migrating to sdk v2.6.0 - build errors (caused by gpiote being disabled?)
Need some help with:
nrf5340 - custom board
NO external Flash
DFU over BLE with simultaneous update of both images allowed ( using this devzone concept  with static partition layout)
builds perfectly with SDK v2.5.2 (which was migrated from v2.3.2)
in overlay file:
&gpiote {
status = "disabled";
Trying to migrate to nrf Connect SDK v2.6.0 but getting lots of build errors which seem to be caused by the fact that gpiote is disabled in the overlay file (which has always been that way when building with prior SDK versions). Can't figure out why I am getting these new build errors in SDK v2.6.0.
Here is the build log from VSCode Terminal:
 *  Executing task: nRF Connect: Build [pristine]: sensor_firmware/build (active)
Building sensor_firmware
west build --build-dir /Users/gerardbucas/GitHub/sensor_firmware/build /Users/gerardbucas/GitHub/sensor_firmware --pristine --board nrf5340dk_nrf5340_cpuapp --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -Dhci_ipc_OVERLAY_CONFIG=/opt/nordic/ncs/v2.6.0/nrf/samples/common/mcumgr_bt_ota_dfu/rpmsg_child_image_overlay.conf;/opt/nordic/ncs/v2.6.0/nrf/subsys/bootloader/image/secure_boot.conf;/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf -Dmcuboot_CONF_FILE=/Users/gerardbucas/GitHub/sensor_firmware/child_image/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.conf -Dmcuboot_DTC_OVERLAY_FILE=/opt/nordic/ncs/v2.6.0/nrf/modules/mcuboot/flash_sim.overlay -Dmcuboot_OVERLAY_CONFIG=/opt/nordic/ncs/v2.6.0/nrf/subsys/pcd/pcd.conf;/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf;/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf -DCACHED_CONF_FILE=/Users/gerardbucas/GitHub/sensor_firmware/prj.conf -DDTC_OVERLAY_FILE=/Users/gerardbucas/GitHub/sensor_firmware/nrf5340dk_nrf5340_cpuapp.overlay
-- Application: /Users/gerardbucas/GitHub/sensor_firmware
-- CMake version: 3.21.0
-- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /Users/gerardbucas/Library/Caches/zephyr
-- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr)
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk)
-- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: /Users/gerardbucas/GitHub/sensor_firmware/nrf5340dk_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: /Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/dts.cmake
warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n), CONSOLE (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up
UART_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: LOG_DEFAULT_LEVEL (defined at subsys/logging/Kconfig.filtering:13) was assigned the value
'3' but got the value ''. Check these unsatisfied dependencies: LOG (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_DEFAULT_LEVEL and/or look up
LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
Parsing /opt/nordic/ncs/v2.6.0/zephyr/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration '/Users/gerardbucas/GitHub/sensor_firmware/prj.conf'
Configuration saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/.config'
Kconfig header saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
=== child image hci_ipc - CPUNET begin ===
loading initial cache file /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.6.0/zephyr/samples/bluetooth/hci_ipc
-- Board: nrf5340dk_nrf5340_cpunet
-- Found BOARD.dts: /opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/dts.cmake
Loaded configuration '/opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
Merged configuration '/opt/nordic/ncs/v2.6.0/zephyr/samples/bluetooth/hci_ipc/prj.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/samples/common/mcumgr_bt_ota_dfu/rpmsg_child_image_overlay.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/bootloader/image/secure_boot.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/.config'
Kconfig header saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/include/generated/autoconf.h'
=== child image b0n - CPUNET (inherited) begin ===
loading initial cache file /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.6.0/nrf/samples/nrf5340/netboot
-- Generated zephyr.dts: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/dts.cmake
Parsing /opt/nordic/ncs/v2.6.0/nrf/samples/nrf5340/netboot/Kconfig
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/samples/nrf5340/netboot/prj.conf'
Configuration saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/.config'
Kconfig header saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/include/generated/autoconf.h'
-- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache
CMake Warning at /opt/nordic/ncs/v2.6.0/zephyr/CMakeLists.txt:1957 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n
=== child image b0n - CPUNET (inherited) end ===
