 Hz (for the whole set), and from 2 more sensors gathering data via BT also at around 100 Hz each. Each sensors create a structure of 40-45 Bytes.
My goal is to forward this data via WiFi in real time, and to achieve so I basically can rely on these networking samples https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.5.2/nrf/samples/net.html
I think the choice should fall between HTTP, MQTT and UDP. I think UDP is the most suitable one since by design allows a fast transmission of data; from what I understood MQTT transmit data as a string, so I guess there will be a string parser on the final application that access data; lastly, regarding HTTP, I think that POST calls to an HTTP server are too slow wrt to my desired data rate.
Do you have any hint or thoughts on this?
