migrating to sdk v2.6.0 - build errors (caused by gpiote being disabled?)
Need some help with:
nrf5340 - custom board
NO external Flash
DFU over BLE with simultaneous update of both images allowed ( using this devzone concept  with static partition layout)
builds perfectly with SDK v2.5.2 (which was migrated from v2.3.2)
in overlay file:
&gpiote {
status = "disabled";
Trying to migrate to nrf Connect SDK v2.6.0 but getting lots of build errors which seem to be caused by the fact that gpiote is disabled in the overlay file (which has always been that way when building with prior SDK versions). Can't figure out why I am getting these new build errors in SDK v2.6.0.
Here is the build log from VSCode Terminal:
 *  Executing task: nRF Connect: Build [pristine]: sensor_firmware/build (active)
Building sensor_firmware
west build --build-dir /Users/gerardbucas/GitHub/sensor_firmware/build /Users/gerardbucas/GitHub/sensor_firmware --pristine --board nrf5340dk_nrf5340_cpuapp --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -Dhci_ipc_OVERLAY_CONFIG=/opt/nordic/ncs/v2.6.0/nrf/samples/common/mcumgr_bt_ota_dfu/rpmsg_child_image_overlay.conf;/opt/nordic/ncs/v2.6.0/nrf/subsys/bootloader/image/secure_boot.conf;/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf -Dmcuboot_CONF_FILE=/Users/gerardbucas/GitHub/sensor_firmware/child_image/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.conf -Dmcuboot_DTC_OVERLAY_FILE=/opt/nordic/ncs/v2.6.0/nrf/modules/mcuboot/flash_sim.overlay -Dmcuboot_OVERLAY_CONFIG=/opt/nordic/ncs/v2.6.0/nrf/subsys/pcd/pcd.conf;/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf;/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf -DCACHED_CONF_FILE=/Users/gerardbucas/GitHub/sensor_firmware/prj.conf -DDTC_OVERLAY_FILE=/Users/gerardbucas/GitHub/sensor_firmware/nrf5340dk_nrf5340_cpuapp.overlay
-- Application: /Users/gerardbucas/GitHub/sensor_firmware
-- CMake version: 3.21.0
-- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found suitable version "3.9.6", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: /Users/gerardbucas/Library/Caches/zephyr
-- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr)
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.5 (/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk)
-- Found Dtc: /opt/nordic/ncs/toolchains/580e4ef81c/bin/dtc (found suitable version "1.6.1", minimum required is "1.4.6")
-- Found BOARD.dts: /opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: /Users/gerardbucas/GitHub/sensor_firmware/nrf5340dk_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: /Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/dts.cmake
warning: UART_CONSOLE (defined at drivers/console/Kconfig:43) was assigned the value 'y' but got the
value 'n'. Check these unsatisfied dependencies: SERIAL (=n), SERIAL_HAS_DRIVER (=n), CONSOLE (=n).
See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_CONSOLE and/or look up
UART_CONSOLE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
too.
warning: LOG_DEFAULT_LEVEL (defined at subsys/logging/Kconfig.filtering:13) was assigned the value
'3' but got the value ''. Check these unsatisfied dependencies: LOG (=n). See
http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_LOG_DEFAULT_LEVEL and/or look up
LOG_DEFAULT_LEVEL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
too.
Parsing /opt/nordic/ncs/v2.6.0/zephyr/Kconfig
Loaded configuration '/opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration '/Users/gerardbucas/GitHub/sensor_firmware/prj.conf'
Configuration saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/.config'
Kconfig header saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd (found version "2.38")
-- Found assembler: /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
=== child image hci_ipc - CPUNET begin ===
loading initial cache file /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.6.0/zephyr/samples/bluetooth/hci_ipc
-- Board: nrf5340dk_nrf5340_cpunet
-- Found BOARD.dts: /opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
-- Generated zephyr.dts: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/dts.cmake
Loaded configuration '/opt/nordic/ncs/v2.6.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
Merged configuration '/opt/nordic/ncs/v2.6.0/zephyr/samples/bluetooth/hci_ipc/prj.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/samples/common/mcumgr_bt_ota_dfu/rpmsg_child_image_overlay.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/bootloader/image/secure_boot.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/.config'
Kconfig header saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/zephyr/include/generated/autoconf.h'
=== child image b0n - CPUNET (inherited) begin ===
