WARNING: Using a bootloader without pm_static.yml on ncs v2.5.2
Procedures to reproduce this issue are as follows.
1. Unzipping caf_flash.zip to C:\ncs\v2.5.2\nrf\samples folder.
2. cd C:\ncs\v2.5.2\nrf\samples\caf_flash
3. west build -b nrf5340dk_nrf5340_cpuapp
The following are log messages of west build.
C:\ncs\v2.5.2\nrf\samples\caf_flash>west build -b nrf5340dk_nrf5340_cpuapp
-- Application: C:/ncs/v2.5.2/nrf/samples/caf_flash
-- CMake version: 3.20.5
-- Using NCS Toolchain 2.5.20231017.848171396279 for building. (C:/ncs/toolchains/c57af46cb7/cmake)
CMake Warning at C:/ncs/v2.5.2/nrf/cmake/partition_manager.cmake:79 (message):
          --- WARNING: Using a bootloader without pm_static.yml.            ---
          --- There are cases where a deployed product can consist of       ---
          --- multiple images, and only a subset of these images can be     ---
          --- upgraded through a firmware update mechanism. In such cases,  ---
          --- the upgradable images must have partitions that are static    ---
          --- and are matching the partition map used by the bootloader     ---
          --- programmed onto the device.                                   ---
  • If you just create a file named pm_static.yml in your project folder, the build system will find this automatically
  • Thanks for your reply! I copied pm_static.yml file from C:\ncs\v2.5.2\nrf\applications\nrf_desktop\configuration\nrf5340dk_nrf5340_cpuapp. But why west build still have the following warning messages.
  • Does it work if you put it inside the nrf_desktop folder instead?
  • Thanks for your reply! Running west build command under nrf_desktop folder doesn't have this issue.
    -- Found partition manager static configuration: C:/ncs/v2.5.2/nrf/applications/nrf_desktop/configuration/nrf5340dk_nrf5340_cpuapp/pm_static.yml
    Partition 'b0_container' is not included in the dynamic resolving since it is statically defined.
    Partition 'b0' is not included in the dynamic resolving since it is statically defined.
    Partition 'provision' is not included in the dynamic resolving since it is statically defined.
    Partition 's0' is not included in the dynamic resolving since it is statically defined.
    Partition 's0_image' is not included in the dynamic resolving since it is statically defined.
    Partition 's1' is not included in the dynamic resolving since it is statically defined.
    Partition 's1_image' is not included in the dynamic resolving since it is statically defined.
    Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
    Dropping partition 's0_pad' since its size is 0.
    Dropping partition 's1_pad' since its size is 0.
  • I have fixed this issue by changing CMakeLists.txt as follows.
    cmake_minimum_required(VERSION 3.20.0)
    set(PM_STATIC_YML_FILE ${CMAKE_CURRENT_SOURCE_DIR}/configuration/${BOARD}/pm_static.yml)
    message(STATUS "PM_STATIC_YML_FILE: ${PM_STATIC_YML_FILE}")
    find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
    project(NONE)
    # NORDIC SDK APP START
    target_sources(app PRIVATE
      src/main.c
    # NORDIC SDK APP END
    # Add include directory for board specific CAF def files
    zephyr_include_directories(
    target_sources_ifdef(CONFIG_CAF_SAMPLE_LED_STATE
      app PRIVATE src/modules/led_state.c)
