MPSL radio notification API has been removed from the nRF Connect SDK v2.6.0.
Is there any alternative way to get radio notifications?
Narendra
Narendra
Hi Vidar,
Thank you. I have looked at the suggested example. This example is about how we can get an event for connection, right?
Would you please help how can we get the event for radio off/inactive?
Narendra
Hi Narendra,
Could you please outline your use case and requirements in a bit more detail so I can check if there may be any alternative solutions? The Event Trigger feature is currently limited to BLE connections, unfortunately.
Hi Vidar,
In our firmware, we are using radio off/inactive events to stop advertisements, switch/change advertisement packets, and measure battery level when the radio is off/inactive.
Narendra
Hi Narendra,
Thanks. Support for triggering on advertisement events has been added as a feature request internally and should be added in a future release. The only workaround I can think of for now is to use PPI+EGU to trigger a SW interrupt on RADIO events, similar to how the PPI trace library does it. This will require some additional application logic to determine when the advertisement event is completed.
Vidar
Hi Vidar,
as I'm also in dire need for triggering an event on each ble package sent (NRF_RADIO_EVENT_PHYEND),
is there already an easy way to set this up on nRF54L15?
I tried the following, but it seems like it does not do the trick...
unsigned int irq = irq_connect_dynamic(DT_IRQN(DT_NODELABEL(radio)), IRQ_PRIO_LOWEST, on_radio_event, NULL, 0);
irq_enable(DT_IRQN(DT_NODELABEL(radio)));
nrf_radio_int_enable(NRF_RADIO, NRF_RADIO_INT_PHYEND_MASK);Hi,
This is different from the request the original poster had. It is not possible to define another ISR for the RADIO IRQ as it is already implemented in the Bluetooth controller. Please create a new ticket and include more details about your setup and what you're trying to achieve.
