nRF5340 BLE: How to create the rpmsg_nrf53_sram in partitions.yml during porting the sample 'peripheral_uart'
Hi Support Team,
I try to use BLE in 'Split Controller and Host' mode on nRF5340 DK. I ported the sample 'peripheral_uart' for appCore and 'hci_rpmsg' for netCore, and the bidirectional communication between the appCore's terminal and 'nRF Connect for Mobile' APP is successful.
But, strangely, the partitions.yml in my project and the one in the sample are different in the SRAM section.
my partitions.yml:
sram_primary:
  address: 0x20000000
  end_address: 0x20080000
  region: sram_primary
The sample's:
rpmsg_nrf53_sram:
  address: 0x20070000
  placement:
    before:
    - end
  sram_primary:
  address: 0x20000000
  end_address: 0x20070000
My questions:
1. In my understanding, the rpmsg_nrf53_sram is for RPMsg transport and is a must for BLE in 'Split Controller and Host' mode. Why there is no rpmsg_nrf53_sram in my partitions.yml, but the communication is still ok?
2. How can I create the rpmsg_nrf53_sram in my partition and let it be shared by the appCore and the netCore?
Thank you very much.
Yanpeng Wu
  • Hi Vidar,
    Sorry for the mistake. When I did a Pristine Build, the rpmsg_nrf53_sram was created properly in partitions.yml.
    But when I flash the image to DK, still can see 'ble_host: Failed to send data over BLE connection', sending data from appCore terminal failed. (the data flow from mobile app to appCore terminal is ok)
    It failed in bt_gatt_notify_cb():
    in bt_gatt_notify_cb:
    data.err = -ENOTCONN;
    data.type = BT_GATT_CCC_NOTIFY;
    data.nfy_params = params;
    LOG_WRN("[in bt_gatt_notify_cb - 7.1], data.err=%d", data.err); //data.err=-128
    bt_gatt_foreach_attr_type(data.handle, 0xffff, BT_UUID_GATT_CCC, NULL,
    1, notify_cb, &data); //failed in notify_cb when Notify all peers configured
    LOG_WRN("[in bt_gatt_notify_cb - 7.2], data.err=%d", data.err); //data.err=-128
    return data.err;
    Yanpeng Wu
  • Hi Yanpeng,
    No worries. But I'm not seeing any errors when sending data here. Please try the attached hex file I built and see if you get the same result. This is built with the original hci_rpmsg sample.
    3527.merged_domains.hex
    Vidar
  • Hi Vidar,
    Thank you so much for your professional support:). I found the send-data error is caused by the unproper operation sequences.
    1. I flashed the HEX you provided to my DK and tried to send/receive data and connect/disconnect. It can work well except in one situation: when the 'TX Characterristic Descriptors - Notifications and indications disabled' in the mobile APP, the 'ble_host: Failed to send data over BLE connection' will be reported.
    I'm not sure if this is a small bug, if the central(the mobile APP) connected with the peripheral (my nRF5340 DK) but disabled the 'Notifications and indications', that just means the central does not subscribe to the notification, the GAP server should send data as usual and should not report a failure, is it right?
    I also found when disconnect and reconnct from the mobile app, the default state of 'Notifications and indications' is enabled, but it is actually disabled. The send data error will occur in this situation too. That's the reason why sometimes only after disconnect/reconnct the error will appear.
    2. In addition, in my application, I created threads on both appCore and netCore, and the priority=7,
    K_THREAD_DEFINE(thread_check_id, LED_THREAD_STACKSIZE, blink_led, NULL, NULL, NULL,
    K_PRIO_COOP(7), 0, 100);
    and the ble_write_thread' priority also is 7
    K_THREAD_DEFINE(ble_write_thread_id, STACKSIZE, ble_write_thread, NULL, NULL,
    NULL, PRIORITY, 0, 0);
    I'm not sure if it will affect the BLE data sent. I changed my thread's priority to 9 now.
    After that, the BLE data bidirectional data exchange works well now.
    Maybe I can say I get the robust BLE connection now:). Next I will construct my BLE services and Characteristics for my application data. Could you help suggest a sample for this? In the sample 'peripheral_uart', I had not found the code for defining the Services and Characteristics. Thank you very much.
    Yanpeng Wu
  • Hi Yanpeng,
    Glad to hear that you were able to make it work. The client must be subscibed to the characteristic in order for the server to be able to send notifications, and this subscription is not retained across connections unless your devices are bonded.
    Is this with the nRF Connect app on Android or iOS?
    You can use the NUS implementation as a reference for creating your own custom service: https://github.com/nrfconnect/sdk-nrf/blob/main/subsys/bluetooth/services/nus.c
    Vidar
  • Hi Vidar,
    I used the nRF Connect app on Android.
    Thank you for the suggestion and I will take the NUS as a reference for my custom service.
    Thank you again for the long and professional guidance and support. I close this ticket.
    Yanpeng Wu