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/subsys/bootloader/cmake/debug_keys.cmake:36 (message):
      --- WARNING: Using generated NSIB public/private key-pair. ---
      --- It should not be used for production.                  ---
      --- See CONFIG_SB_SIGNING_KEY_FILE                         ---
  /opt/nordic/ncs/v2.6.0/nrf/subsys/bootloader/cmake/provision_hex.cmake:47 (include)
  /opt/nordic/ncs/v2.6.0/nrf/subsys/CMakeLists.txt:20 (include)
-- libmetal version: 1.4.0 (/opt/nordic/ncs/v2.6.0/zephyr/samples/bluetooth/hci_ipc)
-- Build type:
-- Host:    Darwin/x86_64
-- Target:  Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.4.0 (/opt/nordic/ncs/v2.6.0/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS :  -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/cmake/partition_manager.cmake:79 (message):
          --- WARNING: Using a bootloader without pm_static.yml.            ---
          --- There are cases where a deployed product can consist of       ---
          --- multiple images, and only a subset of these images can be     ---
          --- upgraded through a firmware update mechanism. In such cases,  ---
          --- the upgradable images must have partitions that are static    ---
          --- and are matching the partition map used by the bootloader     ---
          --- programmed onto the device.                                   ---
  /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules/kernel.cmake:248 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:5 (find_package)
-- Configuring done
-- Generating done
=== child image hci_ipc - CPUNET end ===
-- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter
=== child image mcuboot -  begin ===
loading initial cache file /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: /opt/nordic/ncs/v2.6.0/nrf/modules/mcuboot/flash_sim.overlay
-- Generated zephyr.dts: /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/dts.cmake
Parsing /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration '/Users/gerardbucas/GitHub/sensor_firmware/child_image/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/pcd/pcd.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
Merged configuration '/Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/.config'
Kconfig header saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot
=== child image mcuboot -  end ===
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/modules/mcuboot/CMakeLists.txt:382 (message):
          --- WARNING: Using default MCUBoot key, it should not ---
          --- be used for production.                           ---
-- libmetal version: 1.4.0 (/Users/gerardbucas/GitHub/sensor_firmware)
-- Build type:
-- Machine: arm
-- Machine: arm
-- Found partition manager static configuration: /Users/gerardbucas/GitHub/sensor_firmware/pm_static.yml
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary_1' is not included in the dynamic resolving since it is statically defined.
Partition 'pcd_sram' is not included in the dynamic resolving since it is statically defined.
Partition 'rpmsg_nrf53_sram' is not included in the dynamic resolving since it is statically defined.
Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_1' is not included in the dynamic resolving since it is statically defined.
-- Configuring done
-- Generating done
[1/314] Preparing syscall dependency handling
[8/314] Generating include/generated/version.h
-- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr), build: v3.5.99-ncs1
[1/224] Preparing syscall dependency handling
[3/224] Generating include/generated/version.h
[1/139] Preparing syscall dependency handling
[3/139] Generating include/generated/version.h
[139/139] Linking C executable zephyr/zephyr.elf
           FLASH:       23710 B      34176 B     69.38%
             RAM:        3528 B        64 KB      5.38%
           SRAM1:          0 GB        64 KB      0.00%
        IDT_LIST:          0 GB        32 KB      0.00%
[220/224] Linking C executable zephyr/zephyr.elf
           FLASH:      175900 B       222 KB     77.38%
             RAM:       58252 B        64 KB     88.89%
[285/314] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
FAILED: zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