loading initial cache file /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.6.0/nrf/samples/nrf5340/netboot
-- Generated zephyr.dts: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/dts.cmake
Parsing /opt/nordic/ncs/v2.6.0/nrf/samples/nrf5340/netboot/Kconfig
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/samples/nrf5340/netboot/prj.conf'
Configuration saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/.config'
Kconfig header saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n/zephyr/include/generated/autoconf.h'
-- Using ccache: /opt/nordic/ncs/toolchains/580e4ef81c/bin/ccache
CMake Warning at /opt/nordic/ncs/v2.6.0/zephyr/CMakeLists.txt:1957 (message):
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/gerardbucas/GitHub/sensor_firmware/build/hci_ipc/b0n
=== child image b0n - CPUNET (inherited) end ===
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/subsys/bootloader/cmake/debug_keys.cmake:36 (message):
      --- WARNING: Using generated NSIB public/private key-pair. ---
      --- It should not be used for production.                  ---
      --- See CONFIG_SB_SIGNING_KEY_FILE                         ---
  /opt/nordic/ncs/v2.6.0/nrf/subsys/bootloader/cmake/provision_hex.cmake:47 (include)
  /opt/nordic/ncs/v2.6.0/nrf/subsys/CMakeLists.txt:20 (include)
-- libmetal version: 1.4.0 (/opt/nordic/ncs/v2.6.0/zephyr/samples/bluetooth/hci_ipc)
-- Build type:
-- Host:    Darwin/x86_64
-- Target:  Generic/arm
-- Machine: arm
-- Looking for include file stdatomic.h
-- Looking for include file stdatomic.h - found
-- open-amp version: 1.4.0 (/opt/nordic/ncs/v2.6.0/modules/lib/open-amp/open-amp)
-- Machine: arm
-- C_FLAGS :  -Wall -Wextra
-- Looking for include file fcntl.h
-- Looking for include file fcntl.h - found
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/cmake/partition_manager.cmake:79 (message):
          --- WARNING: Using a bootloader without pm_static.yml.            ---
          --- There are cases where a deployed product can consist of       ---
          --- multiple images, and only a subset of these images can be     ---
          --- upgraded through a firmware update mechanism. In such cases,  ---
          --- the upgradable images must have partitions that are static    ---
          --- and are matching the partition map used by the bootloader     ---
          --- programmed onto the device.                                   ---
  /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules/kernel.cmake:248 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
  /opt/nordic/ncs/v2.6.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
  CMakeLists.txt:5 (find_package)
-- Configuring done
-- Generating done
=== child image hci_ipc - CPUNET end ===
-- Found Python3: /opt/nordic/ncs/toolchains/580e4ef81c/opt/[email protected]/bin/python3.9 (found version "3.9.6") found components: Interpreter
=== child image mcuboot -  begin ===
loading initial cache file /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/child_image_preload.cmake
-- Application: /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: /opt/nordic/ncs/v2.6.0/nrf/modules/mcuboot/flash_sim.overlay
-- Generated zephyr.dts: /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/dts.cmake
Parsing /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration '/Users/gerardbucas/GitHub/sensor_firmware/child_image/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/pcd/pcd.conf'
Merged configuration '/opt/nordic/ncs/v2.6.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
Merged configuration '/Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/.config'
Kconfig header saved to '/Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: /opt/nordic/ncs/v2.6.0/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/gerardbucas/GitHub/sensor_firmware/build/mcuboot
=== child image mcuboot -  end ===
CMake Warning at /opt/nordic/ncs/v2.6.0/nrf/modules/mcuboot/CMakeLists.txt:382 (message):
          --- WARNING: Using default MCUBoot key, it should not ---
          --- be used for production.                           ---
-- libmetal version: 1.4.0 (/Users/gerardbucas/GitHub/sensor_firmware)
-- Build type:
-- Machine: arm
-- Machine: arm
-- Found partition manager static configuration: /Users/gerardbucas/GitHub/sensor_firmware/pm_static.yml
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary_1' is not included in the dynamic resolving since it is statically defined.
Partition 'pcd_sram' is not included in the dynamic resolving since it is statically defined.
Partition 'rpmsg_nrf53_sram' is not included in the dynamic resolving since it is statically defined.
Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_1' is not included in the dynamic resolving since it is statically defined.
