MPSL radio notification API has been removed from the nRF Connect SDK v2.6.0.
Is there any alternative way to get radio notifications?
Narendra
Narendra
Hi Vidar,
I'm also looking for an alternative to the MPSL radio notification API in nRF Connect SDK v2.6.0+. More specifically, I'm relying on notifications fired some time before the radio turns on (MPSL_RADIO_NOTIFICATION_DISTANCE_420US). What is the equivalent API in nRF Connect SDK v2.6.0?
Thanks
We currently do not have a direct replacement for this feature, unfortunately. Could you say a bit more about your use case for this signal?
I'm using the signal to prepare and submit real time notification data for transmission. It is a time critical application, so I need to get the notification close to the connection event, but not too close since it takes some time to prepare and submit the outgoing data. This technique is described in this blog post. If there is no direct replacement, I'm interested to know what my options are for implementing this functionality myself.
Thank you for explaining the use case. I believe you can still use the connection event trigger for this. After initiating the connection event trigger, you could start a one-off timer, a delayable work item, or something similar to acquire the data and add it to the notification queue before the next connection event occurs.
If the delay mechanisms you suggest are sufficiently accurate, that sounds like a promising approach, given that the peripheral is aware of the current connection interval. Of course, there will be no notification before the first connection event after a connection has been established, but I can live with that.
