Problem receiving many data from two different characteristics
We have a home made BLE device based on nrfR1822. This one has two embedded sensors sampling data at a frequency of 25Hz.
In regular mode, the device sends every second or so some markers extracted from 25Hz raw data (local embedded data processing) through 2 characteristic notifications.
In debug mode, the device sends the whole signals (at 25Hz, so one frame per 40ms) through 2 different characteristic notifications.
When I connect the device from and Android phone, I can receive the 25Hz signals in parallel (and even more).
When I connect the device from PC using a s130 dongle, only one characteristic data can be received:
  • If I toggle CCCD On for characteristic #1, I receive data for #1 at a 25Hz frequency
  • If I toggle CCCD On for characteristic #2, I don't receive any data for #2 (still receiving data for #1)
  • If I toggle CCCD Off for characteristic #1, I then receive data at a 25Hz frequency for #2
  • If I toggle CCCD On for characteristic #1, I don't receive any data for #1 (still receiving data for #2)
Looks like s130 dongle is unable to receive a huge amount from two different characteristics.
Note that, in the mean time, CCCD is On for battery level characteristic and I receive this one correctly in any configuration (a battery level is sent every few seconds, so frequency is very low).
Is this a bug? A known issue? A bad configuration I'm using (as it works on Android, I know the problem does not come from my BLE device)...
  • I'm guessing that one of your sd_ble_gatts_hvx() calls returns BLE_ERROR_NO_TX_PACKETS. To solve this you can either call sd_ble_gatts_hvx() in a loop until you get NRF_SUCCESS, or the better way, you can wait for the BLE_EVT_TX_COMPLETE event and then call sd_ble_gatts_hvx().
    Not calling sd_ble_gatts_hvx() for both characteristics in the same connection interval should also work, but I would still recommend handling returned errors.
    The latest release of the S130 SoftDevice, 2.0.0-7.alpha can receive 3 packets per connection interval as a central. It will be 6 packets in the S130 v2 production release. SoftDevice S130 2.0.0-7.alpha is supported in SDK 11.0.0-2.alpha.
