NRF52840 UART Rx received data incorrectly when use HFINT internal oscillator as clock source
Hello, I am currently working on nrf52840 using nrf-sdk v2.2. to build a Matter firmware. I encountered an issue that a small number of chips UART received data incorrectly. I obtained the data waveform using an oscilloscope and did not find any abnormalities.
I use ’mpsl_clock_hfclk_is_running' interface to check if HFXO is enabled, the result is no. Then I try to enable HFXO as clock source and this issue never occurred again.
Given that this issue only occurs in a small number of chips, I believe it is a hardware issue caused by individual differences in the internal oscillators of different chips.
Is my inference reasonable?  Will individual differences in the internal oscillator of nrf52849 lead to unstable serial port timing?
Here are some supplementary information:
Due to the low power consumption requirements of the product. UART enters "sleep" when it is not in use, the RX turns to GPIO mode. When data comming, RX generates a falling edge (UART start bit), triggering a GPIO falling edge interrupt. In interrupt processing, UART will be enabled again. This process is called "wakeup". This issue occurs during the initial wake-up period of UART, and then returns to normal until UART goes back to sleep.
