I2C issue in v2.6.0 SDK
So I had a project for Sparkfun nRF9160 Thing plus on toolchain/SDK v2.5.2. Today I noticed that v2.6.0 is out and decided to upgrade. I used basic cellular udp sample to get the lowest Thing Plus baseline current and noticed something strange. So I needed to put any used peripheral in suspended state. Since there is an onboard accelerometer which needed some additional configuring in .overlay file  naturally in main() I tried to suspend the i2c the device used. When I enabled `CONFIG_I2C=y` in .conf file project built just fine but after programming I checked the current profile which had strange pattern so I enabled serial output and noticed that application constantly resets itself.
The output it gives:
E: ***** BUS FAULT *****
E: Precise data bus error
E: BFAR Address: 0x0
E: r0/a1: 0x0001b120 r1/a2: 0x00d00000 r2/a3: 0x00000000
E: r3/a4: 0x0000000c r12/ip: 0x00000001 r14/lr: 0x000181b5
E: xpsr: 0x81000000
E: Faulting instruction address (r15/pc): 0x0000bfdc
E: >>> ZEPHYR FATAL ERROR 25: Unknown error on CPU 0
E: Current thread: 0x2000ca18 (unknown)
E: Resetting system
So I just wanted to point out, that there is something broken in v2.6.0. I reverted back to 2.5.2 and everything runs smoothly.
To replicate this issue:
1) Upgrade toolchain and SDK version to 2.6.0 in VS code;
2) Create a new application based on cellular UDP sample;
3) Enable serial output in `proj.conf` and also arr "CONFIG_I2C=y";
4) After building and programming, you should get the same output
Here is the generated support information:
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Enterprise",
    "osKernel": "10.0.19045",
    "vscode": "1.87.2",
    "electron": "27.3.2",
    "node": "v18.17.1"
  "system": {
    "date": "2024-03-14T10:21:25.812Z",
    "vscodeRoot": "c:\\Users\\andrisku\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:09:56",
    "osUptime": "03:32:53",
    "cpu": "13th Gen Intel(R) Core(TM) i7-1355U"
  "workspace": {
    "name": "udp",
    "workspaceFile": null,
    "folders": [
      "c:\\Users\\andrisku\\Desktop\\nrf_workspace\\udp"
  "sdks": [
      "version": "v2.6.0",
      "path": "c:\\ncs\\v2.6.0"
      "version": "v2.5.2",
      "path": "c:\\ncs\\v2.5.2"
      "version": "v2.5.0",
      "path": "c:\\Users\\andrisku\\Desktop\\west-workspace\\chester-sdk"
  "activeBuild": "c:\\Users\\andrisku\\Desktop\\nrf_workspace\\udp\\build",
  "apps": [
      "workspace": "c:\\Users\\andrisku\\Desktop\\nrf_workspace\\udp",
      "uri": "c:\\Users\\andrisku\\Desktop\\nrf_workspace\\udp",
      "buildConfigurations": [
          "id": "c:\\Users\\andrisku\\Desktop\\nrf_workspace\\udp\\build",
          "name": "build",
          "boardId": "sparkfun_thing_plus_nrf9160_ns",
          "type": "Zephyr",
          "isChild": false,
          "isStale": false,
          "taskBindings": {
            "build": [],
            "pristineBuild": [],
            "flash": [],
            "eraseAndFlash": []
  "topdir": "c:\\ncs\\v2.6.0",
  "workspaceState": "freestanding-ready",
  "toolchains": [
      "version": "2.6.0",
      "path": "c:\\ncs\\toolchains\\cf2149caf2"
      "version": "2.5.2",
      "path": "c:\\ncs\\toolchains\\c57af46cb7"
  "connectedDevices": [
      "serialNumber": "000960065539"
  "deviceProvider": "nrfutil",
  "tools": {
    "C:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.5",
    "C:\\Program Files\\SEGGER\\JLink_V794e\\JLink.exe": "7.94e",
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.24.0",
    "nrfutil": "Not found",
    "C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\cmake.exe": "3.21.0",
    "C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\Scripts\\west.exe": "1.2.0",
    "C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\python.exe": "3.9.13",
    "C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\ninja.exe": "1.10.2",
    "C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\gperf.exe": "3.1",
    "C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\dtc.exe": "1.4.7",
    "C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\gn.exe": "2154",
    "C:\\ncs\\toolchains\\cf2149caf2\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "gdbPath": "c:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
  "nrfutil": {
    "nrfutil-device": {
      "version": "2.0.0",
      "binPath": "c:\\Users\\andrisku\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.2.214-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device"
    "nrfutil-toolchain-manager": {
      "version": "0.14.1",
      "binPath": "c:\\Users\\andrisku\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.2.214-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
  "environment": {
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\Users\\andrisku",
      "HOMEDRIVE": "V:",
      "HOMEPATH": "\\",