ccache /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/opt/nordic/ncs/v2.6.0/zephyr/include -I/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated -I/opt/nordic/ncs/v2.6.0/zephyr/soc/arm/nordic_nrf/nrf53 -I/opt/nordic/ncs/v2.6.0/zephyr/lib/libc/newlib/include -I/opt/nordic/ncs/v2.6.0/zephyr/soc/common/nordic_nrf/. -I/opt/nordic/ncs/v2.6.0/zephyr/soc/arm/nordic_nrf/common/. -I/opt/nordic/ncs/v2.6.0/zephyr/subsys/mgmt/mcumgr/util/include -I/opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/bootutil/include -I/opt/nordic/ncs/v2.6.0/zephyr/subsys/mgmt/mcumgr/transport/include -I/opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr/include -I/opt/nordic/ncs/v2.6.0/zephyr/subsys/bluetooth -I/opt/nordic/ncs/v2.6.0/zephyr/subsys/settings/include -I/opt/nordic/ncs/v2.6.0/nrf/include -I/opt/nordic/ncs/v2.6.0/nrf/tests/include -I/opt/nordic/ncs/v2.6.0/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v2.6.0/zephyr/modules/cmsis/. -I/opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v2.6.0/zephyr/modules/hal_nordic/nrfx/. -I/Users/gerardbucas/GitHub/sensor_firmware/build/modules/libmetal/libmetal/lib/include -I/opt/nordic/ncs/v2.6.0/modules/lib/open-amp/open-amp/lib/include -I/opt/nordic/ncs/v2.6.0/modules/crypto/tinycrypt/lib/include -I/opt/nordic/ncs/v2.6.0/modules/lib/zcbor/include -I/opt/nordic/ncs/v2.6.0/nrfxlib/softdevice_controller/include -isystem /opt/nordic/ncs/v2.6.0/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/v2.6.0/nrfxlib/crypto/nrf_cc312_platform/include -Wshadow -fno-strict-aliasing -Os -imacros /Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/Users/gerardbucas/GitHub/sensor_firmware=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v2.6.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v2.6.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj -MF zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj.d -o zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj -c /opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c
In file included from /opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_macro.h:34,
                 from /opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/irq_multilevel.h:15,
                 from /opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:20,
                 from /opt/nordic/ncs/v2.6.0/zephyr/modules/hal_nordic/nrfx/./nrfx_config.h:10,
                 from /opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx/nrfx.h:37,
                 from /opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx/drivers/include/nrfx_gpiote.h:37,
                 from /opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:9:
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "Please enable GPIOTE instance for used GPIO port!"
   87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:72:26: note: in definition of macro '__DEBRACKET'
   72 | #define __DEBRACKET(...) __VA_ARGS__
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
   64 |         __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
   59 |         __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1'
  180 |         Z_COND_CODE_1(_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:4151:9: note: in expansion of macro 'COND_CODE_1'
 4151 |         COND_CODE_1(DT_HAS_COMPAT_STATUS_OKAY(DT_DRV_COMPAT),   \
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET'
   69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val
/opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:448:9: note: in expansion of macro 'COND_CODE_1'
  448 |         COND_CODE_1(DT_INST_NODE_HAS_PROP(id, gpiote_instance),                \
/opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:449:18: note: in expansion of macro 'BUILD_ASSERT'
  449 |                 (BUILD_ASSERT(DT_NODE_HAS_STATUS(GPIOTE_PHANDLE(id), okay),    \
/opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:454:9: note: in expansion of macro 'GPIOTE_CHECK'
  454 |         GPIOTE_CHECK(id);                                               \
/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/devicetree_generated.h:15289:50: note: in expansion of macro 'GPIO_NRF_DEVICE'
15289 | #define DT_FOREACH_OKAY_INST_nordic_nrf_gpio(fn) fn(0) fn(1)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in expansion of macro 'DT_FOREACH_OKAY_INST_nordic_nrf_gpio'
  105 | #define UTIL_PRIMITIVE_CAT(a, ...) a##__VA_ARGS__
/opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:476:1: note: in expansion of macro 'DT_INST_FOREACH_STATUS_OKAY'
  476 | DT_INST_FOREACH_STATUS_OKAY(GPIO_NRF_DEVICE)
/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/devicetree_generated.h:15289:56: note: in expansion of macro 'GPIO_NRF_DEVICE'
[286/314] Building C object CMakeFiles/app.dir/src/main.c.obj
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake --build /Users/gerardbucas/GitHub/sensor_firmware/build
 *  The terminal process terminated with exit code: 1.
Can't seem to resolve these new build errors.
Any help would be appreciated!
Thanks
Gerard
    I have asked the relevant team. I will get back to you soon.
    Thanks.
    BR
    Kazi
  • More information on this:
    When I remove the lines:
    &gpiote {
    from the overlay file ( nrf5340dk_nrf5340_cpuapp.overlay ) , all the errors magically disappear & it builds OK and it seems to work (including multi-image DFU over BLE).