-- Configuring done
-- Generating done
[1/314] Preparing syscall dependency handling
[8/314] Generating include/generated/version.h
-- Zephyr version: 3.5.99 (/opt/nordic/ncs/v2.6.0/zephyr), build: v3.5.99-ncs1
[1/224] Preparing syscall dependency handling
[3/224] Generating include/generated/version.h
[1/139] Preparing syscall dependency handling
[3/139] Generating include/generated/version.h
[139/139] Linking C executable zephyr/zephyr.elf
           FLASH:       23710 B      34176 B     69.38%
             RAM:        3528 B        64 KB      5.38%
           SRAM1:          0 GB        64 KB      0.00%
        IDT_LIST:          0 GB        32 KB      0.00%
[220/224] Linking C executable zephyr/zephyr.elf
           FLASH:      175900 B       222 KB     77.38%
             RAM:       58252 B        64 KB     88.89%
[285/314] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
FAILED: zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
ccache /opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DKERNEL -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DUSE_PARTITION_MANAGER=1 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/opt/nordic/ncs/v2.6.0/zephyr/include -I/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated -I/opt/nordic/ncs/v2.6.0/zephyr/soc/arm/nordic_nrf/nrf53 -I/opt/nordic/ncs/v2.6.0/zephyr/lib/libc/newlib/include -I/opt/nordic/ncs/v2.6.0/zephyr/soc/common/nordic_nrf/. -I/opt/nordic/ncs/v2.6.0/zephyr/soc/arm/nordic_nrf/common/. -I/opt/nordic/ncs/v2.6.0/zephyr/subsys/mgmt/mcumgr/util/include -I/opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/bootutil/include -I/opt/nordic/ncs/v2.6.0/zephyr/subsys/mgmt/mcumgr/transport/include -I/opt/nordic/ncs/v2.6.0/bootloader/mcuboot/boot/zephyr/include -I/opt/nordic/ncs/v2.6.0/zephyr/subsys/bluetooth -I/opt/nordic/ncs/v2.6.0/zephyr/subsys/settings/include -I/opt/nordic/ncs/v2.6.0/nrf/include -I/opt/nordic/ncs/v2.6.0/nrf/tests/include -I/opt/nordic/ncs/v2.6.0/modules/hal/cmsis/CMSIS/Core/Include -I/opt/nordic/ncs/v2.6.0/zephyr/modules/cmsis/. -I/opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx -I/opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx/drivers/include -I/opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx/mdk -I/opt/nordic/ncs/v2.6.0/zephyr/modules/hal_nordic/nrfx/. -I/Users/gerardbucas/GitHub/sensor_firmware/build/modules/libmetal/libmetal/lib/include -I/opt/nordic/ncs/v2.6.0/modules/lib/open-amp/open-amp/lib/include -I/opt/nordic/ncs/v2.6.0/modules/crypto/tinycrypt/lib/include -I/opt/nordic/ncs/v2.6.0/modules/lib/zcbor/include -I/opt/nordic/ncs/v2.6.0/nrfxlib/softdevice_controller/include -isystem /opt/nordic/ncs/v2.6.0/zephyr/lib/libc/common/include -isystem /opt/nordic/ncs/v2.6.0/nrfxlib/crypto/nrf_cc312_platform/include -Wshadow -fno-strict-aliasing -Os -imacros /Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mfp16-format=ieee --sysroot=/opt/nordic/ncs/toolchains/580e4ef81c/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/Users/gerardbucas/GitHub/sensor_firmware=CMAKE_SOURCE_DIR -fmacro-prefix-map=/opt/nordic/ncs/v2.6.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/opt/nordic/ncs/v2.6.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -std=c99 -MD -MT zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj -MF zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj.d -o zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj -c /opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c
In file included from /opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_macro.h:34,
                 from /opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/irq_multilevel.h:15,
                 from /opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:20,
                 from /opt/nordic/ncs/v2.6.0/zephyr/modules/hal_nordic/nrfx/./nrfx_config.h:10,
                 from /opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx/nrfx.h:37,
                 from /opt/nordic/ncs/v2.6.0/modules/hal/nordic/nrfx/drivers/include/nrfx_gpiote.h:37,
                 from /opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:9:
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/toolchain/gcc.h:87:36: error: static assertion failed: "Please enable GPIOTE instance for used GPIO port!"
