I have a few questions (using nRF51 DK and/or external nRF51822)
I use an analog pin to measure the voltage of a capacitor of an analog circuit. From time to time, I would like to discharge the capacitor by setting the analog pin to the ground programmatically. Is this possible?
What is the input impedance of an analog pin when using ADC?
I want to use a GPIO pin to control the input voltage of an analog circuit to high or low level. With a voltmeter (on the pin 0.22, also connected to LED2), I get 2.9V and 0.21V readings when I toggle LED2. I need the low level to be exactly 0V (ground)? Is it possible?
Whether set to high or low, what are the output impedance of a non-analog pin used as output?
Can an analog pin be used as an analog output (I guess not but I would like to confirm)?
Regards