    The new build log now looks like this:
    too.
    too.
    -- Configuring done
    -- Generating done
    -- Build type:
    -- Machine: arm
    -- Machine: arm
    -- Configuring done
    -- Generating done
    -- Configuring done
    -- Generating done
    -- Build type:
    -- Machine: arm
    -- Machine: arm
    -- Configuring done
    -- Generating done
    [1/315] Preparing syscall dependency handling
    [6/315] Generating include/generated/version.h
    [175/315] Generating ../../zephyr/net_core_app_update.bin
    image.py: sign the payload
    [189/315] Generating ../../zephyr/net_core_app_signed.hex
    [199/315] Generating ../../zephyr/net_core_app_test_update.hex
    [1/248] Preparing syscall dependency handling
    [5/248] Generating include/generated/version.h
    [248/248] Linking C executable zephyr/zephyr.elf
               FLASH:       27592 B        64 KB     42.10%
                 RAM:      286824 B       440 KB     63.66%
    [305/315] Linking C executable zephyr/zephyr.elf
               FLASH:      184984 B     351744 B     52.59%
                 RAM:       81060 B       440 KB     17.99%
    [308/315] Generating ../../zephyr/app_update.bin
    [310/315] Generating ../../zephyr/app_signed.hex
    [311/315] Generating ../../zephyr/app_test_update.hex
    [315/315] Generating zephyr/merged_domains.hex
    ----------> EDIT: POWER CONSUMPTION IS DRAMATICALLY INCREASED NOW! <----------
    HOWEVER, power consumption is dramatically increased (probably caused by the fact that we can't disable gpiote in the overlay).
    NOTE: our prj.conf file is optimized for lowest possible power consumption, so:
    CONFIG_PM_DEVICE=y
    CONFIG_PM_DEVICE_RUNTIME=y
    CONFIG_BOARD_ENABLE_DCDC_APP=y
    CONFIG_BOARD_ENABLE_DCDC_NET=y
    CONFIG_BOARD_ENABLE_DCDC_HV=y
    CONFIG_SERIAL=n
    CONFIG_CONSOLE=n
    So we are forced to revert back to SDK v2.5.2 for now. Hope you can fix this issue going forward.
    Thanks
    Gerard
    This is perhaps related to the changes in nrfx3.2.0. I got feedback from team.
    Because of adding multi-instance GPIOTE support in nrfx, now the user needs to explicitly enable gpiote node in the board dts. We do it by default for Nordic DKs, but if customer is using custom board it needs to be done manually.
  • Hi
    I don't understand the above response! We specifically do NOT want to enable (or use) the gpiote device (as I mentioned earlier).
    Although we have a custom board, we do not have a custom board file (yet). So we use the nrf5340dk_nrf5340_cpuapp "board" & use an nrf5340dk_nrf5340_cpuapp.overlay file for our board.
    The "problem" with SDK v2.6.0 is that when we disable the gpiote device in the overlay file (as we have done in all earlier SDK's) we get the errors mentioned. So to get a clean build with SDK v2.6.0, we have to remove all references to gpiote in our overlay file BUT then the gpiote device is obviously enabled and the CRITICAL side effect is that power consumption is dramatically increased. So the real question is "how do we disable the gpiote device in SDK v2.6.0.??"