   87 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:72:26: note: in definition of macro '__DEBRACKET'
   72 | #define __DEBRACKET(...) __VA_ARGS__
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:64:9: note: in expansion of macro '__GET_ARG2_DEBRACKET'
   64 |         __GET_ARG2_DEBRACKET(one_or_two_args _if_code, _else_code)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:59:9: note: in expansion of macro '__COND_CODE'
   59 |         __COND_CODE(_XXXX##_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_macro.h:180:9: note: in expansion of macro 'Z_COND_CODE_1'
  180 |         Z_COND_CODE_1(_flag, _if_1_code, _else_code)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/devicetree.h:4151:9: note: in expansion of macro 'COND_CODE_1'
 4151 |         COND_CODE_1(DT_HAS_COMPAT_STATUS_OKAY(DT_DRV_COMPAT),   \
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:69:53: note: in expansion of macro '__DEBRACKET'
   69 | #define __GET_ARG2_DEBRACKET(ignore_this, val, ...) __DEBRACKET val
/opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:448:9: note: in expansion of macro 'COND_CODE_1'
  448 |         COND_CODE_1(DT_INST_NODE_HAS_PROP(id, gpiote_instance),                \
/opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:449:18: note: in expansion of macro 'BUILD_ASSERT'
  449 |                 (BUILD_ASSERT(DT_NODE_HAS_STATUS(GPIOTE_PHANDLE(id), okay),    \
/opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:454:9: note: in expansion of macro 'GPIOTE_CHECK'
  454 |         GPIOTE_CHECK(id);                                               \
/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/devicetree_generated.h:15289:50: note: in expansion of macro 'GPIO_NRF_DEVICE'
15289 | #define DT_FOREACH_OKAY_INST_nordic_nrf_gpio(fn) fn(0) fn(1)
/opt/nordic/ncs/v2.6.0/zephyr/include/zephyr/sys/util_internal.h:105:36: note: in expansion of macro 'DT_FOREACH_OKAY_INST_nordic_nrf_gpio'
  105 | #define UTIL_PRIMITIVE_CAT(a, ...) a##__VA_ARGS__
/opt/nordic/ncs/v2.6.0/zephyr/drivers/gpio/gpio_nrfx.c:476:1: note: in expansion of macro 'DT_INST_FOREACH_STATUS_OKAY'
  476 | DT_INST_FOREACH_STATUS_OKAY(GPIO_NRF_DEVICE)
/Users/gerardbucas/GitHub/sensor_firmware/build/zephyr/include/generated/devicetree_generated.h:15289:56: note: in expansion of macro 'GPIO_NRF_DEVICE'
[286/314] Building C object CMakeFiles/app.dir/src/main.c.obj
FATAL ERROR: command exited with status 1: /opt/nordic/ncs/toolchains/580e4ef81c/bin/cmake --build /Users/gerardbucas/GitHub/sensor_firmware/build
 *  The terminal process terminated with exit code: 1.
Can't seem to resolve these new build errors.
Any help would be appreciated!
Thanks
Gerard
    I have seen this thread, you can even find my posts there. It seems that we need to stick with the /delete-property/ hack for now.
  • Hi grzegorz
    I still have this problem (major power increase when I enable GPIOTE - which I don’t use!). And new SDK version won’t build if disabled it.
    Can you clarify for me what you mean by the ‘delete-property directive’? Where and how is it used to resolve this issue?
    thanks!
    Gerard
  • Any hope of solving this problem soon..!?
    is it solved in SDK v3.x?
    this is really a show-stopper for me…
    major power draw increase when disabling gpiote!
    thx
    Gerard
  • This whole thread is based on a false assumption that enabling the GPIOTE peripheral results in a current consumption increase.
    From a hardware perspective there is no way to disable the GPIOTE peripheral. There is no ENABLE register. It is always enabled. By removing the gpiote instance from the device tree you will get build errors, because it is an integral part of other libraries.
    If you have the gpiote instance in your device tree and you have a high current consumption. There is something else causing the high current consumption.
    The only exception to this is if you have configured a pin as input, sensing for a edge transition. In this configuration the NRF_GPIOTE->CONFIG[] register will be linked to the relevant GPIO and it will enable the GPIOTE IN event, for sensing the edge. This will lead to from 5 to 100 uA current increase (depending on the product type, nRF52/53/54 etc..) If you want to mitigate this you need to use level trigger on the GPIO instead of edge trigger. It will then use the PORT event instead of the IN event. And there will be no extra current consumption.
    So the solution is to use level triggering on the pin, not disabling GPIOTE in the devicetree. How this is done has changed a bit throughout the years. Earlier you had to add the property sense-edge-mask = < 0xffffffff >; to the gpio0 or gpio1 instance in the overlay file. In newer NCS versions you do this in the interrupt configuration, e.g.:
    gpio_pin_interrupt_configure_dt(&button,GPIO_INT_EDGE_TO_ACTIVE);
    or:
    gpio_pin_interrupt_configure_dt(&button,GPIO_INT_LEVEL_ACTIVE);
    https://docs.zephyrproject.org/latest/doxygen/html/group__gpio__interface.html#ga35d2ff0e041236d82004a4bb2b5bf634
    Some more information on the GPIO library can be found here: https://academy.nordicsemi.com/courses/nrf-connect-sdk-fundamentals/lessons/lesson-2-reading-buttons-and-controlling-leds/topic/gpio-generic-api/
    In this thread there are multiple mentions of "major current increase", but I was not able to see any actual numbers. Writing the actual current consumption differences will help in pin pointing the real problem.
    To summarize:
    • If you are using a GPIO as input trigger, you can choose between edge triggering and level triggering. Edge triggering will add some 10s of micro amps to the current, while level triggering will not increase the current.
    • If you are not using a GPIO input trigger, you do not need to do anything.
    • If you still see higher current, it is cause by some other peripheral