      "PATH": "C:\\ncs\\toolchains\\cf2149caf2;C:\\ncs\\toolchains\\cf2149caf2\\mingw64\\bin;C:\\ncs\\toolchains\\cf2149caf2\\bin;C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin;C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\cf2149caf2\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;C:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;C:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\riscv64-zephyr-elf\\bin;c:\\Users\\andrisku\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.2.214-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\WINDOWS\\CCM\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\WINDOWS\\system32\\config\\systemprofile\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Adaptiva\\AdaptivaClient\\bin\\x32;C:\\Program Files (x86)\\Adaptiva\\AdaptivaClient\\bin\\x64;C:\\Program Files (x86)\\IDEMIA\\AWP\\Dlls;C:\\Program Files\\IDEMIA\\AWP\\Dlls;C:\\Program Files (x86)\\eParaksts Token Signing\\;C:\\Program Files\\Gemalto\\Classic Client\\BIN;C:\\Program Files (x86)\\Gemalto\\Classic Client\\BIN;C:\\Program Files\\PuTTY\\;C:\\ncs\\v2.5.2\\toolchain\\bin;C:\\Program Files\\SEGGER\\JLink;C:\\Users\\andrisku\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python312\\Scripts;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2021.10\\bin;C:\\Program Files\\Git\\cmd;C:\\Users\\andrisku\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\andrisku\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
      "ZEPHYR_BASE": "c:\\ncs\\v2.6.0\\zephyr",
      "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk",
      "PYTHONPATH": "C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin;C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\Lib;C:\\ncs\\toolchains\\cf2149caf2\\opt\\bin\\Lib\\site-packages"
    "inherited": {
      "HOMEDRIVE": "V:",
      "HOMEPATH": "\\",
      "Path": "C:\\WINDOWS\\CCM\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\WINDOWS\\system32\\config\\systemprofile\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Adaptiva\\AdaptivaClient\\bin\\x32;C:\\Program Files (x86)\\Adaptiva\\AdaptivaClient\\bin\\x64;C:\\Program Files (x86)\\IDEMIA\\AWP\\Dlls;C:\\Program Files\\IDEMIA\\AWP\\Dlls;C:\\Program Files (x86)\\eParaksts Token Signing\\;C:\\Program Files\\Gemalto\\Classic Client\\BIN;C:\\Program Files (x86)\\Gemalto\\Classic Client\\BIN;C:\\Program Files\\PuTTY\\;C:\\ncs\\v2.5.2\\toolchain\\bin;C:\\Program Files\\SEGGER\\JLink;C:\\Users\\andrisku\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python312\\Scripts;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2021.10\\bin;C:\\Program Files\\Git\\cmd;C:\\Users\\andrisku\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\andrisku\\AppData\\Local\\Programs\\Microsoft VS Code\\bin",
      "PATH": "C:\\WINDOWS\\CCM\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\WINDOWS\\system32\\config\\systemprofile\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\Adaptiva\\AdaptivaClient\\bin\\x32;C:\\Program Files (x86)\\Adaptiva\\AdaptivaClient\\bin\\x64;C:\\Program Files (x86)\\IDEMIA\\AWP\\Dlls;C:\\Program Files\\IDEMIA\\AWP\\Dlls;C:\\Program Files (x86)\\eParaksts Token Signing\\;C:\\Program Files\\Gemalto\\Classic Client\\BIN;C:\\Program Files (x86)\\Gemalto\\Classic Client\\BIN;C:\\Program Files\\PuTTY\\;C:\\ncs\\v2.5.2\\toolchain\\bin;C:\\Program Files\\SEGGER\\JLink;C:\\Users\\andrisku\\AppData\\Local\\Packages\\PythonSoftwareFoundation.Python.3.12_qbz5n2kfra8p0\\LocalCache\\local-packages\\Python312\\Scripts;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files (x86)\\GNU Arm Embedded Toolchain\\10 2021.10\\bin;C:\\Program Files\\Git\\cmd;C:\\Users\\andrisku\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\andrisku\\AppData\\Local\\Programs\\Microsoft VS Code\\bin"
    "toolchainPath": "c:\\ncs\\toolchains\\cf2149caf2",
    "toolchainBinPath": "c:\\ncs\\toolchains\\cf2149caf2\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
    "toolchainVersion": "2.6.0"
  "terminal": {
    "defaultProfile": null
  "config": {
      "topdir": "C:\\ncs\\v2.6.0",
      "toolchain": {
        "path": "C:\\ncs\\toolchains"
      "ozonePath": "C:\\Program Files\\SEGGER\\Ozone\\Ozone.exe",
      "applications": [],
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig"
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [
        "C:\\ncs\\v2.6.0\\zephyr\\boards\\arm"
      "taskBindings": {},
      "buildTerminal": {
        "condensedProgress": true
      "debugging": {
        "flash": true,
        "bindings": {},
        "justMyCode": true
      "deviceProvider": "",
      "flash": {
        "softreset": false,
        "erase": true,
        "recover": false
      "enableTelemetry": false,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": ""
      "nrfutil": {
        "home": "C:\\Users\\andrisku\\.nrfutil"
      "defaultOpenAction": "ask"
      "terminalMode": "character"
  "extensions": {
    "internal": {
        "version": "2024.2.214",
        "path": "c:\\Users\\andrisku\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2024.2.214-win32-x64",
        "isActive": true
        "version": "2024.2.78",
        "path": "c:\\Users\\andrisku\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2024.2.78",
        "isActive": true
        "version": "2024.2.418",
        "path": "c:\\Users\\andrisku\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2024.2.418",
        "isActive": true
        "version": "2024.2.71",
        "path": "c:\\Users\\andrisku\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2024.2.71",
        "isActive": true
    "external": {
      "marus25.cortex-debug": null,
      "ms-vscode.cpptools": "1.19.8",
      "ms-vscode.js-debug": "1.87.0",
      "ms-vscode.js-debug-companion": "1.1.2",
      "ms-vscode.vscode-js-profile-table": "1.0.8",
      "ms-vscode.cmake-tools": "1.17.17",
      "twxs.cmake": "0.0.17"
Hope this helps you to solve the issue!
Andris