    Below is the overlay file we successfully use for SDK v2.5.2 (& earlier SDK's):
    &pinctrl {
    	uart0_default: uart0_default {
    		group1 {
    			psels = <NRF_PSEL(UART_TX, 1, 4)>,
    				<NRF_PSEL(UART_RTS, 1, 6)>;
    		group2 {
    			psels = <NRF_PSEL(UART_RX, 1, 5)>,
    				<NRF_PSEL(UART_CTS, 1, 7)>;
    			bias-pull-up;
    	uart0_sleep: uart0_sleep {
    		group1 {
    				<NRF_PSEL(UART_RTS, 1, 6)>,
    			low-power-enable;
    	i2c1_default: i2c1_default {
    		group1 {
    			psels = <NRF_PSEL(TWIM_SDA, 1, 2)>,
    				<NRF_PSEL(TWIM_SCL, 1, 3)>;
    			bias-pull-up;
    			nordic,drive-mode = < NRF_DRIVE_S0D1 >;
    	i2c1_sleep: i2c1_sleep {
    		group1 {
    			low-power-enable;
    &adc {
    	status = "okay";
    &gpio0 {
    	status = "okay";
    &gpio1 {
    	status = "okay";
    &gpiote {
    &i2c1 {
    	status = "okay";
        accelerometer: accelerometer@5 {
            compatible = "i2c-device";
            reg = < 0x05 >;
            label = "ACCELEROMETER";
    	tdksensor: TDKsensor@8 {
            reg = < 0x08 >;
            label = "TDKSENSOR";
    &uart0 {
        pinctrl-0 = <&uart0_default>;
        pinctrl-1 = <&uart0_sleep>;
    &uart1 {
    &qspi {
    &led0 {
    &led1 {
    &led2 {
    &led3 {
    &pwm_led0 {
    &button0 {
    &button1 {
    &button2 {
    &button3 {
    &zephyr_udc0 {
    	cdc_acm_uart0: cdc_acm_uart0 {
    		compatible = "zephyr,cdc-acm-uart";
    		label = "CDC_ACM_0";
    	chosen {
    			zephyr,console = &cdc_acm_uart0;
    /* Enabling external flash partitions as a workaround to let the partition manager
     *  create the 'ram_flash' partition for us.
        chosen {
            nordic,pm-ext-flash = &mx25r64;
    For SDK v2.6.0, the build errors are caused by the disabling of the gpiote device (as I explained earlier).
    As I also mentioned earlier, to save power, we config SERIAL=n and CONSOLE=n and LOG=n. Below is our CONFIG file:
    CONFIG_REBOOT=y
    # Activate Power Management (reduce power requirements
    # see: https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/optimizing-power-on-nrf53-designs
    # CONFIG_PM=y
    CONFIG_PM_DEVICE=y
    CONFIG_SERIAL=n
    # Errata 160 included in v2.3.0 & later - ensure System Clock is enabled
    CONFIG_SYS_CLOCK_EXISTS=y
    CONFIG_LOG=n
    CONFIG_USE_SEGGER_RTT=n
    CONFIG_RESET_ON_FATAL_ERROR=y   # not sure this works for non "Nordic DK" boards!?
    CONFIG_ASSERT=n    # crashes i2c init when turned on (=y) with RTT logging - need to investigate...!?
    CONFIG_LOG_DEFAULT_LEVEL=3
    # disable all things related to uarts, usb & console (for max power savings) - CONFIG_SERIAL=n already set above
    CONFIG_CONSOLE=n
    # set stack & heap sizes.
    CONFIG_HEAP_MEM_POOL_SIZE=8192
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=8192
    CONFIG_MAIN_STACK_SIZE=10240
    CONFIG_BT_RX_STACK_SIZE=4096
    # Disable the DK (nordic dev Boards) LED and Buttons library for WearSense boards
    CONFIG_DK_LIBRARY=n
    # required for generating random number for suffix of original BLE NAME set for device.
    CONFIG_ENTROPY_GENERATOR=y
    CONFIG_ENTROPY_DEVICE_RANDOM_GENERATOR=y
    # configure Settings to be stored in NVS Flash on nrf5340 SoC
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_SETTINGS_NVS=y
    CONFIG_SETTINGS_RUNTIME=y
    # BLE Settings
    CONFIG_BT=y
    CONFIG_BT_SETTINGS=n                        # for now we take care of our own BLE settings.
    CONFIG_BT_CENTRAL=n
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DEVICE_NAME="WearSense Sensor"    # Name is re-defined & replaced at runtime
    CONFIG_BT_DEVICE_NAME_DYNAMIC=y
    CONFIG_BT_MAX_CONN=1
    CONFIG_BT_MAX_PAIRED=1
    # appearance 1344 = "Generic Sensor"
    # (see: https://specificationrefs.bluetooth.com/assigned-values/Appearance%20Values.pdf )
    CONFIG_BT_DEVICE_APPEARANCE=1344
    # configure BLE "Device Information Service" (BT_DIS) characteristics.
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_MODEL="WearSense LS2"
    CONFIG_BT_DIS_MANUF="wear-sense.com"
    CONFIG_BT_DIS_FW_REV=y
    CONFIG_BT_DIS_SETTINGS=y            # allows following values to be assigned at runtime
    CONFIG_BT_DIS_SERIAL_NUMBER=y       # assigned at runtime in code
    CONFIG_BT_DIS_HW_REV=y              # assigned at runtime in code
    CONFIG_BT_DIS_SW_REV=n              # not required for WearSense app.
