The cs pin of the spi is not working
I'm having problems with the spi api for zephyr, maybe my spi peripherals are not configured correctly, I can see normal signal outputs from the clock and mosi signal lines, but the cs line stays pulled up and doesn't use any other outputs;
I am using the nrf52840dk and trying to drive the st7789v display via spi;
The sdk version I'm using is 2.5.0; the dts used is nrf52840dk_nrf52840;.
Here is the contents of my .overlay file:
&spi1 {
	status = "disabled";
&spi3 {
&i2c0 {
&qspi {
&adc {
&spi0 {
	status = "okay";
	cs-gpios = <&gpio0 30 GPIO_ACTIVE_LOW>;
&spi0_default {
	group1 {
		psels = <NRF_PSEL(SPIM_SCK, 0, 3)>, <NRF_PSEL(SPIM_MOSI, 0, 4)>;
Here are the contents of my prj.conf:
CONFIG_NRFX_SPIM3=y
CONFIG_SPI=y
My spi does it like this:
const struct device *spi= DEVICE_DT_GET(DT_NODELABEL(spi0));
struct spi_config spi_cfg = {
    .operation = SPI_OP_MODE_MASTER | SPI_TRANSFER_MSB | SPI_WORD_SET(8) | SPI_LINES_SINGLE ,
    .frequency = 8000000,
    .slave = 1,
    .cs = {
        .gpio = SPI_CS_GPIOS_DT_SPEC_GET(spi),
        .delay = 2,
int SPI_init(void)
    if(!device_is_ready(spi))
        printk("SPI device is not ready\n");
        return -1;
    printk("is gpio %s\r\n", spi_cs_is_gpio(&spi_cfg.cs) ? "GPIO" : "Hardware CS");
    return 0;
void SPI_write(uint8_t *data, uint16_t len)
    struct spi_buf tx_buf = {
        .buf = data,
        .len = len
    struct spi_buf_set tx = {
        .buffers = &tx_buf,
        .count = 1
    int ret = spi_write(spi, &spi_cfg, &tx);
Here is the git link to my code:
github.com/.../lcd_zephyr_spi
Any help I can get would be appreciated and very much appreciated!