    CONFIG_BT_DIS_PNP=n                 # not required for WearSense app.
    CONFIG_BT_NUS=y         # Enable the NUS service (in advertising)
    CONFIG_BT_BAS=y         # Enable the Battery Level service (in advertising)
    CONFIG_BT_USER_DATA_LEN_UPDATE=y
    CONFIG_BT_GAP_PERIPHERAL_PREF_PARAMS=y
    CONFIG_BT_GAP_AUTO_UPDATE_CONN_PARAMS=y
    # set BLE 'connect parameters' for lowest power consumption
    # so lower data transfer speed but low power when connected but not sending data...
    # 36 = 30ms, 48 = 60ms
    # 24 = able to 'miss' max of 24 intervals of 60ms each to keep BLE connection alive.
    # 500 = 5000 ms - max allowed by Apple (& probably others)
    CONFIG_BT_PERIPHERAL_PREF_MIN_INT=36
    CONFIG_BT_PERIPHERAL_PREF_MAX_INT=48
    CONFIG_BT_PERIPHERAL_PREF_LATENCY=24
    CONFIG_BT_PERIPHERAL_PREF_TIMEOUT=500
    CONFIG_NEWLIB_LIBC=y
    CONFIG_NEWLIB_LIBC_FLOAT_SCANF=y
    # Enable mcumgr (used for reset over BLE and OTA firmware updates).
    CONFIG_MCUMGR=y
    # Ensure an MCUboot-compatible binary is generated.
    CONFIG_BOOTLOADER_MCUBOOT=y
    # CONFIG_MCUMGR_SMP_BT_AUTHEN=n
    CONFIG_DFU_MULTI_IMAGE=y
    CONFIG_DFU_MULTI_IMAGE_MAX_IMAGE_COUNT=2
    CONFIG_NRF53_UPGRADE_NETWORK_CORE=y
    CONFIG_MCUBOOT_IMG_MANAGER=y
    # Enable core DFU/OTA features.
    # CONFIG_MCUMGR_CMD_IMG_MGMT=y
    CONFIG_MCUMGR_GRP_IMG=y
    # CONFIG_MCUMGR_CMD_OS_MGMT=y
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_VALIDATION=y
    CONFIG_DFU_MULTI_IMAGE_PACKAGE_BUILD=y
    CONFIG_DFU_MULTI_IMAGE_PACKAGE_NET=y
    # CONFIG_MCUMGR_SMP_WORKQUEUE_STACK_SIZE=8192
    CONFIG_MCUMGR_TRANSPORT_WORKQUEUE_STACK_SIZE=8192
    # added after devzone case example.
    CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=y
    CONFIG_NCS_SAMPLE_MCUMGR_BT_OTA_DFU_SPEEDUP=y
    # CONFIG_MCUBOOT_IMAGE_VERSION="2.3.0+0" (replaced by VERSION file in v2.5.x)
    CONFIG_UPDATEABLE_IMAGE_NUMBER=2
    CONFIG_ADD_MCUBOOT_MEDIATE_SIM_FLASH_DTS=y
    CONFIG_SIZE_OPTIMIZATIONS=y
    # Enable the SAADC ADC support
    CONFIG_ADC=y
    CONFIG_ADC_ASYNC=y
    CONFIG_ADC_NRFX_SAADC=y
    CONFIG_FPU=y
    # I2C required to read Pressure Sensor & Accelerometer
    CONFIG_I2C=y
    So for now we are reverting back to SDK v2.5.2 but we would still like to move over to SDK v2.6.0 asap. So still need your help with that!
    Thanks!
    Gerard
  • Hello Gerad,
    For custom board, you have to enable GPIOTE node in the board dts manually. Can you try to
    &gpiote {
    }; change this to status enabled?
